Sc00bs Posted April 11, 2021 Share Posted April 11, 2021 Hi Guys Does anyone know of any Sunsynk Canbus compatible BMS's? I don't see any on the list of compatible products and am wondering what the issues are if any. Was thinking of building my own battery and would obviously like it to be CANBUS compatible if possible. Quote Link to comment Share on other sites More sharing options...
Cliff Posted April 11, 2021 Share Posted April 11, 2021 Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf Quote Link to comment Share on other sites More sharing options...
Yellow Measure Posted April 12, 2021 Share Posted April 12, 2021 10 hours ago, Cliff said: Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf That list is a little out of date because it lists Hubble as only supported by voltage based charge settings on the Sunsynk. The Hubble does support CANbus comms based integration on all AM models, and only one of its batteries (X-100) using the RIOT, see https://www.hubblelithium.co.za/uploads/1/3/5/0/135079623/hubble_inverter_compatibility_list.pdf As far as I am aware the BSLBatt supplied by @Backbone Energy also supports CANbus comms with the Sunsynk. But to get OT, I think that @Sc00bs was seeking a list of discrete BMSs that are compatible with Sunsynk, there are many available https://www.alibaba.com/bms-with-canbus-suppliers.html so it may be best to contact Sunsynk directly. Quote Link to comment Share on other sites More sharing options...
Backbone Energy Posted April 12, 2021 Share Posted April 12, 2021 BSLB range of batteries are compatible with Sunsynk as we have confirmed in our testing environment namely: 5,1kw BSLB 6,4kw BSLB 10,2kw BSLB Yellow Measure and bobmabena 2 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted April 12, 2021 Author Share Posted April 12, 2021 11 hours ago, Cliff said: Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf Hi Cliff, I am talking about a discrete BMS, I saw JustinSchoeman's project and it looks awesome but was wondering if there is not a BMS that is natively compatible with the Sunsynk. Would make things a lot easier, although I am pretty sure that Justin would have looked into that when he built up his battery, I thought that maybe things had progressed a bit since he started his project. Quote Link to comment Share on other sites More sharing options...
TonyH Posted April 12, 2021 Share Posted April 12, 2021 (edited) 14 hours ago, Sc00bs said: Hi Guys Does anyone know of any Sunsynk Canbus compatible BMS's? I don't see any on the list of compatible products and am wondering what the issues are if any. Was thinking of building my own battery and would obviously like it to be CANBUS compatible if possible. There is an incomplete list in the manual. I have a Hubble AM2 which communicated well with the Sunsynk although Hubble isn't on the list. Edited April 12, 2021 by TonyH spelling Quote Link to comment Share on other sites More sharing options...
Cliff Posted April 12, 2021 Share Posted April 12, 2021 11 hours ago, Sc00bs said: Hi Cliff, I am talking about a discrete BMS, I saw JustinSchoeman's project and it looks awesome but was wondering if there is not a BMS that is natively compatible with the Sunsynk. Would make things a lot easier, although I am pretty sure that Justin would have looked into that when he built up his battery, I thought that maybe things had progressed a bit since he started his project. Right, that makes sense now. I am sure you could snoop the CAN bus and figure out what the inverter is asking from the battery and then emulate it, but that would require a fair amount of work to implement. Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted April 12, 2021 Author Share Posted April 12, 2021 That's basically what Justin's project is doing so could go that route if I had too. Would rather just find something that speaks the same language as the Sunsynk on Canbus if possible, Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted April 12, 2021 Author Share Posted April 12, 2021 Looks like the Sol-Ark is compatible with the Orion BMS so that may be an option. https://www.sol-ark.com/battery-partners/ https://www.orionbms.com/ Quote Link to comment Share on other sites More sharing options...
JustinSchoeman Posted April 12, 2021 Share Posted April 12, 2021 There are a number of BMSs which are compatible - but they are not generally sold on the DIY market. Mostly wholesale to manufacturers. The ones that are available separately tend to be ludicrously expensive. The 'cheapies' generally used on the DIY market are intended for electric bikes/scooters/other vehicles, so they don't really bother with inverter comms. Quote Link to comment Share on other sites More sharing options...
martinL Posted April 18, 2021 Share Posted April 18, 2021 Looking for the same info. Found that seplos is claiming that (seplos.com) Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
GreenMan Posted April 18, 2021 Share Posted April 18, 2021 I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com) Andre grobler 1 Quote Link to comment Share on other sites More sharing options...
Bain Viljoen Posted April 19, 2021 Share Posted April 19, 2021 11 hours ago, GreenMan said: I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com) Hi As @GreenMan suggests our DALYs with Custom firmware has CABbus communication with Sunsynk inverters. Andre grobler 1 Quote Link to comment Share on other sites More sharing options...
Colin B Posted May 23, 2021 Share Posted May 23, 2021 Hi, I'm installing a Daly 16S 48V 100A on 15 cells, anybody know how the balance leads should be connected for 15 cells ? Quote Link to comment Share on other sites More sharing options...
GreenMan Posted May 23, 2021 Share Posted May 23, 2021 I assume you are using the BMS that is a "15S/16S 48V LiFePO4 Smart BMS" with your 15S battery configuration. If that is the case, the last 2 BMS sense wires BOTH go to cell 15 positive. Also set 15S when you configure the BMS. Quote Link to comment Share on other sites More sharing options...
Colin B Posted March 2, 2022 Share Posted March 2, 2022 On 2021/04/18 at 9:38 PM, GreenMan said: I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com) Did you get your Daly BMS to communicate with the Sunsynk. Is it on CAN Bus, or RS485 ? What pinouts did you use on rhe inverter side ? Quote Link to comment Share on other sites More sharing options...
Raj35 Posted March 3, 2022 Share Posted March 3, 2022 (edited) @Sc00bs I have built my own battery ,Daly has some limitations like parallel and balancing. I think Seplos has but have not tried it , I'm currently using a JBD 200amp with my 15kwh bank no coms with inverter works well with Sunsynk. Edited March 3, 2022 by Raj35 Sc00bs 1 Quote Link to comment Share on other sites More sharing options...
GreenMan Posted March 4, 2022 Share Posted March 4, 2022 On 2022/03/03 at 1:57 AM, Colin B said: Did you get your Daly BMS to communicate with the Sunsynk. Is it on CAN Bus, or RS485 ? What pinouts did you use on rhe inverter side ? My battery does not communicate with an inverter - so not using the CAN or RS485 connections. Quote Link to comment Share on other sites More sharing options...
iiznh Posted March 4, 2022 Share Posted March 4, 2022 If you have a USB-RS485 cable and a USB-CAN cable these comms can be implemented with a little programming. Have helped a friend in the past to build something like this. We used a RaspPi4 Quote Link to comment Share on other sites More sharing options...
CJ Solar Posted May 16, 2022 Share Posted May 16, 2022 Hi Team I would like to know if any of you did some works to connect and BYD Battery Box Pro 13.8 to and 5Kw Sunsynk Inverter. From What I can find the BYD Battery Box Pro use pin 4=Can H and Pin 5 = Can L And the Sunsynk use the same, so and cross connection cale to connect these should work...? Thanks... Quote Link to comment Share on other sites More sharing options...
pedro54 Posted June 15, 2022 Share Posted June 15, 2022 On 2022/03/04 at 11:10 AM, iiznh said: If you have a USB-RS485 cable and a USB-CAN cable these comms can be implemented with a little programming. Have helped a friend in the past to build something like this. We used a RaspPi4 Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk. Quote Link to comment Share on other sites More sharing options...
iiznh Posted June 15, 2022 Share Posted June 15, 2022 1 hour ago, pedro54 said: On 2022/03/04 at 1:10 PM, iiznh said: Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk. Beauty about a public forum is that plenty people can benefit from the process. If you have questions, please ask them. Will try to assist where possible Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted June 15, 2022 Share Posted June 15, 2022 1 hour ago, pedro54 said: Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk. If you are using a decent bms like the jk bms then there is really no need for it to communicate with the inverter. Just use the voltage setting on the inverter side with the correct values to match your battery then you will be good to go. Those JK bms's are awesome and maintain your batteries very well. zsde 1 Quote Link to comment Share on other sites More sharing options...
pedro54 Posted June 15, 2022 Share Posted June 15, 2022 I’m quite new to this, I have a 48v battery pack. What would the sensible values to put in the inverter? In the manual it says if no communication treat as AGM? Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted June 15, 2022 Share Posted June 15, 2022 3 hours ago, pedro54 said: In the manual it says if no communication treat as AGM? Correct, on the sunsynk if no comms then use AGM V (Voltage) - NOT % The actual settings will be according to your battery bank specs, usually close to or the same as you have on the JK bms. The JK BMS will do all the actual work of controlling what happens to the battery, thats if its the JK BMS you are using and it has been setup correctly for your specific battery specs. Quote Link to comment Share on other sites More sharing options...
