Sunsynk/Hubble Install
2 hours ago, YellowTapemeasure said:
That's a great choice of (what I assume to be) your client, 2x 8K Sunsynks and 4x Hubble (looks like Am-2)? Does your client have anything on the roof and if so, what capacity ? Any (anonymised) pics?
Yeah 4 x AM2’s and 19260w of PV. 36 x 535w panels.
5 minutes ago, TimCam said:
So jealous of your customer.😀
Still saving for some Hubble AM-2's
Lovely looking install, is he hoping to be off grid completely?
I think he will be as close as possible to being off grid. Each inverter will supply a separate phase of his home.
Very nice view.
I see you can squeeze a few more panels in if needed.
Lovely tranquil surroundings, hope you got a round or two in while there.😆
6 hours ago, TimCam said:
Very nice view.
Just a couple. He has 18 on the East and 18 on the West. We also have the ability to turn his meter back which is great.
Very nice install @Leshen
I assume it is then two AM2's per Inverter and both Inverters will have panel from East and West side (as opposed to one being fed only from East and other only from West).
What relay are you using for the N/E bond?
Hi Brander
Thank you. Yes 2 x AM2 per inverter and panels as you mentioned.
I use an ACDC relay with a backing plate placed into a 4 way DIN rail DB
19 hours ago, Leshen said:
Hi Brander
@Leshen May I ask you what rating relay did you use? Do you have to match it to the inverter output Amps rating for some reason?
Hi. We use a 10A/230V relay which is way more than you need.
All you are doing is bonding earth to neutral, no load will be going through the relay.
On 2021/08/31 at 8:02 PM, Leshen said:
Two x 8kw Sunsynk Hybrid Inverters with 4 x Hubble AM2
How is the communication between the Sunsynk and Hubbles, do you need any other device or is it only the normal comms cable?
I saw one of your other installation you used the 5KW Bull with the Sunsynk, do you have a favorite between Hubble and the Bull?
SunSynk and Hubble are 100% compatible and work with the CAN cable. Since this post started, I have connected 2x Hubble AM-2's to my own SunSynk 8.8 Kw unit, and couldn't be happier. The load-shedding at the moment has zero effect on my household. 😀
