Sc00bs Posted January 27, 2023 Share Posted January 27, 2023 Hi Guys I managed to score a heat pump for my pool from one of my friends who had it lying around. It is an Aquatemp FT12KS and the manufacturers don't seem to be in business any more. Connected it all up and runs 100% when my inverter is attached to the grid (Sunsynk 8Kw) . It pulls a load of 2.2Kw and has a Copeland Compressor - Model ZR28K3-PFJ-522 installed. The strange thing is that the heatpump will not run when the grid is down. If the grid goes down it stops working and will not switch on again until we attach to the grid again. You can hear the compressor trying to start but immediately stops again. I have tried reducing the load on the inverter as much as possible but no joy. Any Ideas? Quote Link to comment Share on other sites More sharing options...
GreenFields Posted January 27, 2023 Share Posted January 27, 2023 What battery are you using, and can it handle the startup current that is possibly normally carried by the passthrough from the grid? Quote Link to comment Share on other sites More sharing options...
TaliaB Posted January 27, 2023 Share Posted January 27, 2023 It has LRA of 61 amps it needs 61 amps to start runs at 6.5 amps Quote Link to comment Share on other sites More sharing options...
TaliaB Posted January 27, 2023 Share Posted January 27, 2023 https://compressorvietnam.com/en/may-nen-lanh-copeland-model-zr28k3-pfj-522-938525.html Quote Link to comment Share on other sites More sharing options...
GreenFields Posted January 27, 2023 Share Posted January 27, 2023 4 minutes ago, TaliaB said: It has LRA of 61 amps it needs 61 amps to start runs at 6.5 amps And here I was wondering why on earth anyone would need a 5kWh 300A battery. Or 4. TaliaB and CobusK 1 1 Quote Link to comment Share on other sites More sharing options...
TaliaB Posted January 27, 2023 Share Posted January 27, 2023 HVAC takes no prisoners Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted January 27, 2023 Share Posted January 27, 2023 53 minutes ago, TaliaB said: It has LRA of 61 amps it needs 61 amps to start runs at 6.5 amps Hell am I glad my heat pump has an inverter start unit. 1.5kW and never uses more than 1.5kw and that is when working at full power. CobusK 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted January 27, 2023 Author Share Posted January 27, 2023 55 minutes ago, GreenFields said: What battery are you using, and can it handle the startup current that is possibly normally carried by the passthrough from the grid? That is pretty much what I thought. I have 2 x BSL 6.4kw 125A each - 250A total. Don't get any error on the inverter, the heat-pump just doesn't work. Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted January 27, 2023 Share Posted January 27, 2023 My HP (ALLWH72R410) uses 2.75 kW when running, and no problems. Wired on Essentials! (with digital timer). For my 2 geysers in the house, not for a pool, though. Quote Link to comment Share on other sites More sharing options...
Dylan Posted January 27, 2023 Share Posted January 27, 2023 Perhaps HF inverters? Quote Link to comment Share on other sites More sharing options...
Jakac Posted September 30, 2023 Share Posted September 30, 2023 it needs 14kw to start. you will need 300A from battery to start it. The BMS is cutting the power. You probably need 20kw of battery bank Quote Link to comment Share on other sites More sharing options...
Bobster. Posted September 30, 2023 Share Posted September 30, 2023 It has LRA of 61 amps it needs 61 amps to start runs at 6.5 amps That's huge. My main breaker is 60A. I presume that the 61 is for a millisecond or two. Quote Link to comment Share on other sites More sharing options...
TaliaB Posted September 30, 2023 Share Posted September 30, 2023 Yes very short period but causes serious inrush. Quote Link to comment Share on other sites More sharing options...
