Sunsynk Inverter Query
I have recently installed a 5k Deye Inverter , 5kw Shoto Battery and 8 400 CSUN Solar Panels. The inverter was consuming a lot of grid. And my electrician installed CT and nothing is operating. I urgently need a Deye Inverter Electrician. I am based in Pretoria
  • Replies 104
  • Views 59.3k
  • The 8kW has 2 MPPT's with 4 input strings, you must "balance" the PV input across those strings. See the explanation below, make sure you max Voc is calculated correctly.
  • My solution to the Neutral-Earth bond in the OHM 8 kW inverter. Decided to mount the power relay inside the inverter, rather than in the DB (as suggested by @Vassen).  Appears to be working well
I would advise you to start a new thread with the installation details and system settings. You will get better help that way.
My essential loads on the Sunsynk gives me all the data and graphs on the solarman app but when the batteries are fully charged I believe the excess power can also feed the Non-essential loads not on the inverter, Is there anywhere where this data is also displayed as I have not yet came across it anywhere to see if it actually does work. Has anyone actually seen data or proof that it is the way the Sunsynk works?
You should be able to see that in the flow diagram on the inverter screen. Not sure about an app to log and report historical records for non-essential power flow.
Thanks I forgot about the inverter screen, lately been checking the phone only and I see I had “Limit to load” box ticked, so it did not feed the non-essentials. It would be nice though if there were graphs for those loads as well.
