Am I getting ripped off? Goodwe GW5048D-ES being sold as a 6,5KW inverter
Hi guys
I recently signed up for a deal with one of our big name installer/contract solar companies.
They advertise a 6,5Kw system, with 10Kw batteries, and 12 panels.
I managed to get a good look at the system before their custom closed box was fitted over it, and I noticed that it contains a Goodwe GW5048D-ES and four Pylontech Us2000c batteries.
I'm not very clued up on these things, but I looked it up and this Goodwe inverter offers 4,6 Kw backup, while the four batteries only offer 9,6Kw of storage.
Am I being pedantic and is there some magic calculation I am missing, or am I being ripped off?
When I queried it with the installer, they claimed that the inverter's rating is due to it offering a mix of AC and DC, and there is a calculation which brings it to the advertised 6,4 Kw, despite the below specs:
  • Model GW5048D-ES
    Battery Input
    Battery Type Li-ion or Lead-acid
    Nominal Battery Voltage 48V
    Max. Charging Voltage
    Max. Charging Current 100A
    Max. Discharging Current 100A
    Battery Capacity 50 to 2000Ah
    PV String Input
    Max. DC Input Power 4600W
    Max. DC Input Voltage 580V
    MPPT Range 125 to 550V
    Start-Up Voltage 150V
    Nominal DC Input Voltage 360V
    Max.Input Current 11/11A
    Max. Short Current 13.8/13.8A
    No.of MPP Trackers 2
    No.of Strings Per MPP Tracker 1
    AC Output (On Grid)
    Nominal Apparent Power Output to Utility Grid 4600VA
    Max.Apparent Power Output to Utility Grid 5100VA
    Max.Apparent Power from Utility Grid 9200VA
    Nominal Output Voltage 230V
    Nominal Output Frequency 50/60Hz
    Max.AC Current Output to Utility Grid 40A
    Output Power Factor 1
    Output THDi <3%
    AC Output Data (Back-up)
    Max.Output Apparent Power 4600VA
    Peak Output Apparent Power 6900,10sec
    Max.Output Current 20A
    Nominal Output Voltage 230V (+/-2%)
    Nominal Output Frequency 50/60 (+/-0.2%)
    Output THDv <3%
    Efficiency
    Max/Efficiency 97.6%
    Max.Battery to Load Efficiency 94.0%
    European Efficiency 97.0%
    Protection
    Anti-Islanding Protection Integrated
    PV String Input Reverse Polarity Protection Integrated
    Insulation Resistor Detection Integrated
    Residual Current Monitoring Unit Integrated
    Output Overcurrent Protection Integrated
    Output Short Protection Integrated
    Output Over Current Voltage Protection Integrated
    General Data
    Operating Temperature Range -25 to 60 degrees Celsius
    Relative Humidity 0 to 95%
    Operating Altitude <4000m
    Cooling Natural Convection
    Weight 30kg
7 hours ago, justchecking123 said:
 they claimed that the inverter's rating is due to it offering a mix of AC and DC, and there is a calculation which brings it to the advertised 6,4 Kw.
What a bunch of hogwash!
You're right its a 4.6kW inverter...it may handle 6.4 with AC passthrough, but DC to AC is 4.6kW
A 6,5kW Inverter will be able to supply 6,5kW either from Solar or batteries. This inverter can only only supply 4600W. Whatever the AC throughput is from grid is not part of the Inverters own generation/conversion.
The max PV input is also limited to 4600W, so what 12 panels are they including in this deal? 380W perhaps?
this all sounds very devious marketing and slick sales talk to bamboozle the uninformed.
Did they give you the spec sheet that you posted?
I just checked the Goodwe datasheet and the model you specced is 4600W as well but the solar DC input is actually 6500W.
So your data sheet seems to be a mix of the two.
Still, this inverter is not a 6,5kW. The only thing that is 6,5kW is the max solar input
Edited by zsde
Thanks, guys.
This is what I suspected.
I assume this is how they trick people, since they usually do the installation and then stick the whole thing into a box that prevents you from seeing what equipment is actually in there.
I'm now torn between demanding they bring me what I paid for, or cancelling the entire deal, since I don't want to deal with untrustworthy companies.
The worst part is that this is supposedly one of the top rated companies in the country for solar contract deals.
So, I just took a good look at the contract and this is how it is specced in there.
Does this qualify for what was delivered?
The second pic is how it is advertised.
Edited by justchecking123
They will have to show you the official datasheet where precisely it states that it's 4600W + 1900W for battery charge over and above.
I see nothing like that in this spec sheet.
A 6500W Inverter will supply 6500W, thats the industry standard.
Usually when we speak of a XkW system, we understand that it can backup X.
The Goodwe that you mention can back up 4.6kW and can charge at 100a.
The screenshot doesn't mention any brands and doesn't show a Goodwe inverter or pylontech batteries. Ok... That's just illustrative.
If you've already paid and you are sure about the inverter then you can have a steady 4.6kW backed up. I don't see how they get to 6.5, but also they haven't promised that you can backup 6.5.
Its all a bit vague.
To be fair, they don't advertise anywhere on that flyer that it is a 6.5kW backup system. They only specify 6.5kW AC and DC charge which is correct for that inverter.
It's a case of obscure marketing and clients not paying attention what the numbers on the advert really mean.
I agree ,as consumers we should be doing more research about the capabilities of these systems before purchasing them. Basically every company uses marketing tricks like these in this day and age (sadly).
6 minutes ago, PierreJ said:
"Hybrid inverter 6.5kW combined AC load & DC charge"
This is extremely devious marketing. I would not do business with them. Walk away, if you still can.
Absolutely agree!
While many companies do use sly marketing, this is completely devious and dishonest...
9 hours ago, justchecking123 said:
Thanks, guys.
Before cancelling the deal, I would first check what they charged me and compare the prices with other suppliers. It might shock you to see that the price they gave you is deal of a life time and you might reconsider. On the flip side, they might have over priced their package and if that is the case then you can demand that they supply what you have paid for, or cancel the deal.
This is not correct. It can invert DC to AC 5kW+..BUT only invert 4.6kW on backup side.
I have seen 5,5kW on occasion, but it seems to sit at around 4.8kW nominal.
When charging the battery, DC bus, + DC to AC it will go over 5kW easily.
However, the goodwe comes out in a 6kW version as well, so maybe the wires got crossed there.
Frankly, are you sure it's a new inverter because they're more expensive than a 5kW sunsync..
I think your installer is not to be trusted.
It can only output 20A. Everything it reports above that (4600W at 230V) is internal losses. (the only exception is for periods shorter than 10s).
Edited by P1000
Correct, and 20Ax240V = 4.8kW, not 4.6kW..When pushing back to grid I've seen 250V x 19A-20A over an extended period. At 255V the inverter restarts..
So I had another look today and found something rather interesting on the Goodwe reporting...
On the power flow diagram it shows 4764W from panels and 4790W (Battery+25W) into loads BUT on the details page it shows only converting Output Power 4595W!! Maybe @P1000 has a point! Seems not even Goodwe can make its mind up as to just how much power it can deliver to loads...
Edited by FixAMess
Clarification
Thanks very much for everyone's comments and input.
I raised all this with the company, and they agreed that the marketing was misleading but assured me that it was not intentional, but rather a matter of tech people writing the marketing material. Their site has been updated and they've committed to replacing my inverter with a 6 Kw (AC load) model.
That is a refressing response
Edited by I84RiS
Make sure you get a 6kw Inverter.. That AC load text is just misleading. They should tell you the model number of that inverter.
  • 1 year later...
Very late late response, the GW5048D-ES was a good buy back in 2020 given what was available back then. The ad might have been misleading, but it can blend power when the grid is on and give up to 40amps at 230v which is where the 9200W comes from. Mine has run on close to 8000W on grid without issues. The down side is off grid it's only rated at 22amps which is atound 4800W. Depending on the price and your need you can't go wrong with it and 5 x 2000W pylon techs!
These days a Dye or sunsynk is probably a better option since they allow generator input which is a bonus if you want to go off grid and top up with a genny.
