SunSynk 5kW, 8kW and 12kW latest firmware version
45 minutes ago, McAllstar said:
does the Deye use the same firmware? Apparently i have LSW3_15_FFFF_1.0.73
No, Deye firmware versions are different. Deye owners can start their own thread to track those.
  • Replies 297
  • Views 98.6k
  • Latest firmware 12kw - 1096 E018 8kw - 6012 E422 5kw - 3372 E422
  • BobTheDinosaur
    BobTheDinosaur
    Sunsynk 12kW 3 phase Updated very early this morning, didn't even notice other than I could tell from some appliances that power had cycled at some point. (update happened about 6-8 hours after I
  • 5KW FW updated yesterday:
On 2022/03/08 at 5:11 PM, TonyH said:
Today I asked Sunsynk to upgrade me to the latest firmware. The inverter was on e4i4 MCU 3070. After the upgrade the inverter is e422 6030. All working ok after the initial Inverter switching off then bringing in the new firmware. All the old settings were in.
Which Sunsynk inverter?
I have a 8.8kw and it was updated today to MCU 6013
8KV single phase Sunsynk Inverter
Edited by TonyH
spelling
5,5 kw machine.  The machine was dropping AC grid continuously which was resolved after this update yesterday.  Wish they would release a change-log with each release.
M 3.3.7.4
C.E. 4.2.3
8 hours ago, Unintentional said:
Hi all,
So JUST got an update on my 8kW:
  • MCU     : 6014
  • Comm  : 4.2.4
Will check this evening if any noticeable changes.
So I noticed a change to a menu but not sure if it makes a difference per se. The Grid type box is new.
"Grid Reconnect Time" = 1200s. That's 20 minuets, you're a patient man. 😲
Rather change that to 60s. Maybe this is the cause of your inverter "dropping" power on load-shedding?
Edited by TimCam
8 minutes ago, Unintentional said:
Haha yeah we have a 20 min requirement on our grid unfortunately.
You probably live in Midstream. The other change is that the inverter output voltage can be changed. I have mine set on 240V
Yeah, I had that option from 6013 Com 422 - why 240V instead of 230V as a matter of interest?
On 2022/04/19 at 10:26 AM, Unintentional said:
Hi all,
  • MCU     : 6014
  • Comm  : 4.2.4
1 May2022 - just upgraded to this version and it fixed a PV/Battery/Grid prioritisation issue
see  https://powerforum.co.za/topic/12246-help-sunsynk-8k-prioritising-battery-over-solar/ for details
Hello, I have 2x 5kW Sunsynk inverters. The firmware that was installed was M 3.3.70 / S 1.5.1.5 /C E4.2.0. I requested an update and after the update, my firmware versions are M 3.3.7.4 / S 0.0.1.7 / C E4.2.4 on the master and M 3.3.7.4 / S 1.5.1.5 /C E4.2.4 on the slave. What bothers me is the Slave MCU software version that is now different. I spoke to the local Sunsynk guys and according to them the Slave MCU software does not get updated, yet mine was changed and nobody can explain. Does anyone else on this forum have a 5kW parallel system to compare firmware versions?
Where do I see the inverter firmware version?/ Mine is as follows...
Where do I find the latest version to fill the request?
2107309392
1292
 1 .4
  3.8.8.1
 E4A012190069
Alias 2107309392
SW Ver.M 3.8.8.1 / S  -- / C E.4.1.B
Gateway E4A012190069
7 hours ago, Surfrat said:
Sunsynk 5kw
Updated: 2022-05-30
Comm: e41c
MCU: 3374
Anyone know the changelog for the new firmware?
The Sunsynk team keeps ignoring the request for a changelog in their own forum...
