June 14, 20233 yr Author 1 hour ago, fStof said: Is there a way to check with a multimeter maybe if the inverter has the resistor already built in? More than likely doesn't, I think the terminating resistor is built in on the Sunsynk's
June 14, 20233 yr 1 hour ago, fStof said: No I did not... Is that a thing? What is the purpose? Yes its a thing. Measure the voltage across A and B. You should get around 4-5 volts. If not remove R7 as you dont need the terminating resistor Edited June 14, 20233 yr by slipx
June 14, 20233 yr 2 hours ago, slipx said: Yes its a thing. Measure the voltage across A and B. You should get around 4-5 volts. If not remove R7 as you dont need the terminating resistor Yea I get 4.5v across A and B on the Inverter side. So the resistor is not the issue. Anything else I might be missing or need to check?
June 15, 20233 yr Shooting in the dark here but maybe try another LAN cable or even try using pin 4 for flow control Why did you disable CRC? uart: id: mod_bus tx_pin: 17 rx_pin: 16 baud_rate: 9600 stop_bits: 1 debug: direction: BOTH dummy_receiver: false after: delimiter: "\n" sequence: - lambda: UARTDebug::log_string(direction, bytes); modbus: id: modbus1 uart_id: mod_bus flow_control_pin: 5 disable_crc: true
June 15, 20233 yr 26 minutes ago, slipx said: Shooting in the dark here but maybe try another LAN cable or even try using pin 4 for flow control Why did you disable CRC? I actually just cut up one of the cables that came with one of my batteries... figured it would be good enough. I'll try another cable and feed back... Thanks CRC is disabled because "Bad CRC" errors were flooding my logs
June 15, 20233 yr Before you go and do crazy things with wiring, try adding this to your ESP32 YAML config file: esp32: board: esp32dev framework: type: arduino version: 2.0.6 Later versions of the library broke something in the RS485 support, and forcing using version 2.0.6 resolved this for me. (Before mine did exactly the same as yours.)
June 15, 20233 yr 4 hours ago, slipx said: Shooting in the dark here but maybe try another LAN cable or even try using pin 4 for flow control Tried pin 4 with no change (well I got the warning in logs during compile: "WARNING GPIO4 is a Strapping PIN and should be avoided.") 3 hours ago, sgs said: Before you go and do crazy things with wiring, try adding this to your ESP32 YAML config file: Later versions of the library broke something in the RS485 support, and forcing using version 2.0.6 resolved this for me. (Before mine did exactly the same as yours.) Also no difference
June 18, 20233 yr So now I tried with a different cable (CAT6 - Unshielded) and still no difference... values are all over the place Anything else I could try? Would a shielded cable make any difference? I'm running out of options here. Very frustrating.
June 18, 20233 yr 5 minutes ago, fStof said: So now I tried with a different cable (CAT6 - Unshielded) and still no difference... values are all over the place Anything else I could try? Would a shielded cable make any difference? I'm running out of options here. Very frustrating. Haven't read through the problems you're experiencing, but in specific reply to this one post: when extending a temperature sensor (15m) I got erratic readings until I installed a shielded cable - after that readings have been perfect... Shielding goes a long way protect from electromagnetic interference...
June 18, 20233 yr 5 hours ago, markus_m2 said: Haven't read through the problems you're experiencing, but in specific reply to this one post: when extending a temperature sensor (15m) I got erratic readings until I installed a shielded cable - after that readings have been perfect... Shielding goes a long way protect from electromagnetic interference... We'll mine is like 30cm
June 18, 20233 yr @fStof where are you based? I have a spare RS485 ttl adapter you can try. I know you said your voltage across A/B pins was fine but maybe try remove the r7 resistor and see what happens.
June 18, 20233 yr 4 hours ago, slipx said: @fStof where are you based? I have a spare RS485 ttl adapter you can try. I know you said your voltage across A/B pins was fine but maybe try remove the r7 resistor and see what happens. I'm in Pretoria East area... I guess I don't have many other options Thanks
June 18, 20233 yr BOOM! Seems R7 was the culprit. Data loop soos stroop. Thanks for all the input guys... Now to make sure the rest of my address registers are correct
June 27, 20233 yr Firstly, many thanks for the incredible community contributions! Without them, I'd be watching Netflix a lot more! Secondly, I'm really struggling getting the data out my SS8 and have spent a full day exploring all configurations. I've taken primary guidance from this YouTube video and mange to get up to the point of flashing the ESP32 with the yaml however it looks like I'm not getting any data back: My setup: RaspberryPI 3b HomeAssistant version 2023.6.3 ESPHome installed Sunsynk 8kva (set to Slave) Removed R7 resistor I have tried the following setups: Setup 1 substitutions: settings_skipped_updates: "30" devicename: sunsynk esphome: name: esphome-web-d3def0 esp32: board: esp32dev framework: type: arduino # Enable logging logger: baud_rate: 0 # Enable Home Assistant API api: # encryption: # key: !secret api_encryption_key ota: # password: !secret ota_password wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: !secret device_onboard_wifi password: !secret fallback_password fast_connect: true power_save_mode: none captive_portal: # Enable time component to reset energy at midnight # https://esphome.io/components/time.html#home-assistant-time-source time: - platform: homeassistant id: homeassistant_time uart: id: mod_bus tx_pin: 17 # Also tried value 'GPIO17' rx_pin: 16 # Also tried value 'GPIO16' baud_rate: 9600 stop_bits: 1 modbus: id: sunsynk_modbus flow_control_pin: 4 # Also tried value 'GPIO4' modbus_controller: - id: sunsynk address: 0x01 modbus_id: sunsynk_modbus setup_priority: -10 update_interval: "15s" command_throttle: "50ms" <cropped> Pic of the above setup... And also tried network cable numbers 2 and 7 (Green & Orange stripe) into A and 1 and 8 (Orange & Green stripe) ->B Setup 2 esphome: name: esphome-web-868580 friendly_name: ESPHome Web 868580 esp32: board: esp32dev framework: type: arduino substitutions: settings_skipped_updates: "30" devicename: sunsynk # Enable logging logger: baud_rate: 0 # Enable Home Assistant API api: encryption: key: "zgG8S4ludLRSOV8+CSsiqbU+nQ5Q+bQNJIjrXFzwedk=" ota: wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: !secret device_onboard_wifi2 password: !secret fallback_password2 fast_connect: true power_save_mode: none captive_portal: # Enable time component to reset energy at midnight # https://esphome.io/components/time.html#home-assistant-time-source time: - platform: homeassistant id: homeassistant_time uart: id: mod_bus tx_pin: 1 rx_pin: 3 baud_rate: 9600 stop_bits: 1 modbus: id: sunsynk_modbus flow_control_pin: 4 modbus_controller: - id: sunsynk address: 0x01 modbus_id: sunsynk_modbus setup_priority: -10 update_interval: "15s" command_throttle: "50ms" <cropped> Pic of the above Anyone got any further ideas for me? I've tried a second RS485 board, and built a second network cable.. no luck.. TIA!
June 27, 20233 yr 2 and 7 to A 1 and 8 to B Looking at your picture you have these the wrong way around. Edited June 28, 20233 yr by slipx
June 28, 20233 yr Author So your ESP 32 is alive and looks like it is trying to connect. 2 things to check out. You also only need to use one of the pairs, i.e Orange/White & Orange or Brown/White & Brown, not necessary to connect both pairs. On setup 2 I would also check that you are connecting using the correct pins on the ESP32. GPIO 1 & GPIO 3 are pin 4 & 5 from the top on the RHS, it looks like you are connecting to pins, 3 & 4 from the photo.
June 28, 20233 yr @Sc00bs the pinout you show looks a bit different. Below is a pinout which more accurately reflects @Gooseza setup https://www.electronicshub.org/esp32-pinout/
June 28, 20233 yr 13 hours ago, slipx said: 2 and 7 to A 1 and 8 to B This worked, and for both of my setups! I'm so happy and relieved, thank you! I'm going to make some comments on Sc00bs youtube video to help the next person along, as a bit more explaining is needed in a couple of areas. For the next person: Add the Orange (2) and Brown strip (7) to A..... and Orange stripe (1) and Brown (8) to B Edited June 28, 20233 yr by Gooseza
June 28, 20233 yr Author Thanks @jacauc You are 100% correct, sry for the wrong pinout. I would check the connections are correct for the ESP32 you have in any case as the problem seems to be between the ESP32 and the Inverter. Would swop the Orange/White & Orange cables around and see if that works. To me the "no response received" from the modbus requests would probably indicate a problem between the RS485-Inverter connection but I could be wrong. So either from the ESP32 - RS485 board connection or the connection between the RS485 board and the inverter.
June 28, 20233 yr Author 2 hours ago, Gooseza said: This worked, and for both of my setups! I'm so happy and relieved, thank you! I'm going to make some comments on Sc00bs youtube video to help the next person along, as a bit more explaining is needed in a couple of areas. For the next person: Add the Orange (2) and Brown strip (7) to A..... and Orange stripe (1) and Brown (8) to B Glad you got sorted @Gooseza 🙂
July 16, 20233 yr Thanks It is working well I got the new USB-C esp-32dev and it is working.(https://www.robotics.org.za/ESP32-DEV-CH340-C) I tested the Ethernet cable before installing it and it worked well on the pin 1 & 2 after installation it was not working any more so I used pin 7 & 8 Modbus Poll works well to do fault finding on RS485/Modbus RTU or even Modbus TCP
July 16, 20233 yr On 2023/05/29 at 4:43 PM, kellerza said: It would make life easier! One easy change I can think of would be to change _power_kwh, to _energy. I also made this mistake in one of the erlier editions of the addon and since updated & deprecated the old names - https://github.com/kellerza/sunsynk/blob/main/sunsynk/definitions.py#L318 It is a bit painful, since you lose your Energy stats Thanks. I've just updated my ESPHome config to align with those definitions. https://github.com/slipx06/Sunsynk-Home-Assistant-Dash/blob/main/ESPHome-8K-Sunsynk.yaml
July 24, 20233 yr I am rather fed-up with the constant updates on Home Assistant that keeps on crashing my system on a RPI4. The main reason for my installing HA was for the inverter monitoring. If it is not mqtt needing fine tuning, then the system stops reading from the RS485 until I reinsert the usb again. I decided to go back to basics and only using node red as an all-in-one service, including dashboard. It backs up to local emoncms and influxdb if I want to dig up history. (it has not crashed once on node-red...yet.)
July 24, 20233 yr 15 minutes ago, GVC said: I am rather fed-up with the constant updates on Home Assistant that keeps on crashing my system on a RPI4. The main reason for my installing HA was for the inverter monitoring. If it is not mqtt needing fine tuning, then the system stops reading from the RS485 until I reinsert the usb again. I decided to go back to basics and only using node red as an all-in-one service, including dashboard. It backs up to local emoncms and influxdb if I want to dig up history. (it has not crashed once on node-red...yet.) Half of the issues with an unstable HASS OS is probably storage related, the other half a flakey power supply. Standard install & standard MQTT here. I have the official Pi PSU with external SSD storage. Without proper storage, any solution writing loads of stats to the SD card will be doomed in the long run.
July 24, 20233 yr I also use an external ssd drive with the original raspberry power supply. To be fair it did not crash on every update. It started about 2 months ago after an update where the rs485 would lose comms once a day. Thereafter, after an update about 3 weeks ago, it lost the mqtt connection. I read on the ha forum where several people had the same issue. It is probably not a major issue, but I do not have the time to spend on this and rather opted to return to my tried and tested systems. Edited July 24, 20233 yr by GVC
