GREENRICH 3.686 kWh LITHIUM BATTERY REVIEW AND GIVEAWAY
On 2022/09/08 at 3:36 PM, Powerforum Store said:
Hi Guys so here is another GIVE AWAY!
We are busy with a test and review of the Greenrich 1.5C 3.686 kWh Lithium Battery
Yes we will be giving one away to one lucky Power Forum Member in a Lucky Draw
I will post details on how to qualify for this GIVE AWAY soon watch this space!
Sponsored by Elleyhill Power (PTY) LTD
So some information to wet your appetite about these batteries
Greenrich batteries have been in the market for some time now and so far we have had mostly positive feedback from installer and end users alike.
What makes the battery desirable is the 1.5C Rating this means the battery can discharge at 1.5 times its capacity rating.
Why would that be so great?
Here is why if you have a 5KW inverter discharge the battery at 5kWh then this 3.686 kWh battery will be able to absorb a charge rate between 0.5C & 0.75C and a discharge rate at 1.5C without tripping the benefits of that is that when you start of on your solar journey you don't have to break the bank with just one 3.686kWh Greenrich Battery because your 5KW inverter can never reach the discharge rates of the battery.
The 3.686 kWh is also inter compatible with the 4.95 kWh Greenrich Lithium if you require to expand to larger capacity.
This Lithium battery is the only Lithium battery in the market that offers true 1.5C discharge ratings. With 1.5C discharge rates, the Greenrich lithium battery has a much higher power output compared to other 0.5C or 1C lithium batteries.
The cell technology in the battery is LFP cylindrical high density cells which can do up to 2C however for longevity the BMS limits the discharge  to 1.5C and charger rates to 0.5C continuous and boost charge rate for 5 minutes to 0.75C
Battery specifications:
Weight: 41.5kg
Battery Type: Lithium Ion
Nominal Energy: 3686 Wh
Depth of discharge: 95.00 %
Voltage: 51.2v
Continuous Discharge Rate (Normal Use): 5000 W
Maximum Discharge Rate (5 Minutes): 5500 W
Surge Discharge Rate (15 Seconds): 6144 W
Maximum Charge Rate (5 Minutes): 2560 W
Compatible with many of South Africa’s popular Hybrid inverters’ brands.
Built-in BMS that protects the cell from abnormal temperature, current, voltage, SoC, and SoH.
DATA SHEET
Game changer! Experiencing so many installs where 8kw inverters are coupled with .5C 5kwh batteries and then people don't understand why the inverter trips during load shedding. This will bridge that gap nicely. So far Hubble was the defacto champ in this area.
Would like a wall mount unit though. ;)
  • Replies 160
  • Views 33.9k
  • Energy-Jason
    Energy-Jason
    Hi Everyone! Its time as promised! Please find the link below to enter for the 3,6 Greenrich. I am not going to bulk email this competition out. I feel this will give active/regular members
  • Powerforum Store
    Powerforum Store
    The Cell technology used in the Greenrich batteries are not your normal Prysmatic Pouch Cells these batteries use High Density Cylindrical cells so the internal look of the battery is very neat and ti
  • Zhann - Set-the-bar
    Zhann - Set-the-bar
    We have used over 140 of these units, mostly the 5KWH. They are solid and really well performing batteries. Love the 1.5C
On 2022/09/21 at 1:06 PM, PRP said:
Looks great, wall mount would be even better !
You can get a "rack mount wall adaptor" for this. (and most rack mount batteries.) So mine is mounted to the wall perfectly.
Weight: 41.5kg
Voltage: 51.2v
DATA SHEET
Though I fully appreciate the Forum store also testing this battery for issues of:
* Reliability
* Safety
* Confirmation of specs etc...
Wouldn't it be good to have some of us forumites being given test kits to see how they also perform in different environments and circumstances such as:
* Over-abuse (through over discharging and undercharging;
* Various installation sites which, some may have adequate and others even inadequate SPDs;
* Different PV size installations;
* Differing inverters; and
* Various tinkering by some of us "solar users"?
Food for thought as eventually, the collation of such data across different areas and use-cases, gives a more representative and truer picture of how the battery will actually perform out in the "wild".
Weight: 41.5kg
Voltage: 51.2v
DATA SHEET
built my property with a north facing roof ,wanted f all from this useless government ,planned to go  off the grid at some stage ,and Eskom is pushing me off the cliff to step up and get off the grid sooner than later .
It seems like people think they need to reply to this thread in order to enter. Could we add the instructions to enter to the first post?
Perhaps the entry for this one has not been announced yet, this is for the 5kWh one:
Edited by P1000
Thanks that's exactly right. For The 5kWh giveaway in your link. Follow those instructions. We will still post the 3.6kWh unit instructions after the 5kWh had run its 7 days.
42 minutes ago, BritishRacingGreen said:
@Jabu I do have a possibly stupid question here. Are you connecting an external MPPT charge controller to PV input of inverter? Does the inverter not have its own MPPT controller?
