Collection of DSP Axpert Firmware for VM III TWIN and VM IV TWIN
Don't worry man, you're good!
You can't really return to the exact stock firmware that came with the device, as it is (not possible) to extract it or make a backup of it. However, you can reflash the very same firmware version and it should be all good and no differences.
As a general rule, you can always reflash whatever firmware version you like, as long as it is exactly for your device's model. There are no version restrictions when it comes to reflashing a firmware.
You can use the search feature in this forum to find other MCU firmware versions. There are a lot of options if anything would go wrong for you, and I guess you'll find the exact version or a very close one at least. Just always make sure you know what you're searching for!
  • Replies 522
  • Views 90.7k
  • Mohammad Jawish
    Mohammad Jawish
    Thanks for your reply    I upgrade my inverter to the mentioned version  The twin problem not solved  I faced other problem after the update  Max charging current reduced to 1
  • esmail-kassir
    esmail-kassir
    @Coulomb as I can see they shared FTP link so you can explore other folders , and I found many interesting things such as a firmware with 60.10 dated june-2024 (in the file meta data ) , accordin
  • [ Edit: There is a problem with this patched firmware; DO NOT USE! See here for the corrected version, now called x60.96, but still based on factory firmware version 60.95. It may be that unpat
Thank you brother
Attach an image to a file 25.12
But there are two buttons to scroll which one to press
update mcu
or
update dsp
On 2024/06/27 at 10:55 AM, mohamed.kh said:
Finally, can I get a file?25.08
Yes, this post:
Or when we upgrade we cannot go back to a previous version?
You can "go backwards" in firmware revision, as long as the inverter isn't "bricked". Even if it appears to be bricked (unresponsive), it's usually possible to recover.
I don't believe that you will have want or need to go back to 25.08, but at least it's a known quantity that you can go back to if needed.
sorry for the many questions.
Don't be; it's all very confusing until you get used to it.
Added missing link to 25.08display firmware.
49 minutes ago, Coulomb said:
Yes, this post:
Thank you very much. I am pleased that you are interested in my questions
4 hours ago, mohamed.kh said:
Thank you brother
update mcu
or
update dsp
I'm hoping to get some help here on what I need to do to pass the file25.12
update mcu
or
update dsp
25.12 is a display / mcu / secondary firmware, so you click on "update MCU".
As far as I know, you should never press the bottom button. It looks like they wanted to merge the DSP and MCU reflash tools into one, but they never finished it.
8 hours ago, Coulomb said:
Yes, this post:
Sorry, but you totally forgot to include the link
Exactly! Totally on point, I was going to tell him the same thing, but you were quicker than me.
Sorry for the confusion, I should have included the link for DSP and MCU reflash instructions posted by Coulomb since the beginning, to provide you with all the details you needed so you didn't need to ask for more details each time. It just came to my attention that I didn't include the link in the first post of this thread too, so I just included it now.
Here's the link for your convenience:
https://forums.aeva.asn.au/viewtopic.php?p=87767#p87767
Thank you very much for this review
But I'm still confused. I'll quote from the two pictures I have so I don't make a mistake
So I will attach a picture to clarify the matter
I want to upgrade the version shown with the red arrow ..I have to click where the green arrow is
Am I right or wrong?
44 minutes ago, Tarek Yag said:
بالضبط، أنت على الطريق الصحيح! أتمنى لك حظا سعيدا مع هذا. أتفهم أن الأمر مربك جدًا في البداية، ولكن بمجرد القيام بذلك في المرة الأولى تصبح مهمة سهلة.
I very much appreciate your understanding. I wish you a happy day.
Hi all,
I talked to @mhd_murad and he had a problem with MCU firmware 25.12 in saving settings. He can change and save the settings by only using WatchPower, but directly from the display it won't save the changes, so he rolled back to 25.08
Edited by AMalakani
4 hours ago, AMalakani said:
Hi all,
Oh, this is not good news Because sometimes we have to change the settings of WashPower for ease of use Especially factory reset Not available on this model And also when entering the public network I adjust the battery charge value to operate AC2 without waiting for the battery voltage to rise, and it is faster through the application than entering the settings from the device To note, I encounter this problem sometimes in version 25.08 and I have to do a factory reset and redefine the Wi-Fi . Has he tried it?
Oh, sorry to hear this! I'm afraid it has become some sort of incompatibility between MCU and DSP firmware, although I think no one can confirm it. Would he like to try and reflash his DSP firmware too? So he reflashes both DSP and MCU to their latest versions.
@Coulomb any thoughts?
12 hours ago, AMalakani said:
Hi all,
I'm not sure about this bug
now i have version 60.89 and 25.12 for display and all is fine
i think the problem from DSP firmware
i will test it again after some days
On 2024/06/26 at 5:24 AM, Coulomb said:
Just that operating at higher temperatures will cause some components like electrolytic capacitors to age faster. Out of the factory, they aren't particularly long life to start with. But if you have to operate it in a living area, then the quietness is important.
this is voltronic support reply for temperature
@Tarek Yag @Coulomb @AMalakani
Dear Mohamad
We changed the firmware to reduce the fan speed but internal ventilation and hardware don’t do any change,
For surely,the temperature will be higher than before.
We had tested it even we reduce the fan speed,the internal components can afford the higher temperature
Dear Mohamad
Thanks Mohammad.
I think they didn't test it in a 45oC climate 😅.
I'll stick to the 60.89 and I'm going to update the MCU at evening to 25.12
I did a comparison between 25.08 and 25.12, and didn't find anything conclusive so far. It will take some work.
Edit: So the incompatibility seems to be between 60.95 (with the quieter fans) and 25.12, but not 25.08?
Maybe reflashing to 25.08 didn't fix the problem anyway, as it was in 60.95?
No one explicitly said that they tried 60.95 in this thread neither mhd_murad. Quieter fans are introduced in several recent VM III firmware versions as testers mentioned in this thread. @mhd_murad would you please confirm which DSP firmware you had the incompatibility with?
I also tested this version (60.95) and it runs nearly perfectly. My  DisplayFW is : 25.05
Much quieter fans at low loads and the heatsink temperature has never been above 45°C.
At higher loads (>1500W) the temperature drops again because the fan(s) then run faster.
The inverter hangs in my basement at around 19°C.
Another positive thing about the software version is the fact that the MPP-Tracker no longer gets stuck at low voltage. So far I've had to use a version modified by @Coulomb so that the voltage doesn't get stuck below 100V.
 Thank you for this Software-Version.
Edit:typo
Edited by pintopf
Is there a change log for the firmware versions? Are there Improvements?
I control my inverter with an ESP32, which get the data from the VMIII over serial connection  and build up a communication via WiFi (MQTT-Protocol) to my home-automatisation with NodeRed.
Since I don't miss any functions, I conquered my curiosity and didn't install any new firmware yet.  😉
I've never heard of a firmware change log for Voltronic inverters, though Coulomb is always interested in making version comparisons when needed. Since there are no change logs, improvements are not documented, hence not guaranteed!
I salute you for conquering your curiosity! 😂
Great to know that, thanks. It has changed my mind about where the MPPT bug really is. More research required.
