June 17Jun 17 At Solis, we are committed to providing reliable technical support and exceptional after-sales service throughout Africa.Whether you need assistance with troubleshooting, warranty claims, product servicing, or technical guidance, our dedicated local and regional support teams are available to assist you promptly and professionally.For all after-sales and service-related enquiries, please contact our support team at [email protected].Your trusted energy partner, supporting you every step of the way.
Tuesday at 04:303 days I logged a request last year in October for Solis to enable ability to view FreedomWon eTower:Accurate multiple Battery cycles - on App and Web portal - still nothing has been doneBattery packs (number of single module core strings - on App and Web portal - still nothing has been doneNumber of Battery Modules in Series - on App and Web portal - still nothing has been doneKindly assist and attend to this as this needs you to work with FreedomWon R&D team, thank you.
Tuesday at 05:163 days 43 minutes ago, Moffat said:Kindly assist and attend to this as this needs you to work with FreedomWon R&D team, thank you.Hi @Moffat , Solis will not know that you posted this if you do not quote the original poster, or mention a Forum member with an @ tag. Let me do this for you...@Solis Inverters SA - A Client needs your assistance - kindly see above.
Yesterday at 08:491 day On 2026/07/07 at 7:16 PM, HennieL said:Hi @Moffat , Solis will not know that you posted this if you do not quote the original poster, or mention a Forum member with an @ tag. Let me do this for you...@Solis Inverters SA - A Client needs your assistance - kindly see above.Many thanks for the tag @HennieL. Number of cycles keeps going up and down as well. Today it's 10,000 on another day it had come down so clearly there's an issue with accurate comms and or capture of data either by inverter or being sent by the battery FreedomWon eTowers. I've also attached screen shot with circles in RED of area that have no info.I've also closed off personal info so that any update is done, not just for me but for ALL comms between FreedomWon eTower batteries and Solis S6 pro hybrid inverters and I know, not everyone is interested in granular information as much as I am, but it's important to have it. Edited yesterday at 08:571 day by Moffat
Yesterday at 08:521 day 1 minute ago, Moffat said:Many thanks for the tag @HennieLMy pleasure - now let's see how long it takes for Solis to respond - currently 2 full days and counting...
Yesterday at 10:391 day Hello Everyone,The core issue here is not with the Solis inverter hardware or firmware it’s with what data the battery’s BMS actually sends to the inverter via the CAN bus.Why Freedom Won eTower shows limited information:The Freedom Won BMS only transmits a limited set of data points to the Solis basic SoC, voltage, current, charge/discharge limits, etc.Detailed parameters that Moffat is looking for such as individual pack cycles, number of battery modules in series, core strings, and granular per-module data are simply not being reported by the Freedom Won BMS in the CAN messages for the Solis profile.Solis can only display what the BMS sends. If the BMS doesn’t include that data, the app and web portal will show blanks or incorrect values e.g. fluctuating cycle counts.Freedom Won would need to release a BMS firmware update that expands the CAN data set for Solis compatible profiles. This is something they have done in the past for other issues. Kynee batteries for example:Kynee batteries use a more advanced/smart BMS that actively populates all the available fields that Solis supports including detailed cycle information, module counts, etc.Their BMS is better aligned with the richer data protocol that Solis expects, so everything shows up correctly on the Solis Cloud app and portal.Note on other popular brands: Some other popular battery brands also show similar limitations with detailed data on Solis it ultimately comes down to how comprehensive their BMS implementation is.Point is: Solis inverters rely heavily on the battery manufacturer’s BMS to supply rich, accurate data. When the BMS is comprehensive like Kynee, you get excellent visibility. When it’s more limited as with the current Freedom Won eTower, you only see what the BMS provides.Freedom Won has a good track record of resolving these things via remote firmware updates it might be worth tagging them directly or contacting their support to request an expanded Solis CAN profile.Here are a couple of examples of BMS Reporting on the Solis Cloud and you will note the many different and incorrect bms reporting issues this spans over 4 Battery brands on different sites. Some report battery pack count incorrectly others report Battery capacity incorrectly or temperatures incorrectly the point is the Battery BMS dictates what values are reported.
Yesterday at 11:041 day 20 minutes ago, Powerforum Store said:Hello Everyone,The core issue here is not with the Solis inverter hardware or firmware it’s with what data the battery’s BMS actually sends to the inverter via the CAN bus.Why Freedom Won eTower shows limited information:The Freedom Won BMS only transmits a limited set of data points to the Solis basic SoC, voltage, current, charge/discharge limits, etc.Detailed parameters that Moffat is looking for such as individual pack cycles, number of battery modules in series, core strings, and granular per-module data are simply not being reported by the Freedom Won BMS in the CAN messages for the Solis profile.Solis can only display what the BMS sends. If the BMS doesn’t include that data, the app and web portal will show blanks or incorrect values e.g. fluctuating cycle counts.Freedom Won would need to release a BMS firmware update that expands the CAN data set for Solis compatible profiles. This is something they have done in the past for other issues.Kynee batteries for example:Kynee batteries use a more advanced/smart BMS that actively populates all the available fields that Solis supports including detailed cycle information, module counts, etc.Their BMS is better aligned with the richer data protocol that Solis expects, so everything shows up correctly on the Solis Cloud app and portal.Note on other popular brands:Some other popular battery brands also show similar limitations with detailed data on Solis it ultimately comes down to how comprehensive their BMS implementation is.Point is:Solis inverters rely heavily on the battery manufacturer’s BMS to supply rich, accurate data. When the BMS is comprehensive like Kynee, you get excellent visibility.When it’s more limited as with the current Freedom Won eTower, you only see what the BMS provides.Freedom Won has a good track record of resolving these things via remote firmware updates it might be worth tagging them directly or contacting their support to request an expanded Solis CAN profile.Here are a couple of examples of BMS Reporting on the Solis Cloud and you will note the many different and incorrect bms reporting issues this spans over 4 Battery brands on different sites.Some report battery pack count incorrectly others report Battery capacity incorrectly or temperatures incorrectly the point is the Battery BMS dictates what values are reported.My take too. It's not an inverter issue if the BMS does make the info available to it. The comms betwen inverter and BMS is largely dictated by the BMS. @Moffat did you log a ticket with Freedom Won at all? It's where I would start, if I had your issue.
Yesterday at 11:051 day 8 minutes ago, Powerforum Store said:Hello Everyone,The core issue here is not with the Solis inverter hardware or firmware it’s with what data the battery’s BMS actually sends to the inverter via the CAN bus.Why Freedom Won eTower shows limited information:The Freedom Won BMS only transmits a limited set of data points to the Solis basic SoC, voltage, current, charge/discharge limits, etc.Detailed parameters that Moffat is looking for such as individual pack cycles, number of battery modules in series, core strings, and granular per-module data are simply not being reported by the Freedom Won BMS in the CAN messages for the Solis profile.Solis can only display what the BMS sends. If the BMS doesn’t include that data, the app and web portal will show blanks or incorrect values e.g. fluctuating cycle counts.Freedom Won would need to release a BMS firmware update that expands the CAN data set for Solis compatible profiles. This is something they have done in the past for other issues.Kynee batteries for example:Kynee batteries use a more advanced/smart BMS that actively populates all the available fields that Solis supports including detailed cycle information, module counts, etc.Their BMS is better aligned with the richer data protocol that Solis expects, so everything shows up correctly on the Solis Cloud app and portal.Note on other popular brands:Some other popular battery brands also show similar limitations with detailed data on Solis it ultimately comes down to how comprehensive their BMS implementation is.Point is:Solis inverters rely heavily on the battery manufacturer’s BMS to supply rich, accurate data. When the BMS is comprehensive like Kynee, you get excellent visibility.When it’s more limited as with the current Freedom Won eTower, you only see what the BMS provides.Freedom Won has a good track record of resolving these things via remote firmware updates it might be worth tagging them directly or contacting their support to request an expanded Solis CAN profile.Here are a couple of examples of BMS Reporting on the Solis Cloud and you will note the many different and incorrect bms reporting issues this spans over 4 Battery brands on different sites.Some report battery pack count incorrectly others report Battery capacity incorrectly or temperatures incorrectly the point is the Battery BMS dictates what values are reported.@Powerforum Store you are very correct in the information you have shared and I engaged FreedomWon customer care and technicians in this regard and they advised that the whole process of updating the BMS information and it's display would require collaboration between FreedomWon and @Solis Inverters SA . I continually engaged FreedomWon over many months and they in turn blamed Solis team for not their unavailability, now whether that is true or not, I have never been able to verify it hence raising it here that this issue has been outstanding since last year October (2025) when I first raised it including official tickets with FreedomWon, which they kept insisting on closing and eventually went quiet. Previously I was not even able to get the basic information such as:Total Battery capacity (Ah) for more than one module - this was fixedTotal Battery capacity (kWh) - I requested if this could be received on the Solis inverter automatically - this is still done manuallySo the question is whether @Solis Inverters SA got any joy from FreedomWon or not and clearly since this outstanding, it means someone somewhere dropped the ball or thought my request was not important. What FreedomWon sent me was a RS232 cable so I can get information directly off each battery module and information for diagnostic purposes and I even recommended that since that cable is difficult to buy maybe it be sold together with their battery modules.Their distributor was not willing to assist me, in the first instance, as I had bought the battery directly from the @Powerforum Store. My battery had a loom issue and fortunately FreedomWon had a technician travelling to train the distribution personnel and in Zimbabwe and during that time he was able to then resolve my battery issue under warranty, so am very grateful to them for that.I not had any issues with the FreedomWon batteries reliability, to be fair, but I always want to be aware of issues before they escalate or deteriorate, hence having granular information is important, at least to me. Battery sellers and installers (some but not all) are normally interested only in the initial sale and after service is asking for the moon, clearly. So that's my backstory to raising the issue here.
Yesterday at 11:121 day 6 minutes ago, Yellow Measure said:My take too. It's not an inverter issue if the BMS does make the info available to it. The comms betwen inverter and BMS is largely dictated by the BMS.@Moffat did you log a ticket with Freedom Won at all? It's where I would start, if I had your issue.Yes @Yellow Measure I logged the issue and they said they would get in touch with Solis R&D to work on this. This issue is still outstanding. Last comms I did on the matter was in January 2026 with team at Solis Zimbabwe support and it's always a back and forth blame game till eventually I got frustrated and tired. Edited yesterday at 11:151 day by Moffat
Yesterday at 11:561 day I personally don't like it when a manufacturer, supplier or distributor comes onto these forums and post to tell us how great they or their product is and how much they care (biggest lie ever). If they post something like the above then they must be willing to respond to questions being asked on the specific post. They treat it as their own personal advertising board without taking the responsibility. I believe if they post here then the admins of these forums must enforce responsibility rules and remove their "advertisement" posts if they don't respond.I am in the process of upgrading my system to a bigger inverter and battery and I am in the research phase. I remember how Sunsynk ( @Keith Gough @David Drake ) treated their customers and that will affect my decision. I am watching the other guys as well.I see some activity from Solis on the forums lately so why haven't you responded on this post yet, @Solis Inverters SA ?
Yesterday at 12:091 day 52 minutes ago, Moffat said:Yes I logged the issue and they said they would get in touch with Solis R&D to work on this.Great!52 minutes ago, Moffat said:This issue is still outstanding. Last comms I did on the matter was in January 2026 with team at Solis Zimbabwe support and it's always a back and forth blame game till eventually I got frustrated and tired.I think that's where the lines got crossed. You correctly raised the issue with Freedom Won, and you need to hold them accountable for a solution. There can only be one accountable entity, not two. It sounds to me like you believed their excuses and became a ping pong ball.
Yesterday at 01:561 day 1 hour ago, TheMac said:I personally don't like it when a manufacturer, supplier or distributor comes onto these forums and post to tell us how great they or their product is and how much they care (biggest lie ever). If they post something like the above then they must be willing to respond to questions being asked on the specific post. They treat it as their own personal advertising board without taking the responsibility. I believe if they post here then the admins of these forums must enforce responsibility rules and remove their "advertisement" posts if they don't respond.I am in the process of upgrading my system to a bigger inverter and battery and I am in the research phase. I remember how Sunsynk ( @Keith Gough @David Drake ) treated their customers and that will affect my decision. I am watching the other guys as well.I see some activity from Solis on the forums lately so why haven't you responded on this post yet, @Solis Inverters SA ?@TheMac , I fully agree with your sentiments - In my book there are talkers, and there are doers, and unfortunately the businesses that actually DO (care, and respond) are few and far between. I have advised a number of potential buyers to stay away from certain suppliers (brands...), and in doing so have saved a few million Rands from being spent on the wrong brands and suppliers. If companies that advertise on public forums would only perform as well as they advertise, things would be much better for everyone, including financially for those businesses...
21 hours ago21 hr @HennieL I personally did research for my inverter and battery over the course of almost 3-years solid and was really partial and drawn towards the Sunsynk until the reports of inverter issues taking over 6-weeks or longer began to resurface. Granted the huge levels of sales and lack of commensurate growth of their after-sales and support side, may clearly have been the problem, but if one is going to take over 6-weeks plus without a backup option, moreso in the times when loadshedding was at its peak becomes problematic for me and am sure for anyone. On the battery side, I've had an issue with my first purchase via the @Powerforum Store which was no fault of theirs and they were absolutely supportive in linking me up to FreedomWon, who in turn were equally supportive. My only gripe was that their local distributor would not assist me, at all, since I had made a direct purchase. Eventually the battery was fixed, on warranty but being outside of South Africa posed a huge challenge. I also further purchased a second FreedomWon battery and up to date, no issues for both Solis and FreedomWon save for the BMS information issue. Would I recommend both brands, absolutely, but clearly they can do better in respect of missing or incorrect information.
21 hours ago21 hr 7 hours ago, Yellow Measure said:Great!I think that's where the lines got crossed. You correctly raised the issue with Freedom Won, and you need to hold them accountable for a solution. There can only be one accountable entity, not two. It sounds to me like you believed their excuses and became a ping pong ball.@Yellow Measure too true, but what would anyone do who is an ordinary customer when faced with a manufacturer or manufacturers who are the makers of the product?🤔
20 hours ago20 hr 8 hours ago, TheMac said:I personally don't like it when a manufacturer, supplier or distributor comes onto these forums and post to tell us how great they or their product is and how much they care (biggest lie ever). If they post something like the above then they must be willing to respond to questions being asked on the specific post. They treat it as their own personal advertising board without taking the responsibility. I believe if they post here then the admins of these forums must enforce responsibility rules and remove their "advertisement" posts if they don't respond.I am in the process of upgrading my system to a bigger inverter and battery and I am in the research phase. I remember how Sunsynk ( @Keith Gough @David Drake ) treated their customers and that will affect my decision. I am watching the other guys as well.I see some activity from Solis on the forums lately so why haven't you responded on this post yet, @Solis Inverters SA ?Cool @TheMac , how much money have you invested to support the forum? These commercial companies are what keep Powerforum running who do you think pays to make this a free resource for everyone?How long does it take Sunsynk or any other brand to repair a faulty inverter?Short sighted take in my opinion… this is entertainment for some, but real support for others.
18 hours ago18 hr 3 hours ago, Moffat said:@Yellow Measure too true, but what would anyone do who is an ordinary customer when faced with a manufacturer or manufacturers who are the makers of the product?🤔Well, for starters, I think that it's bad form to cast aspersions on Solis support, based on the promises (and hearsay) that Freedom Won gave you, on a public forum. Your issue is with Freedom Won, so why blame Solis?I get it that you are unhappy and desperate, and appear to be willing to blame anyone for the issue, but that does not make it right.
