June 1, 20215 yr Hi, I am looking at installing a 5KW system, and have narrowed my inverter selection down to either a Growatt ES, or a Sunsynk/Deye which I believe are the same inverters. The price difference is about 7k, can anybody tell me what advantages the Sunsynk offers over the Growatt? Any advice will be appreciated!
June 1, 20215 yr 3 hours ago, Marcf said: Hi, I am looking at installing a 5KW system, and have narrowed my inverter selection down to either a Growatt ES, or a Sunsynk/Deye which I believe are the same inverters. The price difference is about 7k, can anybody tell me what advantages the Sunsynk offers over the Growatt? Any advice will be appreciated! Can't comment on the growatt inverters but I'm sure if you check posters here who installed them, most of them would opt for the sunsynk over the growatt inverter. I would also go with the sunsynk over the Deye as the user interface on the sunsynk is much more modern and intuitive. 8 months of running the sunsynk and it just works.
June 1, 20215 yr If cost is not an issue for you, go for Sunsynk. But if I were in your position I would definitely go for the Growatt ES and use the R7k to buy Panels or top it up to get extra Lithium battery. Growatt is good value for money and works perfect if you are hands On and willing to learn, Technical support is bad, very bad. Edited June 1, 20215 yr by hoohloc spelling error
June 1, 20215 yr 7 hours ago, Marcf said: Hi, I am looking at installing a 5KW system, and have narrowed my inverter selection down to either a Growatt ES, or a Sunsynk/Deye which I believe are the same inverters. The price difference is about 7k, can anybody tell me what advantages the Sunsynk offers over the Growatt? Any advice will be appreciated! It depends on your circumstances. I have the growatt and it does all I need it to do. I had to change my 4kw geyser element to a 2 kw one and connected the geyser to the inverter now I'm making full use of my 16(360watt) panels. I wanted to upgrade to the deye or sunsynk to feed my loads before the inverter which I solved by connecting everything to the inverter. No loads before the inverter for me. If you live in a municipality where they pay you for feeding in your excess pv then the sunsynk is better but I don't live in one of those municipalities. So for me where I live with no loads before the inverter the growatt is the best option for me. Tell us more about your setup?
June 1, 20215 yr Not sure if the Growatt is a proper hybrid, because on a SunsynkDeye, you can go higher than 5 kW, in fact up to 8 kW and still feed from solar. battery
June 2, 20215 yr I'm considering the SunSynk for my installation, looks like they quite popular. Does anybody know if PylonTech US3000C 3.5kWh are compatible with them? SolarAdvice looks to have the best price, but they explicitly do not include SunSynk in the list of compatible intevers
June 2, 20215 yr 3 minutes ago, Saliegh said: Does anybody know if PylonTech US3000C 3.5kWh are compatible with them? Am running 4x US3000B in my setup with Sunsynks. As the B and C can be run together, I do not see any reason why the C would not work with the Sunsynk
June 2, 20215 yr 42 minutes ago, Saliegh said: I'm considering the SunSynk for my installation, looks like they quite popular. Does anybody know if PylonTech US3000C 3.5kWh are compatible with them? SolarAdvice looks to have the best price, but they explicitly do not include SunSynk in the list of compatible intevers They are. I'm running 3 x US3000B and 1 x US3000C pylontech batteries on my 8kw sunsynk inverter.
June 3, 20215 yr 17 hours ago, Saliegh said: I'm considering the SunSynk for my installation, looks like they quite popular. Does anybody know if PylonTech US3000C 3.5kWh are compatible with them? SolarAdvice looks to have the best price, but they explicitly do not include SunSynk in the list of compatible intevers They are compatible and work well together. I have the 8kW inverter and 2x US3000C (one of which I bought from them, which I regretted after my installer got my second one for cheaper). They probably don't mention Sunsynk as they rather punt their own rebranded version of the inverter, called the "Fusion".
June 3, 20215 yr On 2021/06/01 at 9:08 AM, Marcf said: Hi, I am looking at installing a 5KW system, and have narrowed my inverter selection down to either a Growatt ES, or a Sunsynk/Deye which I believe are the same inverters. The price difference is about 7k, can anybody tell me what advantages the Sunsynk offers over the Growatt? Any advice will be appreciated! I just got the Growatt ES and it's awesome. Can't see why anyone would spend an extra 7k on another inverter rated at the same output. Plus the Sunsynk/Deye wifi dongle costs an extra 2k or something, with the Growatt it is included in the box.
June 3, 20215 yr I have spent a fair bit of time troubleshooting some funnies I was experiencing, I think when considering which inverter, it is worthwhile considering it alongside the other kit you intend installing. Example Battery, lead acid, or Li? And if Li will you want to run it using the BMS or just on voltages? I found the BMS Li battery on the Growatt locked in settings related to amount of charge utility would charge up batteries with. Not a problem if youre happy with high energy use for this. With the Deye, this field remains configurable. It is a non issue on non BMS given my experience with the system but might be a consideration if down the line you want a BMS Li battery. (Disclaimer, it could be that a firmware update might resolve this in the Growatt?) 2. Hybrid off offgrid? The 5000ES i believe is an offgrid inverter (maybe there are different models under the ES banner). 3. I find the Growatt has presets of SUB, SBU, Solar and Utility, quite handy for quick changes. The Deye seems to be a SBU setup but allows the configuration of individualised time slots where grid will charge batteries up in those times. Good luck. I think both are solid choices, just be more or less clear what you expect from the system and how you expect the system to operate.
June 3, 20215 yr 12 minutes ago, GTP said: The 5000ES i believe is an offgrid inverter (maybe there are different models under the ES banner). Yeah you can't export power with the Growatt. You can however use solar panels without batteries and if your panels aren't producing enough wattage for the load then it mixes in some grid power to make up the rest. Kind of pointless to use it that way considering loadshedding...
July 16, 20224 yr On 2021/06/03 at 2:29 PM, tetrasection said: I just got the Growatt ES and it's awesome. Can't see why anyone would spend an extra 7k on another inverter rated at the same output. Plus the Sunsynk/Deye wifi dongle costs an extra 2k or something, with the Growatt it is included in the box. I would also like to get tour opinion on the sapphire hybrid 5kw inveter
September 10, 20232 yr If cost is not an issue for you, go for Sunsynk. But if I were in your position I would definitely go for the Growatt ES and use the R7k to buy Panels or top it up to get extra Lithium battery. Growatt is good value for money and works perfect if you are hands On and willing to learn, Technical support is bad, very bad. I think technical support is bad for the whole sector.
September 11, 20232 yr I'm considering the SunSynk for my installation, looks like they quite popular. Does anybody know if PylonTech US3000C 3.5kWh are compatible with them? SolarAdvice looks to have the best price, but they explicitly do not include SunSynk in the list of compatible intevers I ended up opting for the Fogstar 12kwh 48v rack renamed but basically similar to the Jakiiper ones I think there probably assembled by Jakki. I had the same question. Hopefully someone will give you a direct answer about the pylontech ones. What I can say is my choice was basically plug and play once I got the can cable correct and that says a lot about my choice. Hope that helps and know poepl can dislike links but im sure a bit of googling and searching the above will give you some more ideas.
September 14, 20232 yr I ended up opting for the Fogstar 12kwh 48v rack renamed but basically similar to the Jakiiper ones I think there probably assembled by Jakki. I had the same question. Hopefully someone will give you a direct answer about the pylontech ones. What I can say is my choice was basically plug and play once I got the can cable correct and that says a lot about my choice. Hope that helps and know poepl can dislike links but im sure a bit of googling and searching the above will give you some more ideas. I've learnt so much since that post of mine. Firstly, not to hijack. Secondly, 1C batteries for the win. I ended up installing an AM2, and almost 2 years later, I added another AM2. Happy with my setup, except that I should have gone with an 8kw. The upgrade now is so pricy, almost does not make sense.
January 26, 20242 yr Im having trouble with my communication between my 5kw growatt inverter and my 2x grocol 5kw batteries any advise?
January 26, 20242 yr 20 minutes ago, Tersius10000 said: Im having trouble with my communication between my 5kw growatt inverter and my 2x grocol 5kw batteries any advise? howzit mate - i reckon start a new topic under the inverters section rather.
