April 11, 20215 yr Hi Guys Does anyone know of any Sunsynk Canbus compatible BMS's? I don't see any on the list of compatible products and am wondering what the issues are if any. Was thinking of building my own battery and would obviously like it to be CANBUS compatible if possible.
April 11, 20215 yr Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf
April 12, 20215 yr 10 hours ago, Cliff said: Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf That list is a little out of date because it lists Hubble as only supported by voltage based charge settings on the Sunsynk. The Hubble does support CANbus comms based integration on all AM models, and only one of its batteries (X-100) using the RIOT, see https://www.hubblelithium.co.za/uploads/1/3/5/0/135079623/hubble_inverter_compatibility_list.pdf As far as I am aware the BSLBatt supplied by @Backbone Energy also supports CANbus comms with the Sunsynk. But to get OT, I think that @Sc00bs was seeking a list of discrete BMSs that are compatible with Sunsynk, there are many available https://www.alibaba.com/bms-with-canbus-suppliers.html so it may be best to contact Sunsynk directly.
April 12, 20215 yr BSLB range of batteries are compatible with Sunsynk as we have confirmed in our testing environment namely: 5,1kw BSLB 6,4kw BSLB 10,2kw BSLB
April 12, 20215 yr Author 11 hours ago, Cliff said: Hi not sure if you mean BMS's as in a third party ones, but they support most batteries, with a BMS, over CAN. Here is a https://www.fullcirclesolar.co.za/wp-content/uploads/2020/08/35-FCS-SunSynk-Inverter-Lithium-Battery-Compatibility.pdf Hi Cliff, I am talking about a discrete BMS, I saw JustinSchoeman's project and it looks awesome but was wondering if there is not a BMS that is natively compatible with the Sunsynk. Would make things a lot easier, although I am pretty sure that Justin would have looked into that when he built up his battery, I thought that maybe things had progressed a bit since he started his project.
April 12, 20215 yr 14 hours ago, Sc00bs said: Hi Guys Does anyone know of any Sunsynk Canbus compatible BMS's? I don't see any on the list of compatible products and am wondering what the issues are if any. Was thinking of building my own battery and would obviously like it to be CANBUS compatible if possible. There is an incomplete list in the manual. I have a Hubble AM2 which communicated well with the Sunsynk although Hubble isn't on the list. Edited April 12, 20215 yr by TonyH spelling
April 12, 20215 yr 11 hours ago, Sc00bs said: Hi Cliff, I am talking about a discrete BMS, I saw JustinSchoeman's project and it looks awesome but was wondering if there is not a BMS that is natively compatible with the Sunsynk. Would make things a lot easier, although I am pretty sure that Justin would have looked into that when he built up his battery, I thought that maybe things had progressed a bit since he started his project. Right, that makes sense now. I am sure you could snoop the CAN bus and figure out what the inverter is asking from the battery and then emulate it, but that would require a fair amount of work to implement.
April 12, 20215 yr Author That's basically what Justin's project is doing so could go that route if I had too. Would rather just find something that speaks the same language as the Sunsynk on Canbus if possible,
April 12, 20215 yr Author Looks like the Sol-Ark is compatible with the Orion BMS so that may be an option. https://www.sol-ark.com/battery-partners/ https://www.orionbms.com/
April 12, 20215 yr There are a number of BMSs which are compatible - but they are not generally sold on the DIY market. Mostly wholesale to manufacturers. The ones that are available separately tend to be ludicrously expensive. The 'cheapies' generally used on the DIY market are intended for electric bikes/scooters/other vehicles, so they don't really bother with inverter comms.
April 18, 20215 yr I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com)
April 19, 20215 yr 11 hours ago, GreenMan said: I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com) Hi As @GreenMan suggests our DALYs with Custom firmware has CABbus communication with Sunsynk inverters.
May 23, 20215 yr Hi, I'm installing a Daly 16S 48V 100A on 15 cells, anybody know how the balance leads should be connected for 15 cells ?
May 23, 20215 yr I assume you are using the BMS that is a "15S/16S 48V LiFePO4 Smart BMS" with your 15S battery configuration. If that is the case, the last 2 BMS sense wires BOTH go to cell 15 positive. Also set 15S when you configure the BMS.
March 2, 20224 yr On 2021/04/18 at 9:38 PM, GreenMan said: I got this BMS and it has a CAN/RS485 port... LBSA DALY 100a 15S/16S 48V LiFePO4 Smart BMS with Optional Display or Bluetooth | Lithium Batteries South Africa (lithiumbatteriessa.co.za) This is pinout of the CAN/RS485 connector - DL-R16A-F16S100ATJ-MM00_Product_Specification_Confirmation_1.pdf (shopify.com) Did you get your Daly BMS to communicate with the Sunsynk. Is it on CAN Bus, or RS485 ? What pinouts did you use on rhe inverter side ?
March 3, 20224 yr @Sc00bs I have built my own battery ,Daly has some limitations like parallel and balancing. I think Seplos has but have not tried it , I'm currently using a JBD 200amp with my 15kwh bank no coms with inverter works well with Sunsynk. Edited March 3, 20224 yr by Raj35
March 4, 20224 yr On 2022/03/03 at 1:57 AM, Colin B said: Did you get your Daly BMS to communicate with the Sunsynk. Is it on CAN Bus, or RS485 ? What pinouts did you use on rhe inverter side ? My battery does not communicate with an inverter - so not using the CAN or RS485 connections.
March 4, 20224 yr If you have a USB-RS485 cable and a USB-CAN cable these comms can be implemented with a little programming. Have helped a friend in the past to build something like this. We used a RaspPi4
May 16, 20224 yr Hi Team I would like to know if any of you did some works to connect and BYD Battery Box Pro 13.8 to and 5Kw Sunsynk Inverter. From What I can find the BYD Battery Box Pro use pin 4=Can H and Pin 5 = Can L And the Sunsynk use the same, so and cross connection cale to connect these should work...? Thanks...
June 15, 20224 yr On 2022/03/04 at 11:10 AM, iiznh said: If you have a USB-RS485 cable and a USB-CAN cable these comms can be implemented with a little programming. Have helped a friend in the past to build something like this. We used a RaspPi4 Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk.
June 15, 20224 yr 1 hour ago, pedro54 said: On 2022/03/04 at 1:10 PM, iiznh said: Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk. Beauty about a public forum is that plenty people can benefit from the process. If you have questions, please ask them. Will try to assist where possible
June 15, 20224 yr 1 hour ago, pedro54 said: Hi, can you contact me about this? I would like my JkBms can communicate with my SunSynk. If you are using a decent bms like the jk bms then there is really no need for it to communicate with the inverter. Just use the voltage setting on the inverter side with the correct values to match your battery then you will be good to go. Those JK bms's are awesome and maintain your batteries very well.
June 15, 20224 yr I’m quite new to this, I have a 48v battery pack. What would the sensible values to put in the inverter? In the manual it says if no communication treat as AGM?
June 15, 20224 yr 3 hours ago, pedro54 said: In the manual it says if no communication treat as AGM? Correct, on the sunsynk if no comms then use AGM V (Voltage) - NOT % The actual settings will be according to your battery bank specs, usually close to or the same as you have on the JK bms. The JK BMS will do all the actual work of controlling what happens to the battery, thats if its the JK BMS you are using and it has been setup correctly for your specific battery specs.
