High pitched noise from Sunsynk 5 kW inverter
Commissioned a Sunsynk 5kW inverter this evening, there is a high pitched noise emanating from the inverter, which also coming from tv, Xbox, a ups, etc, if the grid is switched off and the load is running on batteries, there is no noise
   Firmware version is 2138
  • Replies 140
  • Views 39.3k
  • Hi Members.  To update on my above post, I ended up booking my inverter in to Sunsynk in JHB on 16 August 2022. I received a call on 19 September that they had looked at the inverter and wou
  • Oberfail
    Oberfail
    I must correct myself. After updating to version 3384, a new option appeared. Settings -> Battery -> Page 2 -> Low Noise mode Enabling this setting shuts the inverter down, "Grid Mode
  • I have a 5kW Deye that I installed about two years ago. Same internals as the Sunsynk. I could never hear the high pitched noise, but Eskom recently installed split-prepaid meters which use powerline
Also had this when I initially commissioned mine. With the cover plate on it was less annoying.
At some point I had switched off the inverter completely and disconnected the batteries.
When I turned on everything again, the pitch was really bad.
After a few days I decided to just switch it off with the power button underneath the inverter - did not switch off anything.
When I switched it back on, the pitch was virtually gone (it is there but really really faint only audible when I get your ears in really close).
Not a technical solution but just what I experienced.
Vassen mentioned that it was worse with a certain firmware upgrade and then improved thereafter again...
I have also had the same problem with the high frequency noise on an 8kW unit. My previous unit at my previous residence was a 5kW unit that I used for about a year, which did not give this noise. When I got my new 8kW in May 2021 at my new residence, I had it installed in the scullery. The high frequency noise was barely audible to my installer because it is around 15,000Hz, but to me it is so loud that I could hear it from 10 metres away, and spending 10 minutes in the scullery doing dishes left me with my ears feeling physical discomfort for an hour or so afterwards. After I had run the system for 2 days, I asked the installer to take the unit back to be assessed by tech support, and he was informed by someone (I'm not sure who he spoke to, I think it might have been Shabir from Sunsynk support, not sure...) that they will not swop out the unit because that is just how the Sunsynks sound, and chances are good that if they give me another unit it will be even louder. I then had to pay my installer another installation fee to move the whole setup outside the house, which was another 2 days' work. I was quite disappointed in the supplier for not swopping out the unit.
So to anyone considering a Sunsynk, put it in the garage or outside the house, as the high frequency noise seems to be the luck of the draw.
(EDIT:  I had the software upgraded, which did not make a difference)
Edited by Bernardf
Does the noise only come from the inverter or also audible from all these devices? If also from TV etc, from the device itself or from their speakers?
I also noticed a high pitched sound from the microwave after I added batteries to my 5k inverter. It's not too loud but will hear it when I walk past it.
Just switched my 2 new Sunsynks on - and also had a very loud high noise coming from one of them ☹️ So loud, that I can even hear it from the next room...
Will await the firmware upgrade tomorrow and then see if anything changes
1 minute ago, Tariq said:
that is great service
Agreed - was also impressed
Does your inverter make the high frequency noise when grid is switched off
I only ever had it connected to battery, no grid. Once the inverter had completed the start-up procedure and 'clicked', the noise immediately started. Left it running for 20 mins like this but no change
9 minutes ago, Tariq said:
This inverter only makes the high frequency noise ONLY when on grid,
Similarly loud noise as mine?
Mine was a v1.4
My 2nd inverter is v1.5 and virtually silent
3 hours ago, Tariq said:
My friend can even hear it through a clothing iron, his is model with the fan
😕 Has he tried raising it with his seller?
You mean with the external fan in the back, right? Then I think it is also v1.4 like mine was
@wolfandy He is in contact with Shabbir at Sunsynk, wants them to fix the problem on HIS inverter, as there is no guarantee that the new inverter will not have the same noise issue and then the process starts all over again.
 Yes, he has the v1.4 with the fan
Edited by Tariq
Good luck to him
My replacement v1.5 is sitting with my complex security, waiting for me to return back home and install it on Saturday. As my other v1.5 was fine, I am hoping so will this one be
6 minutes ago, wolfandy said:
Good luck to him
Maybe he should wait till you install yours this weekend and give us a report, then we might be able to say that the v1.5 has taken care of the problem
Will post an update here on the weekend
  • 7 months later...
same here tariq.. noise coming from my pc(power supply) and my cordless phone  ..its so annoying
any recommendation?
Edited by Mahdi
