Hubble Lithium Battery AM-2 5.5kWh
4 hours ago, shovelhead said:
Thanks @system32 - I also see that you had to discharge to 20% and back to 100%.
Do I need to make each battery in turn the "master", run it down individually, then back to 100%? Or can I run all of them collectively down to 20% and then, collectively back to 100%?
When you speak about 20% and 100%, do you allow the (Sunsynk) inverter to do this, or do you need to use AGM settings?
I haven't had any issues with my SOC on my first 2 Hubbles, so wondering if I just need to do this on the new one, and perhaps wasting my time with the older two which are currently in service...🤔
Run the new one up to 100% and keep it there for a few days to balance the cells.
Then when at 100% disconnect and get the older 2 to 100% and then connect all 3.
Ideal time this long weekend with no LS planned up to Sunday.
This is what I will do 🤔
  • Replies 509
  • Views 134.1k
  • Powerforum Store
    Powerforum Store
    I am noticing a trend here on the posts and I find it concerning borders on Product bashing.  It maybe due to lack of Knowledge or lack of understanding how lithium batteries work. The reaso
  • Powerforum Store
    Powerforum Store
    Hi all .Just an update on the Hubble issues you have been experiencing I have been in talks with Hubble Senior Engineer and these are some Highlights of our discussion. 1. All firmware updates an
  • Update time.  Over the past week I've done a lot of monitoring and calculations to determine my capacity and to track down where the problem lies with my pack. The original problem I experienced
This was a repeat of my instructions from Hubble:
"suggested that you discharge the batteries individually to 20% and once both batteries are on 20%, you may link them back up in parallel and let them charge together. This will ensure that both batteries balance from 20% to 100%. "
I just did the bank of 4 in one go.
If power off/reboot an AM-2, it seems to forget the SoC and needs a recharge cycle to recalibrate.
Edited by system32
  • 1 year later...
On 2024/01/11 at 9:51 PM, luwii said:
Thanks, this makes sense to me! Only thing I'm not sure about is what is the voltage level at the serial side. The adapters come in 3.3V or 5V.  Does anybody know what the Hubble AM5 (Pace BMS) expects?
Only 1.5 years later, but I was also looking for a cheaper cable solution to connect my Hubble AM2 to my PC, and was unable to find proper instructions to construct my own cable, so I did some research and decided to publish a working solution here.
You basically need any type of USB to TTL (serial) converter using the FTDI FT232R chip. There are many options available locally, but the most popular options are the cable version, where the chip is inside the USB connector, and the module with an on-board USB mini or type-C connector. The modules cost around R40 at the time of writing (https://make.net.za/product/4me3303/) or (https://www.communica.co.za/products/hkd-ft232rl-usb-to-serial-board?variant=50139935736108). Just make sure you get one with an original FTDI chip, because there is some issue between the cloned chip and the drivers. You can download the driver from https://ftdichip.com/drivers/
The Hubble has a standard RS232 port (-15v/+15V) and the USB to TTL converter or cable provides TTL levels (0V/5V), so you need a level shifter in-between. Fortunately that is also readily available locally at around R12 at the time of writing. (https://www.robotics.org.za/MX3232-MOD) or (https://www.diyelectronics.co.za/store/serial/638-max3232-rs-232-ttl-uart-serial-module-level-shifter.html)
Now you just have to check the pinouts on your USB to TTL converter cable or module and verify the orientation of the level converter module (marked with RS232 <-> TTL on the one side of the board) to ensure that you are connecting the 5V, GND, RX and TX pins to the correct end of the level shifter board. Then connect the GND, <- (IN) and -> (OUT) pins on the opposite end of the level shifter board to PINS 2, 3 and 4 of the RJ12 connecter and you're done. Refer to the attached images which clearly shows all the connections.
@superdiy This should actually work for any battery with a Pace BMS, or not?
Edited by zsde
@superdiy Is it not possible to just use a USB to RS232 directly?
On 2025/06/19 at 3:53 PM, superdiy said:
Cannot say for sure. Just noticed that one reviewer on that product page mentioned that the cable does not work on Windows 11...
Only saw this reply now
It's entirely probable that it's a "pirate" cable with a blocked driver
