Jump to content
Sunsynk connection to home assistant
MV SOLAR
I have installed the software according to the link from kellerza
https://github.com/kellerza/sunsynk
But i get no communication to home assistant via the rs485-usb converter.
I have installed Modbus TCP to Modbus RTU Gateway Add-on but get the following message:
15:48:14] INFO: Starting mbusd -d -L - -v 2 -p /dev/ttyS0 -s 9600 -m 8N1 -P 502
13 Mar 2022 15:48:14 mbusd-0.5.1 started...
13 Mar 2022 15:48:14 tty: trying to open /dev/ttyS0 (speed 9600 mode 8N1)
13 Mar 2022 15:48:14 conn_init(): can't open tty device /dev/ttyS0 (I/O error)
13 Mar 2022 15:48:14 conn_init() failed, exiting...
have configured  /dev/ttyS0 to be the device have tried all of them but still no connection:- please if anybody can help me
Link to comment
Share on other sites
Your usb converter is almost certainly not mounted at /dev/ttyS0; it should be /dev/ttyUSB0 (or more).
It might be that the usb converter is not picked up, or the config is incorrect. If you look at:
https://github.com/kellerza/sunsynk/blob/main/hass-addon-mbusd/config.yaml
You will see it pointing to /dev/ttyUSB0.
If you don't have /dev/ttyUSB0 then your USB converter is not being picked up correctly.
Edited by P1000
Link to comment
I get the following when trying to connect:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-03-13 18:19:56,507 INFO    Loading HASS OS configuration
2022-03-13 18:19:56,514 DEBUG   could not patch umodbus: numpy not found
2022-03-13 18:19:56,517 INFO    Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power
2022-03-13 18:19:56,518 INFO    Connecting to serial:///dev/ttyUSB0
2022-03-13 18:19:56,525 ERROR   Read Error: (1,3,5) [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
2022-03-13 18:19:56,526 INFO    ############################################################
2022-03-13 18:19:56,526 INFO    No response on the Modbus interface, try checking the wiring to the Inverter, the USB-to-RS485 converter, etc
2022-03-13 18:19:56,527 INFO    ############################################################
2022-03-13 18:19:56,528 CRITICAL This Add-On will terminate in 30 seconds, use the Supervisor Watchdog to restart
if i do ls -l /dev/ttyUSB* ubuntu does display ttyUSB0
Sunsynk Inverter Add-on Current version: 2022.03.04-0.1.4
Link to comment
[cont-init.d] done.
[services.d] done.
How are you running Home Assistant?
If you're running it in a container (i.e. docker). if so, you'll need to map /dev/ttyUSB0 -> the container, or be running in privileged mode.
I think the default install will map devices, but I need to check.
Home Assistant also likes devices to be plugged in after its running.  So boot up first make sure HA is running, *then* plugin the USB ,and see if it can see ttyUSB0 inside the container.
If still no luck, then manually check inside the container to see if its seeing the device.
I'd also check outside to see if it see's it.
eg - inside the os
dmesg  grep usb
ls /dev/ttyUSB*
within the container that runs HA -
dmesg  grep usb
ls /dev/ttyUSB*
You'll need some cli experience - i.e. with ssh and docker. you'll need to check that the OS see's the device.
Worst case can assist further
Edited by shanghailoz
Link to comment
Home Assistant is running in a Virtual Box on Linux Ubuntu
I get the following messages in home assistant terminal:
and on the log file i get
2022-04-09 10:40:03,525 INFO    Loading HASS OS configuration
2022-04-09 10:40:03,532 DEBUG   could not patch umodbus: numpy not found
2022-04-09 10:40:03,535 INFO    Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power
2022-04-09 10:40:03,536 INFO    Connecting to serial:///dev/ttyUSB2
2022-04-09 10:40:03,543 ERROR   Read Error: (1,3,5) [Errno 2] could not open port /dev/ttyUSB2: [Errno 2] No such file or directory: '/dev/ttyUSB2'
2022-04-09 10:40:03,544 INFO    ############################################################
2022-04-09 10:40:03,544 INFO    No response on the Modbus interface, try checking the wiring to the Inverter, the USB-to-RS485 converter, etc
2022-04-09 10:40:03,545 INFO    ############################################################
2022-04-09 10:40:03,545 CRITICAL This Add-On will terminate in 30 seconds, use the Supervisor Watchdog to restart automatically.
have also tried USB0 and USB1
The config file is as follows
PORT: serial:///dev/ttyUSB0
DRIVER: umodbus
SUNSYNK_ID: '2***********'
SENSOR_PREFIX: ''
SENSORS:
  - total_pv_power
  - total_battery_charge
  - total_battery_discharge
  - total_grid_export
  - total_grid_import
  - battery_soc
PROFILES: []
MODBUS_SERVER_ID: 1
MQTT_HOST: core-mosquitto
MQTT_PORT: 1883
MQTT_USERNAME: hass
MQTT_PASSWORD: ''
DEBUG: 0
On Ubuntu terminal I do get /dev/ttyUSB0
Link to comment
Found the problem - I am running home assistant on an ubuntu server under virtualbox.
You need to enable usb under virtualbox otherwise no usb device will be seen in Home Assistant
Edited by MV SOLAR
Link to comment
But still not reading the data get the following logging data:
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2022-04-10 11:06:33,585 INFO    Loading HASS OS configuration
2022-04-10 11:06:33,614 INFO    Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power
2022-04-10 11:06:33,624 INFO    Protocol made connection.
2022-04-10 11:06:33,625 INFO    Connected to /dev/ttyUSB0
2022-04-10 11:06:43,631 ERROR   Timeout reading:
2022-04-10 11:06:43,632 INFO    ############################################################
2022-04-10 11:06:43,633 INFO    No response on the Modbus interface, try checking the wiring to the Inverter, the USB-to-RS485 converter, etc
2022-04-10 11:06:43,634 INFO    ############################################################
2022-04-10 11:06:43,634 CRITICAL This Add-On will terminate in 30 seconds, use the Supervisor Watchdog to restart automatically.
[cmd] ./run.py exited 0
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
2022-04-10 11:07:40,854 INFO    Protocol made connection.
2022-04-10 11:07:40,856 INFO    Connected to /dev/ttyUSB0
2022-04-10 11:07:40,917 INFO    ############################################################
2022-04-10 11:07:40,918 INFO                Inverter serial number '2111255555'
2022-04-10 11:07:40,918 INFO    ############################################################
2022-04-10 11:07:40,918 INFO    MQTT: Connecting to mqtt_user@core-mosquitto:1883
2022-04-10 11:07:40,954 INFO    MQTT: Connection successful
2022-04-10 11:07:51,980 ERROR   Timeout reading:
2022-04-10 11:07:51,982 INFO    Retrying individual sensors: ['Total PV Power:last', 'Total Battery Charge:last', 'Total Battery Discharge:last', 'Total Grid Export:last', 'Total Grid Import:last', 'Battery SOC:last']
2022-04-10 11:08:02,017 ERROR   Timeout reading: Total PV Power
2022-04-10 11:08:12,055 ERROR   Timeout reading: Total Battery Charge
2022-04-10 11:08:22,090 ERROR   Timeout reading: Total Battery Discharge
2022-04-10 11:08:32,125 ERROR   Timeout reading: Total Grid Export
2022-04-10 11:08:42,159 ERROR   Timeout reading: Total Grid Import
2022-04-10 11:08:52,195 ERROR   Timeout reading: Battery SOC
2022-04-10 11:09:02,220 ERROR   Timeout reading:
Link to comment
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
I'm having the same issues with my DEYE 8kw inverter. I eventually just gave up. Pretty much getting the same as what you are getting above.
I get this 1st as per below.
"No response on the Modbus interface, try checking the wiring to the Inverter, the USB-to-RS485 converter, etc"
and then i sometimes get the below with my inverter serial number
Inverter serial number '2315xxxxxx'
I wonder if this info below would make any difference? I don't know anything about the coding or if it is even relevant to the code, but they are saying there are differences between the 5KW and the 8KW. maybe the code has to read each one differently????? Who knows. I have an 8KW inverter.
"Another confusion is that the 5.5kw and the 8.8kw does not use the same markings for connecting up the GEN/GRID/LOAD."
8.8kw is GRID/GEN/LOAD
5.5kw is GEN/LOAD/GRID
8.8kw is X/N/L
5.5kw is L/N/E
Link to comment
Same issue here. Been bashing my head against it for 3 days and not getting anywhere!
2 x 8KW Inverters in parallel, a PI3 and this RS485 converter: https://www.robotics.org.za/RS485-3P
Managed to get a serial number out of the inverter but nothing else - just timeouts. Chopped the RS and USB cable to 30cm just in case - still no joy.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2022-06-10 18:28:10,130 INFO    Loading HASS OS configuration
2022-06-10 18:28:10,164 DEBUG   could not patch umodbus: numpy not found
2022-06-10 18:28:10,174 INFO    Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power
2022-06-10 18:28:10,177 INFO    Connecting to serial:///dev/ttyUSB0
2022-06-10 18:28:10,301 INFO    ############################################################
2022-06-10 18:28:10,302 INFO                Inverter serial number 'XXXXXXXXXX'
2022-06-10 18:28:10,302 INFO    ############################################################
2022-06-10 18:28:10,304 INFO    MQTT: Connecting to user@core-mosquitto:1883
2022-06-10 18:28:14,910 INFO    MQTT: Connection successful
2022-06-10 18:28:25,906 ERROR   Timeout reading:
2022-06-10 18:28:25,908 INFO    Retrying individual sensors: ['Total PV Power:last', 'Total Battery Charge:last', 'Total Battery Discharge:last', 'Total Grid Export:last', 'Total Grid Import:last', 'Battery SOC:last']
2022-06-10 18:28:35,957 ERROR   Timeout reading: Total PV Power
2022-06-10 18:28:46,001 ERROR   Timeout reading: Total Battery Charge
Anyone have any ideas? I'm out!
Link to comment
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Did you manage to get this resolved?
Link to comment
From studying the implementation a bit, RS485 cannot really have multiple masters... well not unless there is some form of collision detection like Modbus tcp.
I would assume that the master inverter (in parallel configuration) drives the bus (the modbus not a putco one). So I am not sure you will be able to connect and talk to the inverters over modbus (RS485) when there is already a master.
A workaround might be to implementing the comms on a CAN-bus. Since it allows multiple masters. In theory you should be able to daisy chain all the devides together eg. BMS, Inverter, smart shunt etc and be able to talk to all of them from the Pi or Esp
Link to comment
I have also bumped my head for 2 days now. This is my Log: Any help would be greatly appreciated. Thank you.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2022-09-14 18:22:18,054 INFO    Loading HASS OS configuration
2022-09-14 18:22:18,207 DEBUG   could not patch umodbus: numpy not found
2022-09-14 18:22:18,213 DEBUG   last unit:kWh, id:total_pv_power
2022-09-14 18:22:18,214 DEBUG   last unit:kWh, id:total_battery_charge
2022-09-14 18:22:18,215 DEBUG   last unit:kWh, id:total_battery_discharge
2022-09-14 18:22:18,215 DEBUG   last unit:kWh, id:total_grid_export
2022-09-14 18:22:18,216 DEBUG   last unit:kWh, id:total_grid_import
2022-09-14 18:22:18,217 DEBUG   last unit:%, id:battery_soc
2022-09-14 18:22:18,217 INFO    Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power
2022-09-14 18:22:18,218 DEBUG   Using selector: EpollSelector
2022-09-14 18:22:18,220 INFO    Connecting to serial:///dev/ttyUSB0
2022-09-14 18:22:18,779 WARNING Executing <Task pending name='Task-2' coro=<Sunsynk.read_sensors() running at /usr/local/lib/python3.9/site-packages/sunsynk/sunsynk.py:52> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x7fb08debe0>()] created at /usr/local/lib/python3.9/asyncio/base_events.py:424> cb=[_release_waiter(<Future pendi...events.py:424>)() at /usr/local/lib/python3.9/asyncio/tasks.py:416] created at /usr/local/lib/python3.9/asyncio/tasks.py:462> took 0.234 seconds
2022-09-14 18:22:28,554 ERROR   Timeout reading:
2022-09-14 18:22:28,555 INFO    ############################################################
2022-09-14 18:22:28,555 INFO    No response on the Modbus interface, try checking the wiring to the Inverter, the USB-to-RS485 converter, etc
2022-09-14 18:22:28,556 INFO    ############################################################
2022-09-14 18:22:28,556 CRITICAL This Add-On will terminate in 30 seconds, use the Supervisor Watchdog to restart automatically.
2022-09-14 18:22:58,590 DEBUG   Close <_UnixSelectorEventLoop running=False closed=False debug=True>
Dongle that I use: https://www.robotics.org.za/W17286
Modbus Log when rs485 dongle is removed from RPi4 USB:
15 Sep 2022 09:34:46 tty: trying to open /dev/ttyUSB0 (speed 9600 mode 8N1)
15 Sep 2022 09:34:46 tty_reopen(): can't open tty device /dev/ttyUSB0 (No such file or directory)
Modbus Log when rs485 dongle is present  in the RPi4 USB:
09:42:48] INFO: Starting mbusd -d -L - -v 2 -p /dev/ttyUSB0 -s 9600 -m 8N1 -P 502
15 Sep 2022 09:42:49 mbusd-0.5.1 started...
15 Sep 2022 09:42:49 tty: trying to open /dev/ttyUSB0 (speed 9600 mode 8N1)
So it looks like the USB is "seen" by the RPi4 HA (running in a docker) ?
Link to comment
Thank you P1000
I now sit with another problem... When I go into Terminal (HA) and type login, it prompts me for a login and password!!! I have not seen this before. What do I do now? Any idea?
Not to worry.... I came right. It's working now, but get lots of timeouts?
2022-09-15 16:33:49,179 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:33:59,126 ERROR   Timeout reading:
2022-09-15 16:35:08,394 ERROR   Timeout reading:
2022-09-15 16:36:17,676 ERROR   Timeout reading:
2022-09-15 16:37:17,007 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:37:17,058 DEBUG   Request registers: [78] glen=1. Response [469] len=1. regs={78: 469}
2022-09-15 16:37:17,118 DEBUG   Request registers: [80, 81, 82] glen=3. Response [0, 0, 0] len=3. regs={80: 0, 81: 0, 82: 0}
2022-09-15 16:37:17,170 DEBUG   Request registers: [96, 97] glen=2. Response [1197, 0] len=2. regs={96: 1197, 97: 0}
2022-09-15 16:37:26,948 ERROR   Timeout reading:
2022-09-15 16:38:26,282 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:38:36,231 ERROR   Timeout reading:
2022-09-15 16:39:35,570 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:39:35,622 DEBUG   Request registers: [78] glen=1. Response [469] len=1. regs={78: 469}
2022-09-15 16:39:35,682 DEBUG   Request registers: [80, 81, 82] glen=3. Response [0, 0, 0] len=3. regs={80: 0, 81: 0, 82: 0}
2022-09-15 16:39:35,733 DEBUG   Request registers: [96, 97] glen=2. Response [1197, 0] len=2. regs={96: 1197, 97: 0}
2022-09-15 16:39:45,515 ERROR   Timeout reading:
2022-09-15 16:40:44,845 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:40:44,895 DEBUG   Request registers: [78] glen=1. Response [469] len=1. regs={78: 469}
2022-09-15 16:40:44,956 DEBUG   Request registers: [80, 81, 82] glen=3. Response [0, 0, 0] len=3. regs={80: 0, 81: 0, 82: 0}
2022-09-15 16:40:45,008 DEBUG   Request registers: [96, 97] glen=2. Response [1197, 0] len=2. regs={96: 1197, 97: 0}
2022-09-15 16:40:54,793 ERROR   Timeout reading:
2022-09-15 16:41:54,133 DEBUG   Request registers: [72, 73, 74, 75] glen=4. Response [480, 0, 408, 0] len=4. regs={72: 480, 73: 0, 74: 408, 75: 0}
2022-09-15 16:41:54,185 DEBUG   Request registers: [78] glen=1. Response [469] len=1. regs={78: 469}
2022-09-15 16:41:54,246 DEBUG   Request registers: [80, 81, 82] glen=3. Response [0, 0, 0] len=3. regs={80: 0, 81: 0, 82: 0}
2022-09-15 16:42:04,077 ERROR   Timeout reading:
Edited by BigFan
Link to comment
  • 3 months later...
I had the same issue and the issue still exist.
As a work around, I installed "Modbus TCP to Modbus RTU Gateway Add-on" and used the pymobus serial connection
DEVICE: /dev/ttyUSB0
BAUDRATE: 9600
MODE: 8N1
TIMEOUT: 5
LOGLEVEL: 2
PORT: xx.xxx.xxx.xxx:502
DEVICE: /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
DRIVER: pymodbus
Link to comment
BAUDRATE: 9600
MODE: 8N1
TIMEOUT: 5
LOGLEVEL: 2
DRIVER: pymodbus
Tried this route thanks. Both ways work for me but i get initial Data to mqtt and then just no new data. Almost stale.
@kellerza Not sure if there is an issue.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
