November 11, 20214 yr Good day All. I am starting this thread to document my install from start to finish. Some background on the install. I purchased an 8KW Synsynk with 2 5.5 AM2 Hubble's. In addition, 10 JA Solar 540w panels will be mounted once they arrive. I am linking to system to Home-Assistant with Solar-Assistant on a Raspberry Pi. The installer is starting the install this morning, so here are some pics from before. I will be posting updates as the install progress. Current DB Board Synsink, Batteries, new DB and Solar PV Combiner waiting for install
November 12, 20214 yr Same setup going in for me just the 5kw not 8kw Sunsynk. Always enjoy a good progress thread!
November 12, 20214 yr Author Update: After 6 hours, this is where we are at. The power cables to and from the DB is already in the ceiling as well. Invertor will be properly attached to the wall this morning
November 12, 20214 yr Author 1 minute ago, Shockin said: Hi, where did you get the db board from? DB Board is a Gewiss from ACDC. I could not find a Hager unit locally. All MCB's are Gewiss as well. The board next to the inverter is the PV combiner. That is from PowerForum Store
November 12, 20214 yr Looking good. A note ... if you buy a gewiss board from AC/DC ... dont use the one which looks pretty with grey smokey cover which you push to release (GW400x range ... IP 40 rated) ... the clip is absolute crap ... replaced it out the box at AC/DC then again after installation and now we stuck with a broken clip (too much hassle to remove the entire DB ... becuase they will not replace just the faulty clip) ... the one in this picture should work better ... (GW401X range ... IP 655 rated).
November 12, 20214 yr The OBO trunking is the best looking and most practical to work with ... expensive but cheaper on labour to install ( just dont use a nail gun to install it ) The components like the plugs ... isolators and network jacks look neat when installed
November 12, 20214 yr Author 55 minutes ago, isetech said: The OBO trunking is the best looking and most practical to work with ... expensive but cheaper on labour to install ( just dont use a nail gun to install it ) The components like the plugs ... isolators and network jacks look neat when installed I made my requirements clear to the electrician from the start. No 45 mitre joints!
November 12, 20214 yr 4 hours ago, ggza said: this is where we are at Looks great, and looks like you got the right installer. What are the two isolators on far right hand side for?
November 12, 20214 yr 4 hours ago, ggza said: Update: After 6 hours, this is where we are at. The power cables to and from the DB is already in the ceiling as well. Invertor will be properly attached to the wall this morning That trunking is exactly what i am after. What do you call it and where does one source it from ? BTW looking great so far on the install.
November 12, 20214 yr Author 39 minutes ago, Gerrie said: Looks great, and looks like you got the right installer. What are the two isolators on far right hand side for? Invertor and Municipal Disconnects.
November 12, 20214 yr Author 30 minutes ago, PowerUser said: @WAP It's OBO trunking. @ggza who sells it in SA? o-line https://www.o-line.co.za/
November 14, 20214 yr I use the off cuts of the obo trunking to make plug extenders ... it looks neat and you can fit as many 2 pin socket as you need ... I use it for my machine battery charge station ( 8 machine chargers for makita ... Hilti ... Bosch ... victron ) and I have one in my office for for all the other little chargers for the go pro ... garmin .... ipad ... 18650 chargers etc ... keeps neat and tidy. I need 6 x 2 pin and 7 x 15 amp plugs for all the gadgets ... it looks an absolute mess with double adaptors and extender plugs ... 1 strip of double compartment obo and plugs will tidy it up nicely.
November 17, 20214 yr Author Ok, time for an update. I am now officially no longer affected by load shedding! Panels are hopefully arriving this week, which means I can recoup some of my investment at least. New DB installed and labelled. Still required is sealing around the trunking. Existing loads are fed from the cavity where the old DB was. Inverter supply and feed located in trunking, with spare trunking for future use. All the existing conduits feeding the old DB was full. Trunking for PV still needs to be installed, and some glands and sprag(spelling?) is still required. Some additional cleaning be done as well. I need to tidy up my Raspberry power supply wiring and RIOT unit still needs to be installed. So far I am extremely happy with the workmanship and attention to detail. Hendrik (the electrician doing the install) really ensures that everything is done correctly, and aesthetically pleasing.
November 17, 20214 yr Why do you need a PV combiner, the Sunsync has 4 string inputs into the 2 tracker MMPT?
November 17, 20214 yr Was the new db board fitted over where the old db board used to be? Would love to see inside the db board with the covers off.
November 17, 20214 yr Author 2 hours ago, Shockin said: Was the new db board fitted over where the old db board used to be? Would love to see inside the db board with the covers off. Indeed, it was fitted over the old DB. Will take a photo the next time Hendrik is here. Still need to replace some plugs MCB with 25A breakers.
November 17, 20214 yr 3 hours ago, FixAMess said: Why do you need a PV combiner, the Sunsync has 4 string inputs into the 2 tracker MMPT? Fuse protection, Lightning protection and isolation of the DC strings. This is a legal requirement.
November 17, 20214 yr On 2021/11/12 at 8:14 AM, isetech said: The OBO trunking is the best looking and most practical to work with ... expensive but cheaper on labour to install Does the obo trunking have two compartments inside to separate AC and DC wires?
November 18, 20214 yr Yes they have a divider (sold as an accessory ) which can be fitted to separates the wires for both the single and double compartment trunking. https://www.o-line.co.za/products/building-installations/device-installation-ducts-and-trunking/accessories-device-installation-trunking/separating-retainers/partition-pm.html
