11 minutes ago, Sc00bs said:
We just need to get all the inverter integration authors to standardise the naming of the entities, would make life so much easier.
It would make life easier!
One easy change I can think of would be to change _power_kwh, to _energy. I also made this mistake in one of the erlier editions of the addon and since updated & deprecated the old names
https://github.com/kellerza/sunsynk/blob/main/sunsynk/definitions.py#L318
It is a bit painful, since you lose your Energy stats
  • Replies 657
  • Views 180.1k
Technically you could just rename those in the statistics table, it is still on my todo list
My 2c towards some standard names
It is well documented how to setup your entities here
https://developers.home-assistant.io/docs/core/entity/sensor/#properties
power = kW
energy = kWh  (rieman sum over the time period for the amount of power... a summary of the data)
since all energy is a calculation I tend to name them without energy as it is implied
Summary_Day_PV
Summary_Day_Load
Summary_Month_PV
Summary_Total_PV
But for power
PV1_Power
PV1_Voltage
PV2_Power
PV2_Current
PV_Power
Load_Power
Load_Frequency
16 hours ago, JDSym said:
I agree with you.
Something I also changed in my own integration was to change all measurements with a kWh unit to include the word "energy" instead of "power".
For example, instead of naming the entity "Day_GridSell_Power Wh" as in the official documents, or "grid_export_day" as in some integrations, I named it grid_energy_export_day which I think makes a lot more sense.
agree, I'm using solar assistant and it's such a mission with all of the different entity names to setup cards and dashboards.
On 2022/11/01 at 12:08 AM, slipx said:
Hey,
Would you mind sharing your card codes?
(I've added all the required HACS cards as per your Github).
Also, which sensors are you using for the battery config in the HA Energy Dashboard?
-Energy into battery
-Energy out battery
27 minutes ago, McAllstar said:
sorry any idea why I'm getting this?
I can't figure out which sensor to use for the grid.
Mine shows this when there's loadshedding... are you sure you're not being loadshed when it's that colour/icon?
thanks for the reply. No definitely not being loadshed, you can see it was showing that i was consuming 22w from the grid. It stays like that all the time.
never mind i see that i need to create the template sensors for grid_status_19 and inverter_status_59
where exactly do i put it though? I tried to put it in my configuration.yaml and or sensors.yaml file however I get errors when i check the config from developer tools.
Edited by McAllstar
again figured it out, put it in the sensors.yaml file and had to fix the indentations
image.thumb.png.ce919f2a64baa4c105888902ee514b30.pngI can't figure out which sensor to use for the grid.
I like the colour scheme.
You can clean up a lot of that card configuration as I've made most of the sensors optional specifically when not used e.g. you can delete all the pv3, pv4 sensors lines
excellent thanks for that, I didn't notice, until you mentioned it. I'll clean it up now that I got it working. appreciate the hard work and generosity.
On 2023/03/03 at 2:16 PM, slipx said:
I was playing with some text sensors to get the timezone to display as 02:00 as opposed to 200 etc. You can try them if it helps
text_sensor:
  - platform: template
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_setting_timezone1).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_setting_timezone1).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_setting_timezone1).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
        char formatted_time[6];
        snprintf(formatted_time, sizeof(formatted_time), "%02d:%02d", hours, minutes);
        return esphome::optional<std::string>(formatted_time);
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_setting_timezone2).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_setting_timezone2).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_setting_timezone2).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
Hey,
Me again here to bug you - you're work is just too good not to copy 🤓
I'm struggling to replicate this card - I have the text sensors that you added above in my ESP32 code and I've tried the code below but the result is not anything like ^
type: markdown
content: "  ## System Timer Settings\n<table width=\"100%\"  border=0>\n  <tbody> \n  <tr>\n    <td align=\"left\">\n    <b>Time Slot</b>\n    </td>\n    <td align=\"left\">\n    <b>Battery SOC</b>\n    </td>\n    <td align=\"left\">\n\t<b>Grid</b>\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    01:00 - 05:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone1') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone1', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    05:00 - 09:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone2') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone2', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    09:00 - 17:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone3') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone3', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    17:00 - 20:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone4') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone4', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    20:00 - 22:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone5') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone5', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  <tr>\n    <td align=\"left\">\n    22:00 - 01:00\n    </td>\n    <td align=\"left\">\n    {{ states('sensor.sunsynk_setting_soc_timezone6') }} %\n    </td>\n    <td align=\"left\">\n\t{% if is_state('sensor.sunsynk_setting_grid_charge_timezone6', '1') %} <ha-icon icon=\"mdi:checkbox-marked-outline\"></ha-icon> {% else %} <ha-icon icon=\"mdi:checkbox-blank-outline\"></ha-icon> {% endif %}\n\t</td>\n  </tr>\n  </tbody>\n</table>"
view_layout:
  grid-area: weather
Also, you need to sign up for the buymeacoffeebeer thing!
Edited by Muttley
27 minutes ago, Muttley said:
Hey,
type: markdown
view_layout:
  grid-area: weather
Just remember to update your sensors. You also need to install
https://github.com/benct/lovelace-multiple-entity-row
Now I'm gonna go do the coffee thing 😁
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: tile
        entity: switch.toggle_system_timer
        vertical: true
        icon: mdi:timer-cog-outline
      - type: tile
        entity: switch.toggle_priority_load
        vertical: true
        icon: ''
  - type: entities
    entities:
      - entity: switch.toggle_grid_charge_timezone1
        type: custom:multiple-entity-row
        toggle: true
        state_header: Charge
        state_color: true
        entities:
          - entity: sensor.time_zone1
          - entity: sensor.time_zone2
          - entity: number.set_soc_timezone1
            format: precision0
      - entity: switch.toggle_grid_charge_timezone2
        toggle: true
        state_color: true
        entities:
          - entity: sensor.time_zone3
          - entity: number.set_soc_timezone2
            format: precision0
      - entity: switch.toggle_grid_charge_timezone3
        toggle: true
        state_color: true
        entities:
          - entity: sensor.time_zone4
          - entity: number.set_soc_timezone3
            format: precision0
      - entity: switch.toggle_grid_charge_timezone4
        toggle: true
        state_color: true
        entities:
          - entity: sensor.time_zone5
          - entity: number.set_soc_timezone4
            format: precision0
      - entity: switch.toggle_grid_charge_timezone5
        toggle: true
        state_color: true
        entities:
          - entity: sensor.time_zone6
          - entity: number.set_soc_timezone5
            format: precision0
      - entity: switch.toggle_grid_charge_timezone6
        toggle: true
        state_color: true
        entities:
          - entity: number.set_soc_timezone6
            format: precision0
    state_color: true
view_layout:
  grid-area: a
Edited by slipx
8 hours ago, Muttley said:
Hey,
type: markdown
view_layout:
  grid-area: weather
Hey @Muttley
I am working on this video as we speak, have almost finished the ESP32 part of it and will then start working on the dashboard, hope to have the ESP32 part up today and the Dashboard part  by Monday. 🙂
@slipx I agree with @Muttley , you need to set that up.
People would like to be able to say thanks for all the work you have put in.
Speaking of which I think it would be great to have a forum IRL get together, would be great to be able to put some faces to the forum handles 🙂.
Was thinking of maybe having a few drinks at the Baron Kyalami Corner next Friday 9th June after work if anyone else is keen?
Sounds like fun, but I'm travelling next week. Will try for the next one 😉
cards:
    cards:
      - type: tile
        vertical: true
      - type: tile
        vertical: true
        icon: ''
  - type: entities
    entities:
        toggle: true
        state_color: true
        entities:
            format: precision0
        toggle: true
        state_color: true
        entities:
            format: precision0
        toggle: true
        state_color: true
        entities:
            format: precision0
        toggle: true
        state_color: true
        entities:
            format: precision0
        toggle: true
        state_color: true
        entities:
            format: precision0
        toggle: true
        state_color: true
        entities:
            format: precision0
    state_color: true
view_layout:
  grid-area: a
Me again 🙈
I seem to be struggling with these sensors:
etc
Is this something that should get pulled from the inverter via the ESP32 or is it a manual addition to your configuration.yaml file?
Just send me an invoice and your banking details already 🤑
Hi all. So I'm a bit late on the topic, and I have an issue with something, but figured I'll ask here rather than create a new thread.
I'm trying to get the ESP-32 (with ESPHome) way of monitoring.
My setup is as follows:
Deye 8Kw Inverter
RJ45 with 1+8(B) and 2+7(A) and 3+6(GND) (based on solar assistant docs) hooked up to RS485-TTL module and this again connected to ESP-32 pins 16(RX) + 17(TX) + 5(Flow Control)
Now ESPHome log is going crazy with "Modbus CRC Check" failures and "Got Modbus frame from unknown address"
So in Home Assistant the values are all random... It jumps between "Unavailable" to waay incorrect numbers to actual correct values
Based on the fact that I'm getting correct values some of the time tells me my addresses are correct (and using the values from the Deye modbus doc)
Crazy values
Correct values
Here is my ESPHome config with just 3 sensors shown
substitutions:
  modbus_controller_id: sg01lp1
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
web_server:
  port: 80
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  ap:
    ssid: $name
    password: !secret wifi_failover
captive_portal:
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
  debug:
    direction: BOTH
    dummy_receiver: false
    after:
      delimiter: "\n"
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
modbus:
  uart_id: mod_bus
  flow_control_pin: 5
  disable_crc: true
modbus_controller:
  - id: ${modbus_controller_id}
    modbus_id: modbus1
    address: 0x01
    setup_priority: -10
    update_interval: 3sec
sensor:
  - platform: modbus_controller
    modbus_controller_id: ${modbus_controller_id}
    name: sun8k Battery Voltage
    register_type: holding
    address: 183
    unit_of_measurement: V
    state_class: measurement
    accuracy_decimals: 2
    filters:
      - multiply: 0.01
    value_type: U_WORD
    name: sun8k Battery SOC
    address: 184
    unit_of_measurement: "%"
    accuracy_decimals: 0
    value_type: U_WORD
    name: sun8k Battery Current
    address: 191
    unit_of_measurement: A
    filters:
      - multiply: 0.01
    value_type: S_WORD
Any help would be greatly appreciated
Deye 8Kw Inverter
Crazy values
Correct values
substitutions:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
web_server:
  port: 80
logger:
api:
ota:
wifi:
  ap:
    ssid: $name
captive_portal:
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
  debug:
    direction: BOTH
    after:
      delimiter: "\n"
    sequence:
modbus:
  uart_id: mod_bus
  flow_control_pin: 5
  disable_crc: true
modbus_controller:
    modbus_id: modbus1
    address: 0x01
    setup_priority: -10
sensor:
    address: 183
    filters:
      - multiply: 0.01
    value_type: U_WORD
    address: 184
    value_type: U_WORD
    address: 191
    filters:
      - multiply: 0.01
    value_type: S_WORD
Where have you got the ESP32 & RS485 board located?
At one stage I located mine inside my Inverter and suffered from a lot of weird readings, once I moved it out of the enclosure was not an issue.
16 minutes ago, Sc00bs said:
I made a video for you 🙂
Awe... Just for me? You shouldn't have 😁
So I don't have a heap of these 485 borads laying around... and don't want to just remove it without knowing if it is the actual issue...
Is there a way to check with a multimeter maybe if the inverter has the resistor already built in?
I haven't packaged anything yet... its still jumper wires hanging out the side
