Max panels with Sunsynk 8kw hybrid inverter
Hi guys,
I'd like to get some clarity and confirmation as our additional panels should be going up this week. The frame components are being galvanized and panels are in our garage but the install is imminent.
Will post some pics of the final install when done.
Can anyone advise what is the best way to wire up all the panels?
Current:
  • Currently have 10 x JA Solar 460 Watt panels (2 strings of 5 per MPPT) facing north
  • Sunsynk 8kw inverter firmware: M 6.0.2.2 / S 1.7.2.4 / C E.4.2.6
New:
  • 10 x JA Solar 460 Watt panels (same as current ones) facing north
Panel info:
Screenshot2023-06-07103855.JPG.27affa75ca174f272fd2ff45344063da.thumb.JPG.b0b6d5ccb91e88db2850e3da9363fdbe.JPG
Inverter sticker:
Frame:
Many thanks :)
  • Replies 61
  • Views 28.2k
  • @lavaland 10,400W is NOT a maximum amount of panels you can connect.  10,400W is the maximum amount of DC power that the inverter will use.  As long as ensure that the max voltage of each st
  • I have 12,400W of panels connected to my Sunsynk 8kw inverter BTW 🙂
  • Here is an example with 400W panels: https://solar.co.za/how-to-size-a-pv-array#cs3
2 hours ago, Muttley said:
Hi guys,
Current:
New:
Panel info:
Inverter sticker:
Frame:
Many thanks :)
5s2p Mppt 1 and 5s2p Mppt 2 total 9200 watts 21.84A/Mppt.
Edited by TaliaB
Thanks for the input - would you mind explaining 5s2p?
Is it 5 panels in series and the 2 banks in parallel? 😵‍💫
Edited by Muttley
grammar
3 minutes ago, TaliaB said:
Yes 5s means 5 panels in series. 5s2p  means 5 panels in series 2 of them(strings) in parralel on Mppt1 and the same for the other 10 panels on Mppt2
Awesome, thanks for the clarification :)
  • 1 year later...
I have 6 X JA Solar 555 W panels on one mppt and 10 X 345 W panels on the other mppt of my Sunsynk 5kw inverter. The inverter is connected to the grid and can potentially do 6500 W. the inverter seems to be capping production at around 5300 W. Sunsynk have reportedly upgraded the firmware. The limiter has apparently been updated to 6300 W. production graph shows that production is still clipped to 5300 W. I saw similar issues were solved with upgraded firmware. Is there any other help that I can get.
JA Solar 555W VOC = 50.02V and Isc = 14.07A  Vmp = 42.11V
Art Solar 345W  VOC = 40.45V Isc = 10.84A  Vmp = 33.69V
Your inverter can only invert 5000W. The MPPTs can do 6500W, but then your batteries have to be taking at least 1500W of charge (the rest going to the grid/backup).
Edited by P1000
Is there any other way to use the extra 1500W like via the generator output
No. Your inverter can only invert 5000W. In other words, it can only convert 5000W into AC (ignoring the 10s overload capacity).
@Azimuth because your battery is at 100%, there are no other DC options to send the power to, if your battery was at a lower SOC it would send the extra power over and above your load to the battery up to a max of 6500W.
Your inverter is capped at 5kw AC conversion, so that it is the max amount of DC power it can convert to AC.
  • 4 months later...
I also have a 8kw inverter deye
With this information
Each string should be less than 3250w
How I will manage 2 mppt to have 9720w with 18 solar panels of 540w
