December 20, 20223 yr Author I have installed 2 x ac fans (10cm x 10cm) above my sunsynk inverter. It doesn't go above 60 on hot 2 hours ago, Be4dawn said: Hey guys I noticed now on my app that my inverter Dc Temp is running at around 80 Degrees. Is this normal? inverter was running a big load at the time I checked. AC temp was around 66 Degrees but could not hear any fans running? At What temp wil it be to much for the Inverter? days. I suggest you do the same.
December 20, 20223 yr Ive just put 2 fans at the bottom of the inverter blowing through the fins it helped. Would you say its better to have them on top? Then I assume they have to extract hot air?
December 20, 20223 yr Author 15 minutes ago, Be4dawn said: Ive just put 2 fans at the bottom of the inverter blowing through the fins it helped. Would you say its better to have them on top? Then I assume they have to extract hot air? I'm not sure which is better. I put mine on top extracting because it was easier. Didnt have to try mount the fans at the bottom. Mine just sit directly on top of the heatsink
January 24, 20233 yr Hi Guys, Coming to the party here - I'd like to install some fans on my Sunsynk 5kw inverter and Sunsynk Battery. Thinking of using PC fans fitted with a filter to prevent dust build up. Has anyone done this? Anyone know easiest way to wire the fans?
January 24, 20233 yr 1 hour ago, TheJman said: Hi Guys, Coming to the party here - I'd like to install some fans on my Sunsynk 5kw inverter and Sunsynk Battery. Thinking of using PC fans fitted with a filter to prevent dust build up. Has anyone done this? Anyone know easiest way to wire the fans? the filter will slow the dust build-up but best to keep spare fans around to replace as they will fail at some point... unless you want to start messing around inside the inverter trying to find 12VDC it's easier to just connect to the fans to a 12VDC power supply. I've just recently setup 2 x 92mm PC fans below the heat sink, using a simple 12VDC PSU but I've got the PSU on a smart switch and using Home Assistant to monitor the inverter's radiator temp and turn the fans on/off as needed... Here's a post that started about the benefits of using fans...
January 24, 20233 yr Thanks man - what is powering your 12VDC power supply? Or did you modify an existing power supply to power the fans?
January 25, 20233 yr Author 22 hours ago, TheJman said: Thanks man - what is powering your 12VDC power supply? Or did you modify an existing power supply to power the fans? I setup a DC fan (CPU fan) with my old plug from a ADSL router. its 12v 3A output Edited January 25, 20233 yr by Terminal3k
January 25, 20233 yr On 2022/12/20 at 1:17 PM, Scorp007 said: The newer models don't have a fan for cooling. Only natural cooling. Yep, and they get damn hot. Mine has been up to 78.
January 25, 20233 yr Author Just now, cecilh said: Yep, and they get damn hot. Mine has been up to 78. time to install some fans!
January 25, 20233 yr 7 minutes ago, Terminal3k said: time to install some fans! Yes. But I should not have to do that. Looks like Synsyk is cutting corners Saving R80 on a R25k plus inverter seems pretty short sighted.
January 25, 20233 yr 9 minutes ago, Terminal3k said: time to install some fans! Interesting to know. My Solis grid tied never reaches over about 37 degrees C while it's working close to maximum output.
January 25, 20233 yr Some temps my end - its been VERY hot in Pretoria . I do have a big fan blowing up and a smaller fan at the top pulling hot air
January 27, 20233 yr I see the inverter normal running temperatures are quite high.... Size (W x H x D) - 330 x 310 x 172mm Weight - 11kg Internal Consumption - <1W (Night) Running Temperature - -25°C-65°C Ingress Protection - IP65 Noise Emission - <25dB Cooling Concept - Natural Cooling Max Operating Altitude - 2000m Designed Lifetime - >20 Years Operating Surroundings Humidity - 0-100%
January 27, 20233 yr Author 4 minutes ago, krugerjq said: I see the inverter normal running temperatures are quite high.... Size (W x H x D) - 330 x 310 x 172mm Weight - 11kg Internal Consumption - <1W (Night) Running Temperature - -25°C-65°C Ingress Protection - IP65 Noise Emission - <25dB Cooling Concept - Natural Cooling Max Operating Altitude - 2000m Designed Lifetime - >20 Years Operating Surroundings Humidity - 0-100% mine easily gets over 65 if i dont have my fan on
January 27, 20233 yr you can 3d print this fan housing, attach 2x92mm fans with power supply, and mount to the bottom of the inverter...works very well... https://www.thingiverse.com/thing:5224913
January 31, 20233 yr What's the deal with this picture of Sunsynk 5kW that has a fan: Can find it on a few websites. https://www.arsolar.co.za/product/5kw-sunsynk-invertervat-incl/ Edited January 31, 20233 yr by DrLoLCat
January 31, 20233 yr Author 42 minutes ago, DrLoLCat said: What's the deal with this picture of Sunsynk 5kW that has a fan: Can find it on a few websites. https://www.arsolar.co.za/product/5kw-sunsynk-invertervat-incl/ And now I see my inverter has a hole in the heatsink. Like it has a place for a fan!
June 7, 20242 yr i use a 340mm long cross flow blower at the bottom of mine blowing upwards over the heatsink its on a timer plug its only 35db producing 100cfm
November 9, 20241 yr On 2024/06/07 at 5:16 PM, tristan77 said: i use a 340mm long cross flow blower at the bottom of mine blowing upwards over the heatsink its on a timer plug its only 35db producing 100cfm Hi there. Hope well. Do you have a link for this fan? Sincerely Jason
