georgelza Posted August 11, 2023 Share Posted August 11, 2023 (edited) On 2022/04/06 at 10:27 AM, BrettC said: Yes, the Esphome Modbus specs do say an ESP32 is preferred although an ESP8266 should work too. https://esphome.io/components/modbus_controller.html busy trying to flash my esp32 with esp home... keeps on failing, where as the esp8266 (slightly smaller chip) went easily, this is on my MAC, did try on a Windows box also, same issue with esp32. I'd prefer to use the esp8266, it being a bit cheaper... but if it's going to cause problems then I'll have to figure out how to get the esp32 working... ps I did use arduino to flash a simple getchipid onto the esp32 and it worked (from MAC). can add the esp32 shows a red light while connected where as the esp8266 showed a blue. hmm, let me see if i can find a distro of esp home that i can flash using arduino ideas ? G Edited August 11, 2023 by georgelza Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 11, 2023 Share Posted August 11, 2023 On 2022/11/06 at 12:53 PM, system32 said: Grafana 9.2.3 Canvas Visualizations can do a similar thing. https://grafana.com/docs/grafana/next/panels-visualizations/visualizations/canvas/ system32, any chance you're good at Grafana and/or SVG... I got a sensor that measure water level of a water tank, and would love to input a percentage full and have it visually display it in HA, minnyou I'd love to be able to show the same JoJo tank in Grafana and show / water level based on a input %. G Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 12, 2023 Share Posted August 12, 2023 (edited) On 2023/03/02 at 5:15 PM, CorneSchutte said: "My" ESPHome code, which is a combination of others work before me. But I believe the Deye registers are completely different? esphome: name: "sunsynk" preferences: flash_write_interval: 5min esp32: board: esp32dev framework: type: arduino #################################### GLOBALS #################################### substitutions: modbus_update_interval: "3s" settings_skipped_updates: "10" query_throttle: "50ms" device_name: sunsynk friendly_name: SunSynk Link #################################### STATIC SECTION #################################### wifi: ssid: XXXX password: XXX fast_connect: true ota: safe_mode: true reboot_timeout: 10min num_attempts: 5 web_server: port: 80 #captive_portal: # Enable logging #logger: # baud_rate: 0 # Enable Home Assistant API api: # https://esphome.io/components/time.html#home-assistant-time-source time: - platform: homeassistant id: homeassistant_time #################################### STATIC SECTION #################################### uart: id: mod_bus tx_pin: 17 rx_pin: 16 baud_rate: 9600 stop_bits: 1 modbus: id: sunsynk_modbus flow_control_pin: 4 modbus_controller: - id: sunsynk_esphome address: 0x01 modbus_id: sunsynk_modbus setup_priority: -10 update_interval: ${modbus_update_interval} command_throttle: ${query_throttle} switch: - platform: restart name: "${friendly_name} Restart" - platform: modbus_controller # 248 Toggle System Timer use_write_multiple: true modbus_controller_id: sunsynk_esphome name: "Toggle System Timer" id: sunsynk_esphome_toggle_Time_of_Use register_type: holding address: 248 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 274 Toggle Grid Charge Timezone1 use_write_multiple: true modbus_controller_id: sunsynk_esphome name: "Toggle Grid Charge Timezone1" id: sunsynk_esphome_toggle_grid_charge_timezone1 register_type: holding address: 274 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 275 Toggle Grid Charge Timezone2 modbus_controller_id: sunsynk_esphome use_write_multiple: true name: "Toggle Grid Charge Timezone2" id: sunsynk_esphome_toggle_grid_charge_timezone2 register_type: holding address: 275 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 276 Toggle Grid Charge Timezone3 modbus_controller_id: sunsynk_esphome use_write_multiple: true name: "Toggle Grid Charge Timezone3" id: sunsynk_esphome_toggle_grid_charge_timezone3 register_type: holding address: 276 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 277 Toggle Grid Charge Timezone4 modbus_controller_id: sunsynk_esphome use_write_multiple: true name: "Toggle Grid Charge Timezone4" id: sunsynk_esphome_toggle_grid_charge_timezone4 register_type: holding address: 277 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 278 Toggle Grid Charge Timezone5 modbus_controller_id: sunsynk_esphome use_write_multiple: true name: "Toggle Grid Charge Timezone5" id: sunsynk_esphome_toggle_grid_charge_timezone5 register_type: holding address: 278 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" - platform: modbus_controller # 279 Toggle Grid Charge Timezone6 modbus_controller_id: sunsynk_esphome use_write_multiple: true name: "Toggle Grid Charge Timezone6" id: sunsynk_esphome_toggle_grid_charge_timezone6 register_type: holding address: 279 bitmask: 1 entity_category: config icon: "mdi:toggle-switch" number: - platform: modbus_controller # 268 Settings SoC Timezone1 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone1 name: "Set SoC Timezone1" unit_of_measurement: "%" address: 268 min_value: 0 max_value: 100 step: 5 value_type: U_WORD - platform: modbus_controller # 269 Settings SoC Timezone2 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone2 name: "Set SoC Timezone2" unit_of_measurement: "%" address: 269 min_value: 0 max_value: 100 step: 5 value_type: U_WORD - platform: modbus_controller # 270 Settings SoC Timezone3 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone3 name: "Set SoC Timezone3" unit_of_measurement: "%" address: 270 min_value: 0 max_value: 100 step: 5 value_type: U_WORD - platform: modbus_controller # 271 Settings SoC Timezone4 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone4 name: "Set SoC Timezone4" unit_of_measurement: "%" address: 271 min_value: 0 max_value: 100 step: 5 value_type: U_WORD - platform: modbus_controller # 272 Settings SoC Timezone5 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone5 name: "Set SoC Timezone5" unit_of_measurement: "%" address: 272 min_value: 0 max_value: 100 step: 5 value_type: U_WORD - platform: modbus_controller # 273 Settings SoC Timezone6 use_write_multiple: true modbus_controller_id: sunsynk_esphome id: sunsynk_esphome_set_soc_timezone6 name: "Set SoC Timezone6" unit_of_measurement: "%" address: 273 min_value: 0 max_value: 100 step: 5 value_type: U_WORD sensor: - platform: wifi_signal name: WiFi signal ${device_name} id: wifi_s internal: true update_interval: 60s - platform: template name: Wifi ${device_name} unit_of_measurement: '%' accuracy_decimals: 0 icon: "mdi:wifi" lambda: |- if (id(wifi_s).state < -92.0) return 1.0; if (id(wifi_s).state > -21.0) return 100.0; else return round(( -0.0154 * id(wifi_s).state * id(wifi_s).state ) - ( 0.3794 * id(wifi_s).state ) + 98.182 ); update_interval: 60s - platform: uptime filters: - lambda: return x / 3600; unit_of_measurement: hours name: ${device_name} Uptime - platform: modbus_controller #72 Battery Charge Total modbus_controller_id: sunsynk_esphome name: "SS Battery Charge Total" id: sunsynk_esphome_battery_charge_total register_type: holding address: 72 unit_of_measurement: "kWh" accuracy_decimals: 1 device_class: energy state_class: total_increasing filters: - lambda: |- x = x / -1; if (x > 32767) return (0 - x + 65535) /10; else return (0 - x) /10; - platform: modbus_controller #74 Battery Discharge Total modbus_controller_id: sunsynk_esphome name: "SS Battery Discharge Total" id: sunsynk_esphome_battery_discharge_total register_type: holding address: 74 unit_of_measurement: "kWh" accuracy_decimals: 0 device_class: energy state_class: total_increasing filters: - lambda: |- if (x > 32767) return (x - 65535) /10; else return (x) /10; - platform: modbus_controller # 81 Grid Export Total (Sell) modbus_controller_id: sunsynk_esphome name: "SS Grid Export Total (Sell)" id: sunsynk_esphome_grid_export_total_sell register_type: holding address: 81 unit_of_measurement: "kWh" accuracy_decimals: 2 device_class: energy state_class: total_increasing filters: - lambda: |- if (x > 32767) return (x - 65535) / 10; else return x /10; - platform: modbus_controller # 78 Grid Import Total (Buy) modbus_controller_id: sunsynk_esphome name: "SS Grid Import Total (Buy)" id: sunsynk_esphome_grid_import_total_buy register_type: holding address: 78 unit_of_measurement: "kWh" accuracy_decimals: 0 device_class: energy state_class: total_increasing filters: #GOOD - lambda: |- x = x / -1; if (x > 32767) return (0 - x + 65535) /1; else return (0 - x) /1; - platform: modbus_controller # 85 Load Power Total modbus_controller_id: sunsynk_esphome name: "SS Load Power Total" id: sunsynk_esphome_load_power_total register_type: holding address: 85 unit_of_measurement: "kWh" accuracy_decimals: 0 device_class: energy state_class: total_increasing filters: #GOOD - lambda: |- if (x > 32767) return (0 - x + 65535) /1; else return (0 - x) /1; - platform: modbus_controller modbus_controller_id: sunsynk_esphome name: "SS Total PV Power (kWh)" id: sunsynk_esphome_total_pv_power_kwh register_type: holding address: 96 unit_of_measurement: "kWh" accuracy_decimals: 2 device_class: energy state_class: total_increasing filters: - multiply: 0.1 - platform: modbus_controller # 169 Grid Power modbus_controller_id: sunsynk_esphome name: "SS Grid Power" id: sunsynk_esphome_grid_power register_type: holding address: 169 unit_of_measurement: "W" accuracy_decimals: 0 device_class: power state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 178 Load Power modbus_controller_id: sunsynk_esphome name: "SS Load Power" id: sunsynk_esphome_load_power register_type: holding address: 178 unit_of_measurement: "W" accuracy_decimals: 0 device_class: power state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 186 PV1 Power modbus_controller_id: sunsynk_esphome name: "SS PV1 Power" id: sunsynk_esphome_pv1_power register_type: holding address: 186 unit_of_measurement: "W" accuracy_decimals: 2 device_class: power state_class: measurement - platform: modbus_controller # 187 PV2 Power modbus_controller_id: sunsynk_esphome name: "SS PV2 Power" id: sunsynk_esphome_pv2_power register_type: holding address: 187 unit_of_measurement: "W" accuracy_decimals: 2 device_class: power state_class: measurement - platform: template # PV Total Power name: "SS PV Power" id: sunsynk_esphome_pv_power unit_of_measurement: "W" accuracy_decimals: 2 device_class: power state_class: measurement update_interval: 15s lambda: |- return (id(sunsynk_esphome_pv1_power).state + id(sunsynk_esphome_pv2_power).state); - platform: total_daily_energy # PV Daily Energy name: 'SS PV Daily Energy' id: sunsynk_esphome_pv_daily_energy power_id: sunsynk_esphome_pv_power unit_of_measurement: 'kWh' icon: mdi:circle-slice-3 state_class: total_increasing device_class: energy accuracy_decimals: 2 restore: true filters: # Multiplication factor from W to kW is 0.001 - multiply: 0.001 - platform: modbus_controller # 190 Battery Output modbus_controller_id: sunsynk_esphome name: "SS Battery Output Power" id: sunsynk_esphome_battery_output_power register_type: holding address: 190 unit_of_measurement: "W" accuracy_decimals: 2 device_class: power state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 184 Battery SOC modbus_controller_id: sunsynk_esphome name: "SS Battery SOC" id: sunsynk_esphome_battery_soc register_type: holding address: 184 unit_of_measurement: "%" accuracy_decimals: 0 device_class: battery state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 184 Battery Usable SOC modbus_controller_id: sunsynk_esphome name: "SS Battery Usable SOC" id: sunsynk_esphome_battery_usable_soc register_type: holding address: 184 unit_of_measurement: "%" accuracy_decimals: 0 device_class: battery state_class: measurement filters: #GOOD # battery normally charges to 99%, shutdown level is 20%, so subtract 19 from value and calculate as percentage divided by 80 - lambda: |- if (x > 32767) { int y = ((((x - 65535) -19) /80) *100) /1; if (y > 100) return 100; return y; } else { int y = (((x -19) /80) *100) /1; if (y > 100) return 100; return y; } - platform: modbus_controller # 216 Battery Charging Efficiency modbus_controller_id: sunsynk_esphome name: "SS Battery Charging Efficiency" id: sunsynk_esphome_battery_charging_efficiency register_type: holding address: 216 unit_of_measurement: "%" accuracy_decimals: 1 device_class: battery state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /10; else return (x) /10; # - platform: modbus_controller # 013 Firmware Control Board # modbus_controller_id: sunsynk_esphome # name: "SS Firmware Control Board" # id: sunsynk_esphome_firmware_control_board # register_type: holding # address: 13 # - platform: modbus_controller # 013 Firmware Comms Board # modbus_controller_id: sunsynk_esphome # name: "SS Firmware Comms Board" # id: sunsynk_esphome_firmware_comms_board # register_type: holding # address: 14 - platform: modbus_controller # 079 Grid Frequency modbus_controller_id: sunsynk_esphome name: "SS Grid Frequency" id: sunsynk_esphome_grid_frequency register_type: holding address: 79 unit_of_measurement: "hz" accuracy_decimals: 2 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /100; else return (x) /100; #device_class: none state_class: measurement - platform: modbus_controller # 192 Load Frequency modbus_controller_id: sunsynk_esphome name: "SS Load Frequency" id: sunsynk_esphome_load_frequency register_type: holding address: 192 unit_of_measurement: "hz" accuracy_decimals: 2 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /100; else return (x) /100; #device_class: none state_class: measurement - platform: modbus_controller # 154 Grid Inverter Voltage modbus_controller_id: sunsynk_esphome name: "SS Grid Inverter Voltage" id: sunsynk_esphome_grid_inverter_voltage register_type: holding address: 154 unit_of_measurement: "V" accuracy_decimals: 1 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /10; else return (x) /10; device_class: voltage state_class: measurement - platform: modbus_controller # 150 Grid Voltage modbus_controller_id: sunsynk_esphome name: "SS Grid Voltage" id: sunsynk_esphome_grid_voltage register_type: holding address: 150 unit_of_measurement: "V" accuracy_decimals: 1 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /10; else return (x) /10; device_class: voltage state_class: measurement - platform: modbus_controller # 154 Grid Inverter Voltage modbus_controller_id: sunsynk_esphome name: "SS Grid Voltage" id: sunsynk_inverter_grid_voltage register_type: holding address: 154 unit_of_measurement: "V" accuracy_decimals: 1 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /10; else return (x) /10; device_class: voltage state_class: measurement - platform: modbus_controller # 183 Battery Voltage modbus_controller_id: sunsynk_esphome name: "SS Battery Voltage" id: sunsynk_esphome_battery_voltage register_type: holding address: 183 unit_of_measurement: "V" accuracy_decimals: 1 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) / 100; else return x / 100; device_class: voltage state_class: measurement - platform: modbus_controller # 312 Battery Charge Voltage modbus_controller_id: sunsynk_esphome name: "SS Battery Charge Voltage" id: sunsynk_esphome_battery_charge_voltage register_type: holding address: 312 unit_of_measurement: "V" accuracy_decimals: 1 filters: #GOOD - lambda: |- x = x / -1; if (x > 32767) return (0 - x + 65535) /100; else return (0 - x) /100; device_class: voltage state_class: measurement - platform: modbus_controller # 167 Grid Inverter Load modbus_controller_id: sunsynk_esphome name: "SS Grid Inverter Load" id: sunsynk_esphome_grid_inverter_load register_type: holding address: 167 unit_of_measurement: "W" accuracy_decimals: 0 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; device_class: power state_class: measurement - platform: modbus_controller # 172 Grid External Power modbus_controller_id: sunsynk_esphome name: "SS Grid External Power" id: sunsynk_esphome_grid_external_power register_type: holding address: 172 unit_of_measurement: "W" accuracy_decimals: 0 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; device_class: power state_class: measurement - platform: total_daily_energy # Grid External Daily Energy name: 'SS Grid External Daily Energy' id: sunsynk_esphome_grid_external_daily_energy power_id: sunsynk_esphome_grid_external_power unit_of_measurement: 'kWh' icon: mdi:circle-slice-3 state_class: total_increasing device_class: energy accuracy_decimals: 2 restore: true filters: # Multiplication factor from W to kW is 0.001 - multiply: 0.001 - platform: modbus_controller # 166 Aux Output Power modbus_controller_id: sunsynk_esphome name: "SS Aux Output Power" id: sunsynk_esphome_aux_output_power register_type: holding address: 166 unit_of_measurement: "W" accuracy_decimals: 0 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; device_class: power state_class: measurement - platform: modbus_controller # 164 Inverter Output Current modbus_controller_id: sunsynk_esphome name: "SS Inverter Output Current" id: sunsynk_esphome_inverter_output_current register_type: holding address: 191 unit_of_measurement: "A" accuracy_decimals: 1 device_class: current state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (0 - x + 65535) /100; else return (0 - x) /100; - platform: modbus_controller # 191 Battery Output Current modbus_controller_id: sunsynk_esphome name: "SS Battery Output Current" id: sunsynk_esphome_battery_output_current register_type: holding address: 191 unit_of_measurement: "A" accuracy_decimals: 1 device_class: current state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (0 - x + 65535) /100; else return (0 - x) /100; - platform: modbus_controller # 182 Battery Temperature modbus_controller_id: sunsynk_esphome name: "SS Battery Temperature" id: sunsynk_esphome_battery_temperature register_type: holding address: 182 unit_of_measurement: "°C" accuracy_decimals: 1 device_class: temperature state_class: measurement filters: # GOOD - lambda: |- if (x > 32767) return ((x - 65535)-1000) / 10; else return ((x)-1000) / 10; - platform: modbus_controller # 090 DC Transformer Temperature modbus_controller_id: sunsynk_esphome name: "SS DC Transformer Temperature" id: sunsynk_esphome_dctransformer_temperature register_type: holding address: 090 unit_of_measurement: "°C" accuracy_decimals: 1 device_class: temperature state_class: measurement filters: # GOOD - lambda: |- if (x > 32767) return ((x - 65535)-1000) / 10; else return ((x)-1000) / 10; - platform: modbus_controller # 091 Radiator Temperature modbus_controller_id: sunsynk_esphome name: "SS DC Radiator Temperature" id: sunsynk_esphome_radiator_temperature register_type: holding address: 091 unit_of_measurement: "°C" accuracy_decimals: 1 device_class: temperature state_class: measurement filters: # GOOD - lambda: |- if (x > 32767) return ((x - 65535)-1000) / 10; else return ((x)-1000) / 10; - platform: modbus_controller #076 Grid Import Day (Buy) modbus_controller_id: sunsynk_esphome name: "SS Grid Import Day (Buy)" id: sunsynk_esphome_grid_import_day register_type: holding address: 76 unit_of_measurement: "kWh" accuracy_decimals: 0 device_class: energy state_class: total_increasing filters: # GOOD - lambda: |- if (x > 32767) return (x - 65535) / 10; else return x /10; - platform: modbus_controller # 070 Battery Charge Day modbus_controller_id: sunsynk_esphome name: "SS Battery Charge Day" id: sunsynk_esphome_battery_charge_day register_type: holding address: 70 unit_of_measurement: "kWh" accuracy_decimals: 1 device_class: energy state_class: total_increasing filters: #GOOD - lambda: |- x = x / 10; if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 071 Battery Discharge Day modbus_controller_id: sunsynk_esphome name: "SS Battery Discharge Day" id: sunsynk_esphome_battery_discharge_day register_type: holding address: 71 unit_of_measurement: "kWh" accuracy_decimals: 1 device_class: energy state_class: total_increasing filters: #GOOD - lambda: |- x = x / 10; if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 175 Inverter Output Power modbus_controller_id: sunsynk_esphome name: "SS Inverter Output Power" id: sunsynk_esphome_inverter_output_power register_type: holding address: 175 unit_of_measurement: "W" accuracy_decimals: 1 device_class: power filters: #GOOD - lambda: |- if (x > 32767) return (0 - x + 65535) /-1; else return (0 - x) /-1; ################################################ READ SETTINGS ################################################ - platform: modbus_controller # 250 Settings Timezone1 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone1" id: sunsynk_esphome_setting_timezone1 register_type: holding skip_updates: ${settings_skipped_updates} address: 250 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 251 Settings Timezone2 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone2" id: sunsynk_esphome_setting_timezone2 register_type: holding skip_updates: ${settings_skipped_updates} address: 251 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 252 Settings Timezone3 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone3" id: sunsynk_esphome_setting_timezone3 register_type: holding skip_updates: ${settings_skipped_updates} address: 252 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 253 Settings Timezone4 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone4" id: sunsynk_esphome_setting_timezone4 register_type: holding skip_updates: ${settings_skipped_updates} address: 253 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 254 Settings Timezone5 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone5" id: sunsynk_esphome_setting_timezone5 register_type: holding skip_updates: ${settings_skipped_updates} address: 254 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 255 Settings Timezone6 modbus_controller_id: sunsynk_esphome name: "SSS Setting Timezone6" id: sunsynk_esphome_setting_timezone6 register_type: holding skip_updates: ${settings_skipped_updates} address: 255 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 256 Settings Sell Mode Timezone1 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone1" id: sunsynk_esphome_setting_sellmode_timezone1 register_type: holding skip_updates: ${settings_skipped_updates} address: 256 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 257 Settings Sell Mode Timezone2 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone2" id: sunsynk_esphome_setting_sellmode_timezone2 register_type: holding skip_updates: ${settings_skipped_updates} address: 257 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 258 Settings Sell Mode Timezone3 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone3" id: sunsynk_esphome_setting_sellmode_timezone3 register_type: holding skip_updates: ${settings_skipped_updates} address: 258 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 259 Settings Sell Mode Timezone4 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone4" id: sunsynk_esphome_setting_sellmode_timezone4 register_type: holding skip_updates: ${settings_skipped_updates} address: 259 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 260 Settings Sell Mode Timezone5 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone5" id: sunsynk_esphome_setting_sellmode_timezone5 register_type: holding skip_updates: ${settings_skipped_updates} address: 260 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 261 Settings Sell Mode Timezone6 modbus_controller_id: sunsynk_esphome name: "SSS Setting Sell Mode Timezone6" id: sunsynk_esphome_setting_sellmode_timezone6 register_type: holding skip_updates: ${settings_skipped_updates} address: 261 filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 245 Settings Export Limit modbus_controller_id: sunsynk_esphome name: "SSS Setting Export Limit" id: sunsynk_esphome_setting_export_limit register_type: holding skip_updates: ${settings_skipped_updates} address: 245 unit_of_measurement: "W" device_class: power state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 217 Settings Battery Shutdown modbus_controller_id: sunsynk_esphome name: "SSS Setting Battery Shutdown" id: sunsynk_esphome_setting_battery_shutdown register_type: holding skip_updates: ${settings_skipped_updates} address: 217 unit_of_measurement: "%" device_class: battery state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 219 Settings Battery Low modbus_controller_id: sunsynk_esphome name: "SSS Setting Battery Low" id: sunsynk_esphome_setting_battery_low register_type: holding skip_updates: ${settings_skipped_updates} address: 219 unit_of_measurement: "%" device_class: battery state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 218 Settings Battery Restart modbus_controller_id: sunsynk_esphome name: "SSS Setting Battery Restart" id: sunsynk_esphome_setting_battery_restart register_type: holding skip_updates: ${settings_skipped_updates} address: 218 unit_of_measurement: "%" device_class: battery state_class: measurement filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 210 Settings Battery Max Charge Current modbus_controller_id: sunsynk_esphome name: "SSS Setting Battery Max Charge Current" id: sunsynk_esphome_setting_battery_max_charge_current register_type: holding skip_updates: ${settings_skipped_updates} address: 210 device_class: current state_class: measurement unit_of_measurement: "A" filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 211 Settings Battery Max Discharge Current modbus_controller_id: sunsynk_esphome name: "SSS Setting Max Discharge Current" id: sunsynk_esphome_setting_battery_max_discharge_current register_type: holding skip_updates: ${settings_skipped_updates} address: 211 device_class: current state_class: measurement unit_of_measurement: "A" filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: modbus_controller # 230 Settings Grid Charge Current modbus_controller_id: sunsynk_esphome name: "SSS Setting Grid Charge Current" id: sunsynk_esphome_setting_grid_charge_current register_type: holding skip_updates: ${settings_skipped_updates} address: 230 device_class: current state_class: measurement unit_of_measurement: "A" filters: #GOOD - lambda: |- if (x > 32767) return (x - 65535) /1; else return (x) /1; - platform: total_daily_energy name: 'SS Inverter Daily Energy' id: sunsynk_esphome_inverter_daily_energy power_id: sunsynk_esphome_inverter_output_power unit_of_measurement: 'kWh' icon: mdi:circle-slice-3 state_class: total_increasing device_class: energy accuracy_decimals: 2 restore: true filters: # Multiplication factor from W to kW is 0.001 - multiply: 0.001 ############################################### BINARY SENSORS ############################################### binary_sensor: - platform: status name: Status ${device_name} - platform: modbus_controller # 194 Grid Connected Status modbus_controller_id: sunsynk_esphome name: "SS Grid Connected Status" id: sunsynk_esphome_grid_connected_status register_type: holding address: 194 ############################################### BINARY SENSORS SETTINGS ############################################### - platform: modbus_controller # 244 Settings Load Limit Enabled modbus_controller_id: sunsynk_esphome name: "SSS Setting Load Limit Enabled" id: sunsynk_esphome_setting_load_limit2 register_type: holding skip_updates: ${settings_skipped_updates} address: 244 - platform: modbus_controller # 247 Settings Solar Export Enabled modbus_controller_id: sunsynk_esphome name: "SSS Setting Solar Export Enabled" id: sunsynk_esphome_setting_solar_export_enabled register_type: holding skip_updates: ${settings_skipped_updates} address: 247 - platform: modbus_controller # 232 Settings Battery Grid Charge Enabled modbus_controller_id: sunsynk_esphome name: "SSS Setting Battery Grid Charge Enabled" id: sunsynk_esphome_setting_battery_grid_charge_enabled register_type: holding skip_updates: ${settings_skipped_updates} address: 232 ############################################### TEXT SENSORS SETTINGS ############################################### text_sensor: - platform: wifi_info ssid: name: SSID ${device_name} bssid: name: BSSID ${device_name} id: bssid_id - platform: modbus_controller # 243 Settings Energy Management Model (PL) modbus_controller_id: sunsynk_esphome name: "SSS Setting Energy Management Model" id: sunsynk_esphome_setting_energy_management_model register_type: holding skip_updates: ${settings_skipped_updates} raw_encode: HEXBYTES address: 243 lambda: |- uint16_t value = modbus_controller::word_from_hex_str(x, 0); switch (value) { case 0: return std::string("Battery Priority Mode"); case 1: return std::string("Load First Mode"); default: return std::string("Unknown"); } - platform: modbus_controller # 059 Overall State modbus_controller_id: sunsynk_esphome name: "SS Overall State" id: sunsynk_esphome_overall_state register_type: holding skip_updates: ${settings_skipped_updates} raw_encode: HEXBYTES address: 59 lambda: |- # It is not clear what each of these states mean. TODO Fill in the string values once known uint16_t value = modbus_controller::word_from_hex_str(x, 0); switch (value) { case 0: return std::string("0"); case 1: return std::string("1"); case 2: return std::string("2"); case 3: return std::string("3"); case 4: return std::string("4"); case 5: return std::string("5"); default: return std::string("Unknown"); } I hope it helps! Hi Corne. I'm trying to figure things out. eventually got esp home installed on my esp32 using the esphome-web-tool. I'm guessing I need to get the above code onto my esp home now ? do you have matching HA dashboards ? and/or Grafana? I will use Sc00bs esp32 -> RS485 dev board wiring to connect the R485 to the esp32. Please help, never used a esp32 before, nor esphome. PS: inverter is a 5Kw Sunsynk... G Edited August 12, 2023 by georgelza adding information Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 12, 2023 Share Posted August 12, 2023 ... ok I'm slowly working through the 13 odd pages here... I got a esp32 that I've been able to flash with the demo image using https://esphome.github.io/esp-web-tools/ but now i'm lost... discovered you can't load you devices after the flash, it seems you include your devices in the image you flash. Can someone help. have a sunsynk 5.5 Kw inverter that I want to integrate with HA using one of these examples. G Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 12, 2023 Share Posted August 12, 2023 (edited) On 2023/04/18 at 9:00 AM, roadkill said: @system32 @Sc00bs Thanks for confirming, I thought as much. It would be nice to have the added safety of having the geyser on non essential, but i suppose it is not necessary and also the reason i am going for an 8kw instead of the 5kw so i can add more panels at a later stage. hi, so I'm helping a friend n his Sunsynk atm, but I have a Victron, but how I did it... Put my Geysers and stove on the non essential, but they are connected to the db onto a contractor, which then connected to a isolator. I use 4 channel sonoff tasmotized with which In control/ open/close the contacts points. so my load is carried by a contractor, I control them via sonoffs. The sonoffs themself are on my essential circuit so they always powered. with this setup of contractors and sonoffs it allows me to intelligently control my geysers and pool pump via timers in HA or NodeRed flow. G Edited August 12, 2023 by georgelza adding some comments Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 12, 2023 Share Posted August 12, 2023 On 2022/07/14 at 7:46 AM, Farcus said: Excellent work i have my setup all have gone with Pi zero sending Data to HA on pi 4b and all looking really good. Now with the load shedding animal i need to be able to change my charge settings on my Sunsynk Inverter similar to the settings that you can change on Solar Assistant A lot of work that i still need to get going on grafana but i have some graphs working lekker thanks to Scoobs and Bloubul 7 I just need to figure out how i can change these settings on my inverter and if possible have the schedule changed automaticlly with these hectic schedules we have at the moment but for now if i can just change it using Home assistant or Nodered and write back to the inverter Farcus. I'd be keen to know how you did this on a Pi platform, I have some lying around and would love to understand/know, might be easier for me as I know them vs the ESP32 platform/builds. please DM me. G Quote Link to comment Share on other sites More sharing options...
Ivan_E Posted August 12, 2023 Share Posted August 12, 2023 (edited) Hi Folks, Been building the ESP32 and RS485 project up to connect to an inverter (I am UK based). Anyway bought an ESP32 DEV board and this TTL > RS485 board I've wired them up as described and followed the instructions. I can now see the ESP board in Home Assistant fine but when I click on it there is only 1 entity which is "ESPHome Web 137a18 Firmware". I have tried the following: Removed the R7 resistor Tried a second TTL > RS485 board Tried a second network cable Reversed the network cable wires that are in the TTL > RS485 board Remove the plugin fully (Including removing the old directory left) in Home Assistant Flashed the board a few times. Re-seated the RJ45 into the inverter Reheck and re-soldered the wires again When I check the logs I only get a few lines around the setup see the attachment INFO attached ESPHome 2023.7.1.txt (I have hashed out the MAC), there is no data coming from the Inverter other than the output. I am not sure what else I can do. Any help I would be greatful. Regards Ivan INFO ESPHome 2023.7.1.txt Edited August 12, 2023 by Ivan Endicott Quote Link to comment Share on other sites More sharing options...
Muttley Posted August 12, 2023 Share Posted August 12, 2023 29 minutes ago, Ivan Endicott said: Hi Folks, Been building the ESP32 and RS485 project up to connect to an inverter (I am UK based). Anyway bought an ESP32 DEV board and this TTL > RS485 board I've wired them up as described and followed the instructions. I can now see the ESP board in Home Assistant fine but when I click on it there is only 1 entity which is "ESPHome Web 137a18 Firmware". I have tried the following: Removed the R7 resistor Tried a second TTL > RS485 board Tried a second network cable Reversed the network cable wires that are in the TTL > RS485 board Remove the plugin fully (Including removing the old directory left) in Home Assistant Flashed the board a few times. Re-seated the RJ45 into the inverter Reheck and re-soldered the wires again When I check the logs I only get a few lines around the setup see the attachment INFO attached ESPHome 2023.7.1.txt (I have hashed out the MAC), there is no data coming from the Inverter other than the output. I am not sure what else I can do. Any help I would be greatful. Regards Ivan INFO ESPHome 2023.7.1.txt 1.69 kB · 1 download Not sure if this will help but I found that I initially needed to add just the ESP32 to HA with nothing connected it. Once it's added to HA and online, add the rest of the YAML code to it and upload it wirelessly. Once this is done, connect the TTL > RS485 board to the ESP32. Then try connecting it to the inverter. Hope this helps Quote Link to comment Share on other sites More sharing options...
Ivan_E Posted August 12, 2023 Share Posted August 12, 2023 (edited) 15 minutes ago, Muttley said: Not sure if this will help but I found that I initially needed to add just the ESP32 to HA with nothing connected it. Once it's added to HA and online, add the rest of the YAML code to it and upload it wirelessly. Once this is done, connect the TTL > RS485 board to the ESP32. Then try connecting it to the inverter. Hope this helps When you say the rest of the YAML code, which part are you referring to please? Edited August 12, 2023 by Ivan Endicott Quote Link to comment Share on other sites More sharing options...
Muttley Posted August 12, 2023 Share Posted August 12, 2023 1 hour ago, Ivan Endicott said: When you say the rest of the YAML code, which part are you referring to please? I'm not sure what Inverter you have (assuming it's an 8KW Sunsynk as this is where you've posted but this is the code I'm using courtesy of @slip As he is using a Nodemcu, you'll need to change this plus Wi-Fi details etc but everything from the captive portal should be copy and paste esp32: board: esp32dev framework: type: arduino Quote Link to comment Share on other sites More sharing options...
Ivan_E Posted August 12, 2023 Share Posted August 12, 2023 14 minutes ago, Muttley said: I'm not sure what Inverter you have (assuming it's an 8KW Sunsynk as this is where you've posted but this is the code I'm using courtesy of @slip As he is using a Nodemcu, you'll need to change this plus Wi-Fi details etc but everything from the captive portal should be copy and paste esp32: board: esp32dev framework: type: arduino OK so I have the 5.5kW inverter and I have also change the board to the one listed. I have wired it up like the diagram and adjusted the following config based on the PINOUT diagram, I am much closure but not yet across the line. I can see lots of logs coming out the ESP32 unit now which is a step in the right direction. uart: id: mod_bus tx_pin: GPIO17 rx_pin: GPIO16 baud_rate: 9600 stop_bits: 1 modbus: id: sunsynk_modbus flow_control_pin: GPIO4 Quote Link to comment Share on other sites More sharing options...
XianZA Posted August 13, 2023 Share Posted August 13, 2023 Hi thanks for the advice @XAB@XAB it turned out to be exactly this. All the guides say top left port and it even says RS458. I came accros that 2 in 1 port and thought to myself there is no ways as mine is has a dedicated RS458 and its on the top left. Anyway when reading @fStofs post I thought just maybe and the plugged out battery cable and it just worked. sorry I couldn't reply been working. Made myself a 2 in one cable for the time being and have ordered one of those rj45 splitters. Just need to get the rest of the dashboards graphs working as some of the sensors have esphome in them. XAB 1 Quote Link to comment Share on other sites More sharing options...
XianZA Posted August 13, 2023 Share Posted August 13, 2023 (edited) Hi @georgelza Im also new to esp32 but once you do it correctly one time its starts to make sense and become quite simple. I got a blue led on my esp32 when using GPIO2 and GPIO3 trying to troubleshoot.. But the esp32 supposed to be red led when its working. Make sure you using the top middle port marked RS458/CAN. If your battery is in there just unplug it to test. I also struggled the first 2 weeks as the esp did not have full wifi. Post some pics so we can see at which step you stuck at Edited August 13, 2023 by XianZA Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 so some figuring out. esphome web tool will and can work... you just have to press the "boot" button on the esp32 when you click on the install option in the web tool... what makes it more interesting... doing this for a friend, so trying to figure out as much as I can at my house, now to go and install the physical bits at his, allowing me to return to my house to then remotely work on his HA deployment. eventually figure out that I install ESPHome as a add on onto my HA. I then flash the esp32 and tell it to register with the local esphome running on ha. at that point I can add the yaml in esphome running on my HA to then do the sunsynk config. need to relook at various bits of yaml i copied to make sure I copy/past the Sunsynk 5.5 kW yaml and not the 8.5, as they are all over the sight... just keeping track of the things i made notes off. about to pop over to friend, see if i can do the physical on prem bits. will "remove" the R7 resister also, as it seems it's a common across the board best option. G Quote Link to comment Share on other sites More sharing options...
XianZA Posted August 13, 2023 Share Posted August 13, 2023 Hi @georgelzayou getting there. I also looked at all the different code. I never saw a difference between the 8kw and 5kw. Eventually I settled on slipx version as his seems to be the most versatile and upto date. And he has intergrated certain things from other peoples code but most importantly hes got some things in that others dont have. In the end he has a 8kw and I used his code just fine on my 5kw Quote Link to comment Share on other sites More sharing options...
Ivan_E Posted August 13, 2023 Share Posted August 13, 2023 Hi Folks, I am well and truly stuck. I have the the setup by @Sc00bs in his video https://www.youtube.com/watch?v=VxhmD2GAJv4", not sure if I have to fully remove this before I start with the ESP32Dev \ RS485 build? I have the SunSynk 5.5kW inverter plus batteries. I have check the wiring and can confirm I have followed this wiring diagram to the letter. I have installed the drivers from the ESP website and can see the ESP module when I plug it into my Windows PC on serial port 7. In Home Assistant I add the ESPHome add-on and then prepare the ESP module for initial setup where it joins the ESP module to my Wifi network, this is sucessful, I then click on Adopt in ESP add-on plugin. I then remove the module from the USB port and plug it into a USB powersupply. After a few seconds the Add-on in Home Assistant shows as online. I then add the device in Home Assistant under Device and Services. I go back to ESPHome and click edit, to view the YAML that is installed on the board, I then copy in slipx06's code and change the board: esp32dev, I update the encryption key. I also update as the pins I am using are different from the one slipx06 uses. Quote uart: id: mod_bus tx_pin: GPIO17 rx_pin: GPIO16 baud_rate: 9600 stop_bits: 1 modbus: id: sunsynk_modbus flow_control_pin: GPIO4 I also update the fall back SSID \ Password and the OTA password. I then Save and Install the settings and all appears to run through. I start to receive logs but entity values never appear in Home Assistant and they are marked as Unknown. I have download the log Log.txt and noticed there are lots of these [11:07:11][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=81 count=1 [11:07:11][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=84 count=3 and these [11:07:07][D][modbus_controller:032]: Modbus command to device=1 register=0xBE countdown=0 no response received - removed from send queue [11:07:09][D][modbus_controller:032]: Modbus command to device=1 register=0xF3 countdown=0 no response received - removed from send queue Is this normal? I've also noticed when I push the code down it displays a warning about using Pin 4 for flow control, again is this normal? Regards Ivan Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 54 minutes ago, XianZA said: Hi @georgelzayou getting there. I also looked at all the different code. I never saw a difference between the 8kw and 5kw. Eventually I settled on slipx version as his seems to be the most versatile and upto date. And he has intergrated certain things from other peoples code but most importantly hes got some things in that others dont have. In the end he has a 8kw and I used his code just fine on my 5kw pls send me your yaml you pushed onto the esp32, are you running 5.5 or 8.5 kw inverter looking for code for 5.5 G Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 3 hours ago, XianZA said: Hi @georgelzayou getting there. I also looked at all the different code. I never saw a difference between the 8kw and 5kw. Eventually I settled on slipx version as his seems to be the most versatile and upto date. And he has intergrated certain things from other peoples code but most importantly hes got some things in that others dont have. In the end he has a 8kw and I used his code just fine on my 5kw which size inverter you running, looking for the current goto yaml file for the 5.5, and if you have an associated dashboard yaml also... ? G Quote Link to comment Share on other sites More sharing options...
Ivan_E Posted August 13, 2023 Share Posted August 13, 2023 1 hour ago, georgelza said: which size inverter you running, looking for the current goto yaml file for the 5.5, and if you have an associated dashboard yaml also... ? G Hi George, Are you running a sunsynk 5.5 inverter and trying to get the ESP32Dev board and TTL>RS485 board working? I am almost there but I am seeing in the logs Errors like this [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=154 count=1 [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=160 count=1 [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=164 count=1 and [23:46:05][D][modbus_controller:032]: Modbus command to device=1 register=0xA0 countdown=0 no response received - removed from send queue [23:46:06][D][modbus_controller:032]: Modbus command to device=1 register=0xA4 countdown=0 no response received - removed from send queue [23:46:08][D][modbus_controller:032]: Modbus command to device=1 register=0xA6 countdown=0 no response received - removed from send queue Are you by any chance seeing the same? Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 4 hours ago, Ivan Endicott said: Hi Folks, I am well and truly stuck. I have the the setup by @Sc00bs in his video https://www.youtube.com/watch?v=VxhmD2GAJv4", not sure if I have to fully remove this before I start with the ESP32Dev \ RS485 build? I have the SunSynk 5.5kW inverter plus batteries. I have check the wiring and can confirm I have followed this wiring diagram to the letter. I have installed the drivers from the ESP website and can see the ESP module when I plug it into my Windows PC on serial port 7. In Home Assistant I add the ESPHome add-on and then prepare the ESP module for initial setup where it joins the ESP module to my Wifi network, this is sucessful, I then click on Adopt in ESP add-on plugin. I then remove the module from the USB port and plug it into a USB powersupply. After a few seconds the Add-on in Home Assistant shows as online. I then add the device in Home Assistant under Device and Services. I go back to ESPHome and click edit, to view the YAML that is installed on the board, I then copy in slipx06's code and change the board: esp32dev, I update the encryption key. I also update as the pins I am using are different from the one slipx06 uses. I also update the fall back SSID \ Password and the OTA password. I then Save and Install the settings and all appears to run through. I start to receive logs but entity values never appear in Home Assistant and they are marked as Unknown. I have download the log Log.txt and noticed there are lots of these [11:07:11][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=81 count=1 [11:07:11][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=84 count=3 and these [11:07:07][D][modbus_controller:032]: Modbus command to device=1 register=0xBE countdown=0 no response received - removed from send queue [11:07:09][D][modbus_controller:032]: Modbus command to device=1 register=0xF3 countdown=0 no response received - removed from send queue Is this normal? I've also noticed when I push the code down it displays a warning about using Pin 4 for flow control, again is this normal? Regards Ivan mind pointing me to slipx's code... can't recall if his was for a 5.5Kw or 8.5KW inverter. atm my HA running ESPHome on a little Pi3 is crashing when trying to compile/link/install the bits onto the ESP32. what you running your HA on? wish my friend have upgraded his Pi3=>Pi4 by now... G Quote Link to comment Share on other sites More sharing options...
slipx Posted August 13, 2023 Share Posted August 13, 2023 https://github.com/slipx06 georgelza 1 Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 slipx, which is the yaml for the esphome to be compiled/pushed to the esp32. please confirm this is for the Sunsynk 5.5 ? G Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 35 minutes ago, Ivan Endicott said: Hi George, Are you running a sunsynk 5.5 inverter and trying to get the ESP32Dev board and TTL>RS485 board working? I am almost there but I am seeing in the logs Errors like this [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=154 count=1 [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=160 count=1 [23:46:01][W][modbus_controller:113]: Duplicate modbus command found: type=0x3 address=164 count=1 and [23:46:05][D][modbus_controller:032]: Modbus command to device=1 register=0xA0 countdown=0 no response received - removed from send queue [23:46:06][D][modbus_controller:032]: Modbus command to device=1 register=0xA4 countdown=0 no response received - removed from send queue [23:46:08][D][modbus_controller:032]: Modbus command to device=1 register=0xA6 countdown=0 no response received - removed from send queue Are you by any chance seeing the same? you ahead of me... i'm not getting it compiled on the RPi3b G Quote Link to comment Share on other sites More sharing options...
slipx Posted August 13, 2023 Share Posted August 13, 2023 17 minutes ago, georgelza said: slipx, which is the yaml for the esphome to be compiled/pushed to the esp32. please confirm this is for the Sunsynk 5.5 ? G The 8 and 5 use the same registers. https://github.com/slipx06/Sunsynk-Home-Assistant-Dash/blob/main/ESPHome-8K-Sunsynk.yaml georgelza 1 Quote Link to comment Share on other sites More sharing options...
georgelza Posted August 13, 2023 Share Posted August 13, 2023 17 minutes ago, slipx said: The 8 and 5 use the same registers. https://github.com/slipx06/Sunsynk-Home-Assistant-Dash/blob/main/ESPHome-8K-Sunsynk.yaml oh, ok, for some reason through via other threads they did not... ok, then it's onto your git repo G Quote Link to comment Share on other sites More sharing options...
