September 8, 20223 yr We are in the process of reviewing this product Power Forum Store will be giving one unit away to an approved installer in a LUCKY DRAW close to end of November Retail Value of this give away is R110 000 Vat Included Sponsored by Elleyhill Power (PTY) LTD Installers can contact us directly for installer pricing We will post more details later how to qualify for the the lucky draw watch this thread... here is some details about the system to wet your appetite This inverter is NRS Approved The supplier will make the parallel kit for the inverter will be available at the Beginning of 2023 awaiting on NRS Approval for the kit. DATA SHEET PROMOTIONAL VIDEO SMILE-G3 5 kW 10.1 kWh High Voltage Lithium Battery YOUR ALMIGHTY KNIGHT This residential ESS is with 5kW hybrid single-phase inverter and 10kWh battery module. This product can capture more precise data for stricter VPP requirements. Also, in off-grid scenario, this one has better performance and can work parallel. AlphaESS rolled out its brand new SMILE G3 in South Africa. This residential energy storage system includes a 5kW hybrid single-phase inverter and a 10kWh battery module, expandable to 60.5kWh. This product is able to capture more precise data for stricter VPP requirements and work in an off-grid scenario with parallel function. YOUR ALMIGHTY KNIGHT offers ❤ 200% PV Input ❤ Grid-Forming Function ❤ Off-Grid Parallel Operation ❤ Faster Response for VPP Control ❤ Saving More Than 70% Installation Time ❤ 150% Backup Overload for 30 seconds ❤ Silent Operation Fan less System ❤ Remote Configuration Monitoring Diagnostics and Updates ❤ Wifi Dongle For Remote Monitoring and Configuration Included ❤ NRS Approved ❤ Aesthetically Pleasing Very Clean Installation ❤ IP65 Rated ❤ No PV Isolator Required Only Surge Protection ❤ No Battery Disconnect Required ❤ No AC Breakers Required Only Changeover Switch & Surge Protection ❤ Very Little Cable Trunking Required SPECS Max. AC Output Power 5 kW Capacity Range 10.1 kWh Max. Charging/Discharging Current 60 A Depth of Discharge (DoD) 95% Dimension (W x D x H) 610 X 230 X 1168 mm Operating Temperature Range -10 °C ~ 50 °C IP Protection IP65 Warranty 5 Year Product Warranty, 10 Year Battery Warranty
September 8, 20223 yr 10kW PV 😍 It seems like higher voltage batteries are also going to be a trend, this one is 96V, so no more really thick and expensive cabling. So how do we enter into the draw? Edited September 8, 20223 yr by YellowTapemeasure
September 8, 20223 yr Author Indeed also no cabling between the battery and the inverter everything is integrated including the DC Isolator and on the PV side you only need the type 1 type 2 SPD devices no PV combiner boxes needed and also proper plugs to connect all the inputs and outputs to the inverter no silly connector blocks that can break They claim that the inverter and the battery can be fully installed in 30 Minutes this will reduce labor time wasted considerably ..
September 8, 20223 yr Author 6 minutes ago, madness_za said: Giveaway only to installer we have some giveaway's for Power Forum Members coming up too 😉
September 8, 20223 yr Author 4 hours ago, YellowTapemeasure said: So how do we enter into the draw? We will make a post here with all the details and requirements to qualify for the Lucky Draw.
September 8, 20223 yr This system was installed at my sisters place by a large solar company as an offgrid system. They could not get this unit to work reliably - kept on having brownouts approx once or twice a day . Even contacted China only to be told later this is not designed as an offgrid system. Installation manual explicitly states "that its not an offgrid system" , even though the glossy brouchre says it can work offgrid. Unit was removed and replace with SunSynk. now all is OK
September 8, 20223 yr 7 minutes ago, NoordSolar said: This system was installed at my sisters place by a large solar company as an offgrid system. They could not get this unit to work reliably - kept on having brownouts approx once or twice a day . Even contacted China only to be told later this is not designed as an offgrid system. Installation manual explicitly states "that its not an offgrid system" , even though the glossy brouchre says it can work offgrid. Unit was removed and replace with SunSynk. now all is OK thanks for that
September 8, 20223 yr 9 minutes ago, NoordSolar said: This system was installed at my sisters place by a large solar company as an offgrid system. They could not get this unit to work reliably - kept on having brownouts approx once or twice a day . Even contacted China only to be told later this is not designed as an offgrid system. Installation manual explicitly states "that its not an offgrid system" , even though the glossy brouchre says it can work offgrid. Unit was removed and replace with SunSynk. now all is OK I am aware of some issues with the older generation Alpha ESS SMILE. Did your sister get the SMILE-G3, or the older Alpha ESS SMILE? The G3 has barely launched in SA.
September 8, 20223 yr Author 43 minutes ago, NoordSolar said: This system was installed at my sisters place by a large solar company as an offgrid system. They could not get this unit to work reliably - kept on having brownouts approx once or twice a day . Even contacted China only to be told later this is not designed as an offgrid system. Installation manual explicitly states "that its not an offgrid system" , even though the glossy brouchre says it can work offgrid. Unit was removed and replace with SunSynk. now all is OK This is a new model not the old Alpha ESS this is the new G3 High Voltage model . With extensive improvements on the old one it will also be able to parallel and has a new advanced app and Wifi dongle with Realtime configuration. Edited September 8, 20223 yr by Powerforum Store
September 8, 20223 yr 4 hours ago, Powerforum Store said: we have some giveaway's for Power Forum Members coming up too 😉 YES!! Thats what we talking about!!!
September 8, 20223 yr 5 hours ago, Powerforum Store said: we have some giveaway's for Power Forum Members coming up too 😉 Hopefully the opportunity will include some of us forumites in the region (Zimbabwe), who also contribute in time & discussions on the Powerforum.
September 8, 20223 yr We have the Alpha Ess Smile 5. With 11.4kw backup. This system been installed August 2020. We never had any mayor issue with the system. The minor issues we had Failover switch and surge protector Eskom side burned during loadshedding. Than during loadshedding we might use 1 to many appliances as we forgot that we on loadshedding and the system trip. Only issue what I do have. We are a household of 6. Sometimes we need slightly more power. Wish you can add another Smile 5 inverter parallel to current to up the kw usage. Said that. Our house is 360sqm under roof. The system does everything. Only appliances not connected. Stove and 2 geysers. We dont have a pool pump nor borehole. I so wish I can get the new system as a my frail aunt in need of a system as she needs power for her oxygen machine. 2 hours loadshedding is fine but when the power trip after loadshedding it can take hours to get power back in that suburbs.
September 9, 20223 yr Author 16 hours ago, Thibo said: How to enter the competition? We will make a post here with all the details and requirements to qualify for the Lucky Draw.
September 10, 20223 yr Pity the Australia battery testing facility has closed down, it would’ve been interesting to see how this battery fares in those “stress tests”, they used to do & also of interest would be it’s compatibility with various low-to-high value inverters (Goodwe, Sunsynk, Victron, BYD etc. Generally a battery with a disconnect breaker switch, for me is great and even if I have to double-up with a secondary one. Let’s see how this goes, and if it can also go regional, given Southern African power challenges and it’s support both by installers and online.
September 11, 20223 yr Looks like a great product all around. It is definitely a great beast to install and test. Well done to Design and Manufacturing team. Edited September 11, 20223 yr by TI-Diesel
September 12, 20223 yr On 2022/09/10 at 3:48 AM, Moffat said: also of interest would be it’s compatibility with various low-to-high value inverters (Goodwe, Sunsynk, Victron, BYD etc. It's a combined inverter & battery. Just add solar panels (or use it as a big-ass UPS)
September 15, 20223 yr Integrated systems make setup and installation so much easier. As well as looking a whole lot more attractive. Sexy unit.
September 15, 20223 yr Looks good on paper, would be interesting to see how reliable it is versus: 1. Unreliable grid; 2. Changeover times, when grid goes down; 3. Ability for End-user to tinker settings for "individual preferred settings" 4. How it performs under continuous or intermittent heavy loads say of 3000-4000w or powertools; 5. Effectiveness to reduce energy costs when paired with Pv; 6. Can it be set up to send power to non-essential loads when battery is at "certain soc" or if "battery full"?
September 15, 20223 yr On 2022/09/08 at 10:12 AM, Powerforum Store said: Indeed also no cabling between the battery and the inverter everything is integrated including the DC Isolator and on the PV side you only need the type 1 type 2 SPD devices no PV combiner boxes needed and also proper plugs to connect all the inputs and outputs to the inverter no silly connector blocks that can break They claim that the inverter and the battery can be fully installed in 30 Minutes this will reduce labor time wasted considerably .. Hi, the cable between Battery and inverter are needed. but it "hide" inside.
September 20, 20223 yr On 2022/09/08 at 2:51 PM, NoordSolar said: This system was installed at my sisters place by a large solar company as an offgrid system. They could not get this unit to work reliably - kept on having brownouts approx once or twice a day . Even contacted China only to be told later this is not designed as an offgrid system. Installation manual explicitly states "that its not an offgrid system" , even though the glossy brouchre says it can work offgrid. Unit was removed and replace with SunSynk. now all is OK I bought the AlphaESS Smile5 and luckily got rid of it 1 year later due to it having issues not working off grid . There was no support and they only changed their manual after I had sold mine. Now I have 2x5kva Victron inverters installed and can't be happier. I rather spend more than buy unsupported Chinese equipment.
September 21, 20223 yr On 2022/09/08 at 9:13 AM, Powerforum Store said: We are in the process of reviewing this product Power Forum Store will be giving one unit away to an approved installer in a LUCKY DRAW close to end of November Retail Value of this give away is R110 000 Vat Included Sponsored by Elleyhill Power (PTY) LTD Installers can contact us directly for installer pricing We will post more details later how to qualify for the the lucky draw watch this thread... here is some details about the system to wet your appetite This inverter is NRS Approved The supplier will make the parallel kit for the inverter will be available at the Beginning of 2023 awaiting on NRS Approval for the kit. DATA SHEET PROMOTIONAL VIDEO SMILE-G3 5 kW 10.1 kWh High Voltage Lithium Battery YOUR ALMIGHTY KNIGHT This residential ESS is with 5kW hybrid single-phase inverter and 10kWh battery module. This product can capture more precise data for stricter VPP requirements. Also, in off-grid scenario, this one has better performance and can work parallel. AlphaESS rolled out its brand new SMILE G3 in South Africa. This residential energy storage system includes a 5kW hybrid single-phase inverter and a 10kWh battery module, expandable to 60.5kWh. This product is able to capture more precise data for stricter VPP requirements and work in an off-grid scenario with parallel function. YOUR ALMIGHTY KNIGHT offers ❤ 200% PV Input ❤ Grid-Forming Function ❤ Off-Grid Parallel Operation ❤ Faster Response for VPP Control ❤ Saving More Than 70% Installation Time ❤ 150% Backup Overload for 30 seconds ❤ Silent Operation Fan less System ❤ Remote Configuration Monitoring Diagnostics and Updates ❤ Wifi Dongle For Remote Monitoring and Configuration Included ❤ NRS Approved ❤ Aesthetically Pleasing Very Clean Installation ❤ IP65 Rated ❤ No PV Isolator Required Only Surge Protection ❤ No Battery Disconnect Required ❤ No AC Breakers Required Only Changeover Switch & Surge Protection ❤ Very Little Cable Trunking Required SPECS Max. AC Output Power 5 kW Capacity Range 10.1 kWh Max. Charging/Discharging Current 60 A Depth of Discharge (DoD) 95% Dimension (W x D x H) 610 X 230 X 1168 mm Operating Temperature Range -10 °C ~ 50 °C IP Protection IP65 Warranty 5 Year Product Warranty, 10 Year Battery Warranty That's great news indeed. I hope they can parallel more than two units or make larger units in future. I installed the unit in May this year, and I found it quite a great product. There are few improvement issues to address such as that meter installation manual, which is quite useless, also that the inverter won't work without the meter. They are also not good in explaining the inverter settings. In overall it's a great device quick and easy to install.
