August 31, 20206 yr Author 21 minutes ago, Gnome said: Ah ok gotcha. Still generally you won't see anything mains related without isolation, apart from the no-isolation/shock problem, it can cause fire quite easily if you go out of range. The operating range of your circuit is very narrow I assume (ie. very close to exactly right AC voltage required). At least I can't think of any products I've bought that uses DC without isolation. (expect perhaps an indicator LED with a resistor in series) The basic PSU on the main board is a pretty solid unit. It does include a polyfuse, but it is not really necessary, as the resistances are so high that even a dead short on any of the LV components can't raise the current high enough to trip it.
August 31, 20206 yr 24 minutes ago, Gnome said: At least I can't think of any products I've bought that uses DC without isolation. (expect perhaps an indicator LED with a resistor in series) I've seen many of those. All of them fully enclosed in some kind of flame-resistant plastic with nothing exposed so that it doesn't matter if there is no isolation. Everything from daylight switches to the V9261F-based al-cheapo plug-in energy meter. Capacitive dropper, rectifier bridge, some sort of regulation (zener, linear regulator), and then the goodies.
August 31, 20206 yr 13 minutes ago, JustinSchoeman said: The basic PSU on the main board is a pretty solid unit. It does include a polyfuse, but it is not really necessary, as the resistances are so high that even a dead short on any of the LV components can't raise the current high enough to trip it. The biggest concern isn't so much input resistance (which I assume is close to the MΩ range?). It is the fact that the components don't fail safe. IE> if they fail, they fail short. Whereas transformer(s), Y class capacitors and light sources (ie. Opto) fail open (ie. safe). Even resistors have voltage ratings. Once exceeded, the resistor will fail short, regardless what its resistance rating was. Ditto for diodes (I assume you used 1kV rated diodes because they are super cheap). These failures are more common than people think. A number of cheap-o USB chargers with no isolation were sold in China and electrocuted some people. Again fire hazard is the biggest risk for you, assuming there is no way the thing can touch metal. So I would just have a good way to prevent it burning the place up. 9 minutes ago, plonkster said: I've seen many of those. All of them fully enclosed in some kind of flame-resistant plastic with nothing exposed so that it doesn't matter if there is no isolation. Everything from daylight switches to the V9261F-based al-cheapo plug-in energy meter. Capacitive dropper, rectifier bridge, some sort of regulation (zener, linear regulator), and then the goodies. To your point, I googled V9261F and found this: https://mysku.ru/blog/aliexpress/59870.html To get something like that legal, you probably need quite a bit of testing. Similar to multimeter CAT ratings. Most "reputable" voltage/current measurement equipment I've seen seem to favor current transformers rather than a shunt & direct voltage measurement like that. But to be fair, you can get much more accurate data using a shunt & direct measurement. It is probably just much more expensive to get through EU & US testing procedures. Edited August 31, 20206 yr by Gnome
August 31, 20206 yr 21 minutes ago, Gnome said: To get something like that legal, you probably need quite a bit of testing. Similar to multimeter CAT ratings. I think the only thing you need to do is make sure nothing is exposed and that the plastic won't sustain combustion. Nobody cares beyond that point. Besides, the matter of legality assumes someone is going to police it... 🙂 Inside a DB-board, with an insurance company, there I suppose you have a good point. Edit: Oh, and of course, you need to put a CE mark on there. No idea what it is for, but you put that on there to indicate you thought of safety... some time in the last decade. Edited August 31, 20206 yr by plonkster
August 31, 20206 yr Author 46 minutes ago, Gnome said: Even resistors have voltage ratings. Once exceeded, the resistor will fail short, regardless what its resistance rating was. Ditto for diodes (I assume you used 1kV rated diodes because they are super cheap Again - I have not touched the PSU board - I am using the existing PSU of an existing SANS approved geyser timer. The PSU is poly fuse protected, and has such a low maximum current that it could never pose a fire hazard, even if you replaced my circuit board with a wire from Vcc to GND.
August 31, 20206 yr 3 hours ago, JustinSchoeman said: Again - I have not touched the PSU board - I am using the existing PSU of an existing SANS approved geyser timer. The PSU is poly fuse protected, and has such a low maximum current that it could never pose a fire hazard, even if you replaced my circuit board with a wire from Vcc to GND. Oooh I thought you designed it
September 1, 20206 yr Author LV box is almost complete. Just need to mount PSU and clean up wiring. But at least all the essentials are working, and the inverter and battery are happily talking to each orther.
September 1, 20206 yr Author Code is on github. Still needs lots of cleanups, but some bits and pieces may be useful to others (and an extra set of eyes may help catch bugs ) : https://github.com/justinschoeman/dalybms If anybody is going to play with this, the note in the first line is important. Need to replace stock arduino bootloader with a recent optiboot. Otherwise the hardware watchdog causes a boot loop... Edited September 1, 20206 yr by JustinSchoeman
September 3, 20205 yr Author Smart(er) load control functional (if rather rough and ready): https://github.com/justinschoeman/SmarterLoad Probably not useful, but a good starter if you want to monitor a Sunsynk/Deye inverter (but that really is trivial, so a starter is not really required).
September 15, 20205 yr Author Well, I finally twisted Jaco's arm into a non-blue install, and the results are beautiful... With the whole house as a dummy load, I also got a chance to properly test the battery and assorted bits. Load peaked at 11kW before the geyser controller managed to turn the geyser off, and then stabilised at around 8kW, with 195A draw from the batteries. After around 10 minutes, batteries, terminals and connecting plates were all still at room temperature. The wires connecting to the inverter were however a few degrees warmer. Glad I did not go smaller than the 70mm^2 I eventually settled on. (I have 2x 95mm^2 wires in parallel for joining the banks - and these wires also stayed cool.) All in all, it has turned out to be a successful experiment so far. Been off grid for 15 hours so far, and hope to stay that way pretty much indefinitely.
December 6, 20205 yr @JustinSchoeman Congratulations good job. I have Venus Victron installer on Raspberry pi with Original Display and I want to add for my 4S battery, in the future it will be 16S for my house. I would like to send me information and pinout of the connections to my private email, I have tried to install in code in Arduino mega 2560, but it has not worked for me I have an arduino mega with MCP2515 and I want to connect the serial port or rs485 to my arduino mega serial1 and send it via can bus to venus. In a few days I will receive my BMS 4S UART port. I have this conections, and can bus to Raspberry pi witj venus my idea is to connect the BMS Daly to serial port 1 SPI Pins <=> Arduino Uno <=> Arduino Mega 2560 SCK <=> 13 <=> 52 MISO <=> 12 <=> 50 MOSI <=> 11 <=> 51 CS <=> 10 <=> 53 This demo VEcan work in mega2560, need add your code #include <mcp_can.h> #include <SPI.h> //variables for VE can uint16_t chargevoltage = 49100; //max charge voltage in mv uint16_t chargecurrent = 30000; //max charge current in ma uint16_t disvoltage = 42000; // max discharge voltage in mv uint16_t discurrent = 30000; // max discharge current in ma uint16_t SOH = 100; // SOH place holder unsigned char mes[8] = {0, 0, 0, 0, 0, 0, 0, 0}; unsigned char bmsname[8] = {'S', 'I', 'M', 'P', '-', 'B', 'M', 'S'}; unsigned char bmsmanu[8] = {'T', 'O', 'M', ' ', 'D', 'E', ' ', 'B'}; MCP_CAN CAN(53); //set CS pin for can controlelr int SOC =80; float PackVoltage = 46.7; float AvgTemperature = 20.5; uint16_t currentact = 0; void setup() { Serial.begin(115200); //puerto CAN BUS if (CAN.begin(MCP_ANY, CAN_250KBPS, MCP_8MHZ) == CAN_OK) Serial.print("El BUS CAN se ha iniciado correctamente!!\r\n"); else Serial.print("Error en el inicio del BUS CAN!!\r\n"); CAN.setMode(MCP_NORMAL); } void loop() { // put your main code here, to run repeatedly: VEcan(); delay(200); } void VEcan() //communication with Victron system over CAN { mes[0] = lowByte(chargevoltage / 100); mes[1] = highByte(chargevoltage / 100); mes[2] = lowByte(chargecurrent / 100); mes[3] = highByte(chargecurrent / 100); mes[4] = lowByte(discurrent / 100); mes[5] = highByte(discurrent / 100); mes[6] = lowByte(disvoltage / 100); mes[7] = highByte(disvoltage / 100); CAN.sendMsgBuf(0x351, 0, 8, mes); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(mes[i]); Serial.print(" , "); } mes[0] = lowByte(SOC); mes[1] = highByte(SOC); mes[2] = lowByte(SOH); mes[3] = highByte(SOH); mes[4] = lowByte(SOC * 10); mes[5] = highByte(SOC * 10); mes[6] = 0; mes[7] = 0; CAN.sendMsgBuf(0x355, 0, 8, mes); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(mes[i]); Serial.print(" , "); } mes[0] = lowByte(uint16_t(PackVoltage * 100)); mes[1] = highByte(uint16_t(PackVoltage * 100)); mes[2] = lowByte(uint16_t(currentact / 100)); mes[3] = highByte(uint16_t(currentact / 100)); mes[4] = lowByte(uint16_t(AvgTemperature * 10)); mes[5] = highByte(uint16_t(AvgTemperature * 10)); CAN.sendMsgBuf(0x356, 0, 8, mes); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(mes[i]); Serial.print(" , "); } mes[0] = 0; mes[1] = 0; mes[2] = 0; mes[3] = 0; mes[4] = 0; mes[5] = 0; mes[6] = 0; mes[7] = 0; CAN.sendMsgBuf(0x35A, 0, 8, mes); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(mes[i]); Serial.print(" , "); } delay(5); CAN.sendMsgBuf(0x370, 0, 8, bmsname); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(bmsname[i]); Serial.print(" , "); } delay(5); CAN.sendMsgBuf(0x35E, 0, 8, bmsmanu); Serial.println(" "); for (int i = 0; i<8; i++) { Serial.print(bmsmanu[i]); Serial.print(" , "); } } Edited December 6, 20205 yr by Jose Ibz
December 6, 20205 yr Author MCP2515 connects via SPI, not serial. You can follow any of the howto's on the web for connecting it to the Arduino - you should be able to find one specific to the shield you have.
December 7, 20205 yr 13 hours ago, Jose Ibz said: Venus Victron installer on Raspberry pi If you are on a Victron system you can also try my serial driver if you want. No Arduino required. Only a serial USB connector for your battery. The Daly does have a few changes to the commands than my battery. https://github.com/Louisvdw/dbus-serialbattery
December 7, 20205 yr Ok, I'll check in a few days when I receive the Daly BMS. Thank you very much for the information.
December 8, 20205 yr @JustinSchoeman Morning Justin, question re: your 250A Daly Smart BMS, what is the charge current rating? Looking to get one from AllieExpress but doesn't specify charge current Thanks
December 8, 20205 yr Author 1 hour ago, smurfdbn said: Morning Justin, question re: your 250A Daly Smart BMS, what is the charge current rating? Looking to get one from AllieExpress but doesn't specify charge current 125A charge for the 250A discharge BMS.
December 20, 20205 yr On 2020/09/01 at 11:31 PM, JustinSchoeman said: Code is on github. Still needs lots of cleanups, but some bits and pieces may be useful to others (and an extra set of eyes may help catch bugs ) : https://github.com/justinschoeman/dalybms If anybody is going to play with this, the note in the first line is important. Need to replace stock arduino bootloader with a recent optiboot. Otherwise the hardware watchdog causes a boot loop... Hi Justin AWESOME WORK!! I would like to play with this. Problem is I have no idea where to start. I have just finished my DIY battery, similar to yours, 16s3p 120AH 2nd Life cells. I would like to be able to communicate with my Deye 8kw inverter. Where does one start? Regards
January 1, 20215 yr Author On 2020/12/20 at 11:41 PM, Schallas said: Where does one start? What BMS are you using?
January 1, 20215 yr 37 minutes ago, JustinSchoeman said: What BMS are you using? Hi Justin 150A Daly Smart Bms. Happy New Year everyone
January 1, 20215 yr Author You should be able to use my Arduino project pretty much as-is. Grab your favorite Arduino + a CAN shield (MCP2515 based for direct compatibility) + a RS485 shield.
January 1, 20215 yr 5 minutes ago, JustinSchoeman said: You should be able to use my Arduino project pretty much as-is. Grab your favorite Arduino + a CAN shield (MCP2515 based for direct compatibility) + a RS485 shield. Thank you... I am a complete noob at this sort of thing, but I figured i’d give it a shot, and the Arduino and other bits are on the way from China... I am also working with a mate on a python/raspberry pi project to try see if that will work. So far we have managed to establish comms between the BMS and the Pi. Next step is to Establish comms with the inverter, and then mimic another battery much like you did.
June 18, 20215 yr On 2021/01/01 at 7:39 PM, Schallas said: I am also working with a mate on a python/raspberry pi project to try see if that will work. So far we have managed to establish comms between the BMS and the Pi. Next step is to Establish comms with the inverter, and then mimic another battery much like you did. @Schallas Sorry to revive this old thread, but did you ever get the Daly working over RS485 to a Raspberry PI? I'm interested to know how you connected this up and any Python you wrote to achieve this Thanks!
June 25, 20215 yr On 2021/06/18 at 5:39 PM, Lindsay said: @Schallas Sorry to revive this old thread, but did you ever get the Daly working over RS485 to a Raspberry PI? I'm interested to know how you connected this up and any Python you wrote to achieve this Thanks! Hi Lindsay We did... Its not 100% yet, but it is working most of the time. The serial/uart comms to the Raspberry Pi works fine, but like @JustinSchoeman also mentioned, it spits out dodgy data every now and then. From the Raspberry Pi we had to add a CANHAT to the RPI, and then we went the CANBUS method. The code is a bit messy, I am not a programmer by trade so you can imagine where this is going. I have odd bits and pieces in there to control my pool pump ect... You can check it out here: https://github.com/tomatensaus/bms Regards
June 29, 20215 yr Awesome, this looks great. I've ordered a RS485/CAN PI hat from Micro Robotics, maybe the same as what you have, it passes through all the pins. Useful as I also have some relays etc that I need to operate from the PI (one of which, in summer, switches on a submersible pool pump to heat water on my roof depending on the temperature difference). My inverter sometimes spits out dodgy data or hangs/timeouts when I try access it's comms via usb. So I'm used to having to discard data (or move on if I don't get anything back) and then try again later Thanks again!
