CFE-5100 S 5.12kWh Lithium battery wifi connection with CF energy app
  • Replies 211
  • Views 51.2k
  • Hello, I'm calling from Italy, I have a problem with the storage batteries. I have a growatt sfh 5000 inverter and CFE 5100 batteries. The batteries cannot hold the voltage and therefore shut down.
  • hehe me too - i've even offered to re-translate everything for them
  • Its not our inverters. Its the CFE Batteries. How is it possible that we all have the same problem with CFE Batteries but different inveters.
Good day I have a problem that suddenly my 2 batteries are only dischargeing to 23 percent and not to the settings on the inverter i have 8 kw Deye. If it reach to 23percent it give a F56 DC Volt low fault. Anyone that may be have idea what the problem be?
How old are your batteries?
I'm starting to suspect there might be bad batches of CFE / Raystech 5100s in the wild
51 minutes ago, Jeandre Dup said:
It's 4 months old!
Have you checked the values of each battery in the CFE energy app?
Before my problems started, the app was showing 2 very different SoCs for each battery. One wasn't actually charging
8 hours ago, Jeandre Dup said:
Just for interest what was your problem and the solving?
Similar to you, the system ran fine for about 1 month, then during Loadshedding it tripped under load (was about 5kw load, batteries should handle 10kw) with fault code F56.
After that trip, batteries were not charging properly. Tripped again in a 4 hour load shedding slot with 1kw load. And then the batteries dropped from 51% to 1% in the same 4hour load shedding.
SoC according to Smart BESS was very different for each battery (75 vs 35). I checked this after the first trip and notified my installer
Got help from the battery support yesterday to get one of the batteries to charge properly by using AGM V mode (Float 53.6, Absorption 53.8)
I still have a problem with the other battery refusing to charge. So for now, running off just the one.
Edited by MeepMoop
Oops
Thanks for your time! I manege to get the app update one battery is on 50.4 volt soc 28 and the other one is 50.4 volt and soc 22. It give me the same error code ho did you contact to assist you?
Those values seem okay then.
I spoke to my installer, who spoke to Raystech and got a support agent to WhatsApp call me.
See my latest reply here for how we got 1 of them to charge:
Edited by MeepMoop
Added link
2 minutes ago, PieterO said:
@Jeandre DupIt takes some time, but eventually they do help. Just ask that they update your BMS firmware to the latest version. They can do it remotely, but you have to connect the batteries to the SMART BESS app. Also see attached document for setting the comms that might help if you don't have it already
My problem is I can't get the batteries to connect to any of their Apps. I've been added to a WhatsApp group but the communication in that group sucks, very little feedback and absolutely no real drive to find a resolution 😭
@isie  I assume you tried the steps in the Manual?  Also note that you have to switch 5g off on your network...  Also, not sure if you saw this video for android:  https://youtu.be/ehh9mTTp07I. I have IOS and it worked for me.  I will also write on my Technical Support Group stating that we in SA are in urgent need of support on these Batteries....Not sure if it will yield any results...but can only try...
2 of my CFE batteries had low SOH (state of health). the one was 69%, the other 72%. I've removed those and they're being replaced under warranty. The remaining 4 batteries no longer vacillate between 90 and 100% all the time. they consistently sit around 99/100%
so maybe check the SOH of each battery....
Does anyone have any contacts for a CFE installer in JHB? Owen, Ryan etc don’t answer their phones. 4 batteries on two separate inverters still not working after 3 months of endless attempts and my installer is clueless. Desperate for someone who can help locally.
5 hours ago, Marcocam said:
I'm also on IOS but haven't tried to connect battery to an app. Could you post how you got it working?
I have a luxpower 5kva SNA and noticed today I'm having the same issue, battery that is not even a month old. No PV yet but drains to 90% then import from grid to charge. Today I was watching the app. Battery drained to 89% imported from grid for a then stopped importing and still on 89%.https://ibb.co/MhxBxbs
Hi did you follow the YouTube video i posted earlier. I just followed it amd ot worked on IOS. Its seems thats its standard for the batteries to drain down to 89% and then charge back up. The Tech support from china did a BMS update on my batteries and now it goes to 94% and the charge back up when PV is available. Not ideal but better than going down to 89%
@PieterO, yup followed the manual, videos and every apk that they had, but it never connects
Can you not get your installer to assist.? Its critical to connect the batteries to the app as its ehat they use to update the BMS firmware.
Maybe speak to Patrick from Solar Panel Energy in Vanderbijlpark he was the most helpful. They are resellers, but maybe they can assist with a good installer.   I also agree the guys from CNBM Solar are not helpful at all
Yup, installer is also trying on their side. We play the waiting game for now😐
Last thing I would recommend (if you haven't tried already) is to reset the wifi on the batteries before trying again one more time. You can do so by holding down the little square reset button (near the LAN ports) for a few seconds until the run light flickers a few times.
That was the missing step for me when I struggled to add my batteries
@MeepMoopgood point. Thanks. Also get Adeline +86 183 0301 4060 to add you to the Tech support whatsapp group from China. They are slow to respond, but eventually they help. They might see the need for better support if more people harass them
