FixAMess Posted April 15, 2020 Share Posted April 15, 2020 (edited) I'm looking for such a cable, does anybody know where I can get one made up in SA? CONSOLE PORT (RJ-11 connector) pylontech battery cable as below, its to talk natively to the US3000 battery BMS. It comes from Yodas post; https://powerforum.co.za/topic/2322-youdas-off-grid-lab/page/2/?tab=comments#comment-53641Here's the wiring: Edited April 15, 2020 by FixAMess Update Quote Link to comment Share on other sites More sharing options...
Jaco De Jongh Posted April 15, 2020 Share Posted April 15, 2020 2 hours ago, FixAMess said: I'm looking for such a cable, does anybody know where I can get one made up in SA? If I can just find my RJ11's I can make you one. Ill let you know soon. Quote Link to comment Share on other sites More sharing options...
FixAMess Posted April 16, 2020 Author Share Posted April 16, 2020 Thank you. I'm stuck in Riyadh and have made one up here, but getting it or me back to SA is going to take months! Quote Link to comment Share on other sites More sharing options...
JacquesVDM Posted April 16, 2020 Share Posted April 16, 2020 A "quick" temporary fix is to file a normal ethernet plug down to 4 contact pins. Just file it from both sides until it fits Quote Link to comment Share on other sites More sharing options...
FixAMess Posted April 17, 2020 Author Share Posted April 17, 2020 14 hours ago, Centurionsolar said: https://centurionsolar.co.za/shop/pylontech-cable/ I have one in stock, and can ship worldwide Thanks , but is the pricing correct, USD vs ZAR? Quote Link to comment Share on other sites More sharing options...
Tsa Posted April 17, 2020 Share Posted April 17, 2020 2 hours ago, FixAMess said: but is the pricing correct WOW! Wonder if you get R2000 off your next Pylontech battery with that! Quote Link to comment Share on other sites More sharing options...
Felipe2020 Posted December 10, 2020 Share Posted December 10, 2020 On 15/4/2020 at 10:11, FixAMess said: Estoy buscando un cable de este tipo, ¿alguien sabe dónde puedo conseguir uno en SA? PUERTO DE CONSOLA (conector RJ-11) cable de batería pylontech como se muestra a continuación, es para hablar de forma nativa con el BMS de la batería US3000. Viene de la publicación de Yodas; https://powerforum.co.za/topic/2322-youdas-off-grid-lab/page/2/?tab=comments#comment-53641 Aquí está el cableado: Hello dear, I am able to manufacture the cable, I have searched many parts but I have not found a clear scheme, a man from South Africa sold me one, but he sold it as a precious stone. Quote Link to comment Share on other sites More sharing options...
cristimv Posted February 24, 2021 Share Posted February 24, 2021 I manufactured one for myself, thanks to the schematics above. For the moment I have only 8 US3000 batteries, but I will add another 4 plus a LV Hub, so I will end up with 2 separate banks of 6 batteries. I assume that there is no solution to monitor all connected banks with one cable, but each bank itself...so either you just move the cable from bank to another, or you have one cable per bank. Correct? Quote Link to comment Share on other sites More sharing options...
Denarius Posted February 25, 2021 Share Posted February 25, 2021 Hi @cristimv It's possible to monitor the entire bank via a single cable into the master battery. I use solar assistant, what stats are you interested in monitoring? Then I can tell you if it's there or not. https://solar-assistant.io/ Quote Link to comment Share on other sites More sharing options...
Jesper Posted March 14, 2021 Share Posted March 14, 2021 On 2021/02/24 at 8:42 AM, cristimv said: I manufactured one for myself, thanks to the schematics above. For the moment I have only 8 US3000 batteries, but I will add another 4 plus a LV Hub, so I will end up with 2 separate banks of 6 batteries. I assume that there is no solution to monitor all connected banks with one cable, but each bank itself...so either you just move the cable from bank to another, or you have one cable per bank. Correct? With US3000C you can now connect up to 16 units in one stack without LV Hub. Quote Link to comment Share on other sites More sharing options...
Niko Posted March 20, 2021 Share Posted March 20, 2021 Hi, I have bought this cable (4P4C) https://a.aliexpress.com/_uvJmCP Do you know if it will work? Quote Link to comment Share on other sites More sharing options...
AndreVr Posted March 21, 2021 Share Posted March 21, 2021 On 2020/04/15 at 4:11 PM, FixAMess said: I'm looking for such a cable, does anybody know where I can get one made up in SA? CONSOLE PORT (RJ-11 connector) pylontech battery cable as below, its to talk natively to the US3000 battery BMS. It comes from Yodas post; https://powerforum.co.za/topic/2322-youdas-off-grid-lab/page/2/?tab=comments#comment-53641Here's the wiring: Quote Link to comment Share on other sites More sharing options...
AndreVr Posted March 21, 2021 Share Posted March 21, 2021 Where are you located? Quote Link to comment Share on other sites More sharing options...
Henwilsch Posted March 21, 2021 Share Posted March 21, 2021 Hi, I use a normal USB-Serial converter. I then made a cable DB9 to RJ11 and used the info in the Pylontech manual to wire. It is working fine on ICC software and Raspberry PI. I just bought a US3000C and the console port is now a RJ45. I just made a new DB9 to RJ45 cable using info in Pylontech manual. That is also working fine. Just remember RS232-TX of the Pylontech goes to RS-232 RX on DB9 and RS232-RX of the Pylontech goes to RS-232 TX on DB9. Quote Link to comment Share on other sites More sharing options...
FixAMess Posted March 21, 2021 Author Share Posted March 21, 2021 I bought a cable in 2020 already, thanks... Quote Link to comment Share on other sites More sharing options...
Wanda Posted April 28, 2022 Share Posted April 28, 2022 On 2021/03/21 at 9:17 AM, Henwilsch said: Hi, I use a normal USB-Serial converter. I then made a cable DB9 to RJ11 and used the info in the Pylontech manual to wire. It is working fine on ICC software and Raspberry PI. I just bought a US3000C and the console port is now a RJ45. I just made a new DB9 to RJ45 cable using info in Pylontech manual. That is also working fine. Just remember RS232-TX of the Pylontech goes to RS-232 RX on DB9 and RS232-RX of the Pylontech goes to RS-232 TX on DB9. Hello. How do I wire the RJ45 to DB9 to connect to the battery console inorder to use battery view Quote Link to comment Share on other sites More sharing options...
Marius2001 Posted July 20, 2022 Share Posted July 20, 2022 Hi guys, I've created a simple version - see below. Let me know if anyone is interested - supports both RJ-11 and RJ-45 connectors. The RJ-45 to RJ-11/45 cable supports both the older and newer Pylontech models. See picture and let me know. Based on Pretoria. Quote Link to comment Share on other sites More sharing options...
AgroVenturesPeru Posted April 4, 2023 Share Posted April 4, 2023 On 2022/07/20 at 2:36 PM, Marius2001 said: Hi guys, I've created a simple version - see below. Let me know if anyone is interested - supports both RJ-11 and RJ-45 connectors. The RJ-45 to RJ-11/45 cable supports both the older and newer Pylontech models. See picture and let me know. Based on Pretoria. Where can I get one of these? Can anyone else confirm if it actually works with batteryview and Pylontech US3000 Quote Link to comment Share on other sites More sharing options...
Chris Louw Posted April 4, 2023 Share Posted April 4, 2023 Made this from cable supplied with inverter, cut off the one end and fitted RJ11. Downloaded Batteryview from this Forum. Quote Link to comment Share on other sites More sharing options...
georgelza Posted September 16, 2023 Share Posted September 16, 2023 i'd like to make RJ45 -> USB I don't have a serial port Anyone know the pin connections, which on RJ45 connect to which on USB. Need to FW update US2000B's and US3000C's G Quote Link to comment Share on other sites More sharing options...
georgelza Posted September 17, 2023 Share Posted September 17, 2023 I'd like to make this with a USB on the computer side fanning out to a rj45 and in parallel a rs11 allowing me to connect to my older US2000 and the new US3000C. have anyone done this ? Can I straight connect or do I need to use a TTL/RS232 board. In which case which ports of the TTL/RS232 do I connect to which pins on the RS11 and RS45? G Quote Link to comment Share on other sites More sharing options...
JKKM Posted September 18, 2023 Share Posted September 18, 2023 Buy one of these from Communica. It caters for both RJ11 and RJ45 console port on the Pylontech BATT RS232-USB CABLE KIT PYL - Communica [Part No: BATT RS232-USB CABLE KIT PYL] Quote Link to comment Share on other sites More sharing options...
georgelza Posted September 18, 2023 Share Posted September 18, 2023 Hmm so now I’m sitting with a RS232 port… how I connect that to Pylontech? Looks like 1/2 of what’s needed? This is probably a 1 x activity for me, I think I have most of the bits needed, USB cables, rj45, just need to get RJ11’s prefer to make. G Quote Link to comment Share on other sites More sharing options...
JKKM Posted September 18, 2023 Share Posted September 18, 2023 The USB is on the one side and the RS232 the other. Then the other half of the RS232 either has a RJ11 or a RJ45 at the other end hence the kit coming with both. You have to connect the RS232 male to the RS232 female to complete the cable -> USB - RS232 - RJ11/RJ45. The firmware update would be a once off but at least you can pull the logs from the batteries with the Battery View software at any stage. Quote Link to comment Share on other sites More sharing options...
georgelza Posted September 18, 2023 Share Posted September 18, 2023 The USB is on the one side and the RS232 the other. Then the other half of the RS232 either has a RJ11 or a RJ45 at the other end hence the kit coming with both. You have to connect the RS232 male to the RS232 female to complete the cable -> USB - RS232 - RJ11/RJ45. The firmware update would be a once off but at least you can pull the logs from the batteries with the Battery View software at any stage. i asked as you gave it that this is all i need, looking at the kit it only does usb to rs232, it does not imply (in writing) anywhere that i can see connectivity bits for either RJ45 or RJ11. if you look at the picture the blue at the top clearly rs232/USB and i'm guessing the black cable is RS232 => RJ** implies I need to buy 2 of these. not happening for a once off fw upgrade. Haven't pulled logs in 4 yrs... can't see it being important enough to justify R750+ G Quote Link to comment Share on other sites More sharing options...
