January 31, 20224 yr Super easy Solarman data logger integration with HA. https://github.com/StephanJoubert/home_assistant_solarman Edit: Just to clarify, I'm not the author. The author is quite active and responds to queries within a day or so. Edited February 2, 20224 yr by dino_coder clarity
February 7, 20224 yr I had my installation done last week, so I am new to solar. My first thought was that the monitoring isn't real-time so I find myself waltzing down to check what is really happening on the inverter all the time. I am not familiar with HA, so I will have to explore that, but sounds like this post is exactly what I'm looking for. Are there any other tools available to interact with the wifi adapter on Deye inverters to get real-time information? Thanks in advance.
February 7, 20224 yr You can't go wrong with installing Solar Assistant which gives per second data viewing https://solar-assistant.io/. MdF
February 7, 20224 yr Thanks @MdF , I'm sure I will try solarman smart at some future point. For now, I installed HomeAssistant and managed to get the module listed above installed. But of a mission, but thrilled to be able to get the real-time values! Thank you @dino_coder !
April 27, 20224 yr I also used this info to get Home Assistant to give me info from the data logger. Now to figure out some automations. Any suggestions welcome..... Thank you
June 27, 20223 yr Hi Gents Hope you or anyone else can assist. I setup she solar-assistant software yesterday and I set everything up and it is working like a charm. It’s on it’s own raspberry PI3B. I then have another raspberry PI4 which is running HA and Node-Red. I managed to find my Deye inverter and all of the settings in HA and I created and entity card with the required settings. I would like to set it up to talk to Node-Red on the RPI4 where my HA install is. So I enabled the MQTT from the Solar-Assistant side however I need assistance with the Node-Red setup in my HA installation. I’m pretty new to Node-red and there isn’t documentation on the solar-assistant website on how to do it. It did say coming soon 😊 though, not sure how long that coming soon has been there.
July 2, 20223 yr On 2022/01/31 at 8:49 AM, dino_coder said: Super easy Solarman data logger integration with HA. https://github.com/StephanJoubert/home_assistant_solarman Edit: Just to clarify, I'm not the author. The author is quite active and responds to queries within a day or so. It seems to pull values from the inverter about once per minute. Do you know if one can set this value shorter?
July 2, 20223 yr On 2022/02/07 at 2:41 PM, MdF said: You can't go wrong with installing Solar Assistant which gives per second data viewing https://solar-assistant.io/. MdF I really love solar assistant. Its my go too! Sincerely Jason
July 5, 20223 yr Author On 2022/07/02 at 9:22 PM, Speedster said: It seems to pull values from the inverter about once per minute. Do you know if one can set this value shorter? I also tried set it to shorter intervals without any luck but I'm ok with updates every minute or so. Perhaps log an issue on the github.
September 29, 20223 yr I kind of stopped my urge to monitor real-time after posting this. The fact that the whole setup just works so damn well left me gob-smacked for a couple of months. The only issue is that I do overload the inverter from time to time, and my installed put a trip in front of it to protect the inverter, so then my lights go out temporarily when geyser+pool+kettle are on. It's a minor issue, everyone in the house are trained and understand how to manage the situation. But, it has been stewing in the old noggin for a while now. I almost went solar-assistant but it looked like I can't do automation with it. But, it has good integration into home-assistant, so there's that...but that would now need two rpi's, getting a bit messy. Anyway, solar-assistant is also not real-time as far as I can determine, it give you the values at the same time the wifi-logger tool is updated, which by default is two minutes. So, if a condition occurs (inverter overload) it can be anything from 1 to 120 seconds before the logger reports it. Anyway, I installed home-assistant os on rpi, and the integration that @dino_coder started this thread with works a charm. I have configure HA to give me the ringing alarm bells when there is overload. Next step is to add automation to switch off geyser in such a case. However, I now need to increase the frequency that logger updates at. From the documentation it seems possible, but I have no idea how to change the parameters for the wifi-logger on the Deye inverter. I'm guessing a lot of you folks do though, please help an uneducated soul... thanks
September 29, 20223 yr If you integrated Solar Assistant into HomeAssistant using mqtt then you SHOULD get 1-2 seconds delay from inverter to HomeAssistant. This is ample to allow you to run automations. If you have your geyser / pool on a CBI astute smart plug then your logic would be: If Inverter load > Xw for longer than T time then switch off Geyser and / or pool This is how i have set it up - this also sends a notification to mine and the wife's phone alias: Max Safe Load description: "" trigger: - type: power platform: device device_id: 117ead9d18839677c42ebf09cb30f4e4 entity_id: sensor.load_power domain: sensor above: 5500 for: hours: 0 minutes: 5 seconds: 0 condition: - condition: device type: is_on device_id: f58645638cce28e4225ceffc4fc2b79d entity_id: switch.geyser_switch_1 domain: switch action: - type: turn_off device_id: f58645638cce28e4225ceffc4fc2b79d entity_id: switch.geyser_switch_1 domain: switch - service: notify.mobile_app_nyasha_a52 data: message: Max safe load reached - Geyser off - service: notify.mobile_app_iphone data: message: Max safe load reached - Geyser off mode: single
September 30, 20223 yr 17 hours ago, mzezman said: If you integrated Solar Assistant into HomeAssistant using mqtt then you SHOULD get 1-2 seconds delay from inverter to HomeAssistant. This is ample to allow you to run automations. If you have your geyser / pool on a CBI astute smart plug then your logic would be: If Inverter load > Xw for longer than T time then switch off Geyser and / or pool This is how i have set it up - this also sends a notification to mine and the wife's phone alias: Max Safe Load description: "" trigger: - type: power platform: device device_id: 117ead9d18839677c42ebf09cb30f4e4 entity_id: sensor.load_power domain: sensor above: 5500 for: hours: 0 minutes: 5 seconds: 0 condition: - condition: device type: is_on device_id: f58645638cce28e4225ceffc4fc2b79d entity_id: switch.geyser_switch_1 domain: switch action: - type: turn_off device_id: f58645638cce28e4225ceffc4fc2b79d entity_id: switch.geyser_switch_1 domain: switch - service: notify.mobile_app_nyasha_a52 data: message: Max safe load reached - Geyser off - service: notify.mobile_app_iphone data: message: Max safe load reached - Geyser off mode: single Thanks for the feedback. I *think* I am getting realtime information from the Solarman integration. I just did the install the way it was described in the docs, don't think it uses mqtt? The issue is that Solarman (the "logger") only collects data every sixty seconds. It can be seen if you go to "device" on Solarman smart. This is the value I want to update. Are you sure yours is real-time? Mine seems that way on occasion but if an event occurs just after the last update, it definitely waits a minute before I see it on HA. It's a lot better than Solarman, but I'd like to reduce that value to ten seconds, that would work for me.
September 30, 20223 yr 2 minutes ago, Naboo said: Thanks for the feedback. I *think* I am getting realtime information from the Solarman integration. I just did the install the way it was described in the docs, don't think it uses mqtt? The issue is that Solarman (the "logger") only collects data every sixty seconds. It can be seen if you go to "device" on Solarman smart. This is the value I want to update. Are you sure yours is real-time? Mine seems that way on occasion but if an event occurs just after the last update, it definitely waits a minute before I see it on HA. It's a lot better than Solarman, but I'd like to reduce that value to ten seconds, that would work for me. Ah ok - so you are using the Solarman integration not the Solar Assistant one - makes sense. SO we are talking across purposes and technologies.
September 30, 20223 yr Having 100% "live" up to the second inverter data is not really possible unless you are querying a very limited number of values. I think that it is important to understand that the software has to ask for each value individually i.e. SOC, Battery Voltage, MPPT Voltage, amperage, wattage etc The age of the data that you will in Home Assistant will dependant on: A- How many values you are asking your inverter the value for B- How you are querying the inverter i.e. using the Solarman Dongle, directly through the 9 Pin interface the dongle plugs into or via the RS485/Modbus interface - that all have different data response rates I am using Home Assistant with Node Red and the Bloubul7 flows, using a USB-RS485 converter and it has a QUERY frequency rate of 0.2 seconds between queries, you can make it faster but it does start to stop dropping data if you reduce the gap between queries too much as you don't give the inverter time to give you the answer before you ask the next question. I am querying a total of 20 items every 0.2 seconds and then I have another 10 values that are queries once a minute (daily solar production etc., values that mostly only increase in value and don't change significantly). So in theory any value should not be older than 4 seconds old. If I remember correctly, queries through the solarman dongle are not able to be done as quickly which results in slightly less responsive data. In the big scheme of things I don't think that would really be a problem.
October 27, 20223 yr Is it possible to run Solarman & SolarAssistant? I'm looking into getting a system, and the installer uses Solarman to view and manage (and support) all their installed sites, which I understand and have no issue with. Though looking around I'd like to get the higher rate info from Solar assistant, and pull that into Home Assistant, for exactly the type of fail-safe automations discussed earlier in this thread. So, is it possible to run both Solarman and SolarAssistant?
October 27, 20223 yr 1 hour ago, Elroc said: Is it possible to run Solarman & SolarAssistant? I'm looking into getting a system, and the installer uses Solarman to view and manage (and support) all their installed sites, which I understand and have no issue with. Though looking around I'd like to get the higher rate info from Solar assistant, and pull that into Home Assistant, for exactly the type of fail-safe automations discussed earlier in this thread. So, is it possible to run both Solarman and SolarAssistant? Yes you can - Solarman dongle connect on the RS232 port while Solar Assistant uses the RS485 port. I have it setup like that on my 5kw Sunsynk. Deye should be the same
January 13, 20233 yr Hi, I have solar panels and a battery from Kstar. I use SolarmanPV, I see all the info via the app and website. I am trying to make the home_assistant_solarman work via HA. I have linked the IP as described in the manual, but I do not receive any data. Is there anyone who can help me on my way? Thanks in advance , Tom
January 16, 20233 yr On 2023/01/13 at 9:54 AM, TomH said: Hi, I have solar panels and a battery from Kstar. I use SolarmanPV, I see all the info via the app and website. I am trying to make the home_assistant_solarman work via HA. I have linked the IP as described in the manual, but I do not receive any data. Is there anyone who can help me on my way? Thanks in advance , Tom th best way is to go intoo the issue section of the github repository (Issues · StephanJoubert/home_assistant_solarman (github.com), I solved my problems following some of the many ongoing dicussions
March 1, 20233 yr On 2022/09/30 at 2:06 PM, Sc00bs said: Having 100% "live" up to the second inverter data is not really possible unless you are querying a very limited number of values. I think that it is important to understand that the software has to ask for each value individually i.e. SOC, Battery Voltage, MPPT Voltage, amperage, wattage etc The age of the data that you will in Home Assistant will dependant on: A- How many values you are asking your inverter the value for B- How you are querying the inverter i.e. using the Solarman Dongle, directly through the 9 Pin interface the dongle plugs into or via the RS485/Modbus interface - that all have different data response rates I am using Home Assistant with Node Red and the Bloubul7 flows, using a USB-RS485 converter and it has a QUERY frequency rate of 0.2 seconds between queries, you can make it faster but it does start to stop dropping data if you reduce the gap between queries too much as you don't give the inverter time to give you the answer before you ask the next question. I am querying a total of 20 items every 0.2 seconds and then I have another 10 values that are queries once a minute (daily solar production etc., values that mostly only increase in value and don't change significantly). So in theory any value should not be older than 4 seconds old. If I remember correctly, queries through the solarman dongle are not able to be done as quickly which results in slightly less responsive data. In the big scheme of things I don't think that would really be a problem. @Sc00bs Are you able to use Home Assistant in this setup to also change your inverter settings? If so I would love to know how you set this up. I have a 5kw Deye which should work the same as your sunsynk curently I have the SOLARMAN WiFi logger running but I have ordered a rs to usb cable from the solar assistant website. I am not able to change the inverter settings without this cable from what I understand thanks for your help
March 2, 20233 yr Hi @Clayton321 Not sure if you can do it via Stephan's integration, I think it will depend on the API for the Sunsynk inverter and to be honest I have no idea if it has that ability. You can however write settings using the ESPHome integration with a ESP32 & Max485 RS485 adapter. Have a look at the end of the thread for the changes so that you can write settings@. @jacauchas a Github with the latest code https://github.com/jacauc/SunsynkEsphome
July 24, 20241 yr Good day, I am new to Home Assistant and want to start off by buying the Home Assistant Green (green like me in this regard). I want to link the Green version to a Deye Inverter with Solarman Smart Dongle. Can this be done with the out of the box Green unit? Regards Edited July 25, 20241 yr by DieSter
