July 11, 20233 yr 1 hour ago, wael_fathe said: can you guess their function No, sorry. It's between the two sets of 8 MOSFETs, with many parts not populated. It doesn't seem to correspond to anything I know; my guess is that it's something that is specific to VM models. Connecting to a 100 μF capacitor in the main power supply seems weird. Usually those would have DC only. Edit: Oh, wait, it's cut off, looks like that's a 100 Vdc capacitor. Even weirder. Edited July 11, 20233 yr by Coulomb
July 11, 20233 yr 4 hours ago, Coulomb said: No, sorry. It's between the two sets of 8 MOSFETs, with many parts not populated. It doesn't seem to correspond to anything I know; my guess is that it's something that is specific to VM models. Connecting to a 100 μF capacitor in the main power supply seems weird. Usually those would have DC only. Edit: Oh, wait, it's cut off, looks like that's a 100 Vdc capacitor. Even weirder. the problem is that many people in this and other forum report it to be open circuit when there is primary fet short it seems to do n active or partly active role ....but it looks so passive in the edge of the board
July 14, 20233 yr hello colomb ..it is getting interesting here qmax5000 watt i knew the secondery side igbt circuit assumed to be good all fets in primary are out of circuit i decided to short the sg3525 optical copler i did it and i get a nice square wave so sg3525 is good but why the cpu not send on command ,,,,,i tested across the diode side of the copler one pin was tied to 12vdc the bottom one should be dragged down to ground sg35xx to work but i was shocked with 14vdc at the bottom, leg of the diode side of the copler in short. the copler is reverse biased by the cpu board ,, the cpu wait for 30 second then issue 09 error and in this 30 second it never turn on the sg3525 ...i changed the uln2003 driver ic with used one but it is the same no improvment still no square signal can you guide me a bit ,,,,,what else can prevent the cpu .....i even thought that uln2003 have no ground connection reaching but find it grounded should i do factory reset? should i replace un2003 again?..i have 1.5k with same board should i test it with it? should i clean the cpu with solution may be some dirt stuck on legs? i tested the 3.3 5vdc 12+ -12 all good i totally lost
July 15, 20233 yr 15 hours ago, wael_fathe said: but i was shocked with 14vdc at the bottom, leg of the diode side of the copler 14 VDC with respect to what? Perhaps you are measuring with respect to -12V? The opto coupler circuit is very simple. There is no way you should be seeing 14 VDC with respect to earth at CN11-6. Maybe with respect to -12 V, but then the opto or R65 would have to be faulty. Perhaps you are talking about the transistor side of U19? If so, I assume that Vref is about 5 V positive with respect to -12 V, so around -7V with respect to earth. I still can't see how you get 14 V. That 14 V has to be your problem. Have you checked R65 and the diode drop across the opto coupler? I'm guessing about 0.9 to 1.2 V would be normal (with a multimeter, not when conducting hard).
July 15, 20233 yr Author 3 hours ago, Coulomb said: 14 VDC with respect to what? Perhaps you are measuring with respect to -12V? The opto coupler circuit is very simple. There is no way you should be seeing 14 VDC with respect to earth at CN11-6. Maybe with respect to -12 V, but then the opto or R65 would have to be faulty. Perhaps you are talking about the transistor side of U19? If so, I assume that Vref is about 5 V positive with respect to -12 V, so around -7V with respect to earth. I still can't see how you get 14 V. That 14 V has to be your problem. Have you checked R65 and the diode drop across the opto coupler? I'm guessing about 0.9 to 1.2 V would be normal (with a multimeter, not when conducting hard). He mentions an error 09 occuring, so If the DSP performs the bus soft start and if that test fails, then the DSP does not enable the battery mosfets . So I dont think there is a fault around the mosfet drives.
July 15, 20233 yr Author Hi @Coulomb can you comment on this capacitor bank module of the Infini 5kW inverter ? , link below Its been a number of weeks , had a bit of a winter's break , and ready to take the Infini inverter on again. 🙂 As far as my partial schematics of the Infi is concerned , I have very recently discovered that the Infini 10kW service manual has two interesting partial schematics. They are shown below : here is the battery module : and here is the main board : Note that the 10kW is a 3 phase machine hence the 3 half bridges as shown. When I traced my own partial schematics for the 5kW (there exist no service manual on the public internet) I had not been aware of these schematics. They would have certainly helped me to trace easier, but fortunately they are an indication that my trace work did not turn out to be inaccurate at all. Below is my own : there are a number of components not shown in my schematic , eg. I did not trace the mppt , as my only concern is to repair the faulty infini battery module , and not to trace the entire machine. The 10kW machine schematic of the MPPT confirms my original finding that the MPPT is not split supply , as can be seen on the schematic. So my theory remains that the large split capacitor bank module provides us with a split supply for MPPT around the Neutral midpoint. Edited July 15, 20233 yr by BritishRacingGreen
July 16, 20233 yr 15 hours ago, BritishRacingGreen said: Hi @Coulomb can you comment on this capacitor bank module of the Infini 5kW inverter ? Yes, I think you have it correct; they go to a lot of trouble to provide a mid-point for the DC bus, which they can then connect to neutral in a 3-phase inverter, and the neutral can source and sink current, just like the centre point of a star connected transformer. It has the same use with American style split phase systems, where the neutral could also be called upon to source or sink significant power to or from an unbalanced load. There is also the advantage that PV- (which has to connect to BUS-) doesn't have lethal potential with respect to neutral, and hence also earth and puny human bodies. Now something you said back then makes sense now: for the 230 V single phase model, the two outputs are in synch, and are literally paralleled. This is because with a double bus voltage arrangement, each output can go positive or negative with respect to neutral, so there is no need to connect neutral alternately to bus positive and bus negative. They could use a single half-bridge to generate the active output, but they seem to have chosen to use transistors with half the current rating in parallel instead. They get to use the same printed circuit boards for both single phase and split phase models. Another advantage of this arrangement is that there is far less likelihood of weird problems when panels get wet and start leaking to earth. For example, the problem some Axpert users have reported with bus overvoltage faults and residual current breakers tripping. Against these modest advantages a safety advantage that they don't seem to be talking about, there is the expense of double voltage silicon, and a large number of physically large and moderately expensive electrolytic capacitors. This is possibly a major reason that the Infini models are generally considerably more expensive than similarly rated Axperts; the circuits are far more complex, and the components more expensive. I think it makes the Infinis more bulky than the Axperts, too. Edited July 16, 20233 yr by Coulomb
July 16, 20233 yr Author 33 minutes ago, Coulomb said: Yes, I think you have it correct; they go to a lot of trouble to provide a mid-point for the DC bus, which they can then connect to neutral in a 3-phase inverter, and the neutral can source and sink current, just like the centre point of a star connected transformer. It has the same use with American style split phase systems, where the neutral could also be called upon to source or sink significant power to or from an unbalanced load. There is also the advantage that PV- (which has to connect to BUS-) doesn't have lethal potential with respect to neutral, and hence also earth and puny human bodies. Now something you said back then makes sense now: for the 230 V single phase model, the two outputs are in synch, and are literally paralleled. This is because with a double bus voltage arrangement, each output can go positive or negative with respect to neutral, so there is no need to connect neutral alternately to bus positive and bus negative. They could use a single half-bridge to generate the active output, but they seem to have chosen to use transistors with half the current rating in parallel instead. They get to use the same printed circuit boards for both single phase and split phase models. Another advantage of this arrangement is that there is far less likelihood of weird problems when panels get wet and start leaking to earth. For example, the problem some Axpert users have reported with bus overvoltage faults and residual current breakers tripping. Against these modest advantages a safety advantage that they don't seem to be talking about, there is the expense of double voltage silicon, and a large number of physically large and moderately expensive electrolytic capacitors. This is possibly a major reason that the Infini models are generally considerably more expensive than similarly rated Axperts; the circuits are far more complex, and the components more expensive. I think it makes the Infinis more bulky than the Axperts, too. Thank you for a great answer and explanation.
July 17, 20233 yr On 2023/02/02 at 9:40 AM, Coulomb said: I just got the repaired inverter back into position today; there is so much gear packed into the metal case that it's a pig of a job. There is still an hour's work to wire it in. It was late, so I decided I'd just turn on the already-wired inverter that has been running the house on its own for the past week, and blow me down it did the ker-clunk routine. Maybe something got dislodged, but it sure looks like the symptoms that BritishRacingGreen has been running into with the 1000 μF capacitors drying up. I'm wondering if we'll see a even more of a spate of these as these cheap capacitors reach their end of life. Though I have to wonder about the other dozens of electrolytics. Maybe they don't dry out as fast because they don't suffer the same repetitive surge currents that the high frequency power supply capacitors do. At least it had the decency to hold on until the other inverter was repaired. I'll just have one night of utility power, and it was a poor enough solar day that the battery would not have lasted the whole night anyway. I wonder if powering it up causes a bigger surge than running continuously. They dry out simply since it is very hot (to hot) in this area..I've suggested to add a FAN connected to CN12 (?) on top of the mainboard for efficient cooling of the upper left part of the machine. Kind regards, holm
July 17, 20233 yr thanks colomb i solved the problem i took the wrong repair path all the time asking why the cpu not turn the dc to dc the entire inverter seems ok except the primary side fets the cpu refused to turn on because there was fault in secondery caps when i removed all fets and turned on error 9 appear when i removed all igbts and fets error 52 appear and another good thing ,,,cpu tutn the dc to dc for one second this tells me that sg 25xx working cpu boaard ok and some thing else is wrong i test all things nothing bad as last dispaired attempt i changed the caps and fitted new mosfets when i turn the device i was shocked that the device not make arror sound the screen was turned all the way down when i looked at it i saw a 230vac so lets anylise why that happend the device come in for me to repair with good igbts in secondery and tottally destroied mosfets i failed to thing properly it was quite logical to suspect the caps right a way what could blow mosfets if no bad commponent in secondery side shorted since all parts in secondery ok the caps are prime suspect they pulled large current and failed the soft start to work may be they eventually go almost shorted and stressed the dc to dc to blow the mosfets i failed to analyse the failure and lost 5 days looking for trouble that does not exist thanks
July 17, 20233 yr On 2023/07/15 at 8:24 AM, BritishRacingGreen said: He mentions an error 09 occuring, so If the DSP performs the bus soft start and if that test fails, then the DSP does not enable the battery mosfets . So I dont think there is a fault around the mosfet drives. true that what happen i followed the unlogical path .............could colomb give us the checking process order i know the inverer checked for fan first what else it does if we know the order we know how to trouble shoot
July 17, 20233 yr On 2023/07/15 at 4:41 AM, Coulomb said: 14 VDC with respect to what? Perhaps you are measuring with respect to -12V? The opto coupler circuit is very simple. There is no way you should be seeing 14 VDC with respect to earth at CN11-6. Maybe with respect to -12 V, but then the opto or R65 would have to be faulty. Perhaps you are talking about the transistor side of U19? If so, I assume that Vref is about 5 V positive with respect to -12 V, so around -7V with respect to earth. I still can't see how you get 14 V. That 14 V has to be your problem. Have you checked R65 and the diode drop across the opto coupler? I'm guessing about 0.9 to 1.2 V would be normal (with a multimeter, not when conducting hard). thanks for taking the time i actuallly followed the wrong repair path the problem was in soft start and a case of almost shorted cap that alert the cpu to send 09 error with the caps repaired all things work ok
July 18, 20233 yr So it was the two large bus capacitors? They had gone very high leakage, nearly short circuit?
July 18, 20233 yr 13 hours ago, Coulomb said: So it was the two large bus capacitors? They had gone very high leakage, nearly short circuit? they appear ok ,,,as i checked all things and as i removed all fets and igbts still cpu only for a fraction of second does give the fet and active rectifiers signal drive i suspscted the caps fail the cpu test when i replace them the unit work ok but i have small question the newly installed caps are 400 volt ....will they endure the orginal one were rated 500 another question mppt board does charge those caps the man install 6 seiies solar panels around 250 vdc voc what voltage you would expect across the caps once the mppt works and try to charge them i imagine more than 400? as mppt will try and boost the 250 to 400vdc so that h bridge can turn it to 220vac - last queston during the repair i sus[ected one 500 cap is bad insteaad of replacing them i decided to remove the b+ bus wire that connect the mppt board to the inverter board and when i turn on the inverter fried 2 power igbt and boost diode those parts are some what connected to the bus but what they would short like that ?? they are not in switcing state ? they are for mppt and i not connect the inverter to sun or any thing its just 50vdc power supply? Edited July 18, 20233 yr by wael_fathe
July 19, 20233 yr I think it isn't a very bright idea to change the 500V caps against 400V. The command QPIGS from my PIP4048 displays a BUS Voltage of 422Volts currently... Besides of that, those HV caps are almost never..ever bad. Regards, Holm Edited July 19, 20233 yr by holmoe addition
July 19, 20233 yr 8 hours ago, holmoe said: I think it isn't a very bright idea to change the 500V caps against 400V. The command QPIGS from my PIP4048 displays a BUS Voltage of 422Volts currently... Besides of that, those HV caps are almost never..ever bad. Regards, Holm there is no slight doubt thhat they are bad as the moment i changed them the unit works ok the 400 units were just temporary fix thanks but the fact that they not go bad is just according to you own experience
July 20, 20233 yr On 2023/07/19 at 9:05 AM, wael_fathe said: the newly installed caps are 400 volt ....will they endure the original ones were rated 500 I would definitely replace them with at least 450 V rated parts, but 500 V if you can possibly find them. Even though you might only need 425 V now, one day the customer will add extra panels forgetting this repair altogether. On 2023/07/19 at 9:05 AM, wael_fathe said: what voltage you would expect across the caps once the mppt works and try to charge them i imagine more than 400? Yes, the MPPT will try to boost the panel voltage to at least about 380 V, and if the panels are at say 410 V, you'll get very close to 410 V on the bus. A boost converter can't buck even a little bit. On 2023/07/19 at 9:05 AM, wael_fathe said: during the repair i sus[ected one 500 cap is bad insteaad of replacing them i decided to remove the b+ bus wire that connect the mppt board to the inverter board and when i turn on the inverter fried 2 power igbt and boost diode those parts are some what connected to the bus but what they would short like that ?? they are not in switching state ? That's pretty weird. All I can think of is that the MPPT input capacitors retained some charge, and there was enough energy stored in them to destroy the boost transistor and diode when the MPPT connected and there was no load on the MPPT, so nowhere for the inductor energy to go. Also, the DSP would be using its own bus measurement to decide how much boost the MPPT needs, and since it saw no bus voltage rise, it commanded more and more boost.
July 20, 20233 yr That's pretty weird. All I can think of is that the MPPT input capacitors retained some charge, and there was enough energy stored in them to destroy the boost transistor and diode when the MPPT connected and there was no load on the MPPT, so nowhere for the inductor energy to go. Also, the DSP would be using its own bus measurement to decide how much boost the MPPT needs, and since it saw no bus voltage rise, it commanded more and more boost. the soft start circuit does exist on the mppt board conifirmed ...maybe when i seperate the cables there was not enough capacitance to mooth the resulting bus voltage a nd thus that damaged the booost diode and booost transistor igbt>? could be a possibility?
July 20, 20233 yr 13 hours ago, wael_fathe said: there is no slight doubt thhat they are bad as the moment i changed them the unit works ok the 400 units were just temporary fix thanks but the fact that they not go bad is just according to you own experience Yes, that's my own experience..but not only from repairing some inverters, I'm repairing industry-related electronics like VFD for motor control to make a living, that since 2007. Before that I was Unix system programmer and administrator. I only had exactly one (1) bad HV Cap from Siemens-Matsuhita in a large spindle drive of a CNC milling System. So you can have your own opinion, but I have mine. Regards, Holm Edited July 20, 20233 yr by holmoe
July 20, 20233 yr @wael_fate: Check the Gate drivers and their power supplies from the bad Mosfets.Test the drivers and look at their output waveforms before you put any load on them. How this can be done is described in detail in the large Thread at https://forums.aeva.asn.au/viewtopic.php?p=97123 Regards, Holm
July 21, 20233 yr On 2023/07/20 at 5:06 PM, wael_fathe said: the soft start circuit does exist on the mppt board conifirmed Oh. Well that could explain it. If the bus soft start power supply is located on the solar charger, then it will generate high voltage from the battery, and the DSP will stop it when the voltage it measures on the bus is high enough. But if you cut that connection, then it would not know when to stop, and the bus soft start power supply could apply excessive voltage to the solar charger circuit. The voltage would also rise very quickly without the bus capacitors to slow it down. On all models that I'm familiar with, the bus soft start power supply is located on the main board, not the solar charger board. I think that MAX models have two power supplies on a smallish printed circuit that is attached to the solar charger board; one of these may be the bus soft start circuit. Though I can't think why they'd do that.
July 22, 20232 yr On 2023/06/21 at 2:38 AM, Coulomb said: That might be 90VA and almost no real power. I don't know if the Infinis calculate power properly, I assume that they would, since Axperts do. If you're basing the 90 "watts" on utility current measured by a clamp meter, that's almost certainly the case. It might also be powering losses, which get powered by solar during the day. Some oddity of the circuit might cause that to come from utility at night. Nope, no clamp meter of any sorts. I base my statement only on the EmonCMS monitoring graphs that show numerous little ridges at night that disappear during the day. They look a lot like fans running for a short period of time, which corroborates your theory of internal powering losses.
July 29, 20232 yr Author A number of members have already mentioned that their inverters display the value 120V for the battery , some permanently , others at times. Please if you experience this , switch that inverter off and get it fixed. I was on the receiving end today of a catastrophic failure . I have been requested by a member to check out a faulty 5kW Axpert clone inverter that displays the value of 120V for the battery voltage. The inverter raises the error 03 (battery voltage too high) and of course switches off after a number of seconds. I looked forward to this repair as I am a bit tired of igbt/mosfet failures and driver repair , I mean how difficult can this one be ? @Coulomb has made on number of occasion mention of the measurement resistor strings that can and will go open circuit, So that was the first check . But all resistors is fine . I shorted the battery bus and measured 8 Mohm ( 4+4) on the 2 pins going into the DSP board. Fortunately I obtained a second DSP board from someone I know , but the same 120V and error 03. So logic instructed me to verify the 5V , 12V and -12V that feeds into the DSP. And guess what , the -12V read +1.23V ! Oh dear , I check on the -12V linear regulator (7912 type) and measured the same . Removed the 3 pin device , check for load resistance not shorted, and replaced with a new one. Switched on , and the inverter was fine , producing 220VAC from my current limited PSU , no grid , no PV. Voltage reading on display matches the actual 'battery' voltage. This was way too easy , and while I was satisfied with the quick fix , I was worried why a supply line could go faulty like that ? , without a short circuit on its load output . I am so use by now that when I bring up a 5kW Axpert via PSU , the device draw just short of 1A at 52V VDC when it start inverting 220VAC output , no load. And same here , no excess power requirement. So I decided to let the machine burn-in and I kept it on . The 7912 gets warm on its little heat sink , but I recall this as typical. After 20 minutes I was so confident that I posted a nice whatsapp to member with display image , showing his machine in operation. After about an hour I decided to switch off , and back on , just for the good order. Perfect , but after a couple of minutes the machine suddenly died silently , fortunately without an explosion , but the PSU went into hard current limiting mode. Short on the battery bus. 3 x MOSFET short circuit , 5 x IGBT short circuit . some drivers gate resistors blown open circuit Wow !!! Turns out that this -12V supply of ours might not be as mission critical as the 5V and 12V , but it feeds the 3525 PWM controller ic , which in turn drives the mosfets and the battery side igbts. The problem is it does not feed the circuit on its own , but is combined with the 12V in order to affectively provide a 24V supply for the 3525 . This is somewhat nasty in that should the -12V fail with a reasonably low impedance wrt to GND , the 12V rail can still power the 3525 , but at out of spec conditions. I am of the opinion that either the 3525 or its load circuits was failing , causing the -12V to sag . Meanwhile this same -12V is used on the DSP to power one side of the measurement op-amp , this causes a so called high battery voltage , and the DSP fortunately switches off, albeit all for the wrong reason. So the second time this rail failed while the inverter was inverting , it was less forgiving , it destroyed the power mosfets and igbts. Here I am of the opinion that the failure mode of the -12V caused the 3525 to limp with the +12V , but the out of spec pulses to the mosfets was non-deterministic . It turned the mosfets on at the wrong times , or unable to turn them off in good time. Note that if the -12V regulator is already damaged , there will not be catastrophic failure on startup. This is because error 03 will be generated before the DSP enables the 3525 PWM ic. So on face value this looks like a simple fault on the measurement side , but the catastrophic failure is hidden and abstracted from us , until you 'rectify' the 'fault' . Very unforgiving. Repairing of high power Inverters is not for everyone. It can break your spirit at times. Will investigate whether this failure is viable to repair , but that is for another day. Edited July 29, 20232 yr by BritishRacingGreen
July 29, 20232 yr & so the journey continues...Live to fight another day & not all was lost. A failure of a component by another component can lead to something. But yes I agree it must be hard to swallow. Very intriguing read.
July 30, 20232 yr Thanks @BritishRacingGreen, I had exactly the same 120V battery voltage fault on my old 5kVA clone. I think it was caused by running my panels in 3S with 136.6Voc. It would always trigger the error in the evening or early morning when the PV was switching on and off in low light and cold temps, so i figured it was the panels. At the time I was told it was probably my gel batteries because "the plates can bend and short circuit causing high voltages" which turned out to be a load of hogwash causing me to waste another 22k on a new lithium battery. Could high pv voltages cause this failure at all or would that be more likely to fry the mppt board?
