SunSynk - Inverter Monitoring
44 minutes ago, JuanH said:
Tried it last night. One thing that is missing from our flows to have this work is state_class and last_reset properties. They are needed for Long Term Statistics, which the new system uses: https://developers.home-assistant.io/docs/core/entity/sensor/#long-term-statistics
Once I added these in the the necesarry values, I was able to use them in the new HA Energy configuration:
Ok, something's gone wrong, and maybe you guys can help me figure it out. The above values stopped working at midnight last night. My guess is it has something to do woth the last_reset? Maybe I need to be passing it a value at midnight to update it as having re-initialized?
  • Replies 734
  • Views 208.4k
In the new "Energy" settings in HA there is the Grid consumption bit where you can add entities, I saw my BNETA power monitor plugs were there so I had a look in InfluxDB at those and see they send last_reset, in what looks like a number that is just the date and time. It looks like HA then adds a column called "last_reset_str"
last_reset                                last_reset_str
202011251456369984.00 -> 2020-11-25T14:56:37+00:00
I've tried using the "J: expression" in the change node to set the value.
I've tried the following expressions (with - > being the resulting value from the expression)
$now('[Y0001][M01][D01]000000000.00') -> "20210805000000000.00"
$string($now('[Y0001][M01][D01]000000000.00')) -> "20210805000000000.00"
$number($now('[Y0001][M01][D01]000000000.00')) -> 20210805000000000
(can't seem to get the .00 decimal using the expression unless it is a string)
If I use the debug node to see the data going to MQTT I can see the relevant values but HA seems to be ignoring/disregarding them.
On 2021/07/26 at 10:51 AM, RhysMcW said:
Has anyone tried setting the time on the inverter using the modbus connection?
I've done a NR flow to get the current date/time from the inverter and compare it to the current date/time, on my HA box, and if there is more than 10 seconds difference then I want to set the date/time on the inverter.
The registers are 22,23 & 24 which are 2-byte registers. I can get the date/time fine in NR but I can't seem to get the inverter time set.
Does anyone know how you're supposed to setup the payload for sending to the inverter?
Here's my current function code for setting up the house/minute for register 24 which the inverter seems to be ignoring as the hour/minute is not getting set. (msg.minutes & msg.seconds are setup in a function prior to this one)
function byteArrayToLong(byteArray) {
    var b_value = 0;
    for ( var i = 0; i <= byteArray.length - 1; i++) {
        b_value = (b_value * 256) + byteArray[i];
    return b_value;
msg.payload = {
    'value': [byteArrayToLong([msg.minutes,msg.seconds])],
    'fc': 16,
    'unitid': 1,
    'address': 24,
    'quantity': 1 };
return msg;
which results in the following payload being sent to the ModBusWrite flow, via a link-in/out
"payload": {
        "value": [ 11318 ],
        "fc": 16,
        "unitid": 1,
        "address": 24,
        "quantity": 1
My inverter also loses time - about 15 minutes every month. Not sure if there is a RTC or battery somewhere? (there is a huge array of batteries the inverter can use if it wanted to :))
Did you manage to figure out how to write to 2-byte registers?
Innes
it's not so much the method of writing 2-byte registers, that I can see, it's the format the inverter will accept the new date/time that I think is the issue. I have tried so many variations now I've lost track of what I've tried so given up for now, hoping someone else has a look and finds a solution.
On 2021/08/05 at 1:47 PM, Bloubul7 said:
Could do it with an inject function, timer and timestamp.  And then set the MQTT to retain last value
Managed to get it working via MQTT.
Changed the Assemble config to the following
Added a timestamp inject that injects every 24 hours.  Date/ Time Formatter uses a pallete called moment
flows (9).json
Thanks, @Bloubul7
I've given your new flow a try, but I've noticed that the entities don't update with the "last_reset_topic". I've checked the topic value, and it definitely sends an updated value over MQTT, either as scheduled, or when done manually, but the subscribing entities don't seem to pick it up. Not sure what I am doing wrong?
Example of manually triggering the inject:
Entity's last_rest stays the same:
19 minutes ago, JuanH said:
Thanks, @Bloubul7
Have you tried restarting HA?  I have not defined the last_reset on as a value on my entities, only defined the subscribed topic.  See below screenshot
Hi All,
Complete Noob here.
I want to build a nice dashboard in Home Assistant for my solar installation. I have a Deye inverter which is the base for Sunsynk.
I have a Raspberry 3b+ and a USB to RS232 Cable. How would I get started to get the firmware on the Raspberry, connecting the raspberry and start playing with Node Red?
Kind Regards
Jeremy
Hi Jeremy, the standard rasbian OS for the PI3 has node red pre-installed.
You'd simply connect everything up, and access the node red web ui from a browser.
From there you'd be able to install the prerequisite modules and import the flows into NR. once you have readings in NR, next step is to check integration with mqtt or home assistant running elsewhere on the network.
On 2021/08/12 at 9:36 AM, JeremyJvR said:
Hi All,
Complete Noob here.
Kind Regards
Jeremy
Did you succeed?
Hi Guys, I currently hard code my "Grid trickle feed" because I can't figure out which inverter register stores the value.  Does anyone know which modbus register stores the value in the screenshot below?
Grid_inverter_load - 167      - I think
I'm looking to setup HA, and so far, only got a NUC. This thread looks like a great source for flows and everything that comes after setting up HA and Node Red. Is there a guide that can be followed to get through the initial setup? The reserved posts look exactly like what I need.
FYI, I installed HA Container on Docker, but it didn't look to have the supervisor mode available. I might just need to install HA OS? I'd like to connect to all my SonOff devices without flashing the firmware
Any assistance will be appreciated
Hey Saliegh.
My recomendation would be to install HA OS: https://www.home-assistant.io/installation/generic-x86-64
Once done, install the Node Red add-on from the included add-on store.
Then you can start with the flows in this thread.
I also recomend the Everything Smart Home channel on Youtube. Loads of useful guides for HA on there: https://www.youtube.com/c/EverythingSmartHome/featured
10 hours ago, JuanH said:
Hey Saliegh.
Thanks @JuanH, this got me up and running in no time. Using a live OS on a USB was the simplest way to get there.
I've been told to get the follow device to hook my NUC up to the Inverter
https://www.robotics.org.za/W17286?search=485
Do I use get CAT5 network cable to connect the 2? Probably going to run it about 10 meters
CAT5 cable yes. Or any other copper cable. 10m should be no issue, 485 can run long distances.
Never seen this device before, but can't see why it won't work
The USB will most likely fail pretty soon if you keep it as the main drive, due to the amount of reads/writes.
Look through the Everything Smart Home channel I mentioned earlier. There is a good guide on moving your installation onto an external (or internal if you can with the NUC) SSD drive.
