On 2023/08/13 at 6:25 PM, slipx said:
Hi, slipx. Thanks a mill for all your work on ESPHome. I got set up pretty easily with an ESP32 and following this forum thread and scoobs' youtube vids. Got data pulling through but it was all jumbled, figured out that it's because I have the Sunsynk 12kva 3ph and the register is different.
My question is:
On your github page there's a yaml for the 8kw inverters that is complete (and is what I got started with) and another yaml file for the 12kw inverters. The 12kw file appears incomplete? How do I go about replacing the relevant parts of the 8kw file?
I've tried just copy pasting everything from the 12kw yaml to the 8kw yaml after the BINARY SENSORS line but it breaks the yaml code. After some fiddling I found that the issue that I thought was spacing or something was actually the ${modbus_controller_id} term that was causing trouble. I replaced all instances with "sunsynk".
Also, there appears to be a lot more sensors in the 8kw file than in the 12kw file, is that correct or do I need to pick each sensor code section out one by one from the 12kw file and replace em in the 8kw file?
Thanks again!
  • Replies 657
  • Views 182.1k
Hi. I haven't really looked at the 12kW three phase inverters. That config was copied from another repo just for reference and has not been tested. If I have some time I'll create a proper version.
OK that makes sense this. I'll do some work on it and if it works I'll post it on here.
On 2023/01/08 at 10:43 PM, Klatremis said:
I only made this user to share this 🤣 Thanks all for the inspiration.
Exactly as BrettC suggest, I made this in the weekend for my deye :) I have shared it with some hundreds other danish deye owners and waiting for more feedback.
The adresses i use is matching my 12kW 3 phase, low voltage hybrid deye inverter. I seems for me that the modbus adresses does not match your sunsync inverters(deye inverters).
github.com/klatremis/esphome-for-deye
I'd like to power my ESP32 from the Sunsynk's board as well. Do you know the voltage on the CN2 7&8 pins? Would this USB power supply work?
https://make.net.za/product/usb-fast-charge-module-ip6505-single-usb/
On 2022/09/14 at 2:28 PM, Sc00bs said:
@sjlouw I am doing something wrong and I can't figure out what cause I can't get my ESP32 to work!
I have tried 2 different boards and two different RS485 connectors (same models as you specified) but no joy
Have tried different ethernet cables etc, I am using a T568B cable so using the orange/orange&white cables (pin 1&2)
These are the errors I am getting, any idea?
Settings on the inverter are as specified.
I am also getting this issue. Did you manage to solve it?
Has anyone tried this on a 5kW Deye? I am struggling to get data from the inverter.
Here is my yaml code:
and here is the logs from ESPHome:
I have checked and rechecked wiring and soldering. It's as if no data is coming through.
@kellerza, so I adjusted the polling rates according to the link provided. It then still crash. I then increased to 20 seconds and it still crashed.
here is some of my config. Maybe there is something wrong with the sensors.
SENSOR_DEFINITIONS: single-phase
SENSORS:
  - energy_management
  - power_flow_card
  - pv2_voltage
  - pv2_power
  - pv2_current
  - battery_temperature
  - dc_transformer_temperature
  - radiator_temperature
  - total_load_energy
  - settings
  - load_limit
SENSORS_FIRST_INVERTER:
  - settings
MANUFACTURER: Sunsynk
READ_ALLOW_GAP: 2
READ_SENSORS_BATCH_SIZE: 20
SCHEDULES:
  - KEY: W
    READ_EVERY: 20
    REPORT_EVERY: 60
    CHANGE_BY: 80
  - KEY: RW
    READ_EVERY: 20
    REPORT_EVERY: 60
    CHANGE_ANY: true
  - KEY: any_unit
    READ_EVERY: 30
    REPORT_EVERY: 60
    CHANGE_BY: 80
Depending on your inverter (Think the 3phase is 7&8), yes it will work, Make sure you double check positive and negative. Reversing the polarity leads to fubar micro-controllers. Also make sure you insulate it, you do not want positive to short to ground in the inverter case.
I have a purposefully designed circuit for Deye/Sunsynk/Sol-Ark inverters called the SmartDeyeDongle with custom written firmware (for home assistant) where I actually fixed the quirks in the opensource software. (You can order from me, I ship to all cities/towns in South Africa) smarthomeintegrations(dot)co(dot)za
Considering your time is probably worth more than R250-500p/h most people struggle for days. If you aim is to learn low level electronics, let me not stand in your way. Welcome to the magic realm where the smoke means you lost a life, de-solder, reorder and try again.
If your aim is to get your inverter automated and saving on eskom consumption then getting a ready-made module is probably the way to go. Chances are that you will recoup the cost very quickly in a month or two.
So I am just going to mention this here. Lots of people are trying to build RS485 circuits designed for 5V that was meant to be used on an Arduino platform. The whole arduino platform is 5V. The ESP32/8266 on the other hand is 3.3V. yrmv
On 2023/08/16 at 5:01 PM, XAB said:
Glad I could help @XianZA. I have now connected both cables on the BMS 485/CAN of my SUNSYNK 5.5KW(newer model) with the below RJ45 Duplicator (Important to get one that does not split the pairs but rather "mirrors" it). I connected Orange to A+ - Orange/WHT to B- and Green/WHT to ground on my USB to RS485. Now I can update settings via HASSIO finally.
Important to note that the RX / TX works on pins 1(Orange/WHT) and 2(Orange) and your battery on pins 4(Blue) and 5 ( Blue/WHT). I tested this first when getting the RJ45 splitter/duplicator.
Prior to this I could receive data via the RS485 port next to the CAN port(left of it) but had to use Blue/WHT(A+) & Blue (B-) from the cable to receive data via the USB to RS485. But could not update as the RS485 port only allowed to receive data.
Image of RJ45 Duplicator into BMS 485/CAN
Image of USB to RS485
I think I've connected my sunsynk 8.8kw via the same method however getting a few errors, anyone have any ideas what I can try to get it working?
MQQT shows this in the logs
Sunsynk Multi shows these in the logs:
Appreciate any help getting this working as I'm close to giving up at this stage but feel i'm sooooo close...
Small update, looks like MQTT is looking healthier after installing this https://github.com/SharkyRawr/hass-mqtt-fix
However I'm still getting these errors in the sunsynk multi logs:
Has anyone had this working on a new SunSynk 5.5 Ecco inverter in the UK?
Here are the ports on the UK 5.5 Ecco. I've tried the BMS \ CAN connector and RS485 connectors, I am begining to think that the UK versions do not have the correct pin outs on the BMS \ CAN bus and the RS485 port on the inverter may have a different pin out compared to the BMS \ CAN.
Edited by Ivan Endicott
I assume the USB-RS485 dongle is on another machine with mbusd running? then your problem sounds/seems like a cable problem, between the dongle and the inverter, could even be a broken conductor in the cable making no contact on either of the 2 needed conductors...
Thanks all the contributors here, certainly a massive help!
I'm doing this slightly differently, and for another use case, using a microchip ATMEGA4809 and common line driver circuitry similar to what most are referencing, all at 5 volts.
To the point: The Deye machine I'm developing off.
MODEL NO:         SUN-5K-SG01LP1-EU
MAIN:            Ver 0-3381-1515
HMI:            Ver 0000-C35D
What I've found: T568B
BMS 485/CAN:
B-/Pin 1(orange/white), A+/Pin 2(orange), Pin3/Gnd(green/white).
METER/METER:
B-/Pin 4(blue), A+/Pin 5(blue/white), Pin3/Gnd(green/white).
Hopefully helps, I doubt this is the latest firmware, so you might have to split out with the battery.
Edited by Reuf
clarification
Guys, can you help, I see others get this error.
21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=150 count=1
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=154 count=1
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=160 count=1
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=164 count=1
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=166 count=4
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=172 count=1
[21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=175 count=4
Also, my sensors is unknown
How did you resolve this error,  duplicated Modbus ?
Guys on the Sunsynk 8KVA what must your MODBUS SN number be to use the ESP32Dev board & RS485 ?
Must it be left as 1 or changed to 0 ?
I struggle to get data from the inverter
Everything was working fine for months, did ESPhome updates and Slipx updates and now receiving no data. Re-flashed etc a number of times etc. No luck
I am struggling with the same issue.
I am now trying to figure out what changed, will let you know.
Using a 5kW though.
Perhaps @slipx, do you have any ideas for us, please?
I got mine sorted.
I updated ESPHome and HomeAssistant, then played around with the config for ESPHome:
substitutions:
  settings_skipped_updates: "30"
  devicename: sunsynk
  device_description: "Sunsynk RS485 Logger"
  friendly_name: "SunSynk"
esphome:
  comment: '${device_description}'
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_encryption_key
ota:
  password: !secret ota_password_sunsynk
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: '${devicename}'
    password: !secret fallback_password
  fast_connect: true
  power_save_mode: none
captive_portal:
# Enable time component to reset energy at midnight
# https://esphome.io/components/time.html#home-assistant-time-source
time:
   - platform: sntp
     timezone: Africa/Johannesburg
     servers:
     - pool.ntp.org
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
modbus:
  flow_control_pin: 4
modbus_controller:
  - id: sunsynk
    address: 0x01
    modbus_id: sunsynk_modbus
    setup_priority: -10
    update_interval: "5s"
    command_throttle: "50ms"
############################################### BINARY SENSORS ########################################
binary_sensor:
  - platform: modbus_controller            # 194 Grid Connected Status
    modbus_controller_id: sunsynk
    name: "${friendly_name} Grid Connected Status"
    register_type: holding
    address: 194
  - platform: modbus_controller           # 280 Gen Peak Shaving Status
    name: "${friendly_name} Gen Peak Shaving Status"
    address: 280
    bitmask: 0x10
  - platform: modbus_controller           # 280 Grid Peak Shaving Status
    name: "${friendly_name} Grid Peak Shaving Status"
    address: 280
    bitmask: 0x100
#                                               SENSORS                                               #
############################################### BATTERY ###############################################
sensor:
  - platform: modbus_controller            # 182 Battery Temperature
    name: "${friendly_name} Battery Temperature"
    address: 182
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    device_class: temperature
    state_class: measurement
    value_type: U_WORD
    filters:
      - offset: -1000
      - multiply: 0.1
  - platform: modbus_controller            # 183 Battery Voltage
    name: "${friendly_name} Battery Voltage"
    address: 183
    unit_of_measurement: "V"
    device_class: voltage
    filters:
      - multiply: 0.01
    value_type: U_WORD
  - platform: modbus_controller            # 184 Battery SOC
    name: "${friendly_name} Battery SOC"
    address: 184
    unit_of_measurement: "%"
    accuracy_decimals: 0
    device_class: battery
    value_type: U_WORD
  - platform: modbus_controller            # 190 Battery Power
    name: "${friendly_name} Battery Power"
    address: 190
    unit_of_measurement: "W"
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller            # 191 Battery Current
    name: "${friendly_name} Battery Current"
    address: 191
    unit_of_measurement: "A"
    device_class: current
    value_type: S_WORD
    filters:
      - multiply: 0.01
  - platform: modbus_controller            # 217 Battery Capacity Shutdown
    name: "${friendly_name} Battery Capacity Shutdown"
    address: 217
############################################### INVERTER ##############################################
  - platform: modbus_controller            # 175 Inverter Power
    name: "${friendly_name} Inverter Power"
    address: 175
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller            # 154 Inverter Voltage
    name: "${friendly_name} Inverter Voltage"
    address: 154
    filters:
      - multiply: 0.1
    value_type: U_WORD
  - platform: modbus_controller            # 164 Inverter Current
    name: "${friendly_name} Inverter Current"
    address: 164
    value_type: S_WORD
    filters:
      - multiply: 0.01
  - platform: modbus_controller            # 193 Inverter Frequency
    name: "${friendly_name} Inverter Frequency"
    address: 193
    unit_of_measurement: "Hz"
    accuracy_decimals: 2
    filters:
      - multiply: 0.01
    value_type: U_WORD
############################################### GRID ##################################################
  - platform: modbus_controller             # 079 Grid Frequency
    name: "${friendly_name} Grid Frequency"
    address: 79
    filters:
      - multiply: 0.01
    value_type: U_WORD
  - platform: modbus_controller             # 169 Grid Power
    name: "${friendly_name} Grid Power"
    address: 169
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller             # 167 Grid LD Power
    name: "${friendly_name} Grid LD Power 167"
    address: 167
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller             # 168 Grid L2 Power
    name: "${friendly_name} Grid L2 Power 168"
    address: 168
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller             # 150 Grid Voltage
    name: "${friendly_name} Grid Voltage"
    address: 150
    filters:
      - multiply: 0.1
    value_type: U_WORD
  - platform: modbus_controller             # 160 Grid Current
    name: "${friendly_name} Grid Current"
    address: 160
    value_type: S_WORD
    filters:
      - multiply: 0.01
  - platform: modbus_controller             # 172 Grid CT Power
    name: "${friendly_name} Grid CT Power"
    address: 172
    device_class: power
    value_type: S_WORD
############################################### LOAD ################################################
  - platform: modbus_controller            # 178 Load Power
    name: "${friendly_name} Load Power"
    address: 178
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller            # 176 Load L1 Power
    name: "${friendly_name} Load L1 Power"
    address: 176
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller            # 177 Load L2 Power
    name: "${friendly_name} Load L2 Power"
    address: 177
    device_class: power
    value_type: S_WORD
  - platform: modbus_controller            # 192 Load Frequency
    name: "${friendly_name} Load Frequency"
    address: 192
    filters:
      - multiply: 0.01
    value_type: U_WORD
############################################### SOLAR PV1 #############################################
  - platform: modbus_controller            # 186 PV1 Power
    name: "${friendly_name} PV1 Power"
    address: 186
    device_class: power
    value_type: U_WORD
  - platform: modbus_controller            # 109 PV1 Voltage
    name: "${friendly_name} PV1 Voltage"
    address: 109
    filters:
      - multiply: 0.1
    value_type: U_WORD
  - platform: modbus_controller            # 110 PV1 Current
    name: "${friendly_name} PV1 Current"
    address: 110
    filters:
      - multiply: 0.1
    value_type: U_WORD
############################################### SOLAR PV2 #############################################
  - platform: modbus_controller            # 187 PV2 Power
    name: "${friendly_name} PV2 Power"
    address: 187
    device_class: power
    value_type: U_WORD
  - platform: modbus_controller            # 111 PV2 Voltage
    name: "${friendly_name} PV2 Voltage"
    address: 111
    filters:
      - multiply: 0.1
    value_type: U_WORD
  - platform: modbus_controller            # 112 PV2 Current
    name: "${friendly_name} PV2 Current"
    address: 112
    filters:
      - multiply: 0.1
    value_type: U_WORD
############################################### SOLAR TOTAL ###########################################
  - platform: template                   # Sum of PV1 and PV2 to get total PV Power
    name: "${friendly_name} Solar Power"
    device_class: power
    lambda: |-
      return (id(sunsynk_esphome_pv1_power).state + id(sunsynk_esphome_pv2_power).state);
    update_interval: 5s
############################################### OUTPUTS ###############################################
  - platform: modbus_controller            # 166 Aux Power
    name: "${friendly_name} AUX Power"
    address: 166
    device_class: power
    value_type: S_WORD
  - platform: template                   # Essential Power based on register 175 + 167 - 166
    name: "${friendly_name} Essential Power"
    device_class: power
    lambda: |-
      return (id(sunsynk_esphome_inverter_power).state + id(sunsynk_esphome_grid_power_167).state - id(sunsynk_esphome_aux_power).state);
    update_interval: 5s
  - platform: template                   # Essential Power1 based on register 175 + 169 - 166
    name: "${friendly_name} Essential Power 1"
    device_class: power
    lambda: |-
      return (id(sunsynk_esphome_inverter_power).state + id(sunsynk_esphome_grid_power_169).state - id(sunsynk_esphome_aux_power).state);
    update_interval: 5s
  - platform: template                   # Nonessential Power 172 - 167
    name: "${friendly_name} Nonessential Power"
    device_class: power
    lambda: |-
      return (id(sunsynk_esphome_grid_ct_power).state - id(sunsynk_esphome_grid_power_167).state);
    update_interval: 5s
  - platform: template                   # Nonessential Power1 172 - 169
    name: "${friendly_name} Nonessential Power 1"
    device_class: power
    lambda: |-
      return (id(sunsynk_esphome_grid_ct_power).state - id(sunsynk_esphome_grid_power_169).state);
    update_interval: 5s
############################################### ENERGY ################################################
  - platform: modbus_controller            # 070 Day Battery Charge
    name: "${friendly_name} Day Battery Charge"
    address: 70
    unit_of_measurement: "kWh"
    device_class: energy
    state_class: total_increasing
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 071 Day Battery Discharge
    name: "${friendly_name} Day Battery Discharge"
    address: 71
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 072 Total Battery Charge
    name: "${friendly_name} Total Battery Charge"
    address: 72
    value_type: U_DWORD_R
    filters:
     - multiply: 0.1
  - platform: modbus_controller            # 074 Total Battery Discharge
    name: "${friendly_name} Total Battery Discharge"
    address: 74
    filters:
     - multiply: 0.1
  - platform: modbus_controller            # 076 Day Grid Import
    name: "${friendly_name} Day Grid Import"
    address: 76
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 077 Day Grid Export
    name: "${friendly_name} Day Grid Export"
    address: 77
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 078 Total Grid Import
    name: "${friendly_name} Total Grid Import"
    address: 78
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 081 Total Grid Export
    name: "${friendly_name} Total Grid Export"
    address: 81
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 084 Day Load Energy
    name: "${friendly_name} Day Load Energy"
    address: 84
    filters:
      - multiply: 0.1
    value_type: U_WORD
  - platform: modbus_controller            # 085 Total Load Energy
    name: "${friendly_name} Total Load Energy"
    address: 85
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 096 Total PV Energy
    name: "${friendly_name} Total PV Energy"
    address: 96
    filters:
      - multiply: 0.1
  - platform: modbus_controller            # 108 Day PV Energy
    name: "${friendly_name} Day PV Energy"
    address: 108
    filters:
      - multiply: 0.1
    value_type: U_WORD
############################################### TEMPERATURE ################################################
  - platform: modbus_controller            # 090 DC Transformer Temperature
    name: "${friendly_name} DC Transformer Temperature"
    address: 090
    value_type: S_WORD
    filters:
      - offset: -1000
      - multiply:  0.1
  - platform: modbus_controller            # 091 Radiator Temperature
    name: "${friendly_name} Radiator Temperature"
    address: 091
    value_type: S_WORD
    filters:
      - offset: -1000
      - multiply:  0.1
################################################ READ SETTINGS #############################################
  - platform: modbus_controller          # 250 System Mode Time 1
    name: "${friendly_name} System Mode Time1"
    skip_updates: ${settings_skipped_updates}
    address: 250
    icon: "mdi:clock"
  - platform: modbus_controller          # 251 System Mode Time 2
    name: "${friendly_name} System Mode Time2"
    address: 251
    icon: "mdi:clock"
  - platform: modbus_controller          # 252 System Mode Time 3
    name: "${friendly_name} System Mode Time3"
    address: 252
    icon: "mdi:clock"
  - platform: modbus_controller          # 253 System Mode Time 4
    name: "${friendly_name} System Mode Time4"
    address: 253
    icon: "mdi:clock"
  - platform: modbus_controller          # 254 System Mode Time 5
    name: "${friendly_name} System Mode Time5"
    address: 254
    icon: "mdi:clock"
  - platform: modbus_controller          # 255 System Mode Time 6
    name: "${friendly_name} System Mode Time6"
    address: 255
    icon: "mdi:clock"
  - platform: modbus_controller        # 255 Grid Peak Shaving raw register value
    address: 280
    value_type: U_WORD
################################################ WRITE SETTINGS ############################################
switch:
  - platform: modbus_controller          # 326 Toggle Force Generator
    use_write_multiple: true
    name: "${friendly_name} Toggle Force Generator"
    address: 326
    bitmask: 8192 # 2^13 to target bit 13
    icon: "mdi:toggle-switch"
  - platform: modbus_controller          # 247 Toggle Solar Sell
    name: "${friendly_name} Toggle Solar sell"
    address: 247
    bitmask: 1
  - platform: modbus_controller          # 248 Toggle System Timer
    name: "${friendly_name} Toggle System Timer"
    address: 248
    bitmask: 1
  - platform: modbus_controller          # 243 Priority Load
    name: "${friendly_name} Toggle Priority Load"
    address: 243
    bitmask: 1
  - platform: modbus_controller          # 274 System Mode Grid Charge Time 1
    name: "${friendly_name} System Mode Grid Charge Time1"
    address: 274
    bitmask: 1
  - platform: modbus_controller          # 275 System Mode Grid Charge Time 2
    name: "${friendly_name} System Mode Grid Charge Time2"
    address: 275
    bitmask: 1
  - platform: modbus_controller          # 276 System Mode Grid Charge Time 3
    name: "${friendly_name} System Mode Grid Charge Time3"
    address: 276
    bitmask: 1
  - platform: modbus_controller          # 277 System Mode Grid Charge Time 4
    name: "${friendly_name} System Mode Grid Charge Time4"
    address: 277
    bitmask: 1
  - platform: modbus_controller          # 278 System Mode Grid Charge Time 5
    name: "${friendly_name} System Mode Grid Charge Time5"
    address: 278
    bitmask: 1
  - platform: modbus_controller          # 279 System Mode Grid Charge Time 6
    name: "${friendly_name} System Mode Grid Charge Time6"
    address: 279
    bitmask: 1
number:
  - platform: modbus_controller         # 268 System Mode SoC Time 1
    name: "${friendly_name} System Mode SoC Time1"
    address: 268
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 269 System Mode SoC Time 2
    name: "${friendly_name} System Mode SoC Time2"
    address: 269
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 270 System Mode SoC Time 3
    name: "${friendly_name} System Mode SoC Time3"
    address: 270
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 271 System Mode SoC Time 4
    name: "${friendly_name} System Mode SoC Time4"
    address: 271
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 272 System Mode SoC Time 5
    name: "${friendly_name} System Mode SoC Time5"
    address: 272
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 273 System Mode SoC Time 6
    name: "${friendly_name} System Mode SoC Time6"
    address: 273
    min_value: 0
    max_value: 100
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 256 System Mode Power Time 1
    name: "${friendly_name} System Mode Power Time1"
    address: 256
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 257 System Mode Power Time 2
    name: "${friendly_name} System Mode Power Time2"
    address: 257
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 258 System Mode Power Time 3
    name: "${friendly_name} System Mode Power Time3"
    address: 258
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 259 System Mode Power Time 4
    name: "${friendly_name} System Mode Power Time4"
    address: 259
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 260 System Mode Power Time 5
    name: "${friendly_name} System Mode Power Time5"
    address: 260
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 261 System Mode Power Time 6
    name: "${friendly_name} System Mode Power Time6"
    address: 261
    min_value: 0
    max_value: 8000
    step: 100
    value_type: U_WORD
  - platform: modbus_controller         # 230 Grid Charge Battery current
    name: "${friendly_name} Grid Charge Battery current"
    address: 230
    min_value: 0
    max_value: 185
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 210 Battery Max Charge current
    name: "${friendly_name} Battery Max Charge current"
    address: 210
    min_value: 0
    max_value: 185
    step: 5
    value_type: U_WORD
  - platform: modbus_controller         # 211 Battery Max Discharge current
    name: "${friendly_name} Battery Max Discharge current"
    address: 211
    min_value: 0
    max_value: 185
    step: 5
    value_type: U_WORD
  - platform: modbus_controller            # 293 Grid Peak Shaving Power
    name: "${friendly_name} Grid Peak shaving power"
    address: 293
    min_value: 0
    max_value: 8000
    step: 500
    value_type: U_WORD
  - platform: modbus_controller            # 245 Max Sell Power
    name: "${friendly_name} Max Sell power"
    address: 245
    min_value: 0
    max_value: 8000
    step: 500
    value_type: U_WORD
################################################ TEXT SENSORS ##################################################
text_sensor:
  - platform: modbus_controller            # 059 Overall State
    name: "${friendly_name} Overall State"
    raw_encode: HEXBYTES
    address: 59
    lambda: |-
      uint16_t value = modbus_controller::word_from_hex_str(x, 0);
      switch (value) {
        case 0: return std::string("standby");
        case 1: return std::string("selftest");
        case 2: return std::string("normal");
        case 3: return std::string("alarm");
        case 4: return std::string("fault");
        default: return std::string("unknown");
    name: "${friendly_name} Time Slot 1"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time1).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time1).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time1).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
        char formatted_time[6];
        snprintf(formatted_time, sizeof(formatted_time), "%02d:%02d", hours, minutes);
        return esphome::optional<std::string>(formatted_time);
    name: "${friendly_name} Time Slot 2"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time2).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time2).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time2).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
    name: "${friendly_name} Time Slot 3"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time3).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time3).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time3).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
    name: "${friendly_name} Time Slot 4"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time4).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time4).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time4).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
    name: "${friendly_name} Time Slot 5"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time5).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time5).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time5).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
    name: "${friendly_name} Time Slot 6"
    icon: "mdi:clock"
    lambda: |-
        int minutes, hours;
        if (id(sunsynk_esphome_system_mode_time6).state) {
        minutes = static_cast<int>(id(sunsynk_esphome_system_mode_time6).state) % 100;
        hours = static_cast<int>(id(sunsynk_esphome_system_mode_time6).state) / 100;
        } else {
          minutes = 0;
          hours = 0;
################################################ SELECT SENSORS ################################################
select:
  - platform: modbus_controller                   #243 Select Energy Patern
    name: "${friendly_name} Energy Pattern"
    address: 243
    value_type: U_WORD
    optionsmap:
      "Battery first": 0
      "Load first": 1
  - platform: modbus_controller                   #244 Select Work Mode
    name: "${friendly_name} Work Mode"
    address: 244
    value_type: U_WORD
    optionsmap:
      "Selling First": 0
      "Zero Export + Limit to Load Only": 1
      "Limited to Home": 2
  - platform: modbus_controller                  #280 Select Grid Peak Shaving
    name: "${friendly_name} Grid Peak Shaving"
    address: 280
    value_type: U_WORD
    optionsmap:
      "Disabled": 0
      "Enabled": 256
    lambda: |-
      // we are only interested in the 8th bit binary 0001 0000 0000 need to map the options 0, 256 in select
      //ESP_LOGE("main","Modbus Number incoming value = %d",x);
      //ESP_LOGE("main","Modbus eval value = %d",(x & 0x0100));
      if ((x & 0x0100) == 0)
        return  std::string("Disabled");
      if ((x & 0x0100) == 256)
        return  std::string("Enabled");
      return {};
    write_lambda: |-
      //ESP_LOGE("main","Modbus write gets = %d",value);
      uint16_t unmodified =  id(grid_peak_shaving_raw).state;
      //ESP_LOGE("main","Modbus write unmodified = %d", unmodified);
      // optionsmap should only return 2 values... 0 , 256 so bitmask with complement 0x0100 to ensure we keep the original values in register. Then appply OR with the value that was chosen
      uint16_t modified = ((unmodified & ~0x0100) | value);
      //ESP_LOGE("main","Modbus write to write = %d", modified);
      return modified;
Guys eventually got my Esp32 & RS485 working again. The problem was the RS485 board not sure what happened to it.  Added a new board and all data started coming through.
Something things I learned.
1. Don't need two pairs of wires coming from the your RS45. Only need the orange ( goes to A on RS485 ) and the orange/white (goes to B on the RS485)
2. If you get this error  " 21:51:58][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=150 count=1  "    I was told to increase your Modbus_controller update_interval. When I increased this the error went away.
3. I read that don't add power to the RS485 from the ESP32 only connect the ground and not the 5v.
Hope this all correct but it seems to be working fine now.
What I am concerned about is that I read that you should power the ESP32 Dev board with 3v and not 5v ?
I am using a phone charger and usb cable to power the ESp32 dev board, is this going to cause a problem ?
Well done @McGuywer, excellent. Also got min sorted today by adding a new RS485 board. For some reason the board got damaged even though the RED led lights up.
I thought the problem was because of all the updates on Esphome and Dashboard updates.
So now I bought extra boards.
What do you power your ESP32 board with ?
Hi @Vaughanza
Heinz from Smarthomeintegrations imports a very nice ESP32Shield that includes a power supply and 3.3V RS485/Canbus interface that he uses in his SmartHomeDongle. If you have an 8, 12 or 16kw Sunsynk/Deye inverter (not sure about the 5kw) you can then power the unit from the 12V power supply inside the inverter which is very neat.
I did a review of the whole package on my Youtube channel and he did say that he would sell them without his firmware for the DIYers if someone wants. Is a very neat solution and gets rid of all of the soldering and most of the wiring issues that seem to plague people's ESP32 installs.
On 2023/11/03 at 8:18 AM, Sc00bs said:
Hi @Vaughanza
Thanks @Sc00bs appreciate it. Was thinking that when I watched your video earlier.
