Youda's off-grid LAB
41 minutes ago, Youda said:
Hi @PurePower
Just double-checked that and I can confirm that at the end of 2022 the latest FW versions for US2000 variants were:
US2000plus = us2000b_v2.9_Crc.bin
US2000plus95 = us2000B_Plus_V3.4_Crc.bin
For a shame, I do not have the first file, just the second one. Sorry :(
Also, there's no easy way of identify which variant you have, as both of the above are reporting device model = 2KBPL in the BatteryView.
On top of that, beware that:
- US3000 firmware is NOT compatible with US2000, so don't try to flash us3000a_V3.4_Crc.bin in the US2000.
- US2000C and US3000C firmware IS unified. You can flash it into both, US2000C and US3000C.
- US5000 has a special firmware.
Like I wrote in the beginning - if it works, then don't repair it. However, if you have some problems and will be able to get us2000b_v2.9_Crc.bin from your seller or Pylontech support, then share it with the others afterwards, please.
Thanks for the update, yip i am fully aware of not mixing the various firmware's. For the sake of science, I loaded the us3000a firmware onto a us2000b plus module. Firmware loaded fine but it registered the device as a 75ah module which it was not. The firmware load worked as they use the same CMU and PMU board just the us3000a has a larger capacity battery. Firmware's were specifically made for their respective capacity at the time. The C models are different as after the firmware load, you are asked to specify the aH of the battery, hence the reason why the US2000C and US3000C can use the same firmware zip files.
I searched for v2.9 and managed to only find the us2000BPLS_v2.9_Crc.bin file. Here it is.
US2000BPLS_V2.9_Crc.bin
I am personally running v3.4 in 4 of my US2000B Plus modules with no issues.
Edited by PurePower
  • Replies 422
  • Views 232.5k
Oh man! Looks like you do know what the fear is :D
Yeah, exactly.
Funny is, that no matter what, the BatteryView is always asking user for entering the coulomb value at the end of the FW update, even if it cannot use it. For the models like US2000 or US3000 it logs error then, but for the C models it actually writes that value in the NVRAM as seen on the attached screenshots.
It says coulomb, but it's actually expecting amp-hours, like 50 or 74:
US3000:
US3000C:
On 2020/08/20 at 11:47 AM, Youda said:
Last year, I added a wallbox to my solar, for charging electric vehicles. It's a single-phase 32A, so the max charging power is roughly 7.5kW.  Some details are written in my previous post here: https://powerforum.co.za/topic/2322-youdas-off-grid-lab/page/2/?tab=comments#comment-58507
Personally, I don't own an EV, but for the nine months in a year the solar production is so excessive, that I have no use for all that power. Therefore, I offered EV charging for free and published the wallbox location on the PlugShare.com and on some other local charging maps too. Since then, curious EV drivers are stopping by, mostly just to check whether the charging a car from solar is really possible. And yes - it is :)
Some of the cars that stopped for charging were Mitsubishi (hybrid), Citroen C-Zero, Hyundai Ioniq, Fiat 500e and the last one, just couple of days ago, was Hyundai Kona.
Hyundai Ioniq:
Fiat 500e:
Hyundai Kona:
Most of the drivers are charging just for 30 minutes or so, which equals to 3-4kWh and 15km of range. On the chart below, it's marked as "EVSE". If I do remember correctly, just one driver stayed longer than hour and took 8kWh. That equals to 30-40km, based on the model of the car.
By the way - is there anybody else on the forum, charging his EV from the off-grid solar? If so, do you offer free charging to the other drivers or not?
Since the original post above, dozens of hybrids and EV's stopped by my solar charger for a few kWh's. Here's a couple of them:
The last one was funny:
Renault was charging for an hour or so, then the Merc arrived and queued-up...on a slow solar charger :D
The Renault let him to and the Merc was charging for 2,5hrs.
Later that day, Renault arrived once again - as seen on the chart bellow:
Pylontech is sending out the us2000B_Plus_V3.4_Crc.bin firmware for older US2000B plus batteries as well, so I suspect that they might be allowing the 95% discharge even on the older batteries. Alternatively, the firmware could be smart and detect the minimum SoC from the serial number. I have never run any of my batteries down below 15% SoC, so I do not know.
It could have been a mistake on their part, but since I only gave them the serial number for the battery (I didn't mention the model number) in my firmware request I reckon it's not likely.
This definitely sounds like what Pylontech is doing, its my suspicion as well. I am using US2000B's purchased between 2017 - 2019, all running v3.4 without any issues.
BatteryView HV 3.5 and 3.8
Pylontech's "BatteryView HV" is a diagnostic tool used for the high-voltage batteries like:
  • H48050 + external BMS
  • Force H1
  • Force H2
If you are adding a new brick to the existing high-voltage stack, this tool might be useful for checking the voltage levels of the individual cells and ensuring that the stack is properly balanced.
You'll need a Windows laptop with a serial port (or with USB2Serial converter) and a serial cable. Bear in mind that you will need real RS232 interface, NOT the 5V/3.3V UART.
Common pinout of the RJ-45 CONSOLE port on the most of the Pylontech HV batteries:
If your battery uses a different pinout, then consult the wiring with the product manual.
Edited by Youda
This is amazing!!
@tomvi
for the BatteryView HV 3.8.2:
User = user
Administrator = Pylon2019001!
Warning: Do not play with the stuff you are not trained on.
Youda
Edited by Youda
9 hours ago, Youda said:
@tomvi
User = user
Youda
Thank you, i used terminal to scan batteries and i got very strange results. 5 batteries are ok, the last one is completely out of order. At the same time, BMS pretends that everything is in order and Gooodwe writes that the SOC is 50%
Perhaps I can insert a slightly longer statement here
pylon_debug>unit
AverageTempr: 14111
Index  Volt   Curr   Tempr  AvgTempr BTlow  BThigh BVlow  BVhigh Base.St  Volt.St  Temp.St  CoulombAH                CoulombWH               Time
1      49340  0      17000  12000  12000  12000  3287   3291    Idle     Normal   Normal    84%          41819 mAH  83%            1995 WH 2023-02-21 03:37:28
2      49335  0      18000  13333  13000  14000  3289   3289    Idle     Normal   Normal    84%          41819 mAH  83%            1995 WH 2023-02-21 03:37:28
3      49355  0      18000  14000  14000  14000  3290   3291    Idle     Normal   Normal    84%          41819 mAH  83%            1995 WH 2023-02-21 03:37:28
4      49346  0      18000  14000  14000  14000  3289   3290    Idle     Normal   Normal    84%          41819 mAH  83%            1995 WH 2023-02-21 03:37:28
5      49364  0      19000  15000  15000  15000  3290   3291    Idle     Normal   Normal    84%          41819 mAH  83%            1995 WH 2023-02-21 03:37:28
6      49311  0      20000  16333  16000  17000  3287   3288    Idle     Normal   Normal    50%          25123 mAH  54%            1286 WH 2023-02-21 03:37:28
Command completed successfully
pylon_debug>bat
Time: 2023-02-21 03:37:36
A.Tempr: 14111
C.Curr : 25000   mA
D.Curr : -25000  mA
B.State: Idle
BalVolt: 3360
Bat  Volt Curr    Tempr   V.State T.State AH(mAH)       WH(mWH)            Bal
0    3286 0       12000   Normal  Normal   84%    41819  84%       133758   N
1    3291 0       12000   Normal  Normal   84%    41819  84%       133748   N
2    3290 0       12000   Normal  Normal   84%    41819  84%       133749   N
3    3290 0       12000   Normal  Normal   84%    41819  84%       133751   N
4    3292 0       12000   Normal  Normal   84%    41819  84%       133754   N
5    3289 0       12000   Normal  Normal   84%    41819  84%       133752   N
6    3289 0       12000   Normal  Normal   84%    41819  84%       133751   N
7    3290 0       12000   Normal  Normal   84%    41819  84%       133750   N
8    3288 0       12000   Normal  Normal   84%    41819  84%       133751   N
9    3290 0       12000   Normal  Normal   84%    41819  84%       133753   N
10   3289 0       12000   Normal  Normal   84%    41819  84%       133751   N
11   3289 0       12000   Normal  Normal   84%    41819  84%       133748   N
12   3290 0       12000   Normal  Normal   84%    41819  84%       133749   N
13   3290 0       12000   Normal  Normal   84%    41819  84%       133752   N
14   3287 0       12000   Normal  Normal   84%    41819  84%       133762   N
15   3289 0       14000   Normal  Normal   84%    41819  84%       133741   N
16   3289 0       14000   Normal  Normal   84%    41819  84%       133734   N
17   3289 0       14000   Normal  Normal   84%    41819  84%       133737   N
18   3289 0       14000   Normal  Normal   84%    41819  84%       133737   N
19   3289 0       14000   Normal  Normal   84%    41819  84%       133738   N
20   3289 0       13000   Normal  Normal   84%    41819  84%       133741   N
21   3289 0       13000   Normal  Normal   84%    41819  84%       133734   N
22   3289 0       13000   Normal  Normal   84%    41819  84%       133736   N
23   3289 0       13000   Normal  Normal   84%    41819  84%       133736   N
24   3289 0       13000   Normal  Normal   84%    41819  84%       133741   N
25   3289 0       13000   Normal  Normal   84%    41819  84%       133743   N
26   3289 0       13000   Normal  Normal   84%    41819  84%       133739   N
27   3289 0       13000   Normal  Normal   84%    41819  84%       133738   N
28   3289 0       13000   Normal  Normal   84%    41819  84%       133740   N
29   3289 0       13000   Normal  Normal   84%    41819  84%       133743   N
30   3290 0       14000   Normal  Normal   84%    41819  84%       133738   N
31   3290 0       14000   Normal  Normal   84%    41819  84%       133734   N
32   3290 0       14000   Normal  Normal   84%    41819  84%       133733   N
33   3290 0       14000   Normal  Normal   84%    41819  84%       133736   N
34   3290 0       14000   Normal  Normal   84%    41819  84%       133738   N
35   3290 0       14000   Normal  Normal   84%    41819  84%       133739   N
36   3290 0       14000   Normal  Normal   84%    41819  84%       133734   N
37   3291 0       14000   Normal  Normal   84%    41819  84%       133732   N
38   3290 0       14000   Normal  Normal   84%    41819  84%       133735   N
39   3290 0       14000   Normal  Normal   84%    41819  84%       133737   N
40   3291 0       14000   Normal  Normal   84%    41819  84%       133737   N
41   3291 0       14000   Normal  Normal   84%    41819  84%       133734   N
42   3291 0       14000   Normal  Normal   84%    41819  84%       133733   N
43   3291 0       14000   Normal  Normal   84%    41819  84%       133734   N
44   3290 0       14000   Normal  Normal   84%    41819  84%       133739   N
45   3290 0       14000   Normal  Normal   84%    41819  84%       133726   N
46   3290 0       14000   Normal  Normal   84%    41819  84%       133720   N
47   3290 0       14000   Normal  Normal   84%    41819  84%       133720   N
48   3290 0       14000   Normal  Normal   84%    41819  84%       133721   N
49   3290 0       14000   Normal  Normal   84%    41819  84%       133722   N
50   3290 0       14000   Normal  Normal   84%    41819  84%       133726   N
51   3290 0       14000   Normal  Normal   84%    41819  84%       133721   N
52   3290 0       14000   Normal  Normal   84%    41819  84%       133721   N
53   3289 0       14000   Normal  Normal   84%    41819  84%       133721   N
54   3289 0       14000   Normal  Normal   84%    41819  84%       133725   N
55   3290 0       14000   Normal  Normal   84%    41819  84%       133726   N
56   3290 0       14000   Normal  Normal   84%    41819  84%       133720   N
57   3290 0       14000   Normal  Normal   84%    41819  84%       133720   N
58   3290 0       14000   Normal  Normal   84%    41819  84%       133719   N
59   3290 0       14000   Normal  Normal   84%    41819  84%       133725   N
60   3291 0       15000   Normal  Normal   84%    41819  84%       133732   N
61   3291 0       15000   Normal  Normal   84%    41819  84%       133728   N
62   3291 0       15000   Normal  Normal   84%    41819  84%       133726   N
63   3291 0       15000   Normal  Normal   84%    41819  84%       133731   N
64   3291 0       15000   Normal  Normal   84%    41819  84%       133735   N
65   3291 0       15000   Normal  Normal   84%    41819  84%       133731   N
66   3291 0       15000   Normal  Normal   84%    41819  84%       133728   N
67   3291 0       15000   Normal  Normal   84%    41819  84%       133730   N
68   3291 0       15000   Normal  Normal   84%    41819  84%       133728   N
69   3290 0       15000   Normal  Normal   84%    41819  84%       133734   N
70   3291 0       15000   Normal  Normal   84%    41819  84%       133735   N
71   3291 0       15000   Normal  Normal   84%    41819  84%       133729   N
72   3291 0       15000   Normal  Normal   84%    41819  84%       133730   N
73   3291 0       15000   Normal  Normal   84%    41819  84%       133728   N
74   3291 0       15000   Normal  Normal   84%    41819  84%       133733   N
75   3287 0       17000   Normal  Normal   50%    25123  52%        83829   N
76   3288 0       17000   Normal  Normal   53%    26413  55%        87951   N
77   3288 0       17000   Normal  Normal   52%    26123  54%        86995   N
78   3288 0       17000   Normal  Normal   50%    25123  52%        83777   N
79   3288 0       17000   Normal  Normal   54%    26913  56%        89658   N
80   3288 0       16000   Normal  Normal   52%    25913  54%        86393   N
81   3287 0       16000   Normal  Normal   50%    25123  52%        83719   N
82   3287 0       16000   Normal  Normal   53%    26413  55%        87940   N
83   3287 0       16000   Normal  Normal   51%    25623  53%        85361   N
84   3287 0       16000   Normal  Normal   51%    25623  53%        85457   N
85   3287 0       16000   Normal  Normal   53%    26413  55%        88060   N
86   3288 0       16000   Normal  Normal   52%    25913  54%        86391   N
87   3288 0       16000   Normal  Normal   51%    25623  53%        85404   N
88   3288 0       16000   Normal  Normal   51%    25623  53%        85418   N
89   3287 0       16000   Normal  Normal   53%    26413  55%        88086   N
On 2023/02/02 at 11:26 PM, Youda said:
5) This list indicates firmware version suitable for the each model and what file to flash:
Model: US2000plus
FW: V2.9
FLASH: us2000b_v2.9_Crc.bin
Model: US2000plus95
FW: V3.4
FLASH: us2000B_Plus_V3.4_Crc.bin
Model: US3000
FW: V3.4
FLASH: us3000a_V3.4_Crc.bin
Model: US2000C (original chip)
FW: V2.8
FLASH: NT1.7+2.8.zip
Model: US3000C (original chip)
FW: V2.8
Model: US2000C (new chip)
FW: V1.7
Model: US3000C (new chip)
FW: V1.7
Model: US5000 (original chip)
FW: V1.3
FLASH: US5000 ST+NT 1.3.zip
Model: US5000 (new chip)
FW: V1.3
New firmware for the C model range. Its an update to v1.8 for the new chip C models.
NT1.8+ST2.8.zip
Edited by PurePower
Hi all, i'm using Pylontech US3000c in a custom solar system. My question is: is it possible to leave a 53V fixed charger voltage even if battery is 100% charged? In my system this can happen during the daylight since i don't manage charger stop when battery reached 100% SOC or "charge enable" flag from battery is "0". I'm not sure if the charger stop is mandatory in these condition or not...
Edited by gt4020
Yes, it is possible, but:
1) You don't have to stop the charger once the Pylontech is charged to 100% SoC, as once the voltage of battery reaches the voltage set on the charger then the charging current will quickly drop to zero.
You just have to watch for the situations where the voltage of charger suddenly jumps up. This might happen when large AC load is switched off, while the sun is fully shining. This might cause overvoltage alarm, if the resting voltage of the battery is already too high.
Therefore, if you don't have a way how to disable the charger, it's better to set the charger to 52,5V (15x 3,5V). Such a voltage is still able to charge Pylontech to 100% SoC, while leaving sufficient "voltage margin" for these unexpected jumps.
Got it?
2) Even some basic chargers have 2 settings that you can combine, in order to protect the battery from overvoltage and/or overcharging:
  • CC voltage = 53V
  • CV voltage = 52,5V.
When both settings above are used together, the battery is charged to 53V first, then the charger lowers it's voltage to the resting 52,5V.
3) This is how the charging current looks in the last stage of charging, when the voltage of the Pylontech starts to reach the voltage set on the charger:
  • From 10:00 the charging currents starts to drop quickly, reaching zero amps at 10:25.
  • Note a small current spike at 10:46 - it's caused by a sudden voltage jump mentioned above.
I would assume senario 2 would be using the inverter's communication link to Pylontech BMS and these particular settings would be available to configure in the inverter/charger software. Seem to recall seeing it on my Multiplus.
Got it?
  • CC voltage = 53V
Ok, i noticed the Pylon charge current behaviour when i designed my solar charger (it is a charger produced by me), so i assumed that Pylontech bms is able to manage itself entirely charge process. For this reason i did not add a way to stop charge at 100 % or when charge enable flag is 0. Lately however i tested an Mpp solar inverter with Pylontech batteries and i noticed that they completely stop charge when battery is 100%. For this reason i was asking what is the correct way to manage a fully charged Pylon battery. Response seems to be that leaving fixed 53V or stopping charger at 100% soc is indifferent... Do you agree?
Not really @warick_wrx
Scenario 2 is possible even without any comm cable between the Pylontech BMS and Inverter. It works purely based on the analog voltage and current measurement. It's basically the same logic that was used for lead-acid batteries in the old times when there were no BMS.
If you have a comm cable and working communication between the BMS and the inverter, the possibilities are even richer.
Yeah, in reality, both of these have a very similar effect. Let me just repeat that 53V is too much. Set your charger to 52,5V and that's it. No communication with the BMS necessary.
In order to be precise: Normally, Pylontech BMS does NOT limit charging current. Yes, there is FET in the BMS input, but it's used as ON/OFF protective device only. The reason why you see that the charging current is going down is based purely on the fact that the battery is full and it's not accepting charge anymore. Lead-acid battery, without any BMS, has a very similar curve too. The only difference is that with the lead-acid the last stage of charging takes much longer, the amps curve is not so steep....and voltage levels per cell are different, of course:
Programmable Battery Charger for Lead-Acid and Lithium Batteries -MEAN WELL  Switching Power Supply Manufacturer
Example of practical implementation in a Mean Well charger: https://www.meanwell.com/newsInfo.aspx?c=5&i=946
In my experience with Us3000 and US2000 i'm quite sure that during charge, when Soc rise to almost 100%,charging current has not a linear or parabolic  descending curve, but it switch from full current charge to 10A and 2A (maintaining charger in CV @ 53V), so i think that bms has some sort of current modulation. I have an us3000c on my work table, tomorrow i will test again voltage/current charging curve...
On 2020/08/29 at 11:22 AM, Youda said:
Hi guys,
based on the fact that many forum users are trying to understand how to use Pylontech batteries efficiently, I've extracted some of the internal configuration values. It's from a stack of 8xUS3000. What instantly catched my eye are especially these values. So I added a couple of my comments and thougths:
Total Num                 : 8                    //Number of maximum daisy-chained bricks supported by the firmware.
Present Num            : 8
//Number of actually daisy-chained (RS485) bricks.
Shut time                  : 72.0 H            //If the brick is not charged/discharged for 3 days, it will auto-power off.
Balance Volt             : 30 mV
Balance Start           : 3360 mV
//Looks like the BMS is able start balancing cells at this voltage it's not
                                                          //a static top-balancing, as I know that the BMS chip is able to stop balancing
                                                          //at a much higher voltage, if all the cells are at roughly the same voltage level.
Recommend chg voltage    : 53250    mV   //This is what inverters like Axpert are reading
        //from the BMS and using as CC.
Over VoltageR           : 51000 mV                 //Strange, that this is triggered at 51V, given
        //the recommended CC=53.2V.
High VoltageR           : 52500 mV
High Voltage             : 53900 mV                 //Just 650mV of margin between recommended CC=53.2V and alarm.
Over Voltage             : 54000 mV                 //Just 750mV of margin between recommended CC=53.2V and panic.
A complete list goes here. Please note that the column "Battery" means actually a CELL while the column "Power" means a single US3000 BRICK:
Protect Attribution
 Item                      Battery       Power
 Over Voltage            : 3700          54000     mV
 Over VoltageR           : 3600          51000     mV
 High Voltage            : 3650          53900     mV
 High VoltageR           : 3500          52500     mV
 Low Voltage             : 3050          46000     mV
 Low VoltageR            : 3100          47000     mV
 Under Voltage           : 2900          44500     mV
 Under VoltageR          : 3250          49000     mV
 Sleep Voltage           : 2500          38000     mV
 Charging OT             : 61000         61000     mC
 Charging OTR            : 55000         55000     mC
 Charging HT             : 59000         59000     mC
 Charging HTR            : 55000         55000     mC
 Charging LT             : -9000         -9000     mC
 Charging LTR            : -5000         -5000     mC
 Charging UT             : -11000        -11000    mC
 Charging UTR            : -5000         -5000     mC
 Discharging OT          : 61000         61000     mC
 Discharging OTR         : 55000         55000     mC
 Discharging HT          : 59000         59000     mC
 Discharging HTR         : 55000         55000     mC
 Discharging LT          : -9000         -9000     mC
 Discharging LTR         : -5000         -5000     mC
 Discharging UT          : -11000        -11000    mC
 Discharging UTR         : -5000         -5000     mC
 Charging OC             : 102000                  mA
 Charging OC Alarm       : 50000                   mA
 Charging OC AlarmR      : 40000                   mA
 Discharging OC          : -100000                 mA
 Discharging OC Alarm    : -50000                  mA
 Discharging OC AlarmR   : -45000                  mA
 OC Delay                : 15000                   mS
 OC Release              : 60000                   mS
 Charging OC2            : 200000                  mA
 Discharging OC2         : -200000                 mA
 OC2 Delay               : 100                     mS
 OC2 Release             : 60000                   mS
 Discharging SC          : -400000                 mA
 SC Delay                : 0                       mS
 SC Release              : 60000                   mS
 Charging Max Cur        : 10000                   mA
 Shut time               : 72.0 H
 BUV/PUV time            : 2400 S
 Sleep ctrl state        : OFF
 Sleep every day
 StartTime               : 20:00
 EndTime                 : 08:00
 HwSleepInfo
 HwSleepStatus           : OFF
 HwSleepTime             : 6 S
 HwWakeupTime            : 60 S
 Data Save every day
 StartTime               : 00:00
 EndTime                 : 23:59
 Save Interval           : 1800 S
Power System Information
 System is idle
 Total Num                : 8
 Present Num              : 8
 Sleep Num                : 0
 System Volt              : 49381    mV
 System Curr              : -367     mA
 System RC                : 352367   mAH
 System FCC               : 585266   mAH
 System SOC               : 60       %
 System SOH               : 99       %
 Highest voltage          : 3294     mV
 Average voltage          : 3292     mV
 Lowest voltage           : 3290     mV
 Highest temperature      : 23000    mC
 Average temperature      : 21875    mC
 Lowest temperature       : 21000    mC
 Recommend dsg voltage    : 47000    mV
 Recommend chg current    : 296000   mA
 Recommend dsg current    : -296000  mA
Hope this helps all the young scientists that are developing their own monitoring and control solution for the batteries and inverters ;)
Youda
A big thank for this informations!
If I may ask a question, as I try to run a setup with presently 2 US2000 and 1 US200C, linked to Growatt inverter(s), but I have an issue with my 2nd inverter, it doesn't communicate with BMS, and thus I can't include it in my setup.
This issue I try to solve with Growatt, but it may take some time, and I woud like to run the setup without BMS communication on both inverters, wich needs to set correct voltages in the inverters: Charge voltage, float voltage and low DC cut-off.
Do you think that 53.2V for charge voltage, 52.5V for Float and 44,5V for low DC cut off are correct values for my 3 Pylontech stack?
Possibly a bit off topic here, but I'll ask anyway.
Has anyone ever seen that US3000's report a SOC higher than 100%
I have two in parallel and quite often find them to be 117% charged. They are obviously not overflowing with electrons, but I suspect that there is some kind of calibration issue with the SOC.
Any ideas, comments, suggestions?
On 2023/04/12 at 5:58 PM, gt4020 said:
I'm testing an US3000C charge curve with CC/CV power supply at 52.85V. THis is the graph at the end of charge. I also tried to vary CV voltage from 52,85 to 53,25V (you can see a short current peak after voltage increase). I noticed that when battery is at 100% current drops near to 0A but battery cells are held at charger voltage/15 all the time. My question is: is it acceptable to maintain cells at maximum voltage for some hour per day even if they are fully charged? LiPoFe batteries life is not shorted when they stay at 100% voltage for many time?
image.thumb.png.a2071fdf064bdc187927513732dd30e6.png2023-04-1413_00_56-.thumb.png.9c078f377a5f3cc38024453d5daae68e.png
Edited by gt4020
