August 5, 20233 yr I have a Deye 5kv inverter with 9 x Jinko 555w panels on one string. The voltage with load is around 420v and I have another panel that i want to add on. The Voc on the panel is 49.72v which will still be below the 500v limit, it is safe to add another panel to this?
August 5, 20233 yr 4 minutes ago, Shai said: I have a Deye 5kv inverter with 9 x Jinko 555w panels on one string. The voltage with load is around 420v and I have another panel that i want to add on. The Voc on the panel is 49.72v which will still be below the 500v limit, it is safe to add another panel to this? With these panels you are already running a risk that the voltage can get too high for comfort. Also to make it worse you will have a voltage exceeding the MPPT range. Rather not do it.
August 5, 20233 yr You can have maximum of 8 of those panels on 1 string. 9 is already over the limit.
August 5, 20233 yr Jinko 555wp Voc = 49.72v. So 9 x 49.72 = 447.48v + 7.5% = 481v. The Deye 5kw Mppt voltage should not exceed 425v so @PowerUseris correct you have already exceeded the safe operating voltage of the Mppt with 9 panels. I agree with @Scorp007do not add another panel rather remove 1 panel from that string. The Mpp(maximum power point) of the Mppt is 370v the sweet spot.
August 5, 20233 yr Is your MPPTs not clipping your production, since the MPPT for the Deye 5kW is rated at 11A and the Jinco 555W panel specs are 13.33A at STC?
August 6, 20233 yr 1 hour ago, Induna said: Is your MPPTs not clipping your production, since the MPPT for the Deye 5kW is rated at 11A and the Jinco 555W panel specs are 13.33A at STC? The MPPT on the SunSynk 5kW is rated for 13A with the latest versions of the firmware. The same should apply for the Deye as well. They are the same inverter.
August 6, 20233 yr 39 minutes ago, PowerUser said: The MPPT on the SunSynk 5kW is rated for 13A with the latest versions of the firmware. The same should apply for the Deye as well. They are the same inverter. Thanks for the info. I was not aware of the upgrade and their datasheets still reflect 11A per MPPT. Yep, I know the Deye, Sunsynk and Sol-Ark is one and the same inverter, just with different OS's.
August 6, 20233 yr 6 hours ago, Induna said: Is your MPPTs not clipping your production, since the MPPT for the Deye 5kW is rated at 11A and the Jinco 555W panel specs are 13.33A at STC? We must be careful not to confuse "clipping" or current limiting of the Mppt with the maximum voltage allowed. Overvoltage is detrimental to the Mppt controller as this exceeds the components voltage thresholds. When the batteries are full and the SCC stops taking current, the panels 'see' this as an open circuit and the voltage will rise to Voc.
August 6, 20233 yr Author My mppt is not clipping at all, its maximum is 12.2a Would putting 5 panels on 2 strings still give me about 4.5K plus power ?
August 6, 20233 yr Just now, Shai said: My mppt is not clipping at all, its maximum is 12.2a It is clipping you can see that by how how flat your graph is at the top. 1 minute ago, Shai said: Would putting 5 panels on 2 strings still give me about 4.5K plus power ? Yes they should if they are all facing the same direction. Depending on direction they are facing it may be slightly better or worse.
August 6, 20233 yr Definitely split into two strings, otherwise will only be a matter of time till you see the magic smoke coming from your inverter 🙂
August 6, 20233 yr 28 minutes ago, Nexuss said: It is clipping you can see that by how how flat your graph is at the top. Yes they should if they are all facing the same direction. Depending on direction they are facing it may be slightly better or worse. Spot on that the inverter is already clipping. 2 strings of 5 connected 5 per MPPT should give you over 4.5kW if you currently getting 12.2A at 420V under load=5.1kW which seems very high. Edited August 6, 20233 yr by Scorp007
August 6, 20233 yr 41 minutes ago, Shai said: My mppt is not clipping at all, its maximum is 12.2a Would putting 5 panels on 2 strings still give me about 4.5K plus power ? How old is your firmware? Maybe you haven't upgraded to a recent version which allows 13A per MPPT.
August 6, 20233 yr Author i'm not sure the firmware however i think i will just split the string in two . I have checked on the sticker that it shows 13A per string
August 7, 20233 yr On 2023/08/06 at 8:49 AM, Shai said: My mppt is not clipping at all, its maximum is 12.2a Would putting 5 panels on 2 strings still give me about 4.5K plus power ? You getting 12.2A now in winter?
August 7, 20233 yr Author 14 minutes ago, Chris_S said: You getting 12.2A now in winter? yes , maximum today was 12.5Amps. I have decided to put the panels on 2 stings of 5 each.
