Vision Hybrid Bi-directional inverters
Hi Guys
Have anyone had any experience with vision inverters?
EA3KHD <- Product code, when googled it takes you to eastups website.
Hybrid Bi-Directional Inverter
Hybrid (Bi-direction) Solar Inverter is PV energy combined with energy storage systems. It utilizes solar power, AC utility and
battery power to ensure continuous power supply, and users can store the unused energy produced during the day by PV
system in the battery and use it whenever they need, even at night. It helps increase self-consumption and achieve greater
energy self-suffi ciency.
It is a 3kw 48v hybrid inverter. They are fairly cheap at around R11k ex vat. Does anyone have any comments on them? Seems Vision brings them in and re-brands them.
  • Replies 52
  • Views 16.3k
  • So I got my East/Vision inverter today. Looks and feels solid. Will probably install over the weekend. Will upload pics and post update on how it performs.
  • Hi Hein I got it from Enervision in CPT. What do you think of the ups? So far after reading through the technical data only downside is they cannot be paralleled. It will also switch to comp
  • Ok, I have ordered 2x Vision 3kw 48v inverters. Going to test one out for myself and see how it holds up.
I know of one installer that has tested one of these inverters on an installations and he seemed quite impressed with it.  According to him the inverter does not need batteries and can operate from solar only and a 48v battery bank can be connected to it as well.  It operates very similar to the Infiny inverter and it seems they are in the process of getting the NRS certification..
Hi Hein
What do you think of the ups? So far after reading through the technical data only downside is they cannot be paralleled. It will also switch to completely to bypass when 3kw gets exceeded for too long, which still isn't bad.
That is pretty awesome! I wonder if the Infini's can do this? Does it mean that let's say the load is 10kw, then the inverter will be bypassed and the whole 10kw will be supplied by the grid?
Edited by francois
see specs below.. Doesn't look half bad. I am seriously considering replacing my 2x 5kva Axperts with 1x of these. I rarely exeed 3kw draw. Only reason I have 2x Axperts is for the amount of panels. The vision can handle 4.5kw which will be perfect for me.
MODEL
EA3KHD
Rated power
3000 W
Operating mode
Flexible setup via upper computer software or LCD interface
PV INPUT
Max. input power
4500 W
Rated input voltage
360 Vdc
Max. input voltage
500 Vdc
Start-up voltage
115 Vdc
Initial feeding voltage
150 Vdc
MPPT voltage range
250 Vdc ~ 450 Vdc
Max. input current
18 A
PV short circuit current
18 A
Number of MPPT
1
BATTERIES
Battery type
Lithium battery
Rated voltage
51.2 Vdc
Voltage range
46.4 Vdc ~ 57.6 Vdc
Battery type
VRLAAGM maintenance-free battery
Rated voltage
48 Vdc
Voltage range
40 Vdc ~ 58 Vdc
Battery capacity
100 Ah ~ 120 Ah optimized
Rated charger power
1425 W
Max. charging current
25 A (5 A / 10 A / 15 A / 20 A / 25 A settable)
Charging curve
3-Stage
Max. charging efficiency
94%
Rated discharge power
3000 W
Max. discharge current
100 A
Discharge depth(%)
80% default
Max. discharge efficiency
94%
AC GRID INPUT
AC start-up voltage
120 Vac
Grid voltage range
170 ~ 280 Vac
Rated grid frequency
50 Hz / 60 Hz
Allowed grid frequency
50 ± 5 Hz / 60 ± 5 Hz
AC input power
5100 VA / 5100 W
Max. input current
30 A
AC OUTPUT (connect with load
Rated output power
3000 VA / 3000 W
Rated output voltage
230 Vac(208 / 220 / 240Vac settable)
Rated output current
13.0 A (14.4 A / 13.6 A / 12.5 A)
Output voltage range
184 Vac ~ 264.5 Vac
Rated output frequency
50 Hz / 60 Hz
Output frequency precision
± 1%
Power factor
0.9 leading ~ 0.9 lagging
Output voltage precision
± 1%
Transient recovery time
≤ 40 ms
Peak factor
3 : 1
Linear load waveform distortion
≤ 3%
Short circuit current
45 A (100 ms)
TRANSFER TIME
Off-grid mode → On-grid mode
0 ms
On-grid mode → Off-grid mode
10 ms
EFFICIENCY
MPPT efficiency
99%
Max. PV efficiency
96%
OTHERS
Communications
RS232 / USB / RS485 / SNMP (optional)
Protection rating
IP20
Operating temperature
0 ~ 40℃(> 40℃derating)
Max. relative humidity
0 ~ 90%
Max. altitude
<1000 m (> 1000 m derating)
Cooling
forced ventilation
Alarm
LED, buzzer
Display
LED, LCD
Noise
≤ 50 dB
Topology
Transformerless
Dimensions (W×D×H) (mm)
410×123×470
Packaged dimensions (L×W×H) (mm)
582 ×508 ×183
Net weight (kg)
14.42
Gross weight (kg)
16.40
I also like the DOD on their LLC battery range. I am still waiting on a price on these.
Model Normal Voltage Capacity AH 10H rate Dimensions     L x W x H Weight KG Terminal Type Type Warranty
LLC-300 2 300 125 x 207 x 372 23.4 ΦM8 Lead Carbon 2 Years
LLC-400 2 400 154 x 207 x 372 29.7 ΦM8 Lead Carbon 2 Years
LLC-500 2 500 183 x 207 x 372 35.5 ΦM8 Lead Carbon 2 Years
LLC-600 2 600 212 x 207 x 372 41.5 ΦM8 Lead Carbon 2 Years
LLC-800 2 800 299 x 211 x 372 59 ΦM8 Lead Carbon 2 Years
LLC-1000 2 1000 357 x 211 x 372 71.4 ΦM8 Lead Carbon 2 Years
Hi Francois
As far as I can tell yes. When the load exceeds 9kw (Surge Rating) for too long it will switch to bypass. I will know after next week if it indeed will work like that.
1 minute ago, Johann1982 said:
Hi Francois
Wow if that is the case then no splitting of the DB will be necessary, making the install much easier and cheaper. Please keep us updated.
That was exactly what I was thinking, but I would still not run a stove and oven through one of these. Changes to DB is minimal when only stove & oven gets taken off. There is also a 5kw in the pipeline, just not sure when they will land.
+ 1 on that statement.
On 12/2/2016 at 5:35 PM, Groenkaroo said:
The spec sheet of the Vision matches that of the  Infini 3 kw Plus almost perfectly. If it is reliable it will centainly give most members of Powerforum a new vision. Pitty it can not be paralleled.
Yes, I also noticed that - I think it is just another re-branded infini with some minor changes to the look-and-feel.
I am trying to download the software for the inverter from Eastups website, but seems the FTP server is running on a Telkom dialup connection. Will get a copy from the suppliers on Monday to fine tune. At the moment the batteries are getting priority charge from panels. I would like to set it so that it uses excess power to charge batteries, but hey.. so far so good. At least it is working.
On 12/10/2016 at 2:48 PM, Johann1982 said:
24x 100ah 12v Sonic Gel batteries. I used sisalation to insulate the roof from heat. Batteries are sitting at 22degrees in middle of summer.
Are those 6 parallel strings? :(
Only the first strings of batteries are working. You need a bus bar and all the cables should be the same length. Just a tip on wiring those bats up.
