January 21, 20215 yr Please do find the attached Hubble Lithium Product Sheet (PDF) and our contact details. R24 700 Inclusive of VAT Sincerely Power Forum Store Hubble Lithium AM-2 A4 Pamphlet.pdf
January 21, 20215 yr Wow, that's even cheaper than the November special and it's a 5.5kwh!!! Do these also come with a free mounting bracket?
January 21, 20215 yr I see that the RIOT module is unnecessary for most mainstream inverters such as Victron, GoodWe, Sunsynk, Deye, Growatt, and Sofar, they can all address it natively using CAN bus. But if I were to go for this battery, I'd get one in any case, looks pretty cool.
January 21, 20215 yr Yes it does look pretty cool! I like the fact that it can monitor the individual cells.
January 21, 20215 yr 1 hour ago, Chloe said: Yes it does look pretty cool! I like the fact that it can monitor the individual cells. At only 3000 cycles, though the form factor is good, doesn't that concern you? I'm wondering how long this battery has been in the market to ascertain that it will make it to +/-15 Years as well...
January 21, 20215 yr 7 minutes ago, Moffat said: At only 3000 cycles, though the form factor is good, doesn't that concern you? I'm wondering how long this battery has been in the market to ascertain that it will make it to +/-15 Years as well... That's 3000 cycles @ 1C though... most other batteries are 0.5C. BSL Batt is the only other one that I know of.
January 21, 20215 yr I'm trying to compare it with the Pylontech US3000 and struggling to find the discharge rate of the pylontech to compare. Also warranty is an important factor. The price is tantalising though for it's size. Just found the Pylontech is 0.5c or 1c for 15 seconds, depending on the model. Edited January 21, 20215 yr by Moffat Additional information found.
January 21, 20215 yr 1 minute ago, Moffat said: I'm trying to compare it with the Pylontech US3000 and struggling to find the discharge rate of the pylontech to compare. Also warranty is an important factor. The price is tantalising though for it's size. AFAIK the US3000C is 0.5C, 37Amps max
January 21, 20215 yr 29 minutes ago, Moffat said: 30 minutes ago, Moffat said: At only 3000 cycles, though the form factor is good, doesn't that concern you? I'm wondering how long this battery has been in the market to ascertain that it will make it to +/-15 Years as well... Sorry I was referring to the Riot module that can monitor individual cells. As for the battery it is a 1C with 3000 cycles @ 80%. BSL bull is also a 1C and Pylontech claims to have a 1C but got this on a google search: "Medium discharge: These batteries can be discharged at 0.7C (35A), unlike BYD that can be discharged at 1C." https://www.todoensolar.com/epages/61987244.mobile/en_GB/?ObjectPath=/Shops/61987244/Products/BAT0475[1]&Locale=en_GB
January 21, 20215 yr 3 minutes ago, Chloe said: Sorry I was referring to the Riot module that can monitor individual cells. As for the battery it is a 1C with 3000 cycles @ 80%. BSL bull is also a 1C and Pylontech claims to have a 1C but got this on a google search: "Medium discharge: These batteries can be discharged at 0.7C (35A), unlike BYD that can be discharged at 1C." https://www.todoensolar.com/epages/61987244.mobile/en_GB/?ObjectPath=/Shops/61987244/Products/BAT0475[1]&Locale=en_GB Load / unload capacity The charge / discharge capacity of these recommended batteries is 0.5 C (25 or 37 Amp depending on the model), allowing a capacity of 1 C (50 or 37 Amp depending on the model), and a load capacity / maximum discharge of 100 Amp, for a maximum of 15 seconds. https://www.todoensolar.com/Pylontech-lithium-battery-48V-35kw-/-h-US3000s
January 21, 20215 yr 6 minutes ago, Moffat said: Does anyone know what the self-discharge of the Hubble Lithium AM is? Maybe @HubbleLithium can give you more details.
January 21, 20215 yr Just now, Chloe said: Maybe @HubbleLithium can give you more details. There's nothing on their website next to any of their offered product lines, just option to make an enquiry if one is interested.
January 21, 20215 yr @Moffat I got this from @ HubbleLithium : Self discharge on the AM-2 5.5KW is less than 5% per month. Rememebr the cycle is 3000 cycles then the battery is at 80% life left still, so still works perfectly after 3000 cycles. The AM-2 uses the latest new BYD cells.
February 24, 20215 yr This special still available? Buying a Sunsynk 5kv, will I need to buy extra cabling to get it to work? Is there any communication problems with the sunsynk?
February 24, 20215 yr Author 17 minutes ago, JohanM said: This special still available? Buying a Sunsynk 5kv, will I need to buy extra cabling to get it to work? Is there any communication problems with the sunsynk? Hello @JohanM Yes I can still supply you the battery at that price also I can possibly give you a better price on your intended inverter and all the peripherals you may need with it. You are welcome to contact me via email [email protected] or phone or whats app on 0742189845 or Phone 021 276 2975 I would gladly assist you Regards Steve
February 24, 20215 yr 35 minutes ago, Powerforum Store said: Hello @JohanM Yes I can still supply you the battery at that price also I can possibly give you a better price on your intended inverter and all the peripherals you may need with it. You are welcome to contact me via email [email protected] or phone or whats app on 0742189845 or Phone 021 276 2975 I would gladly assist you Regards Steve Thanks email sent. Edited February 24, 20215 yr by JohanM
March 8, 20215 yr Author 9 hours ago, Dani said: Is this sale still on? Yes @Dani I can still do the Special for you guys for the moment Regards Sales
March 8, 20215 yr Hi, what is the normal price on these and are they compatible with these inverters?: Fronius Primo 8.2 and Fusion Hybrid 8kw? How long is the warranty on these? I assume the warranty starts on date of purchase, not date of installation.
March 12, 20215 yr On 2021/03/08 at 4:41 PM, Powerforum Store said: Yes @Dani I can still do the Special for you guys for the moment I'll take one please
March 17, 20215 yr Thanks Steve from the @Powerforum Store for the supply and @leshen for the install. Quick and neat. Now I wait for loadshedding
March 17, 20215 yr 5 minutes ago, Dani said: Thanks Steve from the @Powerforum Store for the supply and @leshen for the install. Quick and neat. Now I wait for loadshedding Wow, that was quick!
March 24, 20215 yr Author Hi Guys Sadly the Hubble special has now come to an end you can contact me directly I can give you reasonable prices on the battery and the whole range that is available regards Sales Power Forum Store
