  • Replies 948
  • Views 135.3k
  • randomfool
    randomfool
  • randomfool
    randomfool
Similar card here. Except I don’t have battery V/A either
be good to get the house and grid figures working.
Edited by Benseb
14 minutes ago, Gary Waterworth said:
Can't see the values but that all looks good
If you click on the image, you can then zoom in. I thought the would be attributes for current, volt, etc for all phases in there, did not see any.
There aren't. This causes to many possibilities depending on single / parralles / Genny / mini inverter attached
For card use it totals up everything into a single power etc value.
If you want it is straight forward to add extra attributes in the export flow to do what you want with the global export data.
I don't export the raw context data as it causes problems with it's extreme size
Makes sense.
I thought they were meant to fill these on the card...
26 minutes ago, HowserMD said:
@Gary Waterworth, what should show on the card for a 3 phase system, that would not otherwise for a single phase?
No idea :) I dont have 3 phase , so havent even looked or thought about it
Also when I develope something I have to think on how to make it work for all options out there
Hi all,
I loaded everything correctly according to the instructions for v2.2. I am able to log in to pv.inteless.com and api.sunsynk.net (Under region 1) and I see my plant.
I changed the yaml file to reflect region 1 but I get the following on Node Red:
Funny enough I can also login with my credentials under region 2 but no plant comes up. If I change the yaml file to region 2, the flow goes correctly until the end of "Get Plant List" where it obviously doesn't find a plant
Any idea on how to fix this would be greatly appreciated!
3 hours ago, Gary Waterworth said:
I don't have a plant in region 1 anymore so I cant see what they have changed. I thought everything has moved to region 2 ?
If you want you can send you login details to me privately [email protected] and I can look
Thank you Gary. I've sent an email.
Really appreciate the assistance.
This is from the sunsynk-power-flow-card
Hi Guys,
I recently had an issue with my inverter. It was sent in for repairs but now I cannot get the integration to work. The login seems to work perfectly and if I look at debug info gets the serial number etc.
However node red debug shows:
1/26/2024, 2:00:41 PMnode: Calc Last Update Time & General Status Checkfunction : (error)
"Data last updated more than 3 minutes ago. Should be minimum less than a minute - Error With Data "
"Input(Input) - Error With Data "
"Input(Grid) - Error With Data "
"Input(Load) - Error With Data "
1/26/2024, 2:00:41 PMnode: Login Debugmsg.payload : Object
{ username: "xxxxxxxxxxxxxxx", password: "xxxxxxxx", grant_type: "password", client_id: "csp-web" }
1/26/2024, 2:00:42 PMnode: Login Debugmsg.payload : Object
{ code: 0, msg: "Success", data: object, success: true }
1/26/2024, 2:00:43 PMnode: Plant List Debugmsg.payload : Object
1/26/2024, 2:00:43 PMnode: Debug PantIDmsg.payload : Object
{ state: 98162 }
1/26/2024, 2:00:43 PMnode: Debug PLant Invertor Listmsg.payload : Object
1/26/2024, 2:00:43 PMnode: Debug Invertor 1msg.payload : Object
{ sn: "yyyyyyyyyyy" }
1/26/2024, 2:00:44 PMnode: Sunsynk Input Datafunction : (error)
"TypeError: Cannot read properties of undefined (reading 'ppv')"
1/26/2024, 2:00:44 PMnode: Update SunSynk Batterymsg : string[91]
"hass-post: API call http://localhost:8123/api/states/sensor.sunsynk_battery, statusCode 400"
1/26/2024, 2:00:44 PMnode: Parse Tempfunction : (error)
"TypeError: Cannot read properties of undefined (reading 'records')"
1/26/2024, 2:00:44 PMnode: Update SunSynk Loadmsg : string[88]
"hass-post: API call http://localhost:8123/api/states/sensor.sunsynk_load, statusCode 400"
1/26/2024, 2:00:44 PMnode: Event Call Debugmsg.payload : Object
1/26/2024, 2:00:44 PMnode: Sunsynk Gridfunction : (error)
"TypeError: Cannot convert undefined or null to object"
Any idea. I don't think I've changed anything on the inverter. I did in the interim move HA onto a PC, but I did that by back and restore and I'm not sure if that broke something?
7 minutes ago, brussel said:
Hi Guys,
{ state: 98162 }
Looking at the hass-post http status code 400 errors, do you have the entities sensor.sunsynk_battery and sensor.sunsynk_load  in home assistant?
Hi Gary, that is a good question. I went back and reinstalled the latest version 2.4 and got it online last night
However this morning it's offline through no fault of this. Sunsynk website shows a warning, the gateway still connected but a warning on the inverter, no fault code or anything else tho...weird. Will problem solve that later.
Thanks for the help
Thanks for the help
Got the same issue from 03:40 this morning. The inverter is connected to the internet, but no data going out.
Sunsynk just doing sunsynk things again that's all.
Ah came to check if I’d gone over a rate limit or if it was a global issue. Seems it’s not me then
integration setup and working great otherwise. Thanks so much for this. Intelligent octopus starts a slot and now my battery charges automatically!
