November 4, 20214 yr Hi Guys Total newbie here. I am about to get the following system installed on Monday: 8 x JA Solar 540W Mono Sunsynk 8K Hybrid 2 x Pylontech US3000c I am doing this through an installer as I need this done before the next big Eskom madness hike and the next lot of breakdowns by an inept parastatal. I opted to get a bigger inverter to enable me to expand. I already have most of my lights on LED's, my geysers on solar (one tube and one panel) and also on timers. My Hob is gas, not my stove. I have brought my consumption down from 56-59kw/day to 42kw/day. What software can I use to monitor the system? Is there a way to automatically and remotely switch power-hungry systems? kind regards Aubrey
November 4, 20214 yr 10 minutes ago, cyber7 said: What software can I use to monitor the system? Try installing Solar Assistant - works exceptionally well. Check it out here https://solar-assistant.io/ MdF
November 4, 20214 yr I can't comment on ICC but moved from SolarMan Smart directly to Solar Assistant once doing a search on this forum for "user friendly easy to install real-time data". The purchase of the Pi and cables was very easy online and delivered within 24 hours. The installation and setup on my network took all of 15 minutes and I have been very impressed with the quality of data Solar Assistant provides. But horses for courses - hopefully others will comment on ICC.
November 4, 20214 yr 1 hour ago, cyber7 said: How does Solar Assistant hold up to ICC Very well. The main difference in functionality in my opinion is that if you are running ICC you can still use other linux programs in addition to ICC. For example I am running node red which is monitoring ICC values and then controlling my geyser switching via the i/o pins, a relay and then a contactor (a suitable wifi relay wasn't available when I designed the system). I am also running a calibre server for my ebook library on the same pi. ICC also requires the use of VNC or port forwarding for remote access so that can be a pain. I haven't tried the new option ICM so that may have changed. Solar Assistant is pretty much plug and play but your pi can only run it. This does mean that it is very handy on resources and I saw someone had an instance running on a pi zero which is impressive. If you want an easy monitoring solution I would recommend this. On remote switching yes it is very possible. Depending on your technical skills and/or interest you can do a variety of options. ICC would be a better fit though for this as you can get upgrade options to the basic package that can control sonoff (or any tasmota flashable device) wifi switches or even the pi i/o. Node red or Home Assistant are popular pieces of software if you want to look at alternatives. Both can monitor an MQTT broker for information and then carry out commands plus they are free. Solar Assistant does have MQTT integration as well but you need a separate server running the control software, i.e. pi or pc if you want to do remote control. It can only report system values as far as I know. I haven't played with the MQTT on Solar Assistant. Edited November 4, 20214 yr by Shadders Corrected software name.
November 4, 20214 yr @cyber7 you can do your research but I would say, don't buy any monitoring software yet. The native SunSynk dongle is currently in beta testing and should be available soon in production. Rather wait and see, if it can provide the desired functionality.
November 4, 20214 yr Author @PowerUser What exactly is this "dongle"? My system was specced out with WiFi/NW, so is this some kind of add-in?
November 4, 20214 yr Author 3 hours ago, PowerUser said: @cyber7 https://www.sunsynk.org/remote-monitoring Any idea what the cost will be?
November 4, 20214 yr Look into the Riot: https://powerforum-store.co.za/collections/batterys/products/riot-cloud-monitoring
November 4, 20214 yr 34 minutes ago, abeetude said: Look into the Riot: https://powerforum-store.co.za/collections/batterys/products/riot-cloud-monitoring The Riot is only for the Hubble batteries It doesn’t show anything regarding the inverter, loads, etc. Besides - read the thread. He is getting Pylons. Not Hubble. Edited November 4, 20214 yr by PowerUser
November 4, 20214 yr 6 hours ago, cyber7 said: Any idea what the cost will be? I paid less than R1000 and it’s worth it, only problem is if the new Sunsynk dongle under beta testing becomes available in the next few weeks or so you might want to upgrade and spend again.
November 6, 20214 yr On 2021/11/04 at 8:31 AM, cyber7 said: I have brought my consumption down from 56-59kw/day to 42kw/da That's still quite high*. The system you're installing is not going to supply all of that or back it all up. Though you have allowed room for expansion. But if you chose your essential (backed up) loads well you'll live more than tolerably through a load shed. And you'll make a dent in your electricity bill. * before we (2 adults) switched we had gas top but electric oven, heat pump for water heating, pool pump, 2 fridges, deep freeze, tvs, decoder, WiFi etc and seldom got above 15 kw/h a day, averaged around 13.
November 6, 20214 yr On 2021/11/04 at 5:58 PM, PowerUser said: The Riot is only for the Hubble batteries It doesn’t show anything regarding the inverter, loads, etc. it is about to happen On 2021/11/04 at 5:58 PM, PowerUser said: Besides - read the thread. He is getting Pylons. Not Hubble. true
January 3, 20224 yr I have installed the Sunsynk data logger. It is a vast improvement to the Solarmann. With the authorisation you can make changes remotely on your system. The logger is far less expensive than the riot and works brilliantly.
January 3, 20224 yr 22 minutes ago, TonyH said: With the authorisation you can make changes remotely on your system. Ditto for Solarman Smart and and Solarman Business.
January 3, 20224 yr On 2021/11/04 at 5:58 PM, PowerUser said: The Riot is only for the Hubble batteries It doesn’t show anything regarding the inverter, loads, etc. Besides - read the thread. He is getting Pylons. Not Hubble. Riot is not only for Hubble, it works perfectly well with Pylontec batteries. I'm using mine with Pylontech US2000B battery bank
January 3, 20224 yr 👍 great. I don't know what the price is of those packages. The Sunsynk logger is seamless because it is designed by Sunsynk.
January 3, 20224 yr Developed by my son, I can see everything on my two Growatt inverters and LBSA 5.1 Kw Battery. Also can change parameters remotely if need.
January 3, 20224 yr On 2021/11/04 at 8:31 AM, cyber7 said: I already have most of my lights on LED's, my geysers on solar (one tube and one panel) and also on timers. My Hob is gas, not my stove. I have brought my consumption down from 56-59kw/day to 42kw/day. That's still high. You've a gas hob, LED lighting, geysers on solar... where is all that power going? Baking? I would suggest trying to bring that number down before upgrading your system.
January 3, 20224 yr 1 hour ago, hoohloc said: Riot is not only for Hubble, it works perfectly well with Pylontec batteries. I'm using mine with Pylontech US2000B battery bank Correction on my statement then. But since Hubble bought RIOT and renamed it to Hubble Cloudlink, how long the support for other vendors will remain is still to be seen.
January 3, 20224 yr 1 hour ago, TonyH said: 👍 great. I don't know what the price is of those packages. The Sunsynk logger is seamless because it is designed by Sunsynk. @TonyH Can you schedule to charge the batteries to different levels based on different days in the week?
January 5, 20224 yr 7 minutes ago, TonyH said: No, there is no option for different days. Pity because that would be quite useful with the Hubble batteries and their mode of operation.
June 29, 20223 yr On 2022/01/03 at 12:14 PM, Antonio de Sa said: Developed by my son, I can see everything on my two Growatt inverters and LBSA 5.1 Kw Battery. Also can change parameters remotely if need. What is the name of this software ?
