ICC Windows
Pm me with your details with teamview
  • Replies 127
  • Views 32k
  • donatoliu
    donatoliu
    Good morning I wanted to share with you this view with emoncms, just to let you see the potential of this platform.
  • You can download it at http://iccsoftware.co.za/download-2/  You'll need to PM @Manie for a trial key and if you're happy with the software (which I'm 100% sure you will be) you can pay hom and h
  • Hi Pilotfish Where to start is always difficult. I have been using ICC Windows for quite some time and had no complaints. I was running on Windows 10, I3 with 4 Gig ram configuration and except
Just some feedback
The Axperts are added and tested . I will release it soon and then we can take it from there.
Are there still interest for the windows app?
Hi Guys
Let kick off the first version. I will add as we go.  At this stage it's all the Aperts, will add the infin's later
On 2/6/2017 at 1:16 PM, Czauto said:
Would it be possible to integrate a scheduler (something like used in the Bittorrent program) to preprogram daily schedules as to when the inverter switches to grid/battery power.
I remember in 1997 when I discovered the cron feature on my linux system. I was like... Where have you been all my life!? Such a cool solution, standard with the system!
Hello . I'm from the Czech Republic and use the old AICC for Windows.Chtěl Scroll to the new ICC and do not know where to take the license key.Na page http://iccsoftware.co.za/ I had not found it. Are you doing? English, so I can not use a translator. Sometimes it translates poorly to apologize. Thank you.icc.thumb.jpg.327c98ba7220a614b083d7795dfff506.jpg
Hi Ferdik
At the bottom of the page there is a Machine Id. Send me that number by PM (Personal Message)
Regards
On 2017/02/07 at 11:10 PM, Manie said:
Hi Guys
First let me start off by thanking Manie for a job well done so far. There are most likely some more enhancements to follow, and we all wait in anticipation.
This is a screenshot from the latest version I got from Manie. The first one ran for like 250+ hours with no issues, but Manie made a few changes to it on request, this version included all the enhancements and I must say I am pretty impressed with it so far.
It runs stable, and report all the information I need in a nutshell.
I know most are running the RPi version, but for the Windows guys, I can really recommend this one.
Admittedly I have the 24V 3kVa unit, but I am confident that the same success would apply to the other Axpert models as well.
Hi all,
I added some more Info and also corrected the pvoutput problem
Regards
On 14/2/2017 at 7:37 PM, Czauto said:
I'm soooooo glad to hear I'm not the only Windows guy out there.......Thanks Manie
Sent from my S60 using Tapatalk
Hello, you're not the only one, there are also I wait for the ICC windows version. But you can have a version to be tested in waiting?
What inverter do you have?
You'll need to PM @Manie for a trial key and if you're happy with the software (which I'm 100% sure you will be) you can pay hom and he"ll send you a license key.
Installation is a blast. 1:Download 2: Install 3: connect usb cable between Inverter and PC/Laptop running windows 4: Insert security key supplied by @Manie 5: click the little "on" button on the app and enjoy. From there you setup  your PVoutput and Emoncms settings and look at the pretty pictures ;)
Did I explain correctly @Manie?
thanks for the quick answer. Unfortunately the link does not work.
I will check this afternoon. Just send me a mail and also what inverter you have
Sorry. I see the actual download link is down. @Manie will have to assist there and I'm sure he's already on it.
Let's just say like an actual roadside sign I saw some time ago at a stop n go system "We adore your patients" Bloomin' idiots!!
PIP4048 MPPT
Did you send me a mail?
The download link is fixed. Not sure wich version is currently on the site. Will update the site tonight
Hello, I sent the mail. I downloaded version 1.0.0.
The problem now is that my PC's resolution is too low and I can not raise it as my pc is a mini-PC. So I can not read the machine id.
Damn @donatoliu, are you sure you have the correct display settings on your device? How are you going to read the amps and volts if you cannot read the machine ID?
maybe try @The Terrible Triplett, Solarweb if it will work on your screen settings
Let's say that all I need to configure it because I use the dashboard emoncms.
