August 3, 20214 yr Hi Everyone, I am new! I am in Jo’burg and I want to make my life better by investing in some backup and solar power for my house. I have done a bit of research but I now need to get into action. I am planning to install a system according to the following steps: Backup for load shedding and power interruptions: 5kW inverter and 5kWh LiFePO4 Battery with only essential items on the system. Start generating own solar power, gather more information and start to optimise: Add two strings of solar panels in different locations. Move some loads over. Increase storage and panels: Add a 2nd battery, increase PV panels, reduce loads and reduce peak consumption. Move more loads over. Go off grid: Add a 3rd battery, a 2nd Inverter and more panels if required. Off grid!! Final setup expected to be something like: 2x5kW Inverters in parallel, 3x5kWh LiFePO4 batteries, 4 strings of PV with approximately 10kW of panels. The inverters should have own charger, MPPTs, smart load, gen connection, battery interface, WiFi, protection, etc. Batteries should interface with inverter and have own BMS. I have decent roof space but the biggest part of the roof is not facing perfectly North, more like ONO. Other smaller roof sections face NNW or are flat. Some shading on most parts except for the flat part. My idea for where the batteries will fit is somewhat restricting and that influences the physical dimensions of the batteries I can choose from. We are 5 people living/working/studying from home. Current consumption is about 24kWh per day with a rare peak of up to 8.5kW. Big consumers are: Electrical backup for Solar geyser (4kW with Geyserwise mostly required only in winter), Pool pump 0.75kW for many hours, Electrical Oven max 4.2kW, Borehole pump 1.1kW and various other smaller users. All my lights are already LEDs, stove plates are all gas, other geysers are gas, I also have a 2kW generator which I can use in case of poor PV performance or other problems – currently my load shedding backup. I do not have the funds to install everything at the same time but I need backup power asap to allow working and studying from home. To achieve full saving on municipal power I hope to eventually disconnect to have no Service charge or Network charge anymore. I plan to do most of the installation myself and only get in the professionals for final connection/change over and commissioning. Apart from the above solar solution I also plan the following: Reduce peak power use as much as possible by reducing and staggering loads. Install a 3kW PTC geyser element rather than the standard 4kW I have now. Pool blanket to reduce pool pump running hours. Move some consumers to sunshine time to reduce battery need. E.g. pool pump, borehole pump, geyser, Geyser on Smart load (only receives power when battery full and PV power good) or heatpump or more solar collectors or a another solar geyser for winter in series to the current one. Now I have the following questions: Any advice or inputs on the above plans? Any experience with similar setups which can be shared? Looking at my steps and my final setup – do you think it is going to work out? Any other recommendations for optimisation or improvement? Any recommendations on specific equipment? My current favourites are Deye Inverter and Freedom Won batteries. Are there any forum members who would be willing to send me a quote for supply of equipment and/or installation? Are there any forum members with advice on where to get good prices for any of the above components? What are the requirements for such a system? Standards to comply with? What are the approvals I need before I can start with my plan? Thanks in advance – I see there is lots of good advice on this frum and I hope to learn a lot.
August 4, 20214 yr Welcome and thanks for the detailed post makes it very easy to help. Congratulations on being halfway offgrid, since you already have hot water and gas for cooking. That usually takes more than 50% of electricity in a household. My first suggestion is to look at changing your 4kw element to the 1,5kw or 2kw geyserwise ptc elements. Doing that gives you peak loads of exactly 5kw. Which means you might only need one inverter. You are spoiled for choice in 2021 when it comes to hybrid inverters. The powerforum store has the sunsynk 5kw and solis 6kw hybrid inverters at very attractive prices. The choice of inverter will guide the choice of panels that match the mppt requirements(11A vs 13A imp).
August 4, 20214 yr 8 hours ago, Strepies said: My current favourites are Deye Inverter and Freedom Won batteries Your plan/steps taken sounds spot on Great choices, I would get the 8kw machine once off coz if need be for more power (budget depending of cause rather save up) I have the sunsynk version and they work excellent Edited August 4, 20214 yr by Quwatush Shams (Suly)
August 4, 20214 yr Going completely off grid means investing in a lot of expensive batteries for when you have a long stretch of cloudy/rainy days, in Cape Town we have around a R180 service charge per month, I would not consider the expense of going fully off grid. what part of the country do you live in ?
August 4, 20214 yr Looks like allot of thought went into this. Depending on your budget, i would target the reduction of your dependency on eskom first. As much as getting a battery and an invert would cater for load shedding, your consumption is still slightly high. Consider getting few panels, 6 - 8 when installing the inverter and the battery. That way you killing two birds with one stone( catering for load shedding and reducing the monthly cost). Also look into a smaller element for your geyser, belive me, it makes such a huge difference. I just changed mine from 4KW to 2 KW, now my solar production is enough to cater for geyzer and house consumption. 6KWH production maxing at 4KWH. Look into Hubble and Sunsynk, currently using sunsynk and loving it, unfortunately i cant comment on the Hubble but allot of guys have mostly good things to say about it. That should set you back R50K for inverter and battery, then panels 6 x 455W canadian solar should be around R15K then installation and accessories. I built my system over phases, within four months and i feel i wasted money by going the gell batteries and growatt inverter.
August 4, 20214 yr Author 12 hours ago, Tariq said: what part of the country do you live in ? @TariqI am in Johannesburg - I do not blame you for missing that in that long post I wrote....🙃. I am not sure whether we have more or less rainy days in a a row compared to Cape Town - is there a place to find such info? What I do know is that monthly we have a Service charge of R169.29(excl VAT) and a Network Charge of R498.72(excl VAT) plus another "Network Surcharge kWh" which is between R10&R20. With Vat this adds up to R780 per month - just like @87 Dream mentions I definitely want to stop paying that. While connected I will be paying that even if I do not use anything. This is a lot more than what you have in Cape Town @Tariq. This is also in line with what @nightcrawlernic says - once I start spending money on panels I want to end the eskom nightmare fast. @nightcrawlernicFor my "data collection" step I am thinking of putting two small strings of panels in two different locations to get an idea of which location is better. Afterwards I may put them all in the best spot. I am now wondering how much the results will differ between summer and winter even if I test the two locations at the same time. One spot may be good for summer and the other for winter - is there any wisdown out there. Two of the locations will be same angle but one is facing NNW and the other ENE. My geyser is 300liter and I am worried that a PTC element smaller that 3kW will take hours to heat the water - any experience on the forum? I am planning to put my batteries in the back of 4 identical kitchen cupboards of which only the front part is used. I realised that it is only the smaller Freedon Won Lite 5/4 and the Kodak FL5.2 that will fit into these spots. There are other locations which are more exposed to the elements and possibly even a theft concern. With my ;preferred location I am making my life difficult in a few ways: I am limiting myself to more smaller batteries, I am limiting myself to very few manufacturers, and the batteries will be in the back of a wooden kitchen cupboard - Do you think I am foolish to apply these limits to myself? Is there any danger with such a location? (I will add some vents) Thanks so far everyone! I am awaiting any further inputs.....
August 5, 20214 yr @Strepies, boy, I better stop complaining about the Cape aTown municipality, R780 is crazy before you buy your first kWh unit😅 Edited August 5, 20214 yr by Tariq
August 5, 20214 yr Good morning. 1. what Equipment. Inverter DEYE 5kw x 2 Battery Lithium batteries SA 5,1kw X4 Solar panels as big as you can afford. 2. Start off by purchasing 1 inverter and 1 battery total cost around R40k, Install this properly on your essentials, 3. Purchase enough panels to fill up one MPPT on the Deye. 3500watt 4. Purchase enough Panels to fill up the second MPPT on the Deye. 3500watt 5. Save and purchase your second Deye and second battery. 6. follow steps 3 and 4 7. Purchase more batteries. Switch eskom off. If you have a borehole get yourself a tank as well as a proper filter system and pressure pump and reduce your water usage as well.
August 5, 20214 yr look at Sunsynk versus Deye, much better interface and the ceo ( Keith Gough ) is much more involved with clients and pus on a lot of training videos on YouTube, the cost is only a few hundred rand more.
August 5, 20214 yr You don't need rainy days to reduce your system's output, just overcast days. We had a long spell of overcast or partly overcast days in Jhb earlier this year. This is why it's expensive to go completely off grid - you need to have a lot of stored power or some other source of power to see you through such spells. If your provider is City Power, I recommend using a hybrid system and converting to pre-paid. I will go into some detail about this later, but there's no fixed charges on a pre-paid connection (so far, for 3 years now they have considered a R200 per month connection fee). So buy some units each month to stop the municipality snooping around - which they have done to me. The logic is this: If the weather is gloomy, or you have some unusually high loads, then you can draw from the grid as long as you have a credit on your meter. I don't know what the threshold is at which City Power decide to come and see if you have bypassed your meter, but start off with something like 200 units every 3rd month and see how that goes. Remember that once the units are loaded on your meter they don't expire, they stay there. I have about 4 years credit (at current consumption) on my meter. All that said, first find out what it's going to cost to convert to pre-paid. It is not free, and prepaid users pay more per kw/h than post paid users do. But because the fixed charges for a post-paid connection are in excess of R700 per month you will soon make the money back. Also it will be costly for a couple of months because you will be paying off the post-paid account AND feeding the meter. This happened to me for 2 months, then on the 3rd month I got a credit on my account. The installer will read your meter at cut over time, and the meter will come loaded with a few kw/h so that you are not plunged into immediate darkness. Buying units is pretty easy - I buy them using the banking app on my phone, but there are many options (including supermarkets). A hybrid system will use a little grid power each day because it has to constantly synchronise with the grid - same voltage, same frequency. In weather like we are having lately I use 0.8 to 0.9 kw/h per day. BUT when the grid is down most of my house keeps on running off of the batteries and solar. If it's gloomy and we have load shedding I can charge my batteries from the grid ahead of the shedding. Or you can buy a decent generator that your inverter can control. Then you can be truly off grid, but you will have costs for fuel and servicing. PS: I have 6 panels facing north and 6 facing east. My peak production time is about 11:30, with the east facing panels kicking in early and then producing useful output until about 15:00.
August 5, 20214 yr Author @87 DreamNow I thought of something else - I assume if we talk about North for the sun we are talking about True or Geographic North. And a compass reads Magnetic North. I assume my Samsung also reads Magnetic North. I checked my magnetic declination here https://www.magnetic-declination.com/ and found that it is -19° 16' at the moment so I have to apply a correction as follows to confirm exactly which geographic direction my roof is facing. Not that I can change it 🤪
August 6, 20214 yr For the Sun, you have to follow True North. Usually, there is a setting in your phone compass to show True North instead of Magnetic North.
September 1, 20214 yr Author Hi Everyone, I thought I should let you know that I took the first step in my plan..... I am now owner (and operator) of a Deye 5kW inverter and a Freedom Won Lite 5/4. I did the installation myself with the intent of getting a professional in to do the final checks and commissioning. Then there was the threat of possible load shedding and I thought it was going to affect us so I started things up making double sure about everything I did and checking things many times. Everything went well with no trips, surprises or any smoke coming out. My system has now been running for 14 days and as things go we have not even had one power interruption. Is it wrong of me to hope for one? Here and there there are a few things which I suspect I can improve but I will first try and study previous posts and if required post where more appropriate. Thanks for all the inputs - I will be tapping your brains some more in the near future.
