Pylontech US3000C Firmware
  • Replies 167
  • Views 63.9k
  • Coulomb
    Coulomb
    I had a quick peek, and if anyone cares, it appears to be an ARM little endian processor. Some ascii text in the image. Being a binary blob, I haven't found the proper start address. It's possibly a m
  • PhillipMarx
    PhillipMarx
    I read this on an other forum and just want to share here also. Hi everyone, Below are the latest firmware according to my supplier. I think Jaco above mentioned. us_c_v.7_Crc to be use
  • Their is only one firmware for a battery. The zip file contains firmware for different versions of a battery and batteryview selects the correct firmware. This is because the actual bms was changed du
I sent you an email response. You welcome to remove me from the portal.
This is what my system's CCL and Bulk/Absorbtion looks like. The BMS asks mostly for a charging current above 0 Amps, in my case 250 Amps. The bulk of the time is spent in Bulk mode, no pun here..... On the Pylontech, after Firmware update, it looks like the firmware logic is inverted.... see bottom image.
659693093_Screenshot2021-10-16at09_45_36.thumb.png.9bd0c74881b69f4c9c38be261d74eb4f.png
Inverted logic post red line.
1122042928_Screenshot2021-10-16at09_20_57.thumb.png.8836fb6fc8dfe6d0fe64c2d80298a042.png
It's a pleasure. Sorry, don't know about downgrade capability. You might have to contact Pylontech or a dealer or someone on here may know....
As per the below, the Firmware enabled the Min/Max cell voltages being sent to the GX from the BMS on 2 Oct. This indicates that the cables etc are working as it should. It is clear that the firmware are causing a lot of voltage variability as per the graphs, from 2 Oct.
2113657426_Screenshot2021-10-16at10_23_41.thumb.png.3c479c1e6594d79b2ac8ebdcaebaa9b8.png
On 2021/10/16 at 10:05 AM, Randmental said:
Dankie Sarel,
Do you know if one can downgrade the Firmware?
Not sure if there is actually a version earlier than 3.4 available?
Downgrade is possible. I have done it before. Just use the appropriate firmware file version and load it as per normal.
Thanks - Will try to do that
8 hours ago, Bonny said:
I wanna update my pylontech us3000c anyone with the firmware please
Check the first page of this thread... its there v2.2 for the US3000C
Hi . I am adding new US3000C units to an older system. The newer units have V2.2 on them and the older units have V1.9 on them, Where can I get the the V2.2 or the latest version as the supplier is taking long to supply the latest or answers.
Edited by Jaqibar
Found answer.
Here you are...
On 2021/08/27 at 1:47 PM, Henwilsch said:
New Firmware for US3000C. Version 2.2.
7 minutes ago, Tinbum said:
When updating the firmware, will it do all the units or just the one that your plugged into?
Only the one that you plug into will update. You will have to plug into each module separately.
Thank you, That's a bit of a pain.
Hi Guys, anyone know where to get the latest firmware version?
Got a new US3000c today and it's on 2.4, while my older two are on 2.2.
Would rather they all be at the same FW version :)
On 2021/11/10 at 5:00 PM, Rooney Hat said:
And here we go, 2.4 for US3000c.
No idea what the change log is though.
Hey Rooney,
Any new firmware for the US3000C? I have noticed with v2.4 that BatteryView seems to get disconnected from the pack and reconnects... it is rather strange as i did not experience this with v2.2
Lemme know, thank you.
On 2021/12/22 at 7:48 PM, Venom said:
Hello all, where can I download the latest version of Battery View for the Pylontech batteries?
Check this post for v3.0.24. This is the latest I have.
Edited by PurePower
Updated quote
