May 16, 20206 yr Thinking of installing them for a geyser and pool pump, except for the Majortech having more settings, is one better than the other one Tariq
May 16, 20206 yr I used to have a Majortech switching my 3kW geyser element twice a day, and it packed up after a year. Contacts burned out. Not saying your experience will be better or worse, but it is what it is. I now own a CBI for about a year, so far with no catastrophic malfunction, but the battery backup life on it is unsatisfactory during load-shedding. Constantly throws my time settings out. I also do miss the greater variety of settings on the Majortech, because my daily bathroom routine can differ during the week, especially weekends, which this simple timer doesn't cater for. For a pool pump I'd say the CBI's limited daily settings are perfectly okay. Except if you want to time anything more precisely, because the smallest time increment is rather large. I forget offhand if it was to the nearest 15 minutes of nearest half-hour or whatever. For energy-saving or for limiting peak inrush demands on your power network, it could be more useful to get a timer that you can set more accurately to the minute.
May 16, 20206 yr Author I saw a video on YouTube where the guy mentions that the Cbi has a super capacitor. The smallest increment is 15 minutes
May 16, 20206 yr 5 hours ago, GreenFields said: the battery backup life on it is unsatisfactory during load-shedding. I agree battery backup in these timers are very unreliable, I don’t know the major tech timer but the CBI timer should not be left unsupervised when there was load shedding as it will loose it’s time. Unfortunately the internal battery's go flat after about a year and it cannot be replaced you have to buy a new timer.
May 17, 20206 yr On 2020/05/16 at 5:37 PM, GreenFields said: own a CBI for about a year, so far with no catastrophic malfunction I had a CBI for a geyser timer. After about two years it started making a ticking sound (about once a second) and not long after that it stopped working. The display still worked but it no longer pulled in the relay properly. Probably cooked a capacitor or something. 13 hours ago, francois said: There is also this one: My dad has that one on the farm for a water pump. He's on the second one... the first one failed. Just about all of them seem to be yearlings... only good for one year 🙂
May 18, 20206 yr They are great value but some are difficult to program so check this before buying. Don't switch your geyser element directly with its contacts. I know it's a pain but not doing this will shorten the life of the unit big time! Edited May 18, 20206 yr by Richard Mackay
May 18, 20206 yr Author Think I shall start with a cheapie Majortech at R195 each and then once this fails and I have gained some experience with the Victron then switch to Something else
May 18, 20206 yr 3 hours ago, Richard Mackay said: They are great value but some are difficult to program so check this before buying. Don't switch your geyser element directly with its contacts. I know it's a pain but not doing this will shorten the life of the unit big time! Sure you may have a better solution, but this is exactly how these units are advertised to work. If I quote directly from the packaging of the HellermanTyton jobbie above: - Max 20A (3500W) resistive load (Geysers)... - Internal relay contact directly onto load. So that is how any average joe would install it, by following the manufacturer's instructions.
May 18, 20206 yr Author The geyser at 3 kw “should” be ok, what about running a 1.1 kw pool pump, wondering about the start up current though Tariq
May 18, 20206 yr 2 hours ago, Tariq said: The geyser at 3 kw “should” be ok, what about running a 1.1 kw pool pump, wondering about the start up current though The timer should be ok even for the pool pump, but its contact will eventually fail as it only have a certain lifespan. Every time it switches a load on or off, it makes a spark across that contact and that is what eventually kills the unit, unless the internal battery fail first. Then if there was to be a dead short across the load side, that is almost a guarantee to blow that contact. This is what happens quite often to day-night switches when some energy saving globes when they fail cause a dead short blowing the day-night switch as well. Thats why its always better to split the control circuit from a power circuit.
May 28, 20206 yr On 2020/05/18 at 11:26 AM, Tariq said: The geyser at 3 kw “should” be ok, what about running a 1.1 kw pool pump, wondering about the start up current though Tariq I am a bit late to the party but I actually have a Majortech MTD8 switching my 1.1kW pool pump (twice a day, 7 days a week...).... touch wood it has been going for about 4 years now. (inrush on the pump is about 30A at 230V and running it draws about 6.2A...name plate of the pump indicates 7A). I find the setting procedure fairly simple - biggest gripe is that the screen can be very difficult to read in bright light. I also have some majortech plug point timers...they have never switched any thing over 100W and have only seen very intermittent short time use - one is still going also about 4 years on but another one died after only a few uses (when energised the relay sounds like a cell phone in vibration mode)..... An option that I am looking at but way more expensive is a sonoff that switches a contactor...
May 28, 20206 yr Author Thanks for your Input Introverter, what rail do you have the Majortech installed in, DIN or MINI ( Samite ) rail Tariq
May 29, 20206 yr 12 hours ago, Tariq said: Thanks for your Input Introverter, what rail do you have the Majortech installed in, DIN or MINI ( Samite ) rail Din rail (in one of the many available ready-made pool DBs). If looking at putting a timer on a samite board you may be able to use some adapter clips (https://www.cashbuildonline.co.za/products/adaptor-clips-sabs-samite)... for what it is worth I decided I will not put any of the consumer timers (majortech/CBI/hellerman) on my 3kW geyser. My uneducated opinion is that with a geyser the sustained high current draw is too close to the design limits and I suspect heat will be the major culprit leading to premature failure of the timer at best and possibly fire risk at worst. (the very high current on the pool pump startup is only a few milliseconds where after it drops quite low.... a 3kW geyser is very near the top limit and will be doing that for minutes (?) at a time).
June 17, 20233 yr I'm late to this subject. Ive had CBI timers on various geysers: all failed within a year or so. The screen dies and then you have no idea what the settings are. Then I got a Major tech MTD8, which has lasted about 4 years. It still works, but there have been one too many Eskom power cuts, and the battery is now kaput. Without the battery, the timer is useless. I've opened it , it merely clips together. I was expecting to find an NI mh cell, (that's what the instructions say it has) but there isn't such a thing , nor yet a button cell. What I think must be the battery is a tiny component, about 10mm long and 4mm diameter., soldered to the led display circuit board. A trip to Communica or the battery place in Milnerton is indicated
September 9, 20232 yr They are easy to repair if you know how. The CBI requires replacement of the 220nF/400V Capacitor. The standard AC type is fine but for better fire protection the 275Vac Class 2 at 0.022µF is better. [220nano Farad = 0.022 micro Farad for those not acquainted with the metric system]. The major tech can be modded to work better as well. When it starts clicking on turn on or the screen starts to fade then change the 0,33µF/275Vac GS-L capacitor with a standard 330nF/400V capacitor. They also have a 5V1/5W zener in the newer circuit marked 1N5338B which is out of tolerance. Replace it with a standard 0.5W 5.1V zener (the original 5W rating is way over-rated). Make sure you keep focus on the polarity. Replace the 4.7µF/100V capacitor with a one rated at 105degC. Replace the NiCad 3V6 Battery with a super capacitor of 0.22µF or 0.47µF rated at 5.5V. These take some time to charge and nothing appears on the screen until they are up to the voltage of control circuit likes. Don't forget the polarity. I put the Capacitor on its side and soldered pins upright to keep it on its side to fit in the battery position. The supercap lasts a few days to keep the memory but it is better than using the NiCad which fails over time anyway. One last thing you can do but don't have to is to move the MOV in the MTD8 circuit which is not really protecting it at all the way it is located in circuit. Remove it from between L~ and N~ and place it between the L~_to_MOV_150Ω_N~ which will limit the voltage in the case of a power surge instead of blowing up the MOV (I think its a KE350CA which means it limits 350V peaks and the CA means its bi-directional. Note -- in the older MTD8's they have two 24V diodes which is bad news for the LCD control circuit if the 1.5V NiCad Battery Fails here as the voltage increases. I'd put in a 4V7/0.5W zener to limit the voltage across the 1V5 NiCad in case it fails. If you put in a supercap in this circuit, then you need the 4V7 limiting zener and remove the 1K voltage limiting resistor. The NiCad battery difference should help you identify the two circuits of the MTD8.
