July 12, 20215 yr Hi All Just my finding. I have around 4000watts of panels on 1 string facing NE they produce around 1300 to 1400 in winter after clean them they went up to 1950watt. So dust realy affects there performance. Just a thought.
July 12, 20215 yr 4 minutes ago, John2 said: Hi All Just my finding. I have around 4000watts of panels on 1 string facing NE they produce around 1300 to 1400 in winter after clean them they went up to 1950watt. So dust realy affects there performance. Just a thought. thanks, when was the last time you cleaned them?
July 12, 20215 yr 1 hour ago, John2 said: Hi All Just my finding. I have around 4000watts of panels on 1 string facing NE they produce around 1300 to 1400 in winter after clean them they went up to 1950watt. So dust realy affects there performance. Just a thought. Yes, a good clean a couple of times a year is a good thing. Thinks: is this a factor to take into consideration when planning an installation? Ease of access for cleaning?
July 13, 20215 yr Author 18 hours ago, phidz said: thanks, when was the last time you cleaned them? @phidz i try every month as they are easy accessible. Its make a difference.
July 13, 20215 yr 2 hours ago, John2 said: @phidz i try every month as they are easy accessible. Its make a difference. what do you use to clean?
July 13, 20215 yr Hi, I recently installed 12 x 390w (2 strings of 6 panels )JAVA panels with 5000w Mecer inverter Currently the total input from panels never goes higher that 2900w. Will it go up in the summer or can I add more panels The MECER inverter got 4500w MPPT Thanks Deon
July 13, 20215 yr Author 5 hours ago, hoohloc said: what do you use to clean? @phidz i just hose them down with water and then if there ia stubborn dirt i use sunlight with a squeegee. I hose them down first to avoid scratching the glass that my way.
July 13, 20215 yr 1 minute ago, John2 said: @phidz i just hose them down with water and then if there ia stubborn dirt i use sunlight with a squeegee. I hose them down first to avoid scratching the glass that my way. I think I will give this a try, thanks
July 13, 20215 yr Author 2 minutes ago, hoohloc said: I think I will give this a try, thanks @hoohloc sure let us know your outcome.
July 13, 20215 yr 4 hours ago, Deon1 said: Hi, I recently installed 12 x 390w (2 strings of 6 panels )JAVA panels with 5000w Mecer inverter Currently the total input from panels never goes higher that 2900w. Will it go up in the summer or can I add more panels The MECER inverter got 4500w MPPT Thanks Deon Most definitely, you will get higher production in Summer but if you have funds, it will not hurt to add more panels. I would add two more
July 13, 20215 yr 9 hours ago, John2 said: @phidz i try every month as they are easy accessible. Its make a difference. I wish i could do that. i'm afraid of heights so i don't go on top of the roof.
July 16, 20214 yr On 2021/07/13 at 4:51 PM, hoohloc said: Most definitely, you will get higher production in Summer but if you have funds, it will not hurt to add more panels. I would add two more Thanks
July 16, 20214 yr Definitely cleaning the panels grid would generate more watts, dust particles reduce the flow of current. Might be because of that your power watt went up to 1950Watts.
June 5, 20224 yr On 2021/07/13 at 4:45 PM, John2 said: @phidz i just hose them down with water and then if there ia stubborn dirt i use sunlight with a squeegee. I hose them down first to avoid scratching the glass that my way. Good day. Rather searched this topic before starting a new post. Realized the whole week that my panels were only producing 2.1kw (2.4ish) system. (10:40 in the morning) Well, I thought, it's winter and this should be expected. But anyhow, I climbed on the roof and saw a thin layer of dust. Cleaned them using the sponge side of a squeegee and a bit of running water. Got off the roof and immediately saw a jump to 2.4kw . That's an immediate gain of about 300w. Where I live, although on a farm, there's still a lot of mining dust blowing the whole place full. When I was in town, this was a weekly occurrence. About using soap, Imo don't, just use clean water. If you don't get all the soap off, there will be a sticky residue enabling the dust to stick to it. Got this info on google. Anti-reflective (AR) coating: An anti-reflective coating for solar panels is a nano coating which reduces the reflection and glare produced by an uncoated solar panel. It does this by reducing the difference in refractive index between air and glass. Soap will remove this protective layer over time, unless it's specially made for this type of cleaning. (I think)
June 5, 20224 yr ....and this is about half an hour later. Thought it was the cooling effect of the water, but seems to be stable. Edited June 5, 20224 yr by Warlok bad english
June 6, 20224 yr Cleaned mine now because of this talk and this dust buildup is from only one month since they were last cleaned
June 15, 20224 yr I was looking at my panels a few days ago and could see a thick layer of dust. As it happened.. we had decent rain last night and this morning the oanels looked a lot cleaner. Difference on my PV is about 150w better today at peak vs a few days ago..
June 15, 20224 yr The past weekend I just hosed my panels off with water. Getting about 6% more after cleaning.
October 16, 20232 yr My panels look like this 1 week after cleaning.... I am not exactly spiderman and my neighbours are going to think I have gone OCD mad if I jump up and down my roof on a weekly basis. So isn't there a more sustainable solution? Has anyone tried these so called nano ceramic coatings? The information and company details behind these products look a little bit sketchy so I am not sure if it is just a money making gimmick? Kind of makes me think the salesmen behind these proliferate car detailing products which are being hawked at filling stations have simply relabeled some of their product lines as PV coatings. Nevertheless, hoping there is a real McCoy out there someone can recommend
October 16, 20232 yr On 2022/06/06 at 1:30 PM, MakoShark said: Cleaned mine now because of this talk and this dust buildup is from only one month since they were last cleaned
October 16, 20232 yr On 2022/06/15 at 12:27 PM, JacquesVDM said: The past weekend I just hosed my panels off with water. Getting about 6% more after cleaning. Was this 6% still present say 15min after cleaning?
October 16, 20232 yr Just cleaned my panels this evening, will update tomorrow on results I had a thick layer of dust and haven’t cleaned installation (April 2023)
October 17, 20232 yr Wow cleaning my Panels made a huge difference to my PV, by at least 2000w. I used just water. … pleasantly surprised!
October 17, 20232 yr On a hot day cleaning will always make a short-lived difference because the panels cool down. So let them show higher output for an hour or so before you pop the bubbly.
