March 17, 20233 yr Good day! There is a BMS board with connection to the inverter via RS485. so it has a connection speed of 19200, The Battery Monitor program connects normally, sees the board and displays all the data on the laptop screen. But the MultiSIBControl program provides RS485 connection only at a speed of 9600 or 115200. Is it possible to make friends with them somehow?
April 18, 20233 yr looks great an I would be prepared to pay for your software if I only could connect my 3 pylontec clones (TAB4836) ! I spent over 40 hours now working on it with diferent cables, settings, drivers, baud rates etc, RX and TX blinks but after a short while it says pylon stopped. I tried to verify the cable and FTDI Chip with batterieviw but once out of several hundered tries batteryview asked my for a barcode numer that it never accepted, maybe because pylontec does not support TAB
April 24, 20233 yr Hi, For those looking for a french translation for MultiSIBControl, il shared my version here: Bonjour, Pour ceux qui seraient à la recherche d'une traduction en français de MultiSIBControl, j'ai partagé ma version ici.
July 14, 20233 yr multisibcontrol works great now with axpert and 3 pylontec unfortunatedly i had to switch to growatt and miss the multisibcontrol
July 23, 20233 yr Hallo an alle Ich kann weder emoncms- noch PVOutput-Daten aus der Software auf meinen iobroker übertragen. Anscheinend liegt das Problem bei der Software, denn ich bekomme Daten zum Iobroker auf der PVOutput.org Homepage. Weiß jemand, was ich falsch mache?
August 15, 20232 yr Is there any chance this will ever be released to accomodate Ginlong Solis Inverters.? They are the only ones I have and would like to monitor them as well as the Pylontechs. Regards Nick
August 26, 20232 yr HI. I installed this software but i want to know how i can connect my pylontech or axpert inverter with my laptop. can someone guide me on this issue. either i have to connnect rs 485 A and B LIne with usb serial bus or i need special connector or device for it. regards
August 31, 20232 yr On 2023/08/26 at 8:42 PM, Ijaz said: HI. I installed this software but i want to know how i can connect my pylontech or axpert inverter with my laptop. can someone guide me on this issue. either i have to connnect rs 485 A and B LIne with usb serial bus or i need special connector or device for it. regards Hello. To connect Pylontech (CONSOLE) to laptop you need : a ) USB to RS232 (female) convertor FTDI chip and b ) one cable RS232 (male) to RJ45 with pinout : 232 Tx pin 3 to RJ45 pin 3 ; 232 Rx pin 2 to RJ45 pin 6 ; 232 GND pin 5 to RJ45 pin 8. All the best.
September 19, 20232 yr Is there any chance this will ever be released to accomodate Ginlong Solis Inverters.? They are the only ones I have and would like to monitor them as well as the Pylontechs. Regards Nick Would like also to Connect a Solis inverterer in Belgium
September 20, 20232 yr Is there any chance this will ever be released to accomodate Ginlong Solis Inverters.? Would like also to Connect a Solis inverterer in Belgium I couldn't find a good solution for a Solis RHI inverter. I tried my luck by contacting solar assistant as they list "Coming soon" for Solis on their website. It turns out the software already supports it, but it's currently just a small group of people using it with Solis. If you already have a Raspberry PI and know how to hook an RS485 adapter hooked up to your inverter or you have a WiFi dongle that supports modbus TCP, they give you a trial to try it. I found the email by using the "Contact us" link at the bottom of the page: https://solar-assistant.io/ It's not free but works well for monitoring. No inverter setting change support yet. Also works with Pylontech.
September 26, 20232 yr I have this error. It worked perfect for 1 year and now i can do anything but i have this error with pylon stopped. I have the right cable bcs it worked for 1 year. What can be ? Ty.
October 17, 20232 yr Hello lads. sorry for my translated english. I'm desperate, I've been trying to connect my Pylontech US 2000 to the PC for a month. I purchased this cable but I can't find online which wires to connect to the RJ plug. Is there any help possible? Thank you https://www.amazon.it/DSD-TECH-SH-RJ45P-Console-PL2303RA/dp/B083S4LXLS/ref=sr_1_2_sspa?__mk_it_IT=ÅMÅŽÕÑ&crid=2LC5E9VCI3CX&keywords=dsd+tech+sh&qid=1697545808&sprefix=dsd+tech+sh%2Caps%2C142&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
October 17, 20232 yr will this software work with jsd solar battries please ? , i am having trouble finding software that will read it and let me do software updates , i have tried via rs232 j11 and via the can socket , cheers , paul
December 26, 20232 yr I just saw version 1.18 was released here. Tested and working well. Pity this is only Windows based. Edited December 26, 20232 yr by jbroo
January 22, 20242 yr Hi Everyone, Has anyone spent some time Device Control tab in MultiSIBControl to get those notifications working through pushsafer? My goal is to e.g. turn on my geyser as soon as my batteries are @ 100%. Still looking for the best way to accomplish this. Any help would be appreciated.
January 25, 20242 yr Hi is there a way to populate a xls file with live data? Similar to a log file. Not talking about exports. It needs to add the live data to a xls file each time it gets the values. Thank You.
September 16, 20241 yr Hi, I have 4 independent inverters connected to the same PC via RS232, only one inverter has Pylontech batteries connected to it. Is it possible to select just this one for monitoring? I can't find an option to select which COM port to use for inverter. Thanks!
October 28, 20241 yr Hi, I use MultiSIB software but I'm only able to see the data from batteries. I don't see any inverter data. Can someone help me understand why? I'm connected to the console port of the master battery Thank you
October 30, 20241 yr On 2024/10/29 at 6:17 AM, Matteo_Mantovani said: I don't see any inverter data. Can someone help me understand why? I'm connected to the console port of the master battery The battery doesn't get much data from the inverter, at least that it can pass on. My understanding is that the computer running MultiSIB has to connect to the inverter, separately from the connection to the battery's BMS.
November 7, 20241 yr On 10/30/2024 at 7:28 AM, Coulomb said: The battery doesn't get much data from the inverter, at least that it can pass on. My understanding is that the computer running MultiSIB has to connect to the inverter, separately from the connection to the battery's BMS. interesting I hadn't thought about the battery being able to receive data from the inverter .and this made me think about 2 things 1- since the battery sends all itsdata to the inverter , why Axpert VM III doesn't show them (for example the temperature and cell voltages ) 2-can I get a WIFI dingle from Ali Axpress (one designed for inverter ) and connected to my battery and fetch data by watch power ?
November 8, 20241 yr 20 hours ago, esmail-kassir said: I hadn't thought about the battery being able to receive data from the inverter . I may have misspoken. Now that I think about it, I think that the BMS to inverter comms is all one way, BMS to inverter. Sorry for the confusion. 20 hours ago, esmail-kassir said: 1- since the battery sends all its data to the inverter , why Axpert VM III doesn't show them (for example the temperature and cell voltages ) The inverter isn't interested in being a data hub; it just wants what it needs. You should be able to get a program that runs on a PC or Pi that communicates separately with the battery's BMS, often via an RS-232 port (as opposed to the RS-485 or CAN bus port for the inverter comms). 20 hours ago, esmail-kassir said: 2-can I get a WIFI dongle from Ali Axpress (one designed for inverter ) and connected to my battery and fetch data by watch power ? I'm 99% sure that this won't work. Watchpower is only for talking to the inverter, not to the battery/BMS.
November 12, 20241 yr Hi, Do you think that is possible to adapt this software to work also with PYTES batteries? I know PYLON is 15S and PYTES is 16S, but by looking at serial console, menu and commands seems to be similar. I have attached captures from console from both PYTES and PYLON. BR! putty log pylon.txt putty log pytes.txt
December 19, 20241 yr Hi I have read through all 5 pages of this post 3 times in order to figure out how to connect my JK Inverter BMS via CAN from the BMS through a USB to RS485 converter. MultiSIB just won't see the batteries. If I use JK's battery management software I can read all the data. It's just a pain in the butt having to check between 2 screens to see what MultiSIB is doing and what JK's battery management software is doing. It would be nice if I could read all the data on MultiSIB. Also I know it's possible to connect MultiSIB to the internet to monitor remotely but reading on how to do the setup is like reading Chinese for me. Could someone point me in the direction of a site that gives a novice the steps on how to set this up? Regards Alan
