Vision Hybrid Bi-directional inverters
yes, they are 6 strings. All cables are same length. It ran my house for around 15hours without sun drawing constant 700w. System would switch back to grid at 49v. I don't need as many batteries anymore as I got the smart grid inverter.
  • Replies 52
  • Views 16.3k
  • So I got my East/Vision inverter today. Looks and feels solid. Will probably install over the weekend. Will upload pics and post update on how it performs.
  • Hi Hein I got it from Enervision in CPT. What do you think of the ups? So far after reading through the technical data only downside is they cannot be paralleled. It will also switch to comp
  • Ok, I have ordered 2x Vision 3kw 48v inverters. Going to test one out for myself and see how it holds up.
6 hours ago, JDP said:
Only the first strings of batteries are working. You need a bus bar and all the cables should be the same length. Just a tip on wiring those bats up.
Not really. The negative cable goes across to the other end of the bank, so the total length is the same for each string.
Aaa OK I did not see the cable on the other end on my cell phone.
Quick question.. I have 9x 235W panels in series. I have 3x 260W panels sitting in my garage. Would it be ok to add them to the 235w string? The voltages are the same, just the Watts that are a bit higher.. Can't seem to find more 235W panels locally.
16 hours ago, Johann1982 said:
yup, I measured them all to the mm.
Some strings will still work harder than others connected that way.  You need busbars and equal lengths of cable between each sting and each busbar.
I hear you. All cables are equal lengths, will add busbars when I get a chance.
It can be done but it is not recommended, first check the current rating of the panels.  Connecting panels in series that are not the same, the lower current rated panel will drag the performance of the system down.  So if the rated current of the 235w panel is 8A and the 260w is 8.5A, the whole string will only supply 8A,
Lets assume you have no problems with the open circuit voltage being too high:
12 * 235 = 2820Wp (because the 260W panels will behave like 235W panels)
9 * 260 = 2340Wp
So you will only see a 500W improvement.
IF you put the 3 panels on their own controller (if you could... if the inverter had 2 mppts) you'll get an additional 235*3 ~= 700W.
So the penalty for doing it this way is 200W. Feels acceptable considering the alternative.
BUT (and this is actually way more important), with that many panels in series, consider the open circuit voltage. For a 72-cell module (which I suspect those are) you're talking around 45V open circuit on each module, times 12... so you'd be around 540V. The spec sheet of your inverter says the max is 450V (ie you are at the limit already with 9 panels).
So no... do not do it. You will be sad... and right before Christmas too.
@plonkster More like 37.7VOC which should be ok. 452V in total. Max input is 500V, MPPT Range is 450V. The moment I get 380V open circuit if I test with multimeter. Will obviously be higher on cold days. I have an extra inverter incase I bork this one. ;)
Just check the cold temp (ie 0 degree celcius) VOC of the panels in a series string and see if you still fall in the safe zone of the inverter.
I have over volted on my Axpert before, it just bypasses the solar if that happens. I had 4x 260W in series to see what would happen. Let's hope Vision will have that same safety feature. I enjoy testing solar hardware to the max.
On 12/8/2016 at 4:29 PM, Groenkaroo said:
I also got my Vision inverter today. Johann you must make sure to upload enough pics because this is going to be my first solar installation and I can do with any help I can get.
Hi Groen, het jy al jou Vision inverter ge-installeer? Sover is ek baie gelukkig met myne.
Ek het vanaand myne aan die brand geslinger. Sy rook het darem nie uitgekom nie. My installasie is nog nie klaar nie, ek moet nog twee van die drie PV stringe koppel, maar more behoort ek my eerste son energie op te wek. Die inverter is eintlik maar net 'n toetslopie. Ek beplan om net die boorgatpomp en 2 aircons op hom te koppel. Die drie items behoort hom heeldag besig te hou. Volgende jaar beplan ek om 'n groter inverter met 'n battery bank vir die huis te installeer.
Nee, ek het vroeer in die jaar 'n baie goeie prys op 170 W Eging Monochrystaline panele gekry en toe sommer 6 kw se panele gekoop. Die statium loop het twee stringe van 11 panele - 1870 W per string. Die son staan vandag stil in die Karoo en toe ek netnou gaan kyk het, het die panele 3230 W geproduseer. Die panele is so bietjie vuil en moet nog gewas word.
So my inverter works great, I am just having some trouble programming the thing so that it doesn't draw my batteries past 49V. I have set it as follows:
00:00 Gen Prio
01:00 Gen Prio
02:00 Gen Prio
03:00 AC Charge off
04:00 AC Charge off
05:00 AC Charge off
06:00 AC Charge off
07:00 AC Charge off
08:00 Sav Prio
09:00 Sav Prio
10:00 Sav Prio
11:00 Sav Prio
12:00 Sav Prio
13:00 Sav Prio
14:00 Sav Prio
15:00 Sav Prio
16:00 Gen Prio
17:00 Gen Prio
18:00 Gen Prio
19:00 Gen Prio
20:00 Gen Prio
21:00 Gen Prio
22:00 Gen Prio
23:00 Gen Prio
Sorry bout the multiple posts, my pc went haywire.
00:00 Gen Prio
01:00 Gen Prio
00:00 Gen Prio
00:00 Gen Prio
00:00 Gen Prio00:00 Gen Prio
Hi Johann, rather than to trust the inv to manage your batteries, why not install a Victron battery monitor?
Are you looking to run completely off-grid, or just lower your electric bill?
If this unit is indeed similar to the Infini unit, you should be able to program it to use solar+batt during the day and only mains during the night.
P.S. Like the 235W PV's. Where did you get them, as I have been looking for ages. I would love another string of 9 :)
On 12/2/2016 at 2:52 PM, Johann1982 said:
...As far as I can tell yes. When the load exceeds 9kw (Surge Rating) for too long it will switch to bypass. I will know after next week if it indeed will work like that.
Hi Johann,
Were you maybe able to confirm whether this bypass function was working as initially expected?
This inverter seems to be a good option to address my requirements but my load occasionally exceed 3 kW and I don't want to split the DB with everything that goes with it.
Hi Langeraat
I can confirm that I have pushed around 5.5kw through the inverter without any issues. I have not managed to get it to switch to bypass yet. I have only removed the oven from my inverter, all the rest is going through it.
