May 1, 20242 yr Just had an upgrade about 3am last night from from version E426 MCU2022-1724 to M6.0.2.6./S1.7.2.4./CE.4.3.8. Reason is for 6x 8KW in parallel its recommended to get latest version for improved generator port functionality.
June 23, 20242 yr How can I update the firmware on my 5k inverter? Currently on E433-mcu:3384-0513 ... Does not seem to be recording grid power correctly anymore
June 26, 20242 yr We have been having ongoing problems with the data hubs over the last couple of weeks the firmware version on them is 4790123B24R is there are later one?
September 24, 20241 yr Hi all does anyone know what the latest firmware for 5kW Sunsynk is? Would like to compare to what I am currently running and understand if it worth the hassle of going through the upgrade
September 25, 20241 yr 19 hours ago, wolfandy said: Hi all does anyone know what the latest firmware for 5kW Sunsynk is? Would like to compare to what I am currently running and understand if it worth the hassle of going through the upgrade At the beginning of July 2024, we had our one updated. It's currently running the below, I'm not sure if there's been any updates in the last 3 months, but at least it's a reference point: M 3.3.8.6 / S 1.5.1.5 / C E.4.3.9 On the previous page, there was a post from the end of March 2024 where the M and S versions were the same as the above, but the CE was one revision prior - C E.4.3.8
September 25, 20241 yr 6 hours ago, MeTsU said: M 3.3.8.6 / S 1.5.1.5 / C E.4.3.9 what does those letters mean ? I believe M for MCU and S for software ? is Deye has the same software but different MCU ? If you manual upgrade and use Deye MCU I believe you can change the UI
September 25, 20241 yr 52 minutes ago, esmail-kassir said: what does those letters mean ? I believe M for MCU and S for software ? is Deye has the same software but different MCU ? If you manual upgrade and use Deye MCU I believe you can change the UI M: Master MCU software version S: Slave MCU software version C : Communication MCU software version Edited September 25, 20241 yr by MeTsU
September 27, 20241 yr Hi everyone, My first post on this Forum. Installed a 12kW single phase inverter on 6 September 2024 - Firmware as follow: M A.0.2.5 / S 1.7.2.6 / C E.4.3.8
October 3, 20241 yr Hi all, Mine is a 5kW unit... SW Ver.: M 3.3.8.2 / S 1.5.1.5 / C E.4.2.6 Is the update process in any way controllable? Edited October 3, 20241 yr by Buff
October 4, 20241 yr 13 hours ago, Buff said: Hi all, Mine is a 5kW unit... SW Ver.: M 3.3.8.2 / S 1.5.1.5 / C E.4.2.6 Is the update process in any way controllable? The update is done over the air after logging a ticket - so not really controllable, no. Some have had a response within 30mins of logging a ticket, and others receive a response the next day, so your mileage might vary.
October 6, 20241 yr Thankx @MeTsU... I can't see anywhere what the latest is supposed to be? I actually joined this group to try and work that out. And to see what the benefits are of newer softwares. Maybe I am reading things wrong... I'm new on the forum
October 7, 20241 yr On 2024/10/04 at 9:31 AM, MeTsU said: The update is done over the air after logging a ticket - so not really controllable, no. Some have had a response within 30mins of logging a ticket, and others receive a response the next day, so your mileage might vary. is there a way to do it manually ?
October 9, 20241 yr I upgraded my 3Phase 12kW inverter today. Old version: M 2005-1140 / S 18-07 / C 1001-E037 New version: M 2005-1148 / S 18-07 / C 1001-E043 There were no obvious changes to the user interface on the inverter. ---- Also, they said my data logger was already on the latest version, i.e. it hasn’t changed since I manually updated logger firmware in November 2022: Data Logger Hardware version: AEW2-0005-03 Data Logger Firmware version: 4790123B24R Edited October 9, 20241 yr by Planck
October 10, 20241 yr So I contacted support and requested an upgrade... I went from SW Ver.: M 3.3.8.2 / S 1.5.1.5 / C E.4.2.6 to M 3.3.8.7 / S 1.5.1.5 / C E.4.3.D. I asked them if they publish the latest anywhere and they said no... the only way is to request an upgrade and if there is one it is scheduled within the next 24 hours... Strange process.
October 10, 20241 yr 2 hours ago, Buff said: So I contacted support and requested an upgrade... I went from SW Ver.: M 3.3.8.2 / S 1.5.1.5 / C E.4.2.6 to M 3.3.8.7 / S 1.5.1.5 / C E.4.3.D. I asked them if they publish the latest anywhere and they said no... the only way is to request an upgrade and if there is one it is scheduled within the next 24 hours... Strange process. I agree, the process sucks, especially if you work online from home. We need backups for our backup.
October 10, 20241 yr 12 hours ago, Buff said: So I contacted support and requested an upgrade... I went from SW Ver.: M 3.3.8.2 / S 1.5.1.5 / C E.4.2.6 to M 3.3.8.7 / S 1.5.1.5 / C E.4.3.D. I asked them if they publish the latest anywhere and they said no... the only way is to request an upgrade and if there is one it is scheduled within the next 24 hours... Strange process. Did you notice any changes on your setup screens?
October 14, 20241 yr @p_i There are supposed to be changes on the physical screens. I don't go there often... most of the config I use is on the app. I checked it out after your message and I honestly cannot see anything. Maybe it's on one of the screens I don't use often. I think they were mainly cosmetic changes
October 14, 20241 yr On 2024/10/10 at 11:44 AM, Planck said: I agree, the process sucks, especially if you work online from home. We need backups for our backup. 🤣Anywayz... I get the feeling Sunsynk viewed the customer as the installer. They are only pivoting now to be more end-user responsive
November 21, 20241 yr How does the upgrade work in a parallel system? Do all of the inverters get the file copied on to them, then the reboot happens, or one at a time? My router is obviously going to go down when that particular inverter drops the phase if they are done one at a time.
November 21, 20241 yr 8 minutes ago, Snotface said: How does the upgrade work in a parallel system? Do all of the inverters get the file copied on to them, then the reboot happens, or one at a time? My router is obviously going to go down when that particular inverter drops the phase if they are done one at a time. For me it was indeed one at a time. In anticipation I flipped the change-over switch to grid mode (which still allowed PV to power everything via zero-export-to-CT, but wouldn't have provided battery/backup power in an outage). With load shedding not on the menu (for now, at least!) it's feasible to do this for the reason you mention. It took 2 days or so from request to action and the ticket closed when it happened so I knew it was done. Edited November 21, 20241 yr by JayMardern
November 21, 20241 yr 1 minute ago, JayMardern said: For me it was indeed one at a time. In anticipation I flipped the changed-over to grid mode (which still allowed PV to power everything via zero-export-to-CT, but wouldn't have provided battery/backup power in an outage). With load shedding not on the menu (for now, at least!) it's feasible to do this for the reason you mention. It took 2 days or so from request to action and the ticket closed when it happened so I knew it was done. Okay, so in an off-grid situation i'll probably have to put my inverters on a cellphone hotspot for the reboot?
February 2, 20251 yr I have an 8kW Sunsynk inverter. I was advised by Sunsynk support that were upgrading the firmware after I contact them via the support chat to query why my battery was not assisting the load when the PV gen was not sufficient even when tge SOC was 97% Now the firmware is COMM:E43D - MCU:6027-1724 I have no idea what version was in the inverter before. Is there some way of determining what the previous version was?
April 15, 20251 yr Is it still recommended that you place the inverter in bypass mode and have no load?Need to plan when to switch over as there seems to be no real indication how long a update take from request to processing when reading all the posts.And anybody done the firmware update using the firmware requestion option from within the Connect app?
