Deye Inverter Latest Firmware
Deye SUN-5K-SG03LP1-EU
HMI: Ver 0000-C361
MAIN: Ver 0-3384-151
Sadly, the 15kHz noise is still there. There are a few new settings under the Battery section, something along the lines of "Quite Mode" is what you are looking for, to change it from 15kHz to 20Khz.
Update file and manual, to update from 3382 to 3384 only for the specified inverter model. Some updates require an additional LCD update, so if you run a version older than 3382, i do not suggest you to update. https://workupload.com/file/M4WMQxJSjQd
Edited by Oberfail
  • Replies 111
  • Views 110k
  • power.esrl3
    power.esrl3
    So sad to see these kind of topics due to lack of documentation from the manufacturer. We're playing numbers and shooting aimless here without the changelog.
  • SmittySmit
    SmittySmit
    That distributor had no clue whatsoever with his statement of "it's just a change in version numbers". People really should make sure they know what they are talking about before spreading nonsense li
  • Speedster
    Speedster
    8 kW. Version numbers as in the OP
HMI: Ver 0000-C361
I hope uploading firmware files become a norm in this thread and as detailed as this.
Thank you for posting this.
HMI: Ver 0000-C361
Could you drop me a DM regarding that 15KHz noise you have man?
Also  can confirm I still have it.
Hi All
I have upgraded to the latest firmware that Deye support sent me for my Deye 8KW inverter.
Since the upgrade I have had a lot of issues. The inverter does not behave like it should.
If I set it to prioritize the batteries, it does not do it.
When I set the Grid to charge the batteries, it still does not do it.
Is there anyone with the same issue? Can you downgrade firmware? If so, does anyone have working firmware to upload for this model?
Current Firmware:
HMI: 0000-C362
Main: 0-6022-0717
8060B7E4-9695-4314-B359-4C6582B0ACF8Large.thumb.jpeg.7472eeb4349d15ac244e1c651f734067.jpegA12598B0-70F7-4A0C-BD1F-524BABF9B0E2Large.thumb.jpeg.2506d1becbbd5196842c263a5fe5d147.jpegB9A8FB7A-A9BD-436F-8EFF-4E5C633DE08ALarge.thumb.jpeg.b70455f7837ed333f6b71f10b9b50bbe.jpeg
07B88885-9005-4B50-9191-8ACAB6FB7301Large.thumb.jpeg.5a933540ff6185027326b29b64414cc7.jpeg
On 2023/02/20 at 4:02 PM, SmittySmit said:
Model: Deye 8 kW single phase
Date: 14 February 2023:
Version Information
Protocol Version:V0.2.0.1
HMI:VC.3.5.D
MAIN_1:V6.0.2.2
MAIN_2:V0.7.1.7
Changes:
Interface now says Off Grid instead of a red x when there is load shedding.
Hi Smitty
Is there a link for the firmware files, or did Deye do the upgrade remotely?
DEYE 16Kw,
Was delivered in April 2023 with
HMI: Ver 0000-C35A Main: Ver 0-9014-1725
Requested an update as I was having a few generator issues.
Updated to what I assume is the latest
HMI: Ver 0000-C362 Main: Ver 0-9022-1725
Main differences from a menu side seem to be around the grid power settings available.
On 2023/04/16 at 12:13 PM, m0skva said:
Hi All
Current Firmware:
HMI: 0000-C362
Main: 0-6022-0717
Why are you asking technical support questions about battery charging problems in a thread about firmware versions? Your request for help is less likely to be seen here and you are pulling this thread off-topic for other people who are looking for firmware versions. Don't do that guy, start a new thread!
P.S. All the problems you have mentioned seem to relate to batteries. Check your battery settings in the inverter, if the voltages are wrong then that could explain why your inverter has been complaining about DC Low Voltage for more than a year.
41 minutes ago, SmittySmit said:
Hi @m0skva
They upgraded it remotely.
Thank you. Deye eventually sent a guide on how to do the upgrade locally through the wireless dongle interface.
I posted it here as the problems started after a firmware upgrade, so that people are aware of the issues with that firmware version and don't have the same issues as I have had and ignore/skip that version.
Deye sent new firmware which resolved the problem.
So the problem were never the batteries, but firmware as everything worked perfectly before and after the faulty firmware.
HMI: 0000-C362
Main: 0-602-0717
Lucky you, Deye did not seem inclined to send me any files or guides. Maybe I should have been more demanding or disconnected it from the wifi. 😄
I did get them to also update the wireless dongle remotely.
Logger / Wireless Dongle:
Version Information
Module Version No:LSW3_15_FFFF_1.0.86D
Extended System Version:V1.1.00.0F
This was on 23 Feb 2023 and the wireless logger dongle has been working well to date.
HMI: 0000-C362
Main: 0-602-0717
Ah, fair enough. Thank you for this post ^^^ with the resolution details. I'm sure that could help someone.
It looks like you have a newer Human Machine Interface (C362) than what I have (HMI:VC.3.5.D) but they seem to have downgraded your main firmware slightly from 6.0.2.2 to 6.0.2.0. When I asked them for an upgrade I mentioned that I was having trouble getting the inverter to talk to the batteries in Lithium mode so I have it setup to use voltages. Maybe that is why they supplied version 6.0.2.2. Although I see in a separate thread that my troubles may be related to faulty cables.
Btw in my earlier reply I did not mean that your batteries were faulty but that the inverter may have had the wrong settings for the battery stored in its firmware and thus did not want to charge them. As it turns out it seems that it was not so much the settings in the firmware but the firmware code that uses those settings.
On 2023/06/26 at 2:45 PM, shana sk said:
Hello All 👋
Can someone please confirm the latest firmware for Deye 8kw inverter, Model Number: SUN-8k-SG01LP1-EU
Thank you kindly
Mine was updated remotely this morning
HMI:0000-C362 (Up from 0000-C35D)
MAIN : 6024-1724 (Up from 6021-1724)
LCD Type: C100 (Up from 8100)
Regards
Edited by Psynosaur
MAIN : 6021-1724 (this didn't change from previous state) ?
Regards
I think they do the update in two steps, your Main should get updated to 6024-1724 soon. My main fw update was done remotely (2023/05/30) unannounced and resulted in the power going off for a few seconds.
That was my bad, made a typo.
It is in fact 6024-1724 for MAIN
6 hours ago, shana sk said:
Thank you for that info...
do you notice any major changes in MAIN : 6024-1724? my current installed version is MAIN : 6022-1724
Hey
Not really, mostly setting things via Solar Assistant anyways
Good Morning
Mine updated this morning.  Excellent service from Deye China, not even 10 hrs since my e-mail request
HMI: Ver 0000-C364 and MAIN: Ver 0-6024-07DF
What is the latest firmware for the logger?
Mine is  LSW3_15_FFFF_1.0.96
Deye sent me a firmware update but I'm hesitant to upload as the version numbers are completely different.
I attached the file I have not tested it.
MW3_16U_5406_1.57.bin
Edited by Jeppe
Over the passed few months of updates, are there any noticeable changes? If only Deye published a list of upgrades... My 5kW 1ph inverter is still using firmware's: MAIN:3382-1515 and HMI:0000-C35D. Basically is it worth asking Deye to upgrade my system at the cost of a surprise power cycle?
On 2023/07/20 at 9:26 AM, CobusK said:
Good Morning
Good morning
Was there a particular reason for your request or was it just you wanted the latest software?
Regards
Hey
Mine is LSW3_15_FFFF_1.0.92R.
That firmware looks like micro inverters firmware... check this link
https://www.deyeinverter.com/news/events-news/deye-has-launched-new-firmware-version-for-microinverter.html
I wouldn't attempt to flash that on the data logger
Cheers
2 hours ago, ZS1SCI said:
Hey
Cheers
I thought the same thing as the naming structure was completely different to what was on the logger however deye confirmed it was for the logger.
I did the update and it fixed my issue of the logger going offline.
I don't have any disconnects for weeks now.
