New Axpert model from Voltronic?
If Pi3 has WiFi then I guess I will be ok. thanks guys.
Now busy trying to find out if my warranty will be ok if I will paint the shell on a new Infini V.
JDP, when can I buy the Pi application for Infini V from you?
  • Replies 65
  • Views 18.4k
  • Jaco De Jongh
    Jaco De Jongh
    Hi virge, it might be the V-series that I have. It's like 90‰ Axpert, with some grid tie futures from the infini. Not as advanced as the infini bit does a pretty good job when it comes to mixing p
  • Jaco De Jongh
    Jaco De Jongh
    Not crappy at all, maybe you misunderstood me, unless some other Jaco thinks it is a crappy inverter. I would recommend this inverter over and over again, yes the grid feedback can be set to zero, I w
  • Yes, I've just configured mine to use PV, then grid for the rest, no battery while PV and grid is available.  So say 2.5KW from PV and the rest from the grid, depending on your current load requiremen
1 hour ago, viper_za said:
Also looks good when showing off the system
Aaaa there we go lol :P
Should be there in the next month or so.
But there are some issues with the V series. It does not switch correctly.
That is why we have not yet ported it. we are hoping for new firmware but Voltronics said their is non. Maybe @Jaco de Jongh can give some more info ion the matter.
JDP, test was done incorrectly, we were switching the wrong setting, and monitored for the wrong expected result, we expected the same result as with the axpert and forgot that the gridtie would react differently. When retesting after I figured out what to switch and what result we had to look for, it was working fine. When things quite down a bit, me and @Manie will retest from the app. Will give you feedback.
OK cool. So making progress then.
Hello JDP, where did you buy the 3A PSU for Pi from?
Busy downloading raspbian for it. I will get the SD card from Makro tomorrow.
Just a note. Manie and I are working on a huge project. We are not going to move the Infini V code this year. Sorry.
  • 7 months later...
  • 1 year later...
I also have the v series and think its the best thing since chappies
 you can have the grid tie function on or off
I run mine in what I believe is called self  consumption mode meaning ie  it subsidises the solar with Eskom  or whatever solar cannot supply it takes  Eskom for the rest
my  main reason for buying this unit was not to cycle the batteries
today  at 12 I see    10 -40 w at the supply to the  inverter, this fluctuates as the load /sun does  esp cloudy days
im not sure but this could be importing or exporting  as the load/sun fluctuates
my concern is that my prepaid meter doesn't really care (Hexing type ) but I have heard of others that do and will only accept 40 w before tripping
@plonkster wrote this on another thread
BEC23 is 40W over a 15 second window. BEC44 is less, though I cannot remember if it's the wattage or the window size.
generally the Db is split and my thinking is such that if  a small amount is exported from solar side  then it will be absorbed by the Eskom side split   instead of going to the meter / grid as a buffer so to speak ( usually something is drawing some powersowhere)
 just a heads up
cheers Max
As I understand this one does not have the NRS certification that its bigger Infini brother has (not even the 2010 level), and another forum member queried about it and apparently it doesn't comply and never will.
