Leshen Posted August 31, 2021 Share Posted August 31, 2021 Two x 8kw Sunsynk Hybrid Inverters with 4 x Hubble AM2 with 36 x 535w JA Solar panels. dawolf, WJP, Andre Kruger and 3 others 6 Quote Link to comment Share on other sites More sharing options...
Leshen Posted August 31, 2021 Author Share Posted August 31, 2021 Morne SBR, dawolf, Tim003 and 4 others 7 Quote Link to comment Share on other sites More sharing options...
Yellow Measure Posted August 31, 2021 Share Posted August 31, 2021 Love your work @leshen Quote Link to comment Share on other sites More sharing options...
Leshen Posted August 31, 2021 Author Share Posted August 31, 2021 8 minutes ago, YellowTapemeasure said: Love your work @leshen Thank you. Always appreciate your kind words Quote Link to comment Share on other sites More sharing options...
Yellow Measure Posted August 31, 2021 Share Posted August 31, 2021 That's a great choice of (what I assume to be) your client, 2x 8K Sunsynks and 4x Hubble (looks like Am-2)? Does your client have anything on the roof and if so, what capacity ? Any (anonymised) pics? Quote Link to comment Share on other sites More sharing options...
TimCam Posted August 31, 2021 Share Posted August 31, 2021 So jealous of your customer. Still saving for some Hubble AM-2's Lovely looking install, is he hoping to be off grid completely? Quote Link to comment Share on other sites More sharing options...
Leshen Posted August 31, 2021 Author Share Posted August 31, 2021 2 hours ago, YellowTapemeasure said: That's a great choice of (what I assume to be) your client, 2x 8K Sunsynks and 4x Hubble (looks like Am-2)? Does your client have anything on the roof and if so, what capacity ? Any (anonymised) pics? Yeah 4 x AM2’s and 19260w of PV. 36 x 535w panels. Tim003 and Yellow Measure 2 Quote Link to comment Share on other sites More sharing options...
Leshen Posted August 31, 2021 Author Share Posted August 31, 2021 5 minutes ago, TimCam said: So jealous of your customer. Still saving for some Hubble AM-2's Lovely looking install, is he hoping to be off grid completely? I think he will be as close as possible to being off grid. Each inverter will supply a separate phase of his home. Quote Link to comment Share on other sites More sharing options...
TimCam Posted August 31, 2021 Share Posted August 31, 2021 Very nice view. I see you can squeeze a few more panels in if needed. Lovely tranquil surroundings, hope you got a round or two in while there. Quote Link to comment Share on other sites More sharing options...
Leshen Posted September 1, 2021 Author Share Posted September 1, 2021 6 hours ago, TimCam said: Very nice view. I see you can squeeze a few more panels in if needed. Lovely tranquil surroundings, hope you got a round or two in while there. Just a couple. He has 18 on the East and 18 on the West. We also have the ability to turn his meter back which is great. Quote Link to comment Share on other sites More sharing options...
branderplank Posted September 1, 2021 Share Posted September 1, 2021 Very nice install @Leshen I assume it is then two AM2's per Inverter and both Inverters will have panel from East and West side (as opposed to one being fed only from East and other only from West). What relay are you using for the N/E bond? Thanks Quote Link to comment Share on other sites More sharing options...
Leshen Posted September 1, 2021 Author Share Posted September 1, 2021 2 hours ago, branderplank said: Very nice install @Leshen I assume it is then two AM2's per Inverter and both Inverters will have panel from East and West side (as opposed to one being fed only from East and other only from West). What relay are you using for the N/E bond? Thanks Hi Brander Thank you. Yes 2 x AM2 per inverter and panels as you mentioned. I use an ACDC relay with a backing plate placed into a 4 way DIN rail DB Quote Link to comment Share on other sites More sharing options...
Morne SBR Posted September 1, 2021 Share Posted September 1, 2021 Very nice Quote Link to comment Share on other sites More sharing options...
PowerUser Posted September 2, 2021 Share Posted September 2, 2021 19 hours ago, Leshen said: Hi Brander Thank you. Yes 2 x AM2 per inverter and panels as you mentioned. I use an ACDC relay with a backing plate placed into a 4 way DIN rail DB @Leshen May I ask you what rating relay did you use? Do you have to match it to the inverter output Amps rating for some reason? Quote Link to comment Share on other sites More sharing options...
Leshen Posted September 2, 2021 Author Share Posted September 2, 2021 16 minutes ago, PowerUser said: @Leshen May I ask you what rating relay did you use? Do you have to match it to the inverter output Amps rating for some reason? Hi. We use a 10A/230V relay which is way more than you need. All you are doing is bonding earth to neutral, no load will be going through the relay. PowerUser 1 Quote Link to comment Share on other sites More sharing options...
Gerrie Posted November 8, 2021 Share Posted November 8, 2021 On 2021/08/31 at 8:02 PM, Leshen said: Two x 8kw Sunsynk Hybrid Inverters with 4 x Hubble AM2 How is the communication between the Sunsynk and Hubbles, do you need any other device or is it only the normal comms cable? Quote Link to comment Share on other sites More sharing options...
Gerrie Posted November 8, 2021 Share Posted November 8, 2021 1 minute ago, Gerrie said: How is the communication between the Sunsynk and Hubbles, do you need any other device or is it only the normal comms cable? I saw one of your other installation you used the 5KW Bull with the Sunsynk, do you have a favorite between Hubble and the Bull? Quote Link to comment Share on other sites More sharing options...
TimCam Posted November 8, 2021 Share Posted November 8, 2021 43 minutes ago, Gerrie said: How is the communication between the Sunsynk and Hubbles, do you need any other device or is it only the normal comms cable? SunSynk and Hubble are 100% compatible and work with the CAN cable. Since this post started, I have connected 2x Hubble AM-2's to my own SunSynk 8.8 Kw unit, and couldn't be happier. The load-shedding at the moment has zero effect on my household. Leshen, Yellow Measure, Gerrie and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
