Hi Siliconkid
I have followed your instructions.
I have the same inverter as you with the same pylontech battery.
It looks like I need the updates.
Please email to me.
Regards
Vinesh
  • Replies 605
  • Views 275.6k
  • SiliconKid
    SiliconKid
2 hours ago, Vinesh said:
Hi Siliconkid
Please email to me.
Regards
Vinesh
hi guys
what worked for me in the end (and after getting guidance from a Bundu Power tech was the following)
Using a straight through cable (Pin1 to Pin1 etc) ; Run it CAN port to CAN port and change setting 5 to LI, Program 52
That was all I needed.
1 hour ago, George_S said:
hi guys
It will help to state which Growatt inverter you are using. The SPF5000TL model supports only RS485 protocol. Please have a look at page 4 of the user manual of this particular inverter. You do not use CAN 😩
Apologies and good point
It’s the Growatt SPF5000ES and Pylontech US3000C
Hello Power People,
I'm posting this here to hopefully save anyone in a similar situation a lot of headache and possibly an inverter.
I recently installed a Growatt SPF5000TL inverter and a Pylontech US3000C battery. From what I could research on this forum, firmware updates were required to get the BMS communications established. So, I got the firmware and commenced the updates. It broke my inverter! It would not turn on after the 2nd update. Luckily it was still under a warranty and the supplier swapped out the unit.
I was really not comfortable with doing a firmware update on the new inverter, so I found some more information with regards to the cable and managed to get the BMS communicating WITHOUT DOING ANY FIRMWARE UPDATES. So, if you would like to get the inverter and battery communication, follow these  steps.
1. If you are unable to make your own CAT6 network cable, go to your local computer shop and ask them to make one up for you.
2. The cable only requires 3 wired contactors. Refer to picture below:
3. Invert the the wires on either end of the cable connections. It doesn't matter what the colours are, as long as they are inverted in order and pin location.
4. Turn the battery off. and set your Baud rate to 9600. Dipswitches 1 0 0 0 (1-ON 2-OFF 3-OFF 4-OFF)
5. Connect the end with contactors 6, 7 & 8 wired to the battery RJ45 port. Then connect the end with contactors 1, 2 & 3 wired into the BMS port of the inverter.
6. Turn the battery on and inverter back on.
7. Go to setting 5 and select Li with protocol 04. Make sure it is set, then press escape and it should start communicating after a few seconds.
8. If it doesn't work immediately, turn the battery off on the red SW switch and then the main switch then turn the inverter off. Wait 30s and turn back on starting at the battery.
9. To verify that it is communicating, got to setting 12, 13 & 21. These will now be displayed as percentages and no longer voltage. You will also see a Li display next to the battery on permanently.
I really hope this is able to help someone out there. If you have any questions, please don't hesitate to ask.
Neil
2 hours ago, Neil27 said:
Hello Power People,
Neil
Nice guide, straight forward. I remember doing the trolling through this post to get all that info :)
I think though that your replacement inverter might be on the new firmware already though, because I believe that was required to get the Li Protocol 04. But I could be wrong.
On 2021/01/17 at 11:21 PM, Fatboy said:
Hello,
I tried to update my Growatt inverter firmware to 500.008 and it failed. Now it continues to get stuck after it erases the hard drive. It does not continue to the next package.
I tried to follow the instructions regarding failure couple of times with no luck.
Has anyone ever experience the same problem and how did you overcome it. Currently inverter is not working and the lights on the screen are off however, if you run the tool to upgrade, it picks it up, erases the hard drive then get stuck on send...
Hope to hear from anyone. Thank you
Hi Fatboy, did you manage to come right? I had my China supplier assist me & although we initially had your issue, they supplied other firmware files which restored the inverter then we could do the upgrade.
Thanks. Just want to add something helpful. This forum was the only place I could find anything helpful. There seems to be a severe shortage of information on the web with regards to Growatt inverters.
Perhaps it has the updates. But it was replaced within a week, so I assume they were both from the same batch of inverters shipped.
On 2021/07/16 at 10:43 PM, LwL said:
@SiliconKid
Hi there. Will the comms setup be the same for the Growatt SPF5000ES inverter?
Hello @LwL,
BMS comms for the SPF5000ES is pretty straight forward - it supports both CAN and RS485. No funny business like the SPFxxxxTL models.
SPF5000ES using RS485
Network Cable - Cross Over - pins 1,2,3 (inverter side) crossed over to pins 8,7,6 (battery side). That is 1-8, 2-7, 3-6
Inverter Port - RS485
Battery Port - B/RS485 (this is on a Pylontech US3000C)
Battery Dipswitch - 1000 (on, off, off, off). This will give you the required 9600 baud comms speed. Some US3000C's have the dipswitch installed upside down, please take note of this and just do the sensible thing. :)
Inverter Option 5 - Li
Inverter Option 36 - L02
SPF5000ES using CAN
Network Cable - Straight Through - pins 1-8 (inverter side) straight through to pins 1-8 (battery side).
Inverter Port - CAN
Battery Port - A/CAN (this is on a Pylontech US3000C)
Battery Dipswitch - 0000 (off, off, off, off). Dipswitch does not matter for CAN. Some US3000C's have the dipswitch installed upside down, please take note of this and just do the sensible thing. :)
Inverter Option 36 - L52
This should get your comms working.
On 2021/07/12 at 1:49 PM, Neil27 said:
Hello Power People,
Neil
Hi members, please assist me here I need to upgrade my PV Wattage, currently I have 4 x JA 385W connected 2s2p. I need to upgrade to 6 x JA 385W, can I connect 2s3p to Growatt SPF5000TL without damaging the inverter? Also the model of the panels is JAM72S09-385/PR, can I add the 2 x JAM60S20-385-MR to the existing panels without worrying about compatibility? Thank you
With the 5000TL, yes you should be able to connect 2s3p without any problem at all. I have 2s7p. 12 330w and 2 365w.
The important thing is the voltage/amps and how many you have in a string. 5000TL recommends lower than 115v, so if the panels are around 50v each, that's why you should have max 2 in series.
For efficiency sakes, If the voltages and amps are different on the newer panels, you'll always get the lowest value.
So for example: If the old panels are 47v and the new panels are 48v, it will drop the new panels to 47v. Same for Amps, that's why its possible to mix and match, but it's not always efficient. But it shouldn't be an issue.
I just added 2x 365w panels to my 12x 330w system because it's hard to find 330w panels anymore, and I have no issues, but I am losing a bit.
13 hours ago, Supergeek said:
Bonjour @LwL,
Les communications BMS pour le SPF5000ES sont assez simples - elles prennent en charge CAN et RS485. Aucune entreprise amusante comme les modèles SPFxxxxTL.
SPF5000ES utilisant RS485
Câble réseau - croisé - broches 1,2,3 (côté onduleur) croisées aux broches 8,7,6 (côté batterie). C'est-à-dire 1-8, 2-7, 3-6
Port onduleur - Port de
batterie RS485 - B/RS485 (c'est sur un Pylontech US3000C) Dipswitch de
batterie - 1000 (marche, arrêt, arrêt, arrêt). Cela vous donnera la vitesse de communication requise de 9600 bauds. Certains US3000C ont le commutateur DIP installé à l'envers, veuillez en prendre note et faire simplement la chose raisonnable. Onduleur Option 5 - Li Onduleur Option 36 - L02:)
SPF5000ES utilisant CAN
Câble réseau - Straight Through - broches 1-8 (côté onduleur) directement jusqu'aux broches 1-8 (côté batterie).
Inverter Port - CAN
Battery Port - A/CAN (sur un Pylontech US3000C)
Battery Dipswitch - 0000 (off, off, off, off). Le commutateur DIP n'a pas d'importance pour CAN. Certains US3000C ont le commutateur DIP installé à l'envers, veuillez en prendre note et faire simplement la chose raisonnable. Onduleur Option 5 - Li Onduleur Option 36 - L52:)
Cela devrait faire fonctionner vos communications.
Bonjour chers tous, Est-ce que quelqu'un a l'expérience de l'utilisation de groupes de batteries pylontech avec les onduleurs growatt ?
On 2020/03/21 at 1:54 PM, SiliconKid said:
Excellent!
So how does everybody else get those firmware updates now?
I've got several people wanting to buy Dyness but they refuse to commit unless Dyness will make the firmware available.
That nonsense that they won't supply firmware to end users needs to stop. That is not viable in South Africa, the firmware needs to be freely available so people can sort the problems out themselves, we can't rely on installers and suppliers here unfortunately.
Hi is this still the case?
Anyone know if there have been any newer firmware releases for the 5000TL?
I still have the google link, but that specifies that its 500.09
I'm really hoping they release a firmware update that addresses the 100% BMS Solar shut off till 94%. Makes zero sense that it operates like that.
Hi Guys
Please can someone educate me, I have a SPF5000TL HVM WPV inverter, I received firmware for the SPF5000ES, Growatt representative said its the same thing, tried the update but keeps getting stuck on Send Start, now my inverter doesn't register AC/PV/DC values, still turns on but not registering, have to run on Bypass switch, keeps tripping when I try run through inverter, app says its in Wait mode.
8 hours ago, Troye Hanna said:
Hi Guys
I'm pretty sure the firmware for the TL and ES are very different as they are totally different types.
TL can be found here: https://drive.google.com/drive/folders/12ttv9oCoC2rowUPDdsjfs0P4fz9DuSVt
10 hours ago, Troye Hanna said:
Hi Guys
Eish! You have damaged your inverter, the representative mislead you. The firmware of the two inverters can't be the same. ES and TL models are different, if its a new inverter, take it back for warranty swap. Especially because the supplier, assuming that when you said representative you meant supplier, said you can use the firmware for ES model to update your TL model
Thanks to everyone for their replies, I sent the enquiry on the shinephone app and I got a reply from what I assume and would hope is a representative, but it does seem that firmware he supplied had a negative effect, the LCD came on but wasn't registering the currents (even though it was starting up lol)
I just did the flash sent above by Rooney and all of a sudden the AC/INV and CHG LEDS came on but wasn't registering Voltage, I restarted the inverter and now the LCD screen is blank and its just screaming (alarm beeps fast then continously) tried the procedure for update failed but just stuck on send start and seems the communication from laptop to inverter is not working now.
Thanks to everyone for trying, if you have any suggestions its welcome but otherwise I'll try replace under warranty.
Regards
Hi Folks,
So I've been running completely stable on my backup kit (growatt and pylon tech), but for the first time today the SOC Led's are blank. Every few seconds, they all flash on and off simultaneously. The 'run' light still flashes as normal. This has never happened before. Normally all the LED's are on, unless we loadshedding when the battery is running down.
My FW updates were done at time of installation so the BMS was always working fine.
Any ideas? Thanks
29 minutes ago, Kingsway said:
Hi Folks,
Any ideas? Thanks
It is normal for the SOC LEDs to switch off every now and then when your batteries are idle. Mine does the same when not charging or discharging, its like the batteries go into sleep mode or something.
Regards
If I was you, I would have long started with the claims process because it takes long before they can send you a new main board. They are not going to replace the complete inverter and depending on where you bought from, they might be able to change the board for you or you will have to do it yourself like I had to do, earlier this year.
