ICC Windows
  • Replies 127
  • Views 32k
  • donatoliu
    donatoliu
    Good morning I wanted to share with you this view with emoncms, just to let you see the potential of this platform.
  • You can download it at http://iccsoftware.co.za/download-2/  You'll need to PM @Manie for a trial key and if you're happy with the software (which I'm 100% sure you will be) you can pay hom and h
  • Hi Pilotfish Where to start is always difficult. I have been using ICC Windows for quite some time and had no complaints. I was running on Windows 10, I3 with 4 Gig ram configuration and except
@donatoliu are you sorted ?
Is your Pc connected to the network ? , use remote desktop and acss it from there, if still a issue tell me i can make a plan
What ACSS? Yes, the PC is on a network and can be reached via team viewer.
Where do you see ACSS ?
no problem, send me a mail via [email protected] with a screenshot of the thing you don't understand
o sorry spelling mistake you can access the pv for your network using a different PC / Laptop
13 hours ago, donatoliu said:
yes, you can access the PC via "Team Viewer" software you know him? My problem is the PC resolution that does not allow me to read id machine.
@Manie I solved the problems and troubleshooting. Now what's the next step? You have to buy now or is there a chance to try for a few days? If what is the purchase price?
Hello, I use ICC for windows and these values are not implemented on emoncms. While pvwatt is correct or you need to update pvwatt1? Can someone help me?
Please update to the lates version. Pv watts 2 is for the pip inverter with 2 mppt chargers
Thanks, I downloaded version 1.0.1. Now emoncms read all values. It 'a shame to have lost the SOLARWATT input.
Which inverter do you have? Axpert MKS-5K? USB or serial?
the problem was in the ICC version. Now I read all values. However mine is Mppsolar pip4048ms which is similar all'axpert. The connection is USB.
it is simular as my invertor pip4048MSD , only with 1 mppt tracker + if value (of some things) are 0 in emon, if the inverter doesnt know the command, it will be 0, don't use it in emon... its not that bad.. (and i see you do good in emon ;) , you only log what is needed)
but indeed if pvwatt1 is 0 , thats not good, if pvwatt2 is 0, thats normal , because you dont have 2 mppt trackers... ;)
Hi !
  This is my first post and I take this opportunity to greet everyone.
@Manie will consult you if you have tested your software on Solar Mpp inverters Models "Hybrid V". Specifically the model of my inverter is the 4048V or have you received any comment that works well on this device? I plan to couple a second inverter in parallel and I am very interested in the software for Windows that you sell. Thank you very much.
Is it the same as the pip 4080 or as the Invini V series
It looks like the invini v series. Download the windows ICC and select pip inverter. If it does not work i will be the same as the invini V series wich i will add soon
Ok. Any link for download please ?
Thanks.
