CBI Astute Smart Controller
@Zodiac69 @Yuri Thank you! I'm not running any HA instances (I've decommissioned my always-on-servers in an attempt to reduce my energy footprint to deal with load shedding!); presumably this isn't possible with just the native Tuya/SmartLife app - but perhaps it's time for me to spin something up again for this kind of thing 😉
  • Replies 193
  • Views 69.6k
  • charliesjc
    charliesjc
    Just thought I'd post an update on using the CBI Astute with Home Assistant. I have it working without having to Tasmotize it or open it or do anything silly to it. I ignored the CBI app and simp
  • Scubadude
    Scubadude
    I'm no home automation fundi but I got fed-up of my failing pool timer running down my batteries when not expected, so I replaced it with a CBI Astute ASC. Installation was quick and easy even for my
  • MongooseMan
    MongooseMan
    It certainly lowered the average age of component in my DB 🙈
Hi all.
Excuse my inexperience - I'm now very new to Home Automation stuff....
I have the CBI ASI isolator in front of my geyser. It's working 100% with the CBI App. Cool, scheduling, etc, but all manual monitoring so far.
Now I've installed Home Assistant. I have figured out from this thread that to get HA talking to the CBI Isolator, I need to pair it to the Tuya App, and then use the Tuya Integration on HA. Fine...
I'm just having no joy getting the Tuya App to pair with the CBI switch.
I get the switch into paring mode, open the App - and then wait till 2 minutes expire with no joy...  I can re-pair the Switch to CBI App no problem. So, I know I am getting pairing to work. But it just won't play ball with the Tuya App.
Any clues - please ?
Edited by Patrick OReilly
Hold the square button for 5 sec then release it the lights will blink fast
Hold down the square button for 5 sec once more now the lights will blink slow
Use the app's slow blinking set up this always works for me
I also select Socket (Wi-Fi) for adding device
Hmmmm - I was unaware of two different "blink rates" for the pairing.  Interesting.  I'll give that a whirl...
Thank you.
Just installed a CBI asc on my geyser.
Seems to be working fine.
Im using the tuya smart app. Under electricity stats I can see a voltage, but no current?
What would cause that? My geyser is hot so it must be drawing a current
23 minutes ago, crudler said:
Ok good point. Maybe I jumped the gun. I'll leave it over night and look again in the morning
Check once you've used the hot water tonight and you should see both Power and Current produce values above 0, for as long as necessary to re-heat the balance of the water.
Voltage will always remain at supply-voltage when the geyser is connected.
Edited by JayMardern
2 hours ago, crudler said:
Still showing zero. Very strange.
Definitely drawing power because I can see the usage spike on my inverter.
What happens if you use the CBI APP?
Seems there is a problem showing the recorded amps/power used.
No luck... i tried the CBI app and it does the exact same thing
could it be a wiring issue?
The LOAD from the controller goes into an AC Contactor before it goes to the geysers - could that be the issue?
The Full load must go via the ASC. With the way the ASC is wired, you only drive the coil of the contactor, will not even show as the contactor coil power consumption is very low.
(N) to N on ASC
(N) to A1 on Contactor
(L) From breaker to input of ASC
Output of ASC to Contactor to A2 and to the "Input" of your contactor.
Do you have 3phase or is it 3x geysers?
Your total load can not be more than 30A if it is single phase.
If you have 3Phase, then you need 3x ASC units, one per Phase.
I do something similar..
I have two ASC's, one per Geyser as i stagger my load, and two contactors, one contactor per geyser. In my case i have wired the geysers to that i break Live and Neutral via each contactor.
Edited by Zodiac69
(N) to N on ASC
I'm pretty sure this wiring is the issue,
As a side-note, I've used the CBI, Smart Life and Tuya apps with this same CBI Astute controller (complete with it's annoying flashing light!) - and it works perfectly under all 3 apps. It's a fantastic piece of hardware IMO.
(N) to N on ASC
ooo. OK i understand.
All my time switch is doing, is making the contactor close a circuit so the geysers are powered. The time switch doesnt carry the load of the Geyser.
gotcha....
I am single phase. yes i have 3 geysers
so its a rewiring project to get the consumption data - not sure if its worth that. M main goal is I made my geysers smart, and I can integrate them into HA.  Getting consumption data would have been a nice to have
thanks
gotcha....
thanks
It took a while to find out the current does not go through the CBI. If you perhaps reduce the current via 2kW elements the the CBI can switch them directly without the need of the relay.
This will then provide the power which you would like to see.
It seems you have enough space even for another CBI. This can give better control as 3 geysers on at the same time is quite a big load. We all try to stagger geysers coming on at the same time.
  • 3 months later...
Hi All, I just installed a CBI Astute and all working well with the CBI Home APP.
I see that the CBI Home app has options for other Home switches.
Does anyone know what Light switches can be controlled via the CBI Home app?
Or should I get Tuya Light switches and moved the geyser and lights onto the Tuya app?
