January 31, 20224 yr Item: Sunsynk 8.8 kww Age: Brand New (Sunsynk replaced it, have not opened it) Price: R 28 000 - R 30 000 Highest offer gets it. Payment Method Accepted: EFT Warranty: 5 Years Packaging: Yes Condition: Brand New (Sunsynk replaced it, have not opened it) Location: Midrand Reason: Would rather have a Victron Shipping: No Collection: Yes Link: Edited February 8, 20224 yr by Dean
January 31, 20224 yr @Leshen, just curious about the reaction on the thread? If it is because of the Victron comment, then I understand 😅 I'm in the market for a unit as advertised, am I missing something? If there is a warranty, I don't see an issue... @Dean, is the 5 year warranty offered by Sunsynk? Edited January 31, 20224 yr by DieDusman
January 31, 20224 yr 7 minutes ago, DieDusman said: @Leshen, just curious about the reaction on the thread? If it is because of the Victron comment, then I understand 😅 I'm in the market for a unit as advertised, am I missing something? If there is a warranty, I don't see an issue... @Dean, is the 5 year warranty offered by Sunsynk? Purely on the Victron comment
January 31, 20224 yr 2 hours ago, Dean said: Item: Sunsynk 8.8 kww Age: Brand New (Sunsynk replaced it, have not opened it) Price: R 28 000 - R 30 000 Highest offer gets it. Payment Method Accepted: EFT Warranty: 5 Years Packaging: Yes Condition: Brand New (Sunsynk replaced it, have not opened it) Location: Midrand Reason: Would rather have a Victron Shipping: No Collection: Yes Link: I thought that Sunsynk was a Rolls Royce of the inverters 😀
January 31, 20224 yr 3 minutes ago, hoohloc said: I thought that Sunsynk was a Rolls Royce of the inverters 😀 Sunsynk can do most things a Victron can for a third of the price.
January 31, 20224 yr 4 minutes ago, hoohloc said: I thought that Sunsynk was a Rolls Royce of the inverters 😀 You definitely won't get an 8kw(10kva) Victron for R30K
January 31, 20224 yr 2 minutes ago, Leshen said: You definitely won't get an 8kw(10kva) Victron for R30K I see, R30k is still too much for me, that's why 2 x 5kw Growatts for R20k 🤣
January 31, 20224 yr 1 minute ago, hoohloc said: I see, R30k is still too much for me, that's why 2 x 5kw Growatts for R20k 🤣 I'm not clued up with Growatt. Can it blend AC and DC to supply the load
January 31, 20224 yr Just now, Leshen said: I'm not clued up with Growatt. Can it blend AC and DC to supply the load Nope, it can't blend, that is luxury for me. That is why I can't afford Sunsynk and surprised that OP doesn't want it, for the price its going for. If I had R30k to spare, I would grab this without a blink.
January 31, 20224 yr 1 hour ago, Leshen said: I'm not clued up with Growatt. Can it blend AC and DC to supply the load It can blend, I have 2 X SPF 5000 ES and most definitely can blend Solar and Grid, not sure if it can blend from the Battery and AC, That I think it cannot do. Here is dashboard of my system at the moment, on SUB as can see it blends solar with grid. Edited January 31, 20224 yr by Antonio de Sa
January 31, 20224 yr 2 hours ago, YellowTapemeasure said: Is this the same one with the alleged High Voltage Problem? Ah! ok, then that makes sense 🤔
January 31, 20224 yr 1 hour ago, hoohloc said: Ah! ok, then that makes sense 🤔 It doesn't, really: "Sunsynk replaced it, have not opened it"
January 31, 20224 yr 13 minutes ago, jacquesretief said: It doesn't, really: "Sunsynk replaced it, have not opened it" Same with the Axpert King
January 31, 20224 yr 55 minutes ago, YellowTapemeasure said: Same with the Axpert King Seems like a bit of confusion between Voltronic, Sunsynk and Victron
January 31, 20224 yr 5 hours ago, Antonio de Sa said: It can blend, I have 2 X SPF 5000 ES and most definitely can blend Solar and Grid, not sure if it can blend from the Battery and AC, That I think it cannot do. Here is dashboard of my system at the moment, on SUB as can see it blends solar with grid. Mmm... running 2x Growatt SPF-5000ES and they don't truly blend for me. In the early morning if my batteries are low they put the Solar to batteries and run the loads from Grid. I don't really see that as blending really... not like the way I understand SunSynk does. I am actually looking to replace my Growatts with probably SunSynk (likely 2x 5kw) as a Victron 8Kw with separate MPPT units is a little costly. I am looking to run 4 strings of panels.
February 1, 20224 yr 8 hours ago, TDH said: Mmm... running 2x Growatt SPF-5000ES and they don't truly blend for me. In the early morning if my batteries are low they put the Solar to batteries and run the loads from Grid. I don't really see that as blending really... not like the way I understand SunSynk does. I am actually looking to replace my Growatts with probably SunSynk (likely 2x 5kw) as a Victron 8Kw with separate MPPT units is a little costly. I am looking to run 4 strings of panels. @THD Don't understand why yours don't blend. here is dashboard of my system this morning, one can clearly see as the sun comes up it starts to blend solar and grid, only starts to charge the battery once there is more solar then the house load.
